,康佳版号:35023108,通电指示灯不亮,遥控和按键都没反应,换了主芯片RTD2969故障一样,求师傅帮忙分析一下打印信息。感谢
COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809H:
DMA_DrawGraphicWindow, cmd->startY[0]=0
J
Hello world!{m3a} svn-r(Mar 16 2015 15:57:38)
init_hwsetting_c
pre_hwsetting_c
post_hwsetting_c
parse hw setting DONE!
internal rom
force emmc
Normal boot
check boot media...
mmc_init...
emmc:read sys info
mmc_read_sysinfo . read sys info@emmc OK
HW: 0x00000ba0
AC: 0x00003de0
UB: 0x0005f5f0
EXT : 0x00002100
[1;32m ext fw RSA signature verify OK![0m
emmc:read uboot
[1;32m bootcode RSA signature verify OK![0m
GO
U-Boot 2012.07-Mac3_MP/konka/2969_ali/bootcode-svn1021613 (Sep 28 2017 - 16:45:32)
RTC: Init...Running
SCPU: BISR testing ....
SCPU: Finish BISR testing (OK)
CPU : Cortex-A17
[krsv] use default uboot memory:
bank[0] Start = 0x0, Size = 0x20000000
DRAM: 512 MiB
Watchdog: Enabled
IO Config 2= PIN_BL_ON_OFF@0000000001010804
IO Config 2= PIN_BL_ADJ@0000ffc800000108
IO Config 2= PIN_LVDS_ON_OFF@0000000000010004
IO Config 2= PIN_KEYPAD_MENU@0000000a7b000701
IO Config 2= PIN_KEYPAD_SOURCE@0000000a53000701
IO Config 2= PIN_KEYPAD_RIGHT@0000000a36000601
IO Config 2= PIN_KEYPAD_LEFT@0000000a6d000601
IO Config 2= PIN_KEYPAD_UP@0000000a29000701
IO Config 2= PIN_KEYPAD_DOWN@0000000a00000701
IO Config 2= PIN_KEYPAD_PWR@0000000a00000601
IO Config 2= PIN_DTMB_STB@0000000100010f04
IO Config 2= PIN_DTMB_RST@0000000000011c03
IO Config 2= PIN_HDMI1_HOTPLUG@0000000001010404
IO Config 2= PIN_HDMI2_HOTPLUG@0000000001010504
IO Config 2= PIN_HDMI3_HOTPLUG@0000000000000000
IO Config 2= PIN_HDMI_MHL_SELECT@0000000100012804
IO Config 2= PIN_MHL_CABLE_DETECT@0000000000000904
IO Config 2= PIN_LED_R@0000000100010704
IO Config 2= PIN_AMP_MUTE@0000000100010c04
IO Config 2= PIN_AMP_SD@0000000100011004
IO Config 2= PIN_POWER_DETECT@0000000000002504
IO Config 2= PIN_POWER_EN@0000000100010b04
IO Config 2= PIN_HP_OUT_JD@0000000000004703
Board: KONKA alitv Board
POWER ON: AC
Cache: Enabled
Non-Cache Region: 1 MB@0x0b300000
To setup mmu...
MMC: MMC: NOT allocate buffer from non-cache area
emmc:mmc_initial(1) Sep 28 2017 16:45:46
Release SPI Pad !!!
HW Reset eMMC
reset finish...
RTD294x eMMC: 0
Release SPI Pad !!!
RCA= 0x0
mmc:mmccr_set_bits_width(324) bus width switch to 8bits
emmc: clk change to 50MHz
mmccr_set_clk: 0x18000204=0x08601001
RCA= 0x0
Device: RTD294x eMMC
Manufacturer ID: 11
OEM: 100
Tran Speed: 52000000
Rd Block Len: 512
MMC version 4.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 8-bit
Factory: MMC
Factory: seq:0x14c0, blk:0xe000(pp:1), size:0x38a600 (to 0xa900000)
get_bootparam:
------------tmp/factory/bin_panel/000BootParam.h found
BOOT_POWER_ON_MODE=0
BOOT_LOGO_ENABLE=1
CUSTOM_VIDEO1_LENG=0
CUSTOM_VIDEO2_LENG=0
BOOT_MUSIC_ENABLE=0
CUSTOM_AUDIO1_LENG=0
CUSTOM_AUDIO2_LENG=0
LOCAL_UPGRADE_EN=0
BOOT_BACKLIGHT_VALUE=0
IMGFILE_PATTERN=R2969Upgrade.img
boot_power_on_mode=0
get_layout:
------------tmp/factory/layout.txt found
BOOTPART=0
TAG=21
Factory_RO: MMC
[FAC_RO] No factory_ro data in eMMC
[ENV] read_env from factory failed
[ENV] Using default environment variables
Panel: Use parameters in tmp/factory/bin_panel/panel.bin
Panel: knk_boe_HV320WHB_N86_72000124YT
Panel: Use parameters extend in tmp/factory/bin_panel/panel_extend/knk_boe_HV320WHB_N86_72000124YT_extend.bin
Panel:default_c_panel_param_extend 0x0
skip panel_init_1st, mode=2
GDMA module_init finish
In: serial
Out: serial
Err: serial
Net: rtl8139: fuse ready = a000001c
rtl8139: link status = 0000ffff
rtl8139: REALTEK RTL8139 @0xb8016800
Hit Esc or Tab key to enter console mode or rescue linux: 0
------------We will Enter Recovery Rescue
name=PIN_KEYPAD_LEFT ppcb_enum.Name=PIN_KEYPAD_LEFT, ppcb_enum.info=a6d000601
====== Enter into android recovery ======
get header done
# Dump Rescue header:
# magic = 0x6363beef
# size = 0x00522274 (include header)
# Enter Rescue Linux:
# secure_mode = 0
# compressed = 1
# block_no = 0x00002000
# size_bytes = 0x00522274
# target_addr = 0x00108000
read done
skip Verify_SHA256_hash()
start decompress rescue ...
Start Linux at 0x108000 ...
Kernel command line: androidboot.console=ttyS0 console=ttyS0,115200 envp=74100 androidboot.selinux=permissive flashtype=emmc mmcparts=rtkemmc:3866624k,933888k(/system),1163264k(/data),524288k(/cache),16384k(/res) root=/dev/mmcblk0p1 rootfstype=ext4 ro rootwait earlyprintk ac_on
Starting kernel ...
Reset ethernet/disable interrupt/flush cache...
bootargs=androidboot.console=ttyS0 console=ttyS0,115200 envp=74100 androidboot.selinux=permissive flashtype=emmc mmcparts=rtkemmc:3866624k,933888k(/system),1163264k(/data),524288k(/cache),16384k(/res) root=/dev/mmcblk0p1 rootfstype=ext4 ro rootwait earlyprintk ac_on
boot_jump_linux 0x00108000(0x0,0x138b,0x70100)
bsp_serial_init
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 3.10.0-mac3+ (realtek-fae@ubuntu) (gcc version 4.8.3 (Realtek ASDK-4.8.3p1 Build 2003) ) #18 Thu Sep 28 15:28:10 CST 2017
[ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: rtd294x
[ 0.000000] mem=512MB@0x00000000
[ 0.000000] +++++ ATAGS is used +++++
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] cma: CMA: reserved 304 MiB at 02000000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] ext memory size: 0 highmem size: 0
[ 0.000000] ### highmem 0 0 movable 0 0 ###
[ 0.000000] pcbMgr: RTK
[ 0.000000] System CPU has 1 UART.
[ 0.000000] System CPU uses internal timer interrupt.
[ 0.000000] Ethernet Mac address: 00:10:20:30:40:50
[ 0.000000] Base year of RTC is 2013.
[ 0.000000] #@# rtk_init_early(476) release SB2_HD_SEM_NEW_5_reg
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 121344
[ 0.000000] Kernel command line: androidboot.console=ttyS0 console=ttyS0,115200 envp=74100 androidboot.selinux=permissive flashtype=emmc mmcparts=rtkemmc:3866624k,933888k(/system),1163264k(/data),524288k(/cache),16384k(/res) root=/dev/mmcblk0p1 rootfstype=ext4 ro rootwait earlyprintk ac_on
[ 0.000000]
[ 0.000000] rtk_pm_act_8051_code(552)2013/04/08 11:50
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 384MB 94MB = 478MB total
[ 0.000000] Memory: 158720k/158720k available, 365568k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0108000 - 0xc061aee8 (5196 kB)
[ 0.000000] .init : 0xc061b000 - 0xc0980034 (3477 kB)
[ 0.000000] .data : 0xc0982000 - 0xc09b5880 ( 207 kB)
[ 0.000000] .bss : 0xc09b5880 - 0xc09f7718 ( 264 kB)
[ 0.000000] NR_IRQS:256
[ 0.000000] @sb2_intr_setup: enable sb2 interrupt [reserved rbus address]
[ 0.000000] @sb2_dbg_intr_setup: enable sb2 dbg interrupt [reserved rbus OR dbus address]
[ 0.000000] sched_clock: 32 bits at 27MHz, resolution 37ns, wraps every 159072ms
[ 0.000000] console [ttyS0] enabled, bootconsole disabled
[ 0.011764] Calibrating delay loop... 1099.36 BogoMIPS (lpj=5496832)
[ 0.104682] pid_max: default: 32768 minimum: 301
[ 0.109443] Security Framework initialized
[ 0.113648] SELinux: Initializing.
[ 0.117245] Mount-cache hash table entries: 512
[ 0.122131] Initializing cgroup subsys freezer
[ 0.126714] CPU: Testing write buffer coherency: ok
[ 0.131872] Setting up static identity map for 0xc04c5c40 - 0xc04c5c74
[ 0.138921] devtmpfs: initialized
[ 0.142822] cma: CMA: reserved null cma
[ 0.146750] rtktlb: Hello, Realtek TLB Mapper...
[ 0.152019] rtkbp: memmap size: 933888
[ 0.156021] <<<FREE AREA BASE: 02000000>>>
[ 0.160302] 0: 0
[ 0.162282] 1: 0
[ 0.164251] 2: 0
[ 0.166221] 3: 0
[ 0.168191] 4: 0
[ 0.170159] 5: 0
[ 0.172129] 6: 0
[ 0.174105] 7: 0
[ 0.176075] 8: 1
[ 0.178044] Addr: 10100000, order: 8
[ 0.181969] 9: 1
[ 0.183938] Addr: 10200000, order: 9
[ 0.187869] 10: 1
[ 0.189928] Addr: 10400000, order: 10
[ 0.193941] 11: 1
[ 0.196000] Addr: 10800000, order: 11
[ 0.200019] 12: 2
[ 0.202077] Addr: 11000000, order: 12
[ 0.206092] Addr: 14000000, order: 12
[ 0.210110] 13: 2
[ 0.212170] Addr: 0e000000, order: 13
[ 0.216185] Addr: 12000000, order: 13
[ 0.220203] 14: 1
[ 0.222262] Addr: 0a000000, order: 14
[ 0.226276] 15: 1
[ 0.228335] Addr: 02000000, order: 15
[ 0.237478] NET: Registered protocol family 16
[ 0.242165] +++ ALLOC pfn: 65792 order: 6
[ 0.247084] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.254653] Realtek: sysfs init done
[ 0.258588] [RTICE]rtice_init alloc input/output buffer size = 2096*2 bytes
[ 0.267199] bio: create slab <bio-0> at 0
[ 0.271590] SCSI subsystem initialized
[ 0.275531] usbcore: registered new interface driver usbfs
[ 0.281166] usbcore: registered new interface driver hub
[ 0.286666] usbcore: registered new device driver usb
[ 0.292229] Switching to clocksource RTK_CSRC
[ 0.297134] Realtek eMMC Driver Rev:RTK_296X (2015-04-09 16:25)
[ 0.303196] rtkemmc: build at Sep 28 2017 15:24:27
[ 0.308120] rtkemmc: CONFIG_MMC_BLOCK_BOUNCE enable
[ 0.313113] rtkemmc: ##### CONFIG_SMP disable!! #####
[ 0.318308] Boottype emmc!eMMC driver init continue....
[ 0.323663] rtkemmc: IRQ 50
[ 0.326530] [Debug]keep low clock [mmc->f_max = 33000000]
[ 0.332078] rtkemmc: EMMC_SHOUTDOWN_PROTECT not define
[ 0.337437] rtkemmc: bus clock change to 15MHz
[ 0.376724] mmc0: rtkemmc driver initialized
[ 0.381111] Realtek EMMC Controller Driver is successfully installing.
[ 0.381111]
[ 0.389361] NET: Registered protocol family 2
[ 0.394063] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.401342] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.407975] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.414511] TCP: reno registered
[ 0.417830] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.423807] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.430325] NET: Registered protocol family 1
[ 0.434939] RPC: Registered named UNIX socket transport module.
[ 0.441015] RPC: Registered udp transport module.
[ 0.445829] RPC: Registered tcp transport module.
[ 0.450653] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.537544] mmc0: BKOPS_EN bit is not set
[ 0.547424] rtkemmc: bus clock change to 30MHz
[ 0.554050] rtkemmc: change to 8bits mode
[ 0.567013] mmc0: new high speed MMC card at address 0001
[ 0.632599] input: venus_IR_input as /devices/virtual/input/input0
[ 0.639130] [GDMA]panel_parameter->iCONFIG_PANEL_TYPE=11 *********************
[ 0.639130]
[ 0.639130]
[ 0.639130]
[ 0.651167] [GDMA]panel_parameter=knk_boe_HV320WHB_N86_72000124YT *********************
[ 0.651167]
[ 0.651167]
[ 0.651167]
[ 0.663994]
[ 0.663994]
[ 0.663994]
[ 0.663994]
[ 0.663994] ***************** gdma init module *********************
[ 0.663994]
[ 0.663994]
[ 0.663994]
[ 0.681610] [GDMA]gdma->iCONFIG_PANEL_TYPE=11 *********************
[ 0.681610]
[ 0.681610]
[ 0.681610]
[ 0.692665] [GDMA]gdma->iCONFIG_PANEL_CUSTOM_INDEX=98 *********************
[ 0.692665]
[ 0.692665]
[ 0.692665]
[ 0.704424] [GDMA]gdma->i3D_DISPLAY_SUPPORT=0
[ 0.708978] [GDMA]gdma->i3D_LINE_ALTERNATIVE_SUPPORT=0
[ 0.714331] GDMA_init_module, 3818, MIXER 0xff000f
[ 0.720308] [GDMA] Panel Width=0, Height=0
[ 0.724756] [GDMA] busH=333Mhz, dclk=121Mhz
[ 0.729141] [GDMA] gdma->ctrl.enableVFlip 0
[ 0.733511] GDMA module_init finish
[ 0.737191] [GPIO] venus_gpio_dev_init successed
[ 0.741919] ***************** md init module *********************
[ 0.748435] md init module major number = 253
[ 0.752950] Command Buffer Address = d0100000, Physical Address = 10100000, Size = 00004000
[ 0.761515] #@# md_init_reg(529) release SB2_HD_SEM_NEW_5_reg
[ 0.767405]
[ 0.767405]
[ 0.767405]
[ 0.767405]
[ 0.767405] ***************** bakerse init module *********************
[ 0.767405]
[ 0.767405]
[ 0.767405]
[ 0.785215] arch/arm/bsp-realtek/mach-rtd294x/se.c, 792 SE CLK En= 1
[ 0.791727] #@# se_power(803) release SB2_HD_SEM_NEW_5_reg
[ 0.797349]
[ 0.797349]
[ 0.797349]
[ 0.797349]
[ 0.797349] ***************** se init module *********************
[ 0.797349]
[ 0.797349]
[ 0.797349]
[ 0.814714] se init module major number = 252
[ 0.819234] +++ ALLOC pfn: 65856 order: 2
[ 0.823594] B:SE_INIT......se_devices = df630000(1f630000), buffer(noncache) = d0140000(10140000)
[ 0.832772] BB: CmdBase = 10140000 ; limit = 10144000
[ 0.838096]
[ 0.838096]
[ 0.838096]
[ 0.838096]
[ 0.838096] ***************** rtice2ap init module *********************
[ 0.838096]
[ 0.838096]
[ 0.838096]
[ 0.855999] rtice2ap init module major number = 251
[ 0.861096] [linux][CBUS] MHL_init_module[0115]
[ 0.865741] [linux]CBUS: register sucess!!! IRQ 57
[ 0.870694] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.877570] audit: initializing netlink socket (disabled)
[ 0.883118] type=2000 audit(0.839:1): initialized
[ 0.888114] remap initialized
[ 0.891335] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.897455] NTFS driver 2.1.30 [Flags: R/W].
[ 0.901840] YAFFS Driver Rev:329787 (2014-07-31)
[ 0.906577] YAFFS Driver is successfully installing.
[ 0.911678] msgmni has been set to 918
[ 0.916116] io scheduler noop registered
[ 0.920151] io scheduler deadline registered
[ 0.924529] io scheduler cfq registered (default)
[ 0.929362] VenusFB: Framebuffer device driver for Realtek Media Processors
[ 0.936653] VenusFB: load successful (1280x720x32bbp)
[ 0.941918] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.948346] [RTICE]rtice_enable : 1, rtice_port : 0
[ 0.973550] serial8250: ttyS0 at MMIO 0x0 (irq = 57) is a 16550A
[ 0.982127] brd: module loaded
[ 0.986495] loop: module loaded
[ 0.989928] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 0.996523] Nand flash init starting....
[ 1.000554] Boottype emmc!Nand flash driver init exit....
[ 1.006116] 8139cplus: 10/100 PCI Ethernet driver v1.2 (Jul 22, 2014)
[ 1.012719] [ETH] RX_OFFSET = 0x0
[ 1.016328] eth0: RTL-8139C+ at 0xb8016800, 00:10:20:30:40:50, IRQ 52
[ 1.023029] usbcore: registered new interface driver usb-storage
[ 1.029258] cp_hotplug
[ 1.031838] mousedev: PS/2 mouse device common for all mice
[ 1.037752] i2c /dev entries driver
[ 1.041347] #@# i2c_power(102) release SB2_HD_SEM_NEW_5_reg
[ 1.047094] [I2C]Get PCB_ENUM I2C_PORT_0 I2C Mode Config phy_id=0 port_id = -1
[ 1.054514] [I2C]Get PCB_ENUM I2C_PORT_1 I2C Mode Config phy_id=1 port_id = 0
[ 1.061855] [I2C]Get PCB_ENUM I2C_PORT_2 I2C Mode Config phy_id=2 port_id = -1
[ 1.069403] [I2C-0] create_venus_i2c_handle: venus_i2c_flags = 01 irq=57
[ 1.076262] [I2C-0] open successed, reference cnt=1
[ 1.081264] [I2C-0] venus_i2c_probe : model name = RTD294x
[ 1.086885] [I2C-0] WARNING. Pinmux isn't ready.
[ 1.091624] [I2C-0] setting: wr_reg(b806250c)=00000005
[ 1.096893] [I2C-0] setting: wr_reg(b8000290)=002001c0
[ 1.102154] [I2C-0] Bus Status Check.... OK
[ 1.106435] =========================
[ 1.110189] = VER : 2.2
[ 1.114025] =========================
[ 1.117780] = PHY : 0
[ 1.121439] = PORT: -1
[ 1.125186] = MODEL: RTD294x
[ 1.129385] = SPD : 100
[ 1.133222] = SAR : 0x024 (7 bits)
[ 1.136798] = TX FIFO DEPTH : 32
[ 1.140546] = RX FIFO DEPTH : 32
[ 1.144293] = FIFO THRESHOLD: 4
[ 1.147959] =========================
[ 1.151810] [I2C-1] create_venus_i2c_handle: venus_i2c_flags = 03 irq=51
[ 1.158682] [I2C-1] open successed, reference cnt=1
[ 1.163676] [I2C-1] venus_i2c_probe : model name = RTD294x
[ 1.169307] [I2C-1] setting: wr_reg(b801b20c)=00000005
[ 1.174568] [I2C-1] setting: wr_reg(b8000290)=002001c0
[ 1.179837] [I2C-1] Bus Status Check.... OK
[ 1.184118] =========================
[ 1.187873] = VER : 2.2
[ 1.191709] =========================
[ 1.195456] = PHY : 1
[ 1.199122] = PORT: 0
[ 1.202781] = MODEL: RTD294x
[ 1.206980] = SPD : 100
[ 1.210817] = SAR : 0x024 (7 bits)
[ 1.214388] = TX FIFO DEPTH : 32
[ 1.218142] = RX FIFO DEPTH : 32
[ 1.221890] = FIFO THRESHOLD: 4
[ 1.225549] = SDA GPIO : MISC_GPIO 2
[ 1.229215] = SCL GPIO : MISC_GPIO 1
[ 1.232872] = BUS JAM RECORVER 3: ON
[ 1.236716] = NON STOP WRITE : OFF
[ 1.240375] = GPIO RW SUPPORT : ON
[ 1.243945] =========================
[ 1.247777] [I2C-2] create_venus_i2c_handle: venus_i2c_flags = 07 irq=51
[ 1.254636] [I2C-2] open successed, reference cnt=1
[ 1.259640] [I2C-2] venus_i2c_probe : model name = RTD294x
[ 1.265254] [I2C-2] WARNING. Pinmux isn't ready.
[ 1.269992] [I2C-2] setting: wr_reg(b801b40c)=00000001
[ 1.275253] [I2C-2] setting: wr_reg(b8000290)=002001c0
[ 1.280521] [I2C-2] Bus Status Check.... OK
[ 1.284803] =========================
[ 1.288557] = VER : 2.2
[ 1.292392] =========================
[ 1.296140] = PHY : 2
[ 1.299805] = PORT: -1
[ 1.303552] = MODEL: RTD294x
[ 1.307752] = SPD : 100
[ 1.311589] = SAR : 0x024 (7 bits)
[ 1.315159] = TX FIFO DEPTH : 32
[ 1.318913] = RX FIFO DEPTH : 32
[ 1.322660] = FIFO THRESHOLD: 4
[ 1.326318] =========================
[ 1.330236] mmcblk0: mmc0:0001 004G60 3.68 GiB
[ 1.334923] mmcblk0boot0: mmc0:0001 004G60 partition 1 2.00 MiB
[ 1.341044] mmcblk0boot1: mmc0:0001 004G60 partition 2 2.00 MiB
[ 1.348079] data[0] 0x0 signature[0] 0xbabeface
[ 1.352720] data[1] 0x0 signature[1] 0xdeadbeef
[ 1.357369] mmcblk0: p1 p2 p3 p4
[ 1.362553] data[0] 0xffffffff signature[0] 0xbabeface
[ 1.367828] data[1] 0xffffffff signature[1] 0xdeadbeef
[ 1.373089] mmcblk0boot1: unknown partition table
[ 1.379469] data[0] 0xffffffff signature[0] 0xbabeface
[ 1.384731] data[1] 0xffffffff signature[1] 0xdeadbeef
[ 1.390002] mmcblk0boot0: unknown partition table
[ 1.395073] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.400677] usbcore: registered new interface driver usbhid
[ 1.406381] usbhid: USB HID core driver
[ 1.410391] ashmem: initialized
[ 1.413723] TCP: cubic registered
[ 1.417153] NET: Registered protocol family 10
[ 1.422047] sit: IPv6 over IPv4 tunneling driver
[ 1.427064] NET: Registered protocol family 17
[ 1.431742] Realtek Magellan Power Management 2013/05/06 11:30
[ 1.431742] (c) 2013 Realtek Semiconductor Corp.
[ 1.442440] VFP support v0.3: implementor 41 architecture 3 part 30 variant d rev 0
[ 1.450327] ThumbEE CPU extension supported.
[ 1.454709] Registering SWP/SWPB emulation handler
[ 1.462030] Freeing unused kernel memory: 3476K (c061b000 - c0980000)
[ 1.468652] Enter rtk_post_processing(respart:4)
[ 1.473417] mount res partition(4) fail!mount res block_part(4) fail!
[ 1.490224] type=1403 audit(1.449:2): policy loaded auid=4294967295 ses=4294967295
[ 1.498108] SELinux: Loaded policy from /sepolicy
[ 1.507406] init: property_load_boot_defaults, read from :/default.prop
[ 1.514297] init: read default.prop success
[ 1.520294] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 1.570348] init: /dev/hw_random not found
[ 1.582108] init: /dev/hw_random not found
[ 1.590147] type=1400 audit(1.549:3): avc: denied { create } for pid=44 comm="init" name="tasks" scontext=u:r:init:s0 tcontext=ubject_r:rootfs:s0 tclass=file permissive=1
[ 1.606231] type=1400 audit(1.559:4): avc: denied { write } for pid=44 comm="init" path="/acct/uid/0/tasks" dev="rootfs" ino=709 scontext=u:r:init:s0 tcontext=ubject_r:rootfs:s0 tclass=file permissive=1
/ # [ 1.631218] type=1400 audit(1.589:5): avc: denied { rename } for pid=45 comm="busybox" name="modules.dep.bb.new" dev="rootfs" ino=721 scontext=u:r:init:s0 tcontext=ubject_r:rootfs:s0 tclass=file permissive=1
[main:3195]: Starting LoaderM......
argc = 2
argv = /sbin/factory load
0+1 records in
0+1 records out
234 bytes (234B) copied, 0.000130 seconds, 1.7MB/s
command:dd if=/sys/realtek_boards/system_parameters of=/tmp/str.txt, (line=205) [file=src/rtk_common.cpp], ret(0)
command:mkdir -p /tmp/factory, (line=314) [file=src/rtk_factory.cpp], ret(0)
[INSTALL INFO][src/rtk_factory.cpp][317] gfactory_start = 1800000
[INSTALL INFO][src/rtk_factory.cpp][318] gfactory_block_size = 400000
[INSTALL INFO][src/rtk_factory.cpp][319] gfactory_size = 400000
[INSTALL INFO][src/rtk_factory.cpp][320] gerasesize = 200
[INSTALL INFO][src/rtk_factory.cpp][195] pp_ok = 3 current_pp = 1 seq_num = 5312 tarsize =3712512
7251+0 records in
7251+0 records out
3712512 bytes (3.5MB) copied, 0.156521 seconds, 22.6MB/s
command:cd /;/bin/busybox dd if=/dev/block/mmcblk0 bs=512 count=7251 skip=57344 | /bin/busybox tar x, (line=470) [file=src/rtk_factory.cpp], ret(0)
[INSTALL INFO[ 1.847929] EXT4-fs (mmcblk0p4): recovery complete
][src/rtk_common[ 1.853442] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
.cpp][396] remove factory lock success
skipping malformed layout.txt line: #define CREATE_DATE " Aug 24 2017 "
skipping malformed layout.txt line: #define CREATE_TIME " 19:29:30 "
skipping malformed la[ 1.881009] EXT4-fs (mmcblk0p3): recovery complete
yout.txt line: #[ 1.886550] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
define BOOTTYPE " BOOTTYPE_COMPLETE "
skipping malformed layo[ 1.900060] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ut.txt line: #define SSUWORKPART 0
skipping malformed layout.txt line: #define BOOTPART 0
skipping malformed layout.txt line: #define FW_KERNEL " target=108000 offset=2008000 size=105ac08 type=bin "
skipping malformed layout.txt line: #define FW_AKERNEL " target=81700000 offset=3062e00 size=274c98 type=bin "
skipping malformed layout.txt line: #define FW_VKERNEL " target=81a00000 offset=32d7c00 size=2e1ea8 type=bin "
skipping malformed layout.txt line: #define FW_DALOGO " target=deaddead offset=35b9c00 size=1a565 type=bin "
skipping malformed layout.txt line: #define FW_DVLOGO " target=deaddead offset=35d4200 size=16118 type=bin "
skipping malformed layout.txt line: #define FW_CALOGO1 " target=83000000 offset=35ea400 size=10000 type= "
skipping malformed layout.txt line: #define FW_CVLOGO1 " target=deaddead offset=376a400 size=16118 type= "
skipping malformed layout.txt line: #define FW_CALOGO2 " target=deaddead offset=776a400 size=1a565 type= "
skipping malformed layout.txt line: #define FW_CVLOGO2 " target=deaddead offset=78ea400 size=16118 type= "
(device:/dev/block/mmcblk0p3, mount_point:/cache, fs:ext4, size:536870912)
(device:/dev/block/mmcblk0p1, mount_point:/system, fs:ext4, size:956301312)
(device:/dev/block/mmcblk0p2, mount_point:/data, fs:ext4, size:1191182336)
(device:/dev/block/mmcblk0p4, mount_point:/res, fs:ext4, size:16777216)
skipping malformed layout.txt line: #define TAG 21
0 /cache ext4 /dev/block/mmcblk0p3 (null) 0 536870912
1 /system ext4 /dev/block/mmcblk0p1 (null) 0 956301312
2 /data ext4 /dev/block/mmcblk0p2 (null) 0 1191182336
3 /res ext4 /dev/block/mmcblk0p4 (null) 0 16777216
alive!
mount /res ok
[loadExternalLink:2527]: mount_dev:udisk @ point /storage/udisk
[main:3227]: count boot.command[0]==boot-recovery
boot.recovery[0]=recovery
--update_package=/cache/kkupgrade/full_ota_konka_realtek2969d_V2.3.05.zip
--locale=zh_CN
[ExamineCmd:2786]: get command:recovery
--locale=zh_CN
[ExamineCmd:2820]: Get command Path: /cache/kkupgrade/full_ota_konka_realtek2969d_V2.3.05.zip (56)
[ExamineCmd:2826]: Get File Name: full_ota_konka_realtek2969d_V2.3.05.zip
[ExamineCmd:2841]: do mount -t ext4 /dev/block/mmcblk0p3 /cache
[ExamineCmd:2889]: redirectCmdPath:/cache/kkupgrade/full_ota_konka_realtek2969d_V2.3.05.zip (len:56)
[main:3234]: modprobe ehci-hcd && modprobe ohci-hcd
[ 2.436722] #@# usb2_phy_setting(105) +++ for usbphy setting 20140909-1
[ 2.461526] #@# usb2_phy_setting(246) ---
[ 2.465727] ehci ehci0-hcd.0: Rtk EHCI
[ 2.469589] ehci ehci0-hcd.0: new USB bus registered, assigned bus number 1
[ 2.476735] +++ ALLOC pfn: 65860 order: 0
[ 2.481053] +++ ALLOC pfn: 65861 order: 0
[ 2.485352] ehci ehci0-hcd.0: irq 53, io mem 0xfe013000
[ 2.506727] ehci ehci0-hcd.0: USB 2.0 started, EHCI 1.00
[ 2.512329] type=1400 audit(2.469:6): avc: denied { mknod } for pid=8 comm="kdevtmpfs" capability=27 scontext=u:r:kernel:s0 tcontext=u:r:kernel:s0 tclass=capability permissive=1
[ 2.530922] hub 1-0:1.0: USB hub found
[ 2.534777] hub 1-0:1.0: 3 ports detected
[ 2.543030] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.549416] ohci ohci0-hcd.0: Rtk OHCI
[ 2.553266] ohci ohci0-hcd.0: new USB bus registered, assigned bus number 2
[ 2.560421] ohci ohci0-hcd.0: irq 53, io mem 0xfe013400
[ 2.621796] #@# usb_hcd_reset_endpoint(1940) hcd->driver->endpoint_reset (null)
[ 2.631103] hub 2-0:1.0: USB hub found
[ 2.634956] hub 2-0:1.0: 3 ports detected
cancel loader_a timeout handler
[checkIfZipBeOTAImg:2706]: CHECK[ 2.645788] type=1400 audit(2.599:7): avc: denied { unlink } for pid=79 comm="cp" name="recovery" dev="rootfs" ino=204 scontext=u:r:init:s0 tcontext=ubject_r:rootfs:s0 tclass=file permissive=1
_BEOTA
[main:3250]: phase1 detect ota img!!!
[main:3259]: get bootable cmd in factory
[main:3293]: go to loader_end!!!!......
[main:3519]:
>>>>>> Enter android recovery mode (/res)!
[ 2.685613] type=1400 audit(2.639:8): avc: denied { setattr } for pid=81 comm="chmod" name="recovery" dev="rootfs" ino=785 scontext=u:r:init:s0 tcontext=ubject_r:rootfs:s0 tclass=file permissive=1
[main:3522]:
chmod 755 /sbin/recovery
[main:3525]:
>>>>>> Enter android recovery mode (/sbin)!
[ 3.727991] dvr malloc size: 4194304 count: 1024
[ 3.732725] +++ ALLOC pfn: 66560 order: 10
[ 3.738710] dvr_malloc_specific_internal(): returned d0400000
[ 3.744595] ### alloc Memory d0400000 (2^10)...
[ 3.752136]
[ 3.752136]
fun=video_initDisplayArea line=301 addr=c0346fa8
[ 3.759629] #@# Init Display Area...
[ 3.763382] #@# IBuffer: de4dd000...
[ 3.767138] #@# config video standard, ret = 10000000
[ 3.772486] #@# config hdmi, ret = 10000000
[ 3.776952] #@# set background, ret = 10000000
[ 3.781678] #@# config graphic canvas, ret = 10000000
[ 3.787033] #@# Draw Display Area...
[ 3.790782] #@# DBuffer: de4dd000...
[ 3.794531] dvr malloc size: 2490368 count: 608
[ 3.799178] +++ ALLOC pfn: 67584 order: 10
[ 3.804589] dvr_malloc_specific_internal(): returned d0800000
[ 3.810486] #@# set mixer2 buffer d0800000, ret = 10000000
[ 3.816279] #@# transp.offset: 24...
[ 3.820035] #@# red.offset: 0...
[ 3.823427] ##==> video_drawDisplayArea(549): GDMA_CreateGraphicWindow
[ 3.830116] #@# create window, ret = 0
[ 3.834132] ##==> video_drawDisplayArea(575): GDMA_DrawGraphicWindow
[ 3.840644] GDMA_DrawGraphicWindow, cmd->startY[0]=0
