查看: 867|回复: 4
求版主帮忙,TCL-D49A561U--RT95机芯不开机求助。
发表于: 2021-12-9 16:29:35
TCL-D49A561U--RT95机芯不开机求助。此机开机原打印没记,好像就是;错误00007,格几行就几个英文字母就没啦,我先换主芯片也是一样,后读出EMMC数据保存,将EMMC取下发现不能读出,存在多处坏区用1BT可图出,换上新的EMMC写入还是不开机打印有变化就这几行且重复2021-12-9, 16:5:55 COM6, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809F:
GGoo
ARM
JRT
U-Boot 2012.07-svn950629 (May 25 2016 - 16:19:39)
GPU : BISR testing...
GPU : Finish BISR testing (OK)
SCPU: BISR testing ....
SCPU: Finish BISR testing (OK)
CPU  : Cortex-A9 dual core
Media: eMMC BP0
MISC : set FUSE_RDY
MISC: efuse had NOT been written
DRAM:  1.5 GiB
Watchdog: Enabled?
此机以来10多天,还无头绪急,老板在催,求大家帮忙,能有EMMC读出的数据最好,忘记讲啦,是摘板回来修,故没连屏,是不是此机要连屏自检在通过还是啥我在猜,刚我连引导也升过也是这样,谢谢。的确今天把线换下打印出来啦,请师傅们帮我看下是那原因,谢谢。
2021-12-11, 18:32:17
COM6, BaudRate:115200 bps, RXD: VGA->11,TXD: VGA-> 4, Printed by RT809F:
GGoo
ARM
A
U-Boot 2012.07-svn634805 (Mar 07 2014 - 19:10:32)
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1.5 GiB
Watchdog: Enabled
init_amp_prepare
Board: Tv030 2995 Board
REG_AC_DC_ON_reg: 0x0
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x0b300000
MMC:
emmc:mmc_initial(1) Mar  7 2014 19:11:01
RTD299x eMMC: 0
Device: RTD299x eMMC
Manufacturer ID: 90
OEM: 14a
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Extern param: MMC blk:0x7c (to 0x9000)
         rtk_eMMC_read blk_addr=0x0000007c, data_size=0x00000800, buffer=0x00009000
Factory: MMC
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000c048, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00000200, buffer=0x0b200008
         rtk_eMMC_read blk_addr=0x0000e046, data_size=0x00000400, buffer=0x0b200210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00008c00, buffer=0x0a900000
Factory: seq:0x49f0, blk:0xe000(pp:1), size:0x8c00 (to 0xa900000)
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE=1
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=2272770
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=103574
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN not found
[bootparam.c 132]:can't find local_upgrade_en
BOOTUP_POLICY=0
148boot_power_on_mode=1
bootup_policy=0
boot_power_on_mode=0
boot_ac_on=1
get_layout:
------------tmp/factory/layout.txt found
BOOTPART=0
TAG=21
[ENV] read_env from factory failed
[ENV] Using default environment variables
ee read 343, 1
name=EEP_I2C ppcb_enum.Name=EEP_I2C, ppcb_enum.info=4
EEP_I2C=4
name=EEP_DEVICE_ADDR ppcb_enum.Name=EEP_DEVICE_ADDR, ppcb_enum.info=50
name=PIN_EEP_WP ppcb_enum.Name=PIN_EEP_WP, ppcb_enum.info=100011304
m_PIN_EEP_WP = 0x100011304
ee read 366, 1
ee read 647, 1
 Eeprom.c GetProjectID() projectID = 40
panelName_PID40 = [CS_ST4851D01_4_4K2K_NO3D] in tmp/factory/bin_panel/pid_panel_list.h
Panel: Use parameters in tmp/factory/bin_panel/panel.bin
Panel: CS_ST4851D01_4_4K2K_NO3D
In:    serial
Out:   serial
Err:   serial
Net:   rtl8139: REALTEK RTL8139 @0xb8016000
Hit Esc or Tab key to enter console mode or rescue linux:  0 ################# index:hitvalue:torrence:lsadc_key1  0:0:3:63
======== Checking into android recovery ====
TCWCR_reg: 0
Start Boot Setup ...
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000020, buffer=0x0a820000
         rtk_eMMC_read blk_addr=0x00010000, data_size=0x00000400, buffer=0x0a820000
         FW Table to 0x0a820000, size=0x00000400 (0x0a820400)
         FW Table fr 0x02000000, fw count: 14
Normal boot fw follow...
Linux Kernel:
         FW Image to 0x00108000, size=0x0099c8a4 (0x00aa48a4)
         FW Image fr 0x02008000 (non-lzma)
Audio FW:
         FW Image to 0x81700000, size=0x0026c400 (0x8196c400)
         FW Image fr 0x029a4a00 (non-lzma)
         Enter standby, skip this entry
Video FW 1:
         FW Image to 0x81a00000, size=0x002d87c8 (0x81cd87c8)
         FW Image fr 0x02c10e00 (non-lzma)
Video FW 2:
         FW Image to 0x81d00000, size=0x000b33c4 (0x81db33c4)
         FW Image fr 0x02ee9600 (non-lzma)
ECPU FW:
         FW Image to 0x00004000, size=0x000026b7 (0x000066b7)
         FW Image fr 0x02f9ca00 (non-lzma)
         rtk_eMMC_read blk_addr=0x00017ce5, data_size=0x000026b7, buffer=0x00004000
         FW Image entry  checksum=0x000fbb1c
         FW Image result checksum=0x000fbb1c
Audio data 1:
Video data 1:
         FW Image to 0x85700000, size=0x00983127 (0x86083127)
         FW Image fr 0x02fb3000 (non-lzma)
Audio data 2:
Video data 2:
Audio data 3:
Video data 3:
Unknown FW (15):
         FW Image to 0xdeaddead, size=0x00000000 (0xdeaddead)
         FW Image fr 0x05136200 (non-lzma)
         FW Image size is zero, skip this entry
Unknown FW (16):
         FW Image fr 0x05636200 (non-lzma)
Unknown FW (17):
         FW Image fr 0x05a36200 (non-lzma)
Final checksum check:
entry: 0x00004000, origin one 0x000fbb1c, current one 0x000fbb1c
         Kernel entry to 0x00108000, size=0x0099c8a4 (0x00aa48a4)
         Kernel entry fr 0x02008000 (non-lzma)
         rtk_eMMC_read blk_addr=0x00010040, data_size=0x0099c8a4, buffer=0x00108000
         emmc block_no=0x00010040
         flash_to_ram_addr=0x00108000
         imageSize=0x0099c8a4
         Kernel checksum FAILED
         Kernel entry  checksum=0x377ba3d5
         Kernel result checksum=0x377bf018
dump ddr data(base=0x00108000)
000 : 00 90 0f e1 09 e0 a0 e1 1f e0 0e e2 1a 00 5e e3
010 : c0 90 89 e3 1f 90 c9 e3 13 90 89 e3 04 00 00 1a
020 : 01 9c 89 e3 0c e0 8f e2 09 f0 6f e1 0e f3 2e e1
030 : 6e 00 60 e1 09 f0 21 e1 10 4f 11 ee 01 10 c4 e3
040 : 10 4f 01 ee 10 4f 11 ee 01 4a c4 e3 04 40 c4 e3
050 : 10 4f 01 ee 00 40 a0 e3 15 4f 07 ee 10 5f 30 ee
060 : 94 80 9f e5 a5 56 08 e0 00 60 a0 e3 00 80 a0 e3
070 : 06 7f a0 e1 88 72 87 e1 56 7f 07 ee 01 80 88 e2
080 : 05 00 58 e1 f9 ff ff da 01 60 86 e2 04 00 56 e3
090 : f5 ff ff ba 00 40 a0 e3 9a 4f 07 ee 00 40 a0 e3
0a0 : 17 4f 08 ee 00 40 a0 e3 16 4f 08 ee 00 40 a0 e3
0b0 : 15 4f 08 ee 00 40 a0 e3 95 4f 07 ee 10 9f 10 ee
0c0 : 5e 26 11 eb 05 a0 b0 e1 6d 26 11 0a 30 30 8f e2
0d0 : 10 01 93 e8 04 40 43 e0 04 80 88 e0 3e 00 00 eb
0e0 : c6 43 17 eb 08 00 00 eb 10 d0 9f e5 04 e0 8f e2
0f0 : 04 80 a0 e1 10 f0 8a e2 4a 26 11 ea ff 01 00 00
100 : 5c 90 6d c0 04 81 10 c0 00 00 00 c0 41 49 88 e2
110 : 04 00 a0 e1 00 30 a0 e3 01 69 80 e2 04 30 80 e4
120 : 04 30 80 e4 04 30 80 e4 04 30 80 e4 06 00 30 e1
130 : f9 ff ff 1a 08 70 9a e5 90 00 8f e2 68 00 90 e8
140 : 03 00 40 e0 00 50 85 e0 00 60 86 e0 25 5a a0 e1
150 : 26 6a a0 e1 05 3a 87 e1 05 31 84 e7 06 00 55 e1
160 : 01 50 85 32 fa ff ff 3a 03 0a 84 e2 58 60 9f e5
170 : 07 30 88 e1 26 69 84 e0 04 30 80 e4 01 36 83 e2
180 : 06 00 50 e1 fb ff ff 9a 06 33 a0 e3 23 3a a0 e1
190 : 03 3a 87 e1 07 3a c3 e3 0c 30 c3 e3 02 3a 83 e3
1a0 : fe 0d 84 e2 00 30 80 e5 22 0a a0 e1 00 0a b0 e1
1b0 : 08 30 40 10 03 31 83 12 23 39 84 10 00 60 87 11
1c0 : 00 60 83 15 0c 70 9a e5 0e f0 a0 e1 b3 a4 ae c0
1d0 : d0 81 10 c0 a0 87 55 c0 c0 87 55 c0 03 00 12 e3
1e0 : 0b 00 00 1a 00 50 92 e5 2c 60 9f e5 06 00 55 e1
1f0 : 06 00 00 0a 05 00 55 e3 02 00 55 13 04 00 00 1a
resetting ...
0xb8000804=0x00F00010
0xb8000808=0xF030F000
0xb8000810=0x10101010
0xb8000814=0xF0101010
0xb8000818=0x10101010
  part cfg    : 0x02
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x01
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x00
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
boot part idx = 0x00000000
GGoo
ARM
A
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1.5 GiB
Watchdog: Enabled
init_amp_prepare
REG_AC_DC_ON_reg: 0x2379beef
POWER ON: DC
Cache: Enabled
MMC:
RTD299x eMMC: 0
Manufacturer ID: 90
OEM: 14a
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Factory: MMC
get_bootparam:
BOOT_LOGO_ENABLE=1
BOOT_MUSIC_ENABLE=0
BOOTUP_POLICY=0
bootup_policy=0
boot_ac_on=0
get_layout:
BOOTPART=0
TAG=21
init_amp
ee read 330, 12
EEP_I2C=4
a. Eeprom_Read-macaddr is 5c36b85b33bd
 set_mac_cmd is 5c:36:b8:5b:33:bd
ee read 343, 1
ee read 366, 1
ee read 647, 1
panel_init_1st
=[panel.c]=auto power==
2617
***** set DPLL Later *****
================== P_VBY1_4K2K condition ===================
***** Get Chip ID (3) *****
================== VBY_ONE_PANEL_CHINA_STAR_4K2K_VBY1 ===================
DispI : Finish BISR testing done
DispD : Finish BISR testing done
2620
2769
In:    serial
Out:   serial
Err:   serial
Linux Kernel:
Audio FW:
         rtk_eMMC_read blk_addr=0x00014d25, data_size=0x0026c400, buffer=0x01700000
         emmc block_no=0x00014d25
         flash_to_ram_addr=0x01700000
         imageSize=0x0026c400
         FW Image checksum FAILED
         FW Image entry  checksum=0x0bdc7e5e
         FW Image result checksum=0x0bdc7be3
dump ddr data(base=0x01700000)
000 : 10 00 00 63 00 00 00 00 10 00 00 61 00 00 00 00
010 : 5f 5f 67 68 73 65 6e 64 5f 62 73 73 81 96 c4 01
020 : 41 55 54 48 bd 60 13 61 00 00 00 00 00 00 00 00
030 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
040 : 08 5d 18 a1 00 00 00 00 00 00 00 00 00 00 00 00
050 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
060 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
070 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
080 : 08 5d 18 a1 00 00 00 00 00 00 00 00 00 00 00 00
090 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0a0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0b0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0c0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0d0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0e0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0f0 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100 : 08 5d 18 a1 00 00 00 00 00 00 00 00 00 00 00 00
110 : 00 00 00 00 00 00 00 00 81 74 d1 44 00 00 00 00
120 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140 : 08 5d 18 a1 00 00 00 00 00 00 00 00 00 00 00 00
150 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170 : 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180 : 08 5d 18 a1 00 00 00 00 00 00 00 00 00 00 00 00
190 : 40 14 60 00 00 00 00 00 3c 01 ff fc 34 21 ff fe
1a0 : 02 81 40 24 3c 01 30 00 01 01 40 25 3c 01 ff ff
1b0 : 34 21 00 ff 01 01 40 24 40 88 60 00 3c 08 08 00
1c0 : 40 88 68 00 00 80 a8 21 00 a0 b0 21 00 c0 b8 21
1d0 : 3c 1d 81 94 27 bd 63 00 3c 1c 81 97 27 9c c4 00
1e0 : 0c 5c 00 b5 24 04 00 01 0c 5c 00 b5 24 04 00 00
1f0 : 3c 08 81 97 25 08 c4 00 3c 09 81 97 25 29 c4 01
resetting ...
  part cfg    : 0x02
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x01
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x00
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
GGoo
ARM
ARB
U-
GGoo
ARM
A
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1.5 GiB
Watchdog: Enabled
init_amp_prepare
POWER ON: AC
Cache: Enabled
MMC:
RTD299x eMMC: 0
Manufacturer ID: 90
OEM: 14a
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Factory: MMC
get_bootparam:
BOOT_LOGO_ENABLE=1
BOOT_MUSIC_ENABLE=0
BOOTUP_POLICY=0
bootup_policy=0
boot_ac_on=1
get_layout:
BOOTPART=0
TAG=21
init_amp
ee read 330, 12
EEP_I2C=4
ee read 343, 1
ee read 366, 1
ee read 647, 1
panel_init_1st
2617
2620
2769
In:    serial
Out:   serial
Err:   serial
TCWCR_reg: 0
Linux Kernel:
Audio FW:
resetting ...
  part cfg    : 0x02
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x01
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x00
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
GGoo
ARM
A
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1.5 GiB
Watchdog: Enabled
init_amp_prepare
POWER ON: DC
Cache: Enabled
MMC:
RTD299x eMMC: 0
Manufacturer ID: 90
OEM: 14a
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Factory: MMC
get_bootparam:
BOOT_LOGO_ENABLE=1
BOOT_MUSIC_ENABLE=0
BOOTUP_POLICY=0
bootup_policy=0
boot_ac_on=0
get_layout:
BOOTPART=0
TAG=21
init_amp
ee read 330, 12
EEP_I2C=4
ee read 343, 1
ee read 366, 1
ee read 647, 1
panel_init_1st
2617
2620
2769
In:    serial
Out:   serial
Err:   serial
Linux Kernel:
Audio FW:
resetting ...
  part cfg    : 0x02
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x01
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x00
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
GGoo
ARM
ARB
U-?
GGoo
ARM
A
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1.5 GiB
Watchdog: Enabled
init_amp_prepare
POWER ON: AC
Cache: Enabled
MMC:
RTD299x eMMC: 0
Manufacturer ID: 90
OEM: 14a
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Factory: MMC
get_bootparam:
BOOT_LOGO_ENABLE=1
BOOT_MUSIC_ENABLE=0
BOOTUP_POLICY=0
bootup_policy=0
boot_ac_on=1
get_layout:
BOOTPART=0
TAG=21
init_amp
ee read 330, 12
EEP_I2C=4
ee read 343, 1
ee read 366, 1
ee read 647, 1
panel_init_1st
2617
2620
2769
In:    serial
Out:   serial
Err:   serial
TCWCR_reg: 0
Linux Kernel:
Audio FW:
resetting ...
  part cfg    : 0x02
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x01
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x00
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
GGoo
ARM
A
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1.5 GiB
Watchdog: Enabled
init_amp_prepare
POWER ON: DC
Cache: Enabled
MMC:
RTD299x eMMC: 0
Manufacturer ID: 90
OEM: 14a
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Factory: MMC
get_bootparam:
BOOT_LOGO_ENABLE=1
BOOT_MUSIC_ENABLE=0
BOOTUP_POLICY=0
bootup_policy=0
boot_ac_on=0
get_layout:
BOOTPART=0
TAG=21
init_amp
ee read 330, 12
EEP_I2C=4
ee read 343, 1
ee read 366, 1
ee read 647, 1
panel_init_1st
2617
2620
2769
In:    serial
Out:   serial
Err:   serial
Linux Kernel:
Audio FW:
resetting ...
  part cfg    : 0x02
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x01
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
  part cfg    : 0x00
  boot cfg    : 0x00
  boot wp sts : 0x00
  boot wp     : 0x00
GGoo
ARM
ARB
U-
GGoo
ARM
A
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1.5 GiB
Watchdog: Enabled
init_amp_prepare
POWER ON: AC
Cache: Enabled
MMC:
RTD299x eMMC: 0
Manufacturer ID: 90
OEM: 14a
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 7.3 GiB
Bus Width: 8-bit
Factory: MMC
get_bootparam:
BOOT_LOGO_ENABLE=1
BOOT_MUSIC_ENABLE=0
BOOTUP_POLICY=0
bootup_policy=0
boot_ac_on=1
get_layout:
BOOTPART=0
TAG=21
init_amp
ee read 330, 12
EEP_I2C=4
ee read 343, 1
ee read 366, 1
ee read 647, 1
panel_init_1st
2617
2620
2769
In:    serial
Out:   serial
Err:   serial
TCWCR_reg: 0
Linux Kernel:
Audio FW:
也是重复开机。
发表于: 2021-12-9 17:11:45
读出的程序写到新EMMC在U盘刷机试试。
发表于: 2021-12-10 09:40:30
只有这点打印一般是串口线序错了,切换线序看看完整的打印信息。这种情况软件和DDR都有可能会引起
 楼主| 发表于: 2021-12-11 18:45:57
技术支持008 2021-12-10 09:40
你好,的确是串口线序错了,换好来啦,还请师傅帮我看下是那事,新的打印在1楼,谢谢。
GMT+8, 2024-11-18 14:45 , Processed in 0.067060 sec., 14 queries .
