查看: 1719|回复: 12
求助:海信LED48K300U引导
发表于: 2021-12-5 19:41:42
用户升级失败,开机无图无声,按面板开机键指示灯红蓝有变化,遥控器任何按键都无效。求助:EMMC程序或者是引导程序
 楼主| 发表于: 2021-12-5 19:46:59
爱修网官方备份找到相似机型文件:LED48K3000U(BM1)(0000)_6299_海思HI3751_HD4800DU-B31_809H_EMMC_AUTO,刷入后故障不变。
发表于: 2021-12-6 11:29:21
发表于: 2021-12-6 11:41:52
发表于: 2021-12-6 11:55:03
 楼主| 发表于: 2021-12-6 16:45:58
感谢:技佳维修,我试试
 楼主| 发表于: 2021-12-6 18:59:24
刷机报错什么情况?
 楼主| 发表于: 2021-12-6 19:01:03
进度条到50%几报错,重新刷一样的问题
 楼主| 发表于: 2021-12-6 20:35:52
刷了引导,可是插上U盘的升级包,没有反应
 楼主| 发表于: 2021-12-11 18:52:18
按面板上在音量减键可以读U盘,但是不升级,打印信息如下,是什么原因,淘宝买的升级包
2021-12-11, 18:41:32
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
Bootrom start
Boot from eMMC
Starting fastboot ...
System startup
Bootrom start
Boot from eMMC
System startup
Fastboot 3.3.0 (gfkfcmo@ubuntu) (Aug 27 2018 - 12:29:06)
Fastboot:      Version 3.3.0
Build Date:    Aug 27 2018, 12:29:20
CPU:           Hi3751v600
Boot Media:    eMMC
MMC/SD controller initialization.
MMC/SD Card:
    MID:         0x11
    Read Block:  512 Bytes
    Write Block: 512 Bytes
    Chip Size:   3776M Bytes (High Capacity)
    Chip Type:   MMC
    Version:     4.0
    Speed:       25000000Hz
    Bus Width:   8bit
    Boot Addr:   0 Bytes
The DDR memory layout:
      page table: 0x0c000000 - 0x0c400000  4 MiB
           stack: 0x0c400000 - 0x0c800000  4 MiB
     global data: 0x0cbfffc4 - 0x0cc00000  60 Bytes
          malloc: 0x0cc00000 - 0x10c00000  64 MiB
           .text: 0x10c00000 - 0x10c82728  521.8 KiB
            data: 0x10c82728 - 0x10d9c004  1.1 MiB
Boot Env on eMMC
    Env Offset:          0x00100000
    Env Size:            0x00010000
    Env Range:           0x00010000
nuc: BootMode:  0owerup 1:Suspend 2:Memory
nuc: BootSel:   0:AC(Power On) 1C(Suspend)
nuc: BootMode = 2  BootSel = 0
nuc: u8EnterRecovery = 0
     u8BootAfterReboot = 0
BootMode = MEM:AC
nuc: Power On!
CUSTOM Func[HI_DRV_CUSTOM_BoardInit] Line[144] :Board Name is HISENSE_HI3751V600_K300_BOARD
power_btwifi onoff.
power_ir_led.
hisense:  HI_Boot_Mclk_Main done !
ERR: HI_DB_GetDBFromMem, use default baseparam!
tag is: version=1.0.0.2 baseparam=0x5fffc000,0x2000
press the ir!!!
get key = 0xcc1218810cd5064, status = 281977792, ret = -1
ir failure. status = 281977792, ret= -1
get the ir code 0xffffffffffffffff
keypad value keycode=0x0
keypad value keycode=0x64
update check revovery,kpupKeycode=100
LDR_CheckRecovery,needn't enter recover
HI_DRV_I2C_Exit,478: hi_i2c Release success.
mac:080:B7:B0:C5:92
power_btwifi onoff.
Reserve Memory
    Start Addr:          0x5FFFF000
    Bound Addr:          0x13D9D000
    Free  Addr:          0x5FFFC000
    Alloc Block:  Addr        Size
                  0x5FFFC000       8192
Press Esc to stop autoboot
MMC read: dev # 0, block # 225280, count 20480 ... 20480 blocks read: OK
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   Linux-3.10.0_s5
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    7077296 Bytes = 6.7 MiB
   Load Address: 02000000
   Entry Point:  02000000
   Loading Kernel Image ... OK
OK
Starting kernel ...
Invalid PDM tag, errno:0
Warning: unable to open an initial console.
init: /init.hi3751.rc: 43: invalid command 'sleep'
init: /init.hi3751.rc: 284: ignored duplicate definition of service 'preload'
init: /dev/hw_random not found
init: cannot open '/initlogo.rle'
             A N D R O I D
init: cannot find '/system/xbin/btdl', disabling 'btdl'
healthd: No charger supplies found
init: cannot find '/system/bin/rild', disabling 'ril-daemon'
init: cannot find '/system/bin/dbus-daemon', disabling 'dbus'
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
init: cannot find '/system/bin/frontPanel', disabling 'frontPanel'
init: cannot find '/system/bin/dtvserver', disabling 'dtvserver'
init: cannot find '/system/bin/hidns-sd', disabling 'hidns-sd'
init: property 'sys.powerctl' doesn't exist while expanding '${sys.powerctl}'
init: powerctl: cannot expand '${sys.powerctl}'
init: property 'sys.sysctl.extra_free_kbytes' doesn't exist while expanding '${sys.sysctl.extra_free_kbytes}'
init: cannot expand '${sys.sysctl.extra_free_kbytes}' while writing to '/proc/sys/vm/extra_free_kbytes'
init: untracked pid 1472 exited
root@Hi3751:/ # sd 0:0:0:0: [sda] No Caching mode page present
sd 0:0:0:0: [sda] Assuming drive cache: write through
init: untracked pid 1787 exited
Bootrom start
Boot from eMMC
System startup
Bootrom start
Boot from eMMC
System startup
CPU:           Hi3751v600
Boot Media:    eMMC
MMC/SD Card:
    MID:         0x11
    Chip Type:   MMC
    Version:     4.0
    Speed:       25000000Hz
    Bus Width:   8bit
    Boot Addr:   0 Bytes
Boot Env on eMMC
BootMode = MEM:AC
nuc: Power On!
power_btwifi onoff.
power_ir_led.
press the ir!!!
mac:080:B7:B0:C5:92
power_btwifi onoff.
Reserve Memory
                  0x5FFFC000       8192
OK
Starting kernel ...
             A N D R O I D
Bootrom start
Boot from eMMC
System startup
Bootrom start
Boot from eMMC
System startup
CPU:           Hi3751v600
Boot Media:    eMMC
MMC/SD Card:
    MID:         0x11
    Chip Type:   MMC
    Version:     4.0
    Speed:       25000000Hz
    Bus Width:   8bit
    Boot Addr:   0 Bytes
Boot Env on eMMC
BootMode = MEM:AC
nuc: Power On!
power_btwifi onoff.
power_ir_led.
press the ir!!!
mac:080:B7:B0:C5:92
power_btwifi onoff.
Reserve Memory
                  0x5FFFC000       8192
OK
Starting kernel ...
             A N D R O I D
GMT+8, 2024-11-19 08:27 , Processed in 0.057141 sec., 9 queries .
