用户名  找回密码
查看: 1488|回复: 4
康佳LED55T60U(35021065)灰屏求助
发表于: 2021-10-15 18:57:53
型号:
LED55T60U板号:35021065,主芯片为RTD2995D
故障现象:
用户描述为有时不开机,放置一段时间后,偶尔能正常开机观看,后来越来越严重,一致不能开机。
初步检查:
通电打开主开关,背光灯亮,按待机键不能关机,等会儿背光灯不亮了,此时按待机键不能二次开机,也就是待机键不起作用。
检测主板电压,不受控的3.3VN804)电压正常,在背光亮时,受控的1.2VL801)、1.5VL807)、2.5VN807)、3.3VL818)电压都正常,背光灭时全部消失。接上打印串口XS511,电脑联不上机,无法读取打印信息,初步判断EMMC数据损坏,
网友给的备份整片写入还是灰屏,用U盘升级原样,这到底是哪的问题?
打印信息:
OM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809H:
R
U-Boot 2012.07-svn815094 (Mar 31 2015 - 16:54:34)
GPU : BISR testing...
GPU : Finish BISR testing (OK)
SCPU: BISR testing ....
SCPU: Finish BISR testing (OK)
CPU  : Cortex-A9 dual core
Media: eMMC BP0
MISC : set FUSE_RDY
DRAM:  1 GiB
Watchdog: Enabled
Board: Tv035 2995D 512M_512M Board
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x07900000
MMC:
emmc:mmc_initial(1) Mar 31 2015 16:54:58
RTD299x eMMC: 0
MMC: set bus width 8 fail, try other mode
Device: RTD299x eMMC
Manufacturer ID: 11
OEM: 100
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 4-bit
Extern param: MMC blk:0x7c (to 0x9000)
         rtk_eMMC_read blk_addr=0x0000007c, data_size=0x00000800, buffer=0x00009000
Factory: MMC
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x00000200, buffer=0x07880008
         rtk_eMMC_read blk_addr=0x0000c742, data_size=0x00000400, buffer=0x07880210
         rtk_eMMC_read blk_addr=0x0000e000, data_size=0x00000200, buffer=0x07880008
         rtk_eMMC_read blk_addr=0x0000e742, data_size=0x00000400, buffer=0x07880210
         rtk_eMMC_read blk_addr=0x0000c000, data_size=0x000e8400, buffer=0x07000000
Factory: seq:0x289, blk:0xc000(pp:0), size:0xe8400 (to 0x7000000)
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE=1
BOOT_BACKLIGHT_VALUE=253
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=0
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=0
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN=0
BOOT_UART_OPEN_CLOSE=0
BOOT_MUSIC_VOL_VALUE=29
BOOT_LOGO_LED_MODE=1
bootparam.bUart = 0
举报
发表于: 2021-10-15 22:44:57
灯条坏 全机保护 换灯条有惊喜
举报
 楼主| 发表于: 2021-10-16 07:56:45
马龑 2021-10-15 22:44
灯条坏 全机保护 换灯条有惊喜
灯条正常啊,主板的问题,用TV160显示器试过主板没正常的信号输出
举报
发表于: 2021-11-3 19:35:16
确定程序没问题就换主芯片,这个芯片爱坏
举报
发表于: 2025-3-21 09:37:15
修好了吗?我遇到了同样问题
举报
GMT+8, 2025-4-16 19:58 , Processed in 0.098008 sec., 9 queries .
