查看: 925|回复: 4
海信55 寸 不开机, 打印信息不停重复
发表于: 2022-3-13 16:31:09
海信LED55N3600U   1112
上电蓝灯亮  不开机,按键  遥控不起作用,打印信息不停重复
ootrom start
Boot Media: eMMC
Decrypt auxiliary code ...OK
Entry boot auxiliary code
Reg Version:  v1.5.3l
Reg Time:     2017/06/16 16:33:16
Reg Name:     hi3751v551dmoB_4layers_cpu1100Mbps_DDR4_1866_1536M_1024Mch0_512Mch1_emmc.reg
DDRTR Suc
Boot auxiliary code success
Bootrom success
System startup
Fastboot 3.3.0 (gfkfcmo@ubuntu-CI-3) (Nov 22 2017 - 08:00:46)
Fastboot:      Version 3.3.0
Build Date:    Nov 22 2017, 08:01:45
CPU:           Hi3751v550
Boot Media:    eMMC
MMC:   Synopsys Mobile storage: 0
MMC/SD Card:
    MID:         0x000015
    OID:         0x0100
    PSN:         0x58b4e2bc
    DATA:        11/2017
    Chip Type:   MMC
    MMC Version: 5.0
    Timing:      HS
    Host Clk:    50000000Hz
    Host Div:    0
    Bus Width:   8bit
    Chip Size:   3909091328 Bytes (High Capacity)
    Read Block:  512 Bytes
    Write Block: 512 Bytes
    Boot Addr:   0
The DDR memory layout:
      page table: 0x0c000000 - 0x0c400000  4 MiB
           stack: 0x0c400000 - 0x0c800000  4 MiB
       irq stack: 0x0cafff7c - 0x0cbfff7c  1 MiB
     global data: 0x0cbfffc4 - 0x0cc00000  60 Bytes
          malloc: 0x0cc00000 - 0x10c00000  64 MiB
           .text: 0x10c00000 - 0x10c9dc3c  631.1 KiB
            data: 0x10c9dc3c - 0x10d56c00  739.9 KiB
Boot Env on eMMC
    Env Offset:          0x00100000
    Env Size:            0x00010000
    Env Range:           0x00010000
SDK_VERSION: [HiDPTAndroidV300R002C01SPC050_20170710]
No eeprom.
sizeof(HisDatabase) = 1024!
Set CEC onetouchplay :0
Set WAKEUPMODE 0xf8409ff8 0
BootMode = MEM:AC
get bootloader message reserved:
BootMode = 2 ACDC = 0
will_enter_recovery = 0
boot_after_reboot = 0
BootMode = MEM:AC
PowerOn!
CUSTOM Func[HI_DRV_CUSTOM_BoardInit] Line[785] :--Board Name is:HI3751V551_N3600U_BOARD, Power on optimize: TRUE
nuc: LED_Resume in boot
CUSTOM Func[CustomBtWiFiPowerOn] Line[159] :Custom BTWIFIPowerOn
CUSTOM Func[CustomBtWiFiPowerOn] Line[165] :CustomBtWiFiReset PULL DOWN
[HI_DRV_PANEL_Init]-[3422]Panel Init
CUSTOM Func[HI_DRV_CUSTOM_GetParseParamMode] Line[1180] arse Tcon.Bin!
nuc: Tcon PMU pData[00] = 0x00
nuc: Tcon PMU pData[01] = 0x00
nuc: Tcon PMU pData[02] = 0x40
nuc: Tcon PMU pData[03] = 0x00
nuc: Tcon PMU pData[04] = 0x00
nuc: Tcon PMU pData[05] = 0x00
nuc: Tcon PMU pData[06] = 0x00
nuc: Tcon PMU pData[07] = 0x00
nuc: Tcon PMU pData[08] = 0x00
nuc: Tcon PMU pData[09] = 0x00
nuc: Tcon PMU pData[10] = 0x00
nuc: Tcon PMU pData[11] = 0x00
nuc: Tcon PMU pData[12] = 0x00
nuc: Tcon PMU pData[13] = 0x00
nuc: Tcon PMU pData[14] = 0x00
nuc: Tcon PMU pData[15] = 0x00
nuc: Tcon PMU pData[16] = 0x71
nuc: Tcon PMU pData[17] = 0x00
nuc: Tcon PMU pData[18] = 0x00
nuc: Tcon PMU pData[19] = 0x1A
nuc: Tcon PMU pData[20] = 0x17
nuc: Tcon PMU pData[21] = 0x1F
nuc: Tcon PMU pData[22] = 0x00
nuc: Tcon PMU pData[23] = 0xF7
nuc: Tcon PMU pData[24] = 0x0E
nuc: Tcon PMU pData[25] = 0x00
nuc: Tcon PMU pData[26] = 0x00
nuc: Tcon PMU pData[27] = 0x00
nuc: Tcon PMU pData[28] = 0x00
nuc: Tcon PMU pData[29] = 0x00
nuc: Tcon PMU pData[30] = 0x00
nuc: Tcon PMU pData[31] = 0x00
nuc: Tcon PMU pData[32] = 0x00
nuc: Tcon PMU pData[33] = 0x00
nuc: Tcon PMU pData[34] = 0x18
nuc: Tcon PMU pData[35] = 0x0B
nuc: Tcon PMU pData[36] = 0x07
nuc: Tcon PMU pData[37] = 0x00
nuc: Tcon PMU pData[38] = 0x00
nuc: Tcon PMU pData[39] = 0x00
nuc: Tcon PMU pData[40] = 0x00
nuc: Tcon PMU pData[41] = 0x00
nuc: Tcon PMU pData[42] = 0x00
nuc: Tcon PMU pData[43] = 0x00
nuc: Tcon PMU pData[44] = 0x00
nuc: Tcon PMU pData[45] = 0x00
nuc: Tcon PMU pData[46] = 0x00
nuc: Tcon PMU pData[47] = 0x00
nuc: Tcon PMU has been initalized, no need to config
nuc: Tcon Gamma pData[00] = 0x02
nuc: Tcon Gamma pData[01] = 0x6C
nuc: Tcon Gamma pData[02] = 0x3C
nuc: Tcon Gamma pData[03] = 0x62
nuc: Tcon Gamma pData[04] = 0x00
nuc: Tcon Gamma pData[05] = 0x30
nuc: Tcon Gamma pData[06] = 0xF2
nuc: Tcon Gamma pData[07] = 0xE2
nuc: Tcon Gamma pData[08] = 0x2A
nuc: Tcon Gamma pData[09] = 0x42
nuc: Tcon Gamma pData[10] = 0x00
nuc: Tcon Gamma pData[11] = 0x20
nuc: Tcon Gamma pData[12] = 0xA1
nuc: Tcon Gamma pData[13] = 0xD2
nuc: Tcon Gamma pData[14] = 0x20
nuc: Tcon Gamma pData[15] = 0x01
nuc: Tcon Gamma pData[16] = 0x3C
nuc: Tcon Gamma pData[17] = 0x10
nuc: Tcon Gamma pData[18] = 0x20
nuc: Tcon Gamma pData[19] = 0xD3
nuc: Tcon Gamma pData[20] = 0x20
nuc: Tcon Gamma pData[21] = 0x00
nuc: Tcon Gamma pData[22] = 0x1C
nuc: Tcon Gamma pData[23] = 0xFF
nuc: Tcon Gamma pData[24] = 0xFF
nuc: Tcon Gamma pData[25] = 0xFF
nuc: Tcon Gamma pData[26] = 0xFF
nuc: Tcon Gamma pData[27] = 0xFF
nuc: Tcon Gamma pData[28] = 0xFF
nuc: Tcon Gamma pData[29] = 0xFF
nuc: Tcon Gamma pData[30] = 0xFF
nuc: Tcon Gamma pData[31] = 0xFF
nuc: Tcon Gamma pData[32] = 0xFF
nuc: Tcon Gamma pData[33] = 0xFF
nuc: Tcon Gamma pData[34] = 0xFF
nuc: Tcon Gamma pData[35] = 0xFF
nuc: Tcon Gamma pData[36] = 0xFF
nuc: Tcon Gamma pData[37] = 0x20
nuc: Tcon Gamma pData[38] = 0x02
nuc: Tcon Gamma pData[39] = 0x00
nuc: Tcon Gamma pData[40] = 0x20
nuc: Tcon Gamma pData[41] = 0x02
nuc: Tcon Gamma pData[42] = 0x00
nuc: Tcon Gamma pData[43] = 0x20
nuc: Tcon Gamma pData[44] = 0x02
nuc: Tcon Gamma pData[45] = 0x00
nuc: Tcon Gamma pData[46] = 0x20
nuc: Tcon Gamma pData[47] = 0x02
nuc: Tcon Gamma pData[48] = 0x00
nuc: Tcon Gamma pData[49] = 0x20
nuc: Tcon Gamma pData[50] = 0x02
nuc: Tcon Gamma pData[51] = 0x00
nuc: Tcon Gamma pData[52] = 0x20
nuc: Tcon Gamma pData[53] = 0x02
nuc: Tcon Gamma pData[54] = 0x00
nuc: Tcon Gamma pData[55] = 0x20
nuc: Tcon Gamma pData[56] = 0x02
nuc: Tcon Gamma has been initalized, no need to config
[PANEL_DRV_ParseInterface]-[222]current Interface is [CEDS]
[PANEL_DRV_SetTconCfg]-[606]WRITE TCON BIN REG!!!
DISP_HAL_Get_PanelCfgPara SyncInfo: Hact=3840 Hfb=200 Hbb=360 Vact=2160 Vfb=30 Vbb=60
tcon-less case, pq tcon will work
tcon cfg rgbw! rgbwen=1
tcon cfg customip! en=1
Tpll u32Clk=297000000, u32IntPart=0x4063, u32MinorPart=0x12000000
TPLL Lock Success u32Tmp=10
tcon hpll u32Clk=891000000, u32IntPart=0x1001023, u32MinorPart=0x13a3d70a
HPLL Lock Success u32Tmp=2
HPLL set new mode
u32PixelClk=594000000, HpllTargetClk=891000000,u32HpllCtrl0=0x13a3d70a, u32HpllCtrl1=0x1001023
Set Disp 1 SyncInfo: V (30, 60, 2160) H (200, 360, 3840)
SrInCscEnable=1 , SrOutCscEnable=1, SrInColor=12, SrOutColor=12
enSrPosition =1 stSrZmePara In wh[1920 1080] Out wh[3840 2160] ZME_FMT =2
Set LOG Level [HI_TRACE_LEVEL_WARN]
nuc: u32LogoDataAddr = 0xcc3b260, &u32LogoDataAddr = 0xcafff00
nuc: HS_LogoSelect Enter, line = 567
nuc: logo_cmd = NULL, line = 572
nuc: logo_state =  line = 585
nuc: HS_ParseLogoState Enter, line = 307
nuc: pLogoDataAddr = 0xcafff00, line = 308
nuc: HS_LoadDefaultLogo Enter, line = 272
nuc: HS_GetLogoParam ok, line = 277
nuc: HS_LoadDefaultLogo Out, Ret = 0,  line = 289
nuc: HS_ParseLogoState Out, Ret = 0,  line = 349
nuc: HS_LogoSelect Out, Ret = 0,  line = 615
nuc: u32LogoDataAddr = 0xce3f298, stLogoParam.u32LogoLen = 112989
CUSTOM Func[CustomBtWiFiReset] Line[174] :CustomBtWiFiReset PULL UP
RCtune Value is 5
[HI_DRV_PANEL_SetPowerOn]-[2817]Set Param [Enable:1]
ERROR: No one would be < interval*******
[HI_DRV_PANEL_SetIntfPower]-[2685]Set Param [PowerOn:1]
tag is: version=1.0.0.2 panelparam=0x2bbf7000,0x7000 tconparam=0x2bbeb000,0xb000 PANEL_TCON_SCENE=0x2bbe3000,0x7000 PANEL_TCON_SCENE=0x2bbe1000,0x1000 PANEL_TCON_SCENE=0x2bbdf000,0x1000 PANEL_TCON_SCENE=0x2bbdd000,0x1000 Tcon 2D Timing Buf=0x2bbd9000,0x3000 Tcon 3D Timing Buf=0x2bbd5000,0x3000 SR_ZME_COEF=0x2bbd2000,0x2000 HIFB_ZmeCoef=0x2bac9000,0x3000 HIFB_DispBuf_HD=0x2b2df000,0x7e9000
---boot_select:read misc cmd :
hs>>power-on.
ReadFactroyM: sizeof(HisDatabase)=1024.
ReadFactroyM: FactoryMode is 0
Not in Factory M,need't upgrade.
press the ir!!!
[PANEL_DRV_SetPanelBlPowerTimer]-[220]---Set Backlight on
get key = 0x39653778302c3030, status = 812016690, ret = -1
ir failure. status = 812016690, ret= -1
get the ir code 0xffffffffffffffff
keypad value keycode=0x0
get_bootloader_message: HI_Flash_Read partion misc successfully
mac:A8:82:00:54:11:42
Reserve Memory
    Start Addr:          0x2BBFF000
    Bound Addr:          0x13D57000
    Free  Addr:          0x2A7F7000
    Alloc Block:  Addr        Size
                  0x2A7F7000       3133440
                  0x2AAF5000       8294400
                  0x2B2DF000       8294400
                  0x2BAC9000       12288
                  0x2BACD000       1048576
                  0x2BBCE000       12288
                  0x2BBD2000       8192
                  0x2BBD5000       12288
                  0x2BBD9000       12288
                  0x2BBDD000       4096
                  0x2BBDF000       4096
                  0x2BBE1000       4096
                  0x2BBE3000       28672
                  0x2BBEB000       45056
                  0x2BBF7000       28672
mmc->capacity = 281796550
Press Esc to stop autoboot
MMC read: dev # 0, block # 253952, count 128 ... 128 blocks read: OK
MMC read: dev # 0, block # 190464, count 51200 ... 51200 blocks read: OK
MMC read: dev # 0, block # 251904, count 128 ... 128 blocks read: OK
INFO:set pdmparam version=1.0.0.2 panelparam=0x2bbf7000,0x7000 tconparam=0x2bbeb000,0xb000 PANEL_TCON_SCENE=0x2bbe3000,0x7000 PANEL_TCON_SCENE=0x2bbe1000,0x1000 PANEL_TCON_SCENE=0x2bbdf000,0x1000 PANEL_TCON_SCENE=0x2bbdd000,0x1000 Tcon 2D Timing Buf=0x2bbd9000,0x3000 Tcon 3D Timing Buf=0x2bbd5000,0x3000 SR_ZME_COEF=0x2bbd2000,0x2000 HIFB_ZmeCoef=0x2bac9000,0x3000 HIFB_DispBuf_HD=0x2b2df000,0x7e9000 .
INFO: fdt_add_mem  base = 2bbf7000,len = 7000
INFO: fdt_add_mem  base = 2bbeb000,len = b000
INFO: fdt_add_mem  base = 2bbe3000,len = 7000
INFO: fdt_add_mem  base = 2bbe1000,len = 1000
INFO: fdt_add_mem  base = 2bbdf000,len = 1000
INFO: fdt_add_mem  base = 2bbdd000,len = 1000
INFO: fdt_add_mem  base = 2bbd9000,len = 3000
INFO: fdt_add_mem  base = 2bbd5000,len = 3000
INFO: fdt_add_mem  base = 2bbd2000,len = 2000
INFO: fdt_add_mem  base = 2bac9000,len = 3000
INFO: fdt_add_mem  base = 2b2df000,len = 7e9000
bl33_ep->spsr = 0x1D3
Start Warm reseting
NOTICE:  BL31: v1.2(release):2e762b8
NOTICE:  BL31: Built : 12:44:55, Jul 12 2017
Starting kernel ...
发表于: 2022-3-14 14:54:16
重复打印是EMMC用户区数据错误
 楼主| 发表于: 2022-3-15 14:39:00
多安保 2022-3-14 14:54
重复打印是EMMC用户区数据错误
强制升级没有反应
发表于: 2022-3-16 21:03:57
换EMMC重写引导,u盘强制升级
GMT+8, 2024-11-19 05:33 , Processed in 0.052510 sec., 9 queries .
