查看: 1563|回复: 7
请师傅帮忙看看这个打印信息
发表于: 2021-9-17 17:25:39
2021-9-17, 16:51:7
COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809H:
Boot-
DRAM Channel A Calibration.
Byte 0 : Gating(2 ~ 62), Size=61, Mid=32, Set=32.
Byte 1 : Gating(2 ~ 57), Size=56, Mid=29, Set=29.
Byte 2 : Gating(2 ~ 67), Size=66, Mid=34, Set=34.
Byte 3 : Gating(2 ~ 57), Size=56, Mid=29, Set=29.
HW Byte 0 : DQS(10 ~ 45), Size 36, Set 27, HW_Set 29.
HW Byte 1 : DQS(8 ~ 41), Size 34, Set 24, HW_Set 26.
HW Byte 2 : DQS(11 ~ 42), Size 32, Set 26, HW_Set 28.
HW Byte 3 : DQS(10 ~ 41), Size 32, Set 25, HW_Set 27.
DRAM A Size = 768 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0x23bfa049
:0x04010169
:0x32473163
:0x90014a48
LZHS addr:0x00100040
LZHS size:0x000a73c0
LZHS checksum:0x000000eb
Boot
Start Lmain
MT5880 Boot Loader v0.9
Boot reason: A/C power on!!
use code based  EDID.................
Load HDMI internal EDID.................
CEC Physical offset 152
HDMI1 Physical adr 0x10
HDMI1 PA 0x10
HDMI1 checksum 0xdf
HDMI2 PA 0x10
HDMI2 checksum 0xdf
HDMI3 PA 0x20
HDMI3 checksum 0xcf
HDMI4 PA 0x30
HDMI4 checksum 0xbf
SIF_Master0: new design
IR DATA register : 0x       0
Load T8032 FW (addr: 0x  d80b70, size: 24576)success!!
T8032 FW version: 73
LDR_FlashCopy 0xf010 0x59f80 0x80
1st MAC in EEP is valid (90:cf:7d:eb:5c:44)
1st : (90:cf:7d:eb:5c:44)
2nd : (ff:ff:ff:ff:ff:ff)
PDWNC_Init
Boot reason: A/C power on!!update check revovery,adc value:255
LDR_CheckRecovery,needn't enter recover
Do USB upgrade
USB: Vbus turn up time = 207 ms, Max =0 ms.
No USB device.
USB upgrade stop
Boot reason: A/C power on!!Boot reason: A/C power on!!Org:0x10 Flags:0x10
PDWNC_EnterPowerDown(100,0)
Disable VGA wakeup
LEE TEST: PDWNC_SetLED_Mode 1
Standby            ??enable wakeup H匔吤DRAM Channel A Calibration.
Byte 3 : Gating(2 ~ 62), Size=61, Mid=32, Set=32.
HW Byte 0 : DQS(11 ~ 44), Size 34, Set 27, HW_Set 30.
HW Byte 1 : DQS(8 ~ 42), Size 35, Set 25, HW_Set 26.
HW Byte 2 : DQS(10 ~ 41), Size 32, Set 25, HW_Set 28.
HW Byte 3 : DQS(10 ~ 42), Size 33, Set 26, HW_Set 28.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0x23bfa049
:0x04010169
:0x32473163
:0x90014a48
Boot
Start Lmain
IR DATA register : 0xf20dbf00
PDWNC_Init
Do USB upgrade
USB: Vbus turn up time = 162 ms, Max =0 ms.
No USB device.
USB upgrade stop
Org:0x10 Flags:0x10
Flash load lzhs header from 0x80000 to dram(0x1500020), size=2048
Decompression uboot to 0x00800000...
Flash load image from 0x80000 to dram(0x1500020), size=0x369d7
secure boot ok
LZHS start
LZHS done
Starting image...
U-Boot 2011.12.12 (Nov 18 2016 - 01:01:44)
DRAM:  624 MiB
WARNING: Caches not enabled
MMC:   HOST 1
Dev Num: 0, Timing Position: 0, Sample Edge: 0x00
90014A48:32473163:04010169:23BFA049
id1:4A483247 id2:31630401
eMMC Name: UNKNOWN
Dev Num: 0, Timing Position: 1, Sample Edge: 0x00
Dev Num: 0, Timing Position: 2, Sample Edge: 0x11
: 0
0.0.0.0
In:    serial
Out:   serial
Err:   serial
Net:   Net Initialization Skipped
No ethernet found.
PDWNC_REBOOT_CMD_OFFSET contains
## Booting kernel from Legacy Image at 00008000 ...
   XIP Kernel Image ... OK
OK
Starting kernel ...
Initializing cgroup subsys cpuset
Linux version 3.0.13 (gfkfcmo@ubuntu-num3) (gcc version 4.5.1 (GCC) ) #1 SMP PREEMPT Fri Nov 18 01:01:29 CST 2016
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: MT5880
Memory policy: ECC disabled, Data cache writealloc
====> PMEM BOOTMEM ALLOC <=====
allocating 49283072 bytes at   (null) (40000000 physical) for pmem arena
PERCPU: Embedded 7 pages/cpu @c0af5000 s4960 r8192 d15520 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 191264
Kernel command line: lpj=4571136 console=ttyMT0,115200n1 root=/dev/mmcblk0p5 vmalloc=512M no_console_suspend androidboot.carrier=wifi-only mtdparts=mt53xx-emmc:2M(uboot),2M(uboot_env),1M(misc),16M(recovery),16M(boot),500M(system),500M(userdata),500M(cache),1M(reserved),1M(channelA),1M(channelB),1M(pq),1M(aq),4M(logo),4M(bootlogo) mali_core_num=2 usbportusing=1,1,1,0 usbpwrgpio=-1,-1,-1,-1 usbpwrpolarity=-1,-1,-1,-1 usbocgpio=-1,-1,-1,-1 usbocgpiopolarity=-1,-1,-1,-1
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
allocated 2555904 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 624MB = 624MB total
Memory: 617156k/617156k available, 21820k reserved, 131072K highmem
Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
    vmalloc : 0xdf800000 - 0xff000000   ( 504 MB)
    lowmem  : 0xc0000000 - 0xdf000000   ( 496 MB)
    pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    modules : 0xbf000000 - 0xbfe00000   (  14 MB)
      .init : 0xc0008000 - 0xc0029000   ( 132 kB)
      .text : 0xc0029000 - 0xc049ff44   (4572 kB)
      .data : 0xc04a0000 - 0xc04d71e0   ( 221 kB)
       .bss : 0xc04d7204 - 0xc060f398   (1249 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:256
timekeeping_init done
ckgen Xtal:27000000 Hz
Console: colour dummy device 80x30
console [ttyMT0] enabled
Calibrating delay loop (skipped) preset value.. 1828.45 BogoMIPS (lpj=4571136)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys cpuacct
Initializing cgroup subsys memory
CPU: Testing write buffer coherency: ok
Calibrating local timer... 445.39MHz.
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x73440001, Cache size: 262144 B
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (3656.90 BogoMIPS).
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switching to clocksource timer2
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (junk in compressed archive); looks like an initrd
Freeing initrd memory: 7244K
PMU: registered new PMU device of type 0
Power Management for MTK DTV.
highmem bounce pool size: 64 pages
ashmem: initialized
squashfs: version 4.0 (2009/01/31) Phillip Lougher
msgmni has been set to 963
io scheduler noop registered
io scheduler deadline registered
io scheduleSerial: MT53xxttyMT0 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
ttyMT1 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
ttyMT2 at MMIO 0xf0028800 (irq = 32) is a MT53xx Serial
ttyMT3 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
brd: module loaded
loop: module loaded
pmem: 1 init
android_pmem: probe of android_pmem.0 failed with error -1
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
star: desc addr: 0xffdff000(virtual)/0x1e0f4000(physical)
Star Ethernet: Internal Vitesse PHY
star: PHY addr = 0x0000
star: EthTool installed
star: Star MAC init done
MUC_init 5038: [USB]Controller in DMA mode
MGC_VBusControl 725: [USB0]Vbus Off gpio[-1].
MtkUsbHcd MtkUsbHcd.0: USB Host Controller
MtkUsbHcd MtkUsbHcd.0: new USB bus registered, assigned bus number 1
MtkUsbHcd MtkUsbHcd.0: irq 47, io mem 0xf0050000
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
MGC_VBusControl 725: [USB1]Vbus Off gpio[-1].
MtkUsbHcd MtkUsbHcd.1: USB Host Controller
MtkUsbHcd MtkUsbHcd.1: new USB bus registered, assigned bus number 2
MtkUsbHcd MtkUsbHcd.1: irq 43, io mem 0xf0051000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
MGC_VBusControl 725: [USB2]Vbus Off gpio[-1].
MtkUsbHcd MtkUsbHcd.2: USB Host Controller
MtkUsbHcd MtkUsbHcd.2: new USB bus registered, assigned bus number 3
MtkUsbHcd MtkUsbHcd.2: irq 80, io mem 0xf0052000
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 1 port detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
using rtc device, mt53xx_rtc, for alarms
mt53xx_rtc mt53xx_rtc.0: rtc core: registered mt53xx_rtc as rtc0
mt53xx_rtc mt53xx_rtc.0: MT53xx Real Time Clock driver.
adbattery: android dummy battery driver loaded
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com
Bluetooth: Generic Bluetooth USB driver ver 0.6
usbcore: registered new interface driver btusb
Bluetooth: Atheros AR30xx firmware driver ver 1.0
usbcore: registered new interface driver ath3k
mmc0: 5880
at 0xf006d000 irq 100 data mode 3 Optimization
mmc1: 5880
at 0xf0012000 irq 60 data mode 3
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
logger: created 256K log 'log_main'
logger: created 256K log 'log_events'
logger: created 256K log 'log_radio'
logger: created 256K log 'log_system'
zram: num_devices not specified. Using default: 2
special_arg: 00000002
test mmc...
zram: Creating 2 devices ...
usbcore: registered new interface driver snd-usb-audio
ALSA device list:
  No soundcards found.
nf_conntrack version 0.5.0 (9756 buckets, 39024 max)
NF_TPROXY: Transparent proxy support initialized, version 4.1.0
NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
NET: Registered protocol family 10
ip6_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 17
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
mmc0: new high speed MMC card at address 0001
mmcblk0: mmc0:0001 H2G1c 1.76 GiB
mmcblk0boot0: mmc0:0001 H2G1c partition 1 1.00 MiB
mmcblk0boot1: mmc0:0001 H2G1c partition 2 1.00 MiB
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
VFP support v0.3:
part 01: startblk 0x00000000, blkcnt 0x00001000, <uboot>
part 02: startblk 0x00001000, blkcnt 0x00001000, <uboot_env>
part 03: startblk 0x00002000, blkcnt 0x00000800, <misc>
part 04: startblk 0x00002800, blkcnt 0x00008000, <recovery>
part 05: startblk 0x0000a800, blkcnt 0x00008000, <boot>
part 06: startblk 0x00012800, blkcnt 0x000fa000, <system>
part 07: startblk 0x0010c800, blkcnt 0x000fa000, <userdata>
part 08: startblk 0x00206800, blkcnt 0x000fa000, <cache>
part 09: startblk 0x00300800, blkcnt 0x00000800, <reserved>
part 10: startblk 0x00301000, blkcnt 0x00000800, <channelA>
part 11: startblk 0x00301800, blkcnt 0x00000800, <channelB>
part 12: startblk 0x00302000, blkcnt 0x00000800, <pq>
part 13: startblk 0x00302800, blkcnt 0x00000800, <aq>
part 14: startblk 0x00303000, blkcnt 0x00002000, <logo>
part 15: startblk 0x00305000, blkcnt 0x00002000, <bootlogo>
mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15implementor 41 architecture 3 part 30 variant 9 rev 3
mmcblk0boot1: unknown partition table
mt53xx_rtc mt53xx_rtc.0: setting system clock to 2000-01-01  mmcblk0boot0: unknown partition table
RAMDISK: gzip image found at block 0
UDF-fs: No partition found (1)
List of all partitions:
b300         1847296 mmcblk0  driver: mmcblk
  b301            2048 mmcblk0p1 00000000-0000-0000-0000-000000000000mmcblk0p1
  b302            2048 mmcblk0p2 00000000-0000-0000-0000-000000000000mmcblk0p2
  b303            1024 mmcblk0p3 00000000-0000-0000-0000-000000000000mmcblk0p3
  b304           16384 mmcblk0p4 00000000-0000-0000-0000-000000000000mmcblk0p4
  b305           16384 mmcblk0p5 00000000-0000-0000-0000-000000000000mmcblk0p5
  b306          512000 mmcblk0p6 00000000-0000-0000-0000-000000000000mmcblk0p6
  b307          512000 mmcblk0p7 00000000-0000-0000-0000-000000000000mmcblk0p7
  103:00000     512000 mmcblk0p8 00000000-0000-0000-0000-000000000000mmcblk0p8
  103:00001       1024 mmcblk0p9 00000000-0000-0000-0000-000000000000mmcblk0p9
  103:00002       1024 mmcblk0p10 00000000-0000-0000-0000-000000000000mmcblk0p10
  103:00003       1024 mmcblk0p11 00000000-0000-0000-0000-000000000000mmcblk0p11
  103:00004       1024 mmcblk0p12 00000000-0000-0000-0000-000000000000mmcblk0p12
  103:00005       1024 mmcblk0p13 00000000-0000-0000-0000-000000000000mmcblk0p13
  103:00006       4096 mmcblk0p14 00000000-0000-0000-0000-000000000000mmcblk0p14
  103:00007       4096 mmcblk0p15 00000000-0000-0000-0000-000000000000mmcblk0p15
b310            1024 mmcblk0boot1  (driver?)
b308            1024 mmcblk0boot0  (driver?)
No filesystem could mount root, tried:  ext3 ext2 ext4 squashfs vfat msdos iso9660 udf
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,5)
[<c0033efc>] (unwind_backtrace+0x0/0xe4) from [<c037fd40>] (panic+0x68/0x188)
[<c037fd40>] (panic+0x68/0x188) from [<c0008d6c>] (mount_block_root+0x238/0x288)
[<c0008d6c>] (mount_block_root+0x238/0x288) from [<c00098dc>] (initrd_load+0xa4/0x310)
[<c00098dc>] (initrd_load+0xa4/0x310) from [<c0008fcc>] (prepare_namespace+0xc4/0x1b8)
[<c0008fcc>] (prepare_namespace+0xc4/0x1b8) from [<c00089f4>] (kernel_init+0x124/0x160)
[<c00089f4>] (kernel_init+0x124/0x160) from [<c002f4ec>] (kernel_thread_exit+0x0/0x8)
CPU1: stopping
[<c0033efc>] (unwind_backtrace+0x0/0xe4) from [<c0029368>] (do_IPI+0xc8/0x198)
[<c0029368>] (do_IPI+0xc8/0x198) from [<c002e6ac>] (__irq_svc+0x4c/0xe0)
Exception stack(0xde85ff90 to 0xde85ffd8)
ff80:                                     00000000 00000000 de85ffd8 00000000
ffa0: de85e000 c04af48c c04d72e4 c0384934 0000406a 410fc090 00000000 00000000
ffc0: de9e2044 de85ffd8 c002f548 c002f54c 60000013 ffffffff
[<c002e6ac>] (__irq_svc+0x4c/0xe0) from [<c002f54c>] (default_idle+0x24/0x28)
[<c002f54c>] (default_idle+0x24/0x28) from [<c002f824>] (cpu_idle+0x7c/0xdc)
[<c002f824>] (cpu_idle+0x7c/0xdc) from [<0037d140>] (0x37d140)
MGC_VBusControl 725: [USB0]Vbus On gpio[-1].
MGC_VBusControl 725: [USB1]Vbus On gpio[-1].
MGC_VBusControl 725: [USB2]Vbus On gpio[-1].
发表于: 2021-9-17 18:18:26
主题
129
帖子
1 表示
积分
中等
Rank: 7Rank: 7Rank: 7
积分11670
埃塔塔
发消息
电梯直达
跳转到指定楼层1#
12
月1日,| 回帖奖励
2021-9-17,
16:51:7 COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, 由 RT809H 打印:
引导 -
DRAM 通道 A 校准.
字段 0 : 盖廷 (2 + 62), 大小+61, 中+32, Set=32.
字段 1 : 盖廷 (2 + 57), 大小=56, 中+29, Set=29.
字段 2 : 盖廷 (2 + 67), 大小+66, 中+34, Set=34.
字段 3 : 盖廷 (2 + 57), 大小=56, 中+29, Set=29.
HW 字段 0 : DQS (10 + 45), 大小 36, 设置 27, HW_Set 29.
HW 字组 1 : DQS (8 + 41), 大小 34, 集 24, HW_Set 26.
HW 字组 2 : DQS (11 + 42), 大小 32, 集 26, HW_Set 28.
HW 字组 3 : DQS (10 + 41), 大小 32, 集 25, HW_Set 27.
Dram A 大小 = 768 MB。
启动
Pmain
0x0000a000
EMMC 启动 CID:0x23bfa049 :0x04010169:0x32473163:0x90014a48 LZHS 添加器:0x00100040 LZHS 大小:0x000a73c0 LZHS 检查:0x000000eb启动 Lmain MT5880 启动装载机 v0.9 启动原因: A/C 电源打开!!
负载 Vga 内部 EDID....
使用基于 EDID 的代码...
负载 HDMI 内部 EDID....
CEC 物理偏移
152 HDMI1 物理
adr 0x10 HDMI1
PA 0x10
HDMI1 检查库0xdf HDMI2 PA 0x10
HDMI2 检查库0xdf
HDMI3 PA 0x20
HDMI3 检查库0xcf
HDMI4 PA 0x30
HDMI4
检查0xbf SIF_Master0:新
设计 IR DATA 注册器
: 0x 0 启动原因: A/C 电源打开!!T8032 在案例装载机舞台上的 A/C 中...
负载 T8032 FW (添加器: 0x d80b70, 大小: 24576) 成功!!
T8032 FW 版本:
73 T8032 更改为装载机阶段...
EEP 中
的第
1MAC LDR_FlashCopy 0xf010 0x59f80 0x80有效 (90:cf:7d:eb:eb:5c:44) 第 1: (90:cf:7d:eb:5c:44)
第 2: (ff:ff:ff:ff:ff)
PDWNC_Init
启动原因: A/C 电源打开!!更新检查转录,
adc 值:255 LDR_CheckRecovery, 不需要输入恢复
USB 升级
USB: Vbus 打开时间 = 207 ms, 最大
+0 ms. 无 USB 设备。
USB 升级
停止启动原因: A/C 电源打开!!启动原因: A / C 电源打开!!组织:0x10旗
:0x10 PDWNC_EnterPowerDown(100,0)
禁用VGA唤醒
李测试:PDWNC_SetLED_Mode 1
待机??启用唤醒 H++DRAM 通道 A 校准。
字段 3 : 盖廷 (2 + 62), 大小+61, 中+32, Set=32.
HW 字组 0 : DQS (11 + 44), 大小 34, 设置 27, HW_Set 30.
HW 字组 1 : DQS (8 + 42), 大小 35, 设置 25, HW_Set 26.
HW 字组 2 : DQS (10 + 41), 大小 32, 集 25, HW_Set 28.
HW 字组 3 : DQS (10 + 42), 大小 33, 集 26, HW_Set 28.
Dram A 大小 = 768 MB。
启动
Pmain
0x0000a000
EMMC 启动 CID:0x23bfa049 :0x04010169:0x32473163 :0x90014a48 LZHS 添加器:0x00100040 LZHS 大小:0x000a73c0 LZHS 检查:0x000000eb启动 Lmain MT5880 启动装载机 v0.9 SIF_Master0:新
设计 IR DATA 寄存器 : 0xf20dbf00
T8032 更改为装载机阶段。
EEP 中
的第 LDR_FlashCopy 0xf010 0x59f80 0x80 个 MAC 有效 (90:cf:7d:eb:5c:44)
第 1 个: (90:cf:7d:eb:5c:44)
第二个: (ff:: ff:ff:ff:ff:ff)
PDWNC_Init
更新检查转录,
adc 值: 255
LDR_CheckRecovery,
不需要输入恢复 Usb 升级 Usb: Vbus 打开时间 =
162 ms, 最大 +0 ms。 没有 USB 设备。
USB 升级
停止组织:0x10 标志:0x10 从0x80000
到德拉姆(0x1500020),大小+2048
减压 uboot 到 0x00800000 的闪光加载 lzhs 头...
从0x80000 到德拉姆 (0x1500020) 的闪存负载图像,大小=0x369d7安全启动确定 LZHS 启动 LZHS 完成启动图像...
U-Boot 2011.12.12 (2016年11月18日 - 01:01:44) DRAM: 624 MiB 警告: 缓存未启用 MMC: 主机 1 开发 Num: 0, 计时位置: 0, 示例边缘: 0x00 90014A48:32473163:04010169:23BFA049 ID1:4A483247 id2:31630401 eMMC 名称: 未知开发 Num: 0, 计时位置: 1, 示例边缘: 0x00 Dev Num: 0, 时间位置: 2, 示例边缘: 0x11 : 0 0.0.0 在: 串行出: 串行 Err: 序列网: 净初始跳过没有以太网发现。
PDWNC_REBOOT_CMD_OFFSET包含
命中任何键停止自动启动: 0
## 启动内核从遗产图像在 00008000...
XIP 内核图像...好的
好的启动内核...
诺...完成, 启动内核。
初始 c 组子集 cpuset 初始化 c 组子集 cpu Linux 版本 3.0.13 (gfkfcmo@ubuntu-num3) (gcc 版本 4.5.1 (GCC) ) #1 SMP 预置 11 月 18 日周五 01:01:2 9 CST 2016 CPU: ARMv7 处理器 [413fc090] 修订版 0 (ARMv7), cr=10c53c7d CPU: VIPT 非分配数据缓存, VIPT 别名指令缓存机: MT5880 内存策略: ECC 禁用, 数据缓存写位置 []]=> PMEM BOOTMEM ALLOC <==分配49283072字节(空) (40000000 物理)为 pmem 竞技场 PERCPU:
嵌入式 7 页/cpu @c0af5000 s4960 r8192 d15520 u32768 按区域顺序构建 1 个区域列表, 移动分组。
总总页数: 191264
内核指挥线: lpj=4571136控制台=ttyMT0,115200n1 根=/开发/mmcblk0p5 vmalloc=512M no_console_suspend机器人靴.运营商+wifi-仅mtdpart=mt53xx-emmc:2M(u) 启动),2M(uboot_env),1M(错误),16M(恢复),16M(启动),500M(系统),500M(用户数据),500M(缓存),1M(保留),1M(通道A),1M(通道B),1M(pq),1M (aq), 4M (徽标), 4M (靴子) mali_core_num=2 usbportusing=1,1,1,0 usbpwrgpio=-1,-1,-1
usbpwr极性=-1,-1,-1 usbo cgpio =1, -1, -1, -1 usbocgpio 极性 = -1, -1, -1 PID 哈希表条目: 4096 (订单: 2, 16384 字
节) 登特里缓存哈希表条目: 131072 (订单: 7, 524288字
节) Inode 缓存哈希表条目: 65536 (订单: 6, 262144 字节)
分配2555904字节
的page_cgroup请尝试 "cgroup_disable= 内存" 选项, 如果你不想要内存
c 组记忆: 624MB = 624MB total
NR_IRQS:256 timekeeping_init完成
ckgen Xtal:2700000Hz
控制台: 彩色虚拟设备 80x30
控制台 [ttyMT0] 启用
校准延迟循环 (跳过) 预设值。1828.45 BogoMIPS (lpj=4571136)
pid_max: 默认: 32768 最低: 301
山缓存哈希表条目:
512 初始化 cgroup 子
cpuacct 初始化
c 组子组内存 CPU:
测试编写缓冲系数: 确定校准本地定时器...445.39MHz.
支持 L310 缓
存控制器的 l2x0: 8 路, CACHE_ID 0x410000c8, AUX_CTRL 0x73440001, 缓存大小:
262144 B CPU1:
启动二级处理器带来了
2 个 CPU SMP: 激活的 2 个处理器总数 (3656.90 BogoMIPS)。
NET:
注册协议系列 16 生物: 创建板<bio-0>at 0
SCSI 子系统初始化
usbcore: 注册的新界面驱动程序 usbfs
usbcore: 注册
的新界面驱动程序集线器 usbcore: 注册新设备驱动程序 usb
高级 Linux 声音架构驱动程序版本 1.0.24。
蓝牙: 核心 ver 2.16 NET: 注册协议家庭
31 蓝牙: HCI 设备
和连接经理初始化蓝牙: HCI 插
座层初始蓝牙: L2CAP 插座层
初始化蓝牙: SCO 插座层初始
化切换到时钟源计时
器 2 NET:
注册协议系列 2 IP 路由缓存哈希表条目: 32768
(订单: 5, 131072 字节) TCP 已建立的哈希表条
目: 131072 (订单: 8, 1048576字节) TCP 绑定哈希表条
目: 65536 (订单: 7, 786432 字节) TCP: 配置的哈希表(已建立131072绑定
65536) TCP reno 注册
UDP 哈希表条目: 512 (订单: 2, 16384
字节) UDP-Lite 哈希表条目: 512 (订单: 2, 16384 字节) NET: 注册协议家庭 1
尝试拆包 根夫斯图像作为伊尼特拉姆夫...
根形图像不是无名小孔(压缩存档中的垃圾):看起来像一个第 3 个
释放第 3 个内存:
7244k Pmu:
注册了 Mtk Dtv 0 型电源管理的新 PMU 设备。<
高米反弹池大小: 64
页阿希姆:
初始化壁球: 版本 4.0 (2009/01/31) 菲利普
· 拉夫尔 msgmni 已
设置为 963
io 调度器
noop 注册 io 时间表 mt53xxttymt0 在 MMIO 0xf000c000 (irq = 49)
是 Mt53xx 串行 ttymt1 在 MMIO 0xf000c000 (irq
= 49) 是 Mt53xx 在 MMIO 0xf0028800 (irq =
32) 的串行 ttyMT2 是 MMIO 0xf000c000 (irq =
49)
的 MT53xx 串行 ttyMT3: 模块加载
循环: 模块加载 pmem: 1 init
android_pmem: 探头android_pmem.0 故障与错误 -1
PPP 通用驱动程序版本 2.4.2
PPP 放气压缩模块注册
PPP BSD 压缩模块注册
PPP MPPE 压缩模块注册
NET: 重新gister 协议系列 24
tun: 通用 TUN/TAP 设备驱动程序
, 1.6 tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
星: desc 添加器: 0xffdff000 (虚拟)
/0x1e0f4000 (物理) 星以太网
: 内部 Vitesse PHY
星: PHY 添加
器 = 0x0000星:
Ethtool 安装星: 星 MAC MUC_init 5038 完成: [USB] 控制器在 DMA 模式
MGC_VBusControl 725: [USB0] Vbus 关闭 gpio [-1] 。
MtkusbhcdMtkusbhc. 0: Usb 主
机控制器 MtkusbhcdMtkusbhcd. 0: 注册的新 Usb
巴士, 分配的巴士编号 1 Mtkusbhcd Mtkusbhc.0: irq
47, io mem 0xf0050000枢纽 1
- 0:1.0: USB 集
线器发现集线器 1 -0:1.0: 1 端口检测到MGC_VBusControl 725: [USB1] Vbus 关闭 gpio [-1]。
MtkusbhcdMtkusbhc. 1: Usb 主
机主计长 MtkusbhcdMtkusbhcd. 1: 注册的新 Usb
巴士, 分配的巴士编号 2 Mtkusbhcd Mtkusbhc. 1:
irq 43, io mem 0xf0051000枢纽
2 - 0: 1.0: USB 集线器发现集线器 2 - 0:1.0: 1 端口检测到
MGC_VBusControl 725: [USB2] Vbus 关闭 gpio [-1] 。
MtkusbhcdMtkusbhcd. 2: Usb
主机控制器 MtkusbhcdMtkusbhcd. 2: 注册的新 USB
巴士, 分配巴士编号 3 Mtkusbhcd Mtkusbhc.2: irq
80, io mem 0xf0052000集线器
3 - 0: 1.0: USB 集线器发现集线器 3 - 0:1.0: 1 端口检测初始
化 USB 大规模存储驱动器。
usbcore: 注册的新界面驱动器 usb 存储
USB 大规模存储支持注册。
鼠标: PS/2 鼠标设备常见于
所有使用 rtc 设备的鼠标,mt53xx_rtc,
用于报警mt53xx_rtc mt53xx_rtc.0: rtc 内核:注册mt53xx_rtc为 rtc0
mt53xx_rtc mt53xx_rtc.0:MT53xx 实时时钟驱动程序。
adbattery: 机器人虚拟电池驱动程序加
载设备 mapper: uevent: 版本 1.0.3
设备 mapper: ioctl: 4.20.0 - ioctl (2011 - 02 - 02) 初始化: dm-devel@redhat.com
蓝牙: 通用
蓝牙 USB 驱动程序 ver
0.6 usbcore: 注册新界面驱动程序 btusb
蓝牙: 阿瑟罗斯 AR30xx
固件驱动程序 ver 1.0 usbcore: 注册新界面驱动程序 ath3k m mc0: 5880
在 0xf006d000 irq 100 数据模式 3 优化
mmc1: 5880
在 0xf0012000 irq 60 数据模式 3
usbcore: 注册的新界面驱动器 usbhid
usbhid: USB HID 核心驱动程序
记录器: 创建 256K 日志 "log_main"
记录器: 创建 256K 日志 "log_events"
记录器: 创建 256K 日志 "log_radio"
记录器: 创建 256K 日志 "log_system"
zram: num_devices 指定。使用默认值:
2 special_arg: 00000002
测试 mmc...
zram: 创建 2 台设备...
usbcore: 注册的新界面驱动器 snd -
usb 音频
Alsa 设备列表: 未找到声音卡。
分享到:
QQ 不
分享淘
回复 支持 2 反对 0
 楼主| 发表于: 2021-9-17 17:30:01
海信LED46K360J  板号RSAG7.820.5277  开机黑屏,遥控不能关机,请高手看看打印信息,哪里出问题了
发表于: 2021-9-17 17:38:47
Do USB upgrade
No USB device.
USB upgrade stop
Boot reason: A/C power on!!Boot reason: A/C power on!!Org:0x10 Flags: 都有已经有升级提示了,没看到吗?
 楼主| 发表于: 2021-9-17 17:54:49
维修自由工作者 2021-9-17 17:38
Do USB upgrade
看不懂打印信息,多谢指导
发表于: 2021-9-17 23:27:45
龙的传人 2021-9-17 18:18
20
主题
请问用什么翻译的?
发表于: 2021-9-18 06:11:39
5楼是高手,都给翻译过来了
发表于: 2021-9-18 09:01:48
qq365418819 2021-9-17 23:27
请问用什么翻译的?
百度翻译
GMT+8, 2024-11-19 09:19 , Processed in 0.084735 sec., 10 queries .
