查看: 1215|回复: 7
长虹UD49C6000iD看不懂打印信息,求助!白板暗屏!
发表于: 2021-10-3 18:31:40
长虹UD49C6000iD最初是指示灯不亮,有开机信号Power电压有PFC电压390V.无背光开启信号换主芯片后正常,看了有30天左右就出现有开机音乐,白屏暗屏,而且指示灯一直在闪烁不停(不符合正常开机的情况吧,真是屏显没有,指示灯常亮或是熄灭才对吧)逐一断开逻辑板下屏线没见一半图像出来,还是暗屏,换了逻辑板也不行。打印信息附上求助大家!!UART_115200
[AT][MB][start sb][0]
AC_ON
AutoDQS0-[456789ABCDE][56789ABCDE][3456789ABCD][3456789ABC]-[0x7899]
AutoDQS1-[456789ABCDE][56789ABCDEF][3456789ABCDE][3456789ABCD]-[0x88A9]
BIST0-OK
BIST1-OK
_U[AT][MB][start ub][347]
U-Boot 2011.06-svn31 (Jun 18 2014 - 16:42:57)
CPU  : Nike
Board: BD_MST049B_10AQV_NIKE
Hello U-Boot
DRAM:  256 MiB
SPI:  Flash is detected (0x0507, 0xC2, 0x20, 0x15)
spi_init: cfg_env_offset: 0x1e0000, at 560
uboot held at [2ecddf60~30000000]
Now running in RAM - U-Boot at: 2f100000
MMC:    [ eMMC_LoadDDRTTable() ] eMMC Err: ChkSum error, no DDRT Table
[ eMMC_FCIE_EnableDDRMode() ] eMMC Warn: no DDR Timing Table, 8000001Bh
[ eMMC_FCIE_BuildDDRTimingTable() ] eMMC Info: building DDR table, please wait...
  eMMC DDR Timing Table: Cnt:0 CurIdx:0
[ eMMC_FCIE_BuildDDRTimingTable() ] eMMC Err: max clk can NOT run DDR
[ eMMC_FCIE_BuildDDRTimingTable() ] eMMC Err: fail! please call CAE or RD for helps, 80000027h
eMMC 3775MB [75FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
Get MAC from ethaddr env
MAC:  0x64: 0x88: 0xff: 0xad:0xa9: 0xb1
@@@@@@ u32CpuSpeedMHz= 792 MHz
read_dbtable success...>>>
read table >>>
logo  offset[0x00140038] size[0x00018744] end[0x0015877c]
music offset[0x0015877c] size[0x00005b07] end[0x0015e283]
panel offset[0x0015e283] size[0x0000005c] end[0x0015e2df]
ursa  offset[0x0015e2eb] size[0x00000000] end[0x0015e2eb]
keypad  offset[0x0015e2fb] size[0x00000000] end[0x0015e2fb]
It's the last cmd
msIR_Initialize
EEPROM @0xA2 read: addr 2ecf0860  off 0207  count 1 ... done
e2p 0x207 = 0xb9
EEPROM @0xA2 read: addr 2ecf0860  off 0306  count 12 ... done
==>In do_load_eeprom_data,no need to saveenv()
ERRlease check the blk# or partiton name!
get_boot_mode_from_mtd0: 'mmc read.p 0x20200000 misc 32' fails, at 374
Wait for PM51 standby...........PM51 APP build code time Apr 25 2014  13:19:11
Lib51 build code time Aug 23 2013  17:14:16
Hello Main
_MDrv_PM_PowerDown2Standby
UART_115200
DC_ON
AutoDQS1-[456789ABCDE][56789ABCDE][3456789ABCDE][3456789ABC]-[0x7899]
BIST0-OK
BIST1-OK
_U[AT][MB][start ub][353]
CPU  : Nike
Hello U-Boot
DRAM:  256 MiB
In:    serial
Out:   serial
Err:   serial
read table >>>
It's the last cmd
msIR_Initialize
e2p 0x207 = 0xb9
[ERROR] get_boot_status_from_mtd0:576: get_boot_status_from_mtd0: 'mmc read.p 0x20200000 misc 40' fails, at 576
Wait for PM51 standby DRAM ...........PM51 run ok...........[LED_INV] src/CusPM.c pm_led_flash 360
Unknown command 'if_51OnRam_set' - try 'help'
[INFO] Load Ukulele 8x Mode DRAM Settings
Ukulele MIU BIST: OK
mmc change mount : uinside
** Partition 0 not valid on device 0 **
Unable to use mmc 0:0 for fattable
Loading file "/MERGE_VB1.bin" at offset 0x0 from mmc device 0
[ERROR] vfs_read:522: ext4load mmc fail
vfs_read fail
db_table.panelpara_offset =:0x15e283...db_table.panelpara_size=:0x5c
Read_PanelParaFromflash success...>>>
## CRC check done, panel_crc
panel_data.m_wPanelVStart=: 0x18
panel_data.m_wPanelWidth=: 0x780
panel_data.m_wPanelHeight=: 0x438
db_table.boardpara_offset =:0x15e2df...db_table.boardpara_size=:0xc
Read_BoardParaFromflash success...>>>
## CRC check done, board_crc
db_table.ursa_offset =:0x15e2eb...db_table.ursa_size=:0x10
## CRC check done, ursa_crc
cmd_table.URSA_EXTERNAL is 0
cmd_table.URSA_MEMC_ENABLE is 0
cmd_table.URSA_LVDS_CHANNEL_SWAP_MODE is 0
cmd_table.URSA_LVDS_SWAP_POL is 1
cmd_table.URSA_IN_LVDS_TIMODE is 0
cmd_table.URSA_IN_LVDS_TI_BITNUM is 2
cmd_table.URSA_OUT_LVDS_TIMODE is 1
cmd_table.URSA_OUT_LVDS_TI_BITNUM is 2
cmd_table.URSA_SSC_SEL is 1
cmd_table.URSA_SSC_ENABLE is 0
cmd_table.URSA_SSC_FREQ is c8
cmd_table.URSA_SSC_PERCENT is 64
cmd_table.URSA_OSD_PROTECT_MODE is 1
>>CMD:62,2,0,0,e4,0,0
MDrv_Ursa_8_3D_Cmd write data fail.....
sellect video swap mode error!!!
>>CMD:d2,1,0,0,0,2c,0
osd_protect_mode = 1
[URSA_8]Write cmd:a5,9,1,0,0,0,0
[Ursa_8]Send cmd:8, return:0
>>CMD:82,4,0,0,0,0,34
sellect output lvds swing error!!!
>>CMD:53,9,10,0,c8,0,64
MDrv_PNL_Init u32PnlRiuBaseAddr = 1f200000
MDrv_PNL_Init u32PMRiuBaseAddr = 1f000000
LINK TYPE = EXT [_MDrv_PNL_Init_LPLL][300]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_LPLL][302]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][345]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_Output_Dclk][347]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[URSA_8]Write cmd:93,8,1,0,0,0,0
[Ursa_8]Send cmd:4, return:0
Init PWM1[ERROR] No Support PWM Clock Unit Divider in Nike Platform Changhong818_mboot_Version=v1.0026
Check USB port[2]:
Host type:2
scanning bus for devices...
[USB] interface[0] conf:1 value 9:
Wait for hub reset....
checking hub ports...
[USB] interface[0] conf:1 value ff:
2 USB Device(s) found
       scanning bus for storage devices... 0 Storage Device(s) found
FAIL : can not init usb!!
>>CMD:62,2,0,0,e4,0,0
>>CMD:d2,1,0,0,0,2c,0
>>CMD:82,4,0,0,0,0,34
[MAPI PNL][001103] Initialization more than once
Need to check USB
Check USB port[2]:
Host type:2
==>In do_check_changhong_upgrade,no need to saveenv()
db_table.logo_offset =:0x140038 ... db_table.logo_size=: 0x18744
Read_LogoToDisplayAddr success...>>>
## CRC check done, logo_crc
[AutoTest][MBoot][JPD Decode]
[GOP0, PID 0, TID 0x-1][Driver Version]: 0089, BuildNum: 0002, ChangeList: 00000340
[AutoTest][MBoot][Show Logo][7936]
Read_>>>
Read_MusicToPlayAddr success...>>>
Read_MusicToPlayAddr success...>>> 2
## CRC check done, music_crc
[[utopia]]      DSPBinBaseAddress 0= 0x0
[[utopia]]      DSPMadBaseBufferAdr 0= 0x19100000
[[utopia]]      DSPBinBaseAddress 1= 0x0
[[utopia]]      DSPMadBaseBufferAdr 1= 0x18fc8000
[[utopia]]      DSPBinBaseAddress 2= 0x0
[[utopia]]      DSPMadBaseBufferAdr 2= 0x18e88000
HAL_MAD_SetMemInfo : DDR_ADDR = 0x19100000, MIUBank = 0
******Amplifier_TI5711_SWMute(0)
[AutoTest][MBoot][Play Melody]
Wrong Image Format for bootm command
ERROR: can't get kernel image!
<< MStar >>#
 楼主| 发表于: 2021-10-3 18:36:14
2021-9-28, 0:7:20
COM4, BaudRate:115200 bps, RXD: VGA->11,TXD: VGA-> 4, Printed by RT809F:
UART_115200
DC_ON
AutoDQS0-[456789ABCDEF][56789ABCDE][3456789ABCD][3456789ABC]-[0x7899]
BIST0-OK
BIST1-OK
_U[AT][MB][start ub][351]
CPU  : Nike
Hello U-Boot
DRAM:  256 MiB
In:    serial
Out:   serial
Err:   serial
read table >>>
It's the last cmd
msIR_Initialize
e2p 0x207 = 0xb9
vfs_read fail
>>CMD:62,2,0,0,e4,0,0
>>CMD:d2,1,0,0,0,2c,0
>>CMD:82,4,0,0,0,0,34
Check USB port[2]:
Host type:2
>>CMD:62,2,0,0,e4,0,0
>>CMD:d2,1,0,0,0,2c,0
>>CMD:82,4,0,0,0,0,34
Need to check USB
Check USB port[2]:
Host type:2
[AutoTest][MBoot][Show Logo][7922]
Read_>>>
<< MStar >>#
 楼主| 发表于: 2021-10-3 18:38:14
2021-9-28, 0:7:20
UART_115200
DC_ON
BIST0-OK
BIST1-OK
CPU  : Nike
Hello U-Boot
DRAM:  256 MiB
In:    serial
Out:   serial
Err:   serial
read table >>>
It's the last cmd
msIR_Initialize
e2p 0x207 = 0xb9
vfs_read fail
>>CMD:62,2,0,0,e4,0,0
>>CMD:d2,1,0,0,0,2c,0
>>CMD:82,4,0,0,0,0,34
Init PWM1[ERROR] No Support PWM Clock Unit Divider in Nike Platform Changhong818_mboot_Version=v1.0026Check USB port[2]:
Host type:2
>>CMD:62,2,0,0,e4,0,0
>>CMD:d2,1,0,0,0,2c,0
>>CMD:82,4,0,0,0,0,34
Need to check USB
Check USB port[2]:
Host type:2
Read_>>>
<< MStar >>#
 楼主| 发表于: 2021-10-3 19:04:30
wadopin 2021-10-3 18:49
用U盘升级呀!!
试过了,优盘升级没反应,淘宝的V1.00042版本的,我原机主板贴纸是ZL S4 7His-V1.00030-13版本,卖家说可以用,但是按照升级操作没反应!!难道还有其它的刷机方法我不知道吗?
 楼主| 发表于: 2021-10-3 23:02:20
用U盘升级呀!!
也不清楚不同版本的优盘主程序能导致刷机不成功吗?刷机用的优盘都是正常刷机用的,而且换了2个也刷机没反应,况且指示灯开机音乐过后一直闪,这不属于正常电视机的开机收看状态是的情景吧,一直闪也刺眼啊,从这个层面讲,不正常。但是不知道哪里出现了问题。
 楼主| 发表于: 2021-10-4 21:27:03
感谢回复,可能刷机方法有误,第一个卖家说把文件大的那个拷贝优盘进行刷机,可能导致我这次刷机不成功,后又淘宝了另外一个卖家说要把2个文件包括那个引导文件一起拷贝到优盘进行刷机,我还没试验呢,试验 后结果一定回复大家!!看看到底那个对,或是硬件真的有毛病!
GMT+8, 2024-11-26 05:59 , Processed in 0.063931 sec., 9 queries .
