查看: 1016|回复: 3
SELFTEST VGA 11.4.15 РАЗОМКНУТЫ
发表于: 2021-7-21 23:06:19
Здравствуйте! Не проходит SELFTEST через VGA подскажите пожалуйста в чём проблема, как её исправить? Заранее спасибо! Возможно ли получить схему на этот программатор?
发表于: 2021-7-22 15:33:20
Please describe your self-test steps in English, this is not possible normally.  The self-test is only connected to one USB cable, so try uninstalling and reinstalling the software
 楼主| 发表于: 2021-7-22 19:41:29
The programmer used to run the self-test normally, but now it does not work. I describe the first step in order - the reading of the test goes well, the second step does not go through the VGA, writes that the contacts are open 11,4,15, the third step - the comparison of the contents also goes well without errors. I tried to reinstall the usb driver and software, after that it can go through a self-test normally, but then it can go through again or maybe not, and so it constantly writes that the contacts are open 11,4,15 I have an operating system on my computer installed windows 10 x 64
 楼主| 发表于: 2021-7-29 21:51:02
GMT+8, 2025-12-18 04:37 , Processed in 0.058568 sec., 11 queries .
