用户名  找回密码
查看: 1695|回复: 2
帮忙看看这个打印信息
发表于: 2021-7-12 11:38:34
暴风40X开机LOGO死机。重启。
2021-7-12, 11:33:33
COM2, BaudRate:115200 bps, RXD: VGA-> 4,TXD: VGA->11, Printed by RT809H:
[   36.002178] SAR5 eMMC WARN.
UART_115200
AC_ON
BIST0-OK
BIST1-OK
#_U
Relocation Offset is: 01700000
[AT][MB][start ub][447]
U-Boot 2011.06-svn2715 (Jan 22 2019 - 23:10:36)
msIR_Initialize
[SYS][Utopia]: Function = SYSOpen, Line = 1115, current resource pri_shm content is: 0
[SYS][Utopia]: Function = SYSOpen, Line = 1134, [SYS INFO] OPEN INSTANCE...
create instance at 293EAEA8 with private size 128 bytes at 293EAEF0
[MIU][Utopia]:
[MIU INFO] miu opencreate instance at 293EAF78 with private size 80 bytes at 293EAFC0
create instance at 293EB018 with private size 48 bytes at 293EB060
uboot held at [291DDF60~2AC00000],size=01A220A0
DRAM:  172 MiB
Now running in RAM - U-Boot at: 2A200000
eMMC: HS400 200MHz
eMMC 7.28 GB [E8FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MAC:  0x40: 0xBC: 0x68: 0x16:0x25: 0xC7
[CPU][Utopia]:
[CPU INFO] cpu opencreate instance at 293FB4D0 with private size 44 bytes at 293FB518
[CPU][Utopia]: CPUIoctl - MDrv_CMD_CPU_QueryClock
[UTOPIA INFO] close moduleNames[tu]:  *? *? *  *` *? *xV4
[AT][MBoot][Driver Init][605]
AC on
MPOOL size : 0x200000
Changelist:        24543697
====cvte do_cvt_check_usb  ====
AC on
====cvte power on check usb and upgrade ====
<628> do_cvte_init_at_prama4env
<628> custar = -1
<628> USB Disk Not Found
<CVTE> do_cvte_get_mac_from_emmc
block_data[0]:40
block_data[1]:BC
block_data[2]:68
block_data[3]:16
block_data[4]:25
block_data[5]:C7
<628> Read MAC Value-->40:BC:68:16:25:C7
<628> EMMC MAC-->40:bc:68:16:25:c7 , ENV MAC-->40:bc:68:16:25:c7
<leeo> do_baofeng_check_panelid
<628> Read MAC Value-->32 00 74 2 2
<338> do_cvte_init_at_env_by_value AT_Read=0 OR AT_B=0 OR AT_T=0 OR AT_K=0 OR AT_BOOTCH=0:
Same as console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init CORE_DUMP_PATH=/data/core_dump.%%p.gz KDebug=1 androidboot.selinux=permissive swiotlb=512 LX_MEM=0x1DB00000 LX_MEM2=0xA0400000,0x1FC00000 EMAC_MEM=0x40000 PM51_ADDR=0x20010000 PM51_LEN=0x10000 tee_mode=nuttx SAR5=ON CMA0=VDEC_XC_STR_MBOOT,miu=0,hid=20,sz=0x2800000,st=0x8400000 CMA1=RETURN_ENUM0,miu=0,hid=26,sz=0x2000000,st=0xac00000 CMA2=OTHERS,miu=0,hid=23,sz=0x2000000,st=0xcc00000 CMA3=RETURN_ENUM2,miu=1,hid=27,sz=0x1400000,st=0x400000 CMA4=VDEC1,miu=1,hid=19,sz=0x7c00000,st=0x1800000 BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON
<338> AT Start UART Control-init_pram.AT_P=0
AC on
Writing to MMC(0)... 128 blocks written: OK
done
fore uup IRKey [0xFF]
AC on
<CVTE> [do_cvte_boot_Aging_loop][LINE:8] Enter Boot AgingMode isAT_B_Mode:0, powermode:0
<628> is_at_mode AT_Read=0, AT_B=0, AT_T=0, AT_K=0
<628> is_burnkey_ok burn MAC or HDCP OK, auto power on
[PWM][Utopia]: Init PWM0do_cvte_cmd_LED_PWM_init(20,0)
WIFI_RESET gpio out: 1
mmc change mount : tvconfig
Loading file "/config/PM.bin" at offset 0x0 from mmc device 0 partition tvconfig
24575 bytes read
[PM][Utopia]: Wait for PM51 standby...........[PM][Utopia]: PM51 run ok...........UART_115200
DC_ON
BIST0-OK
BIST1-OK
#_U
msIR_Initialize
[MIU][Utopia]:
DRAM:  172 MiB
eMMC: HS400 200MHz
In:    serial
Out:   serial
Err:   serial
[CPU][Utopia]:
[AT][MBoot][Driver Init][602]
DC on
WIFI_RESET gpio out: 0
DC on
block_data[0]:40
block_data[1]:BC
block_data[2]:68
block_data[3]:16
block_data[4]:25
block_data[5]:C7
DC on
done
DC on
[PWM][Utopia]: Init PWM0do_cvte_cmd_LED_PWM_init(0,0)
[ERROR] do_frc_bringup:797: get E_MMAP_ID_FRC_R2 mmap fail
create instance at 2940C3D0 with private size 348 bytes at 2940C418
MsDrv_PNL_Init:Bypass SetDivison
MDrv_PNL_Init u32PnlRiuBaseAddr = tx
MDrv_PNL_Init u32PMRiuBaseAddr = tx
[_MDrv_PNL_Init_LPLL][340]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_LPLL][342]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][392]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_Output_Dclk][394]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[MApi_XC_MLG_GetStatus, 2670]No instance existed, please get an instance by calling MApi_XC_Init() first
u16Value = 60
period=EA5F, pwm_duty=9AB0[AT][MB][panel_pre_init][1048]
[AT][MB][bootlogo begin][1051]
create instance at 294157A0 with private size 312 bytes at 294157E8
[AT][MB][JPD Decode][1077]
[UTOPIA INFO] close moduleNames[tu]: *` *? *? *  *` *? *xV4
[showLogo] GOP Boot Logo Index 2
create instance at 294157A0 with private size 1728 bytes at 294157E8
create instance at 29415EB0 with private size 9596 bytes at 29415EF8
[AT][MB][Show Logo][1124]
R2 Boot from 0x1F600000
[CPU][Utopia]:
[CPU INFO] cpu opencreate instance at 293FB9A0 with private size 44 bytes at 293FB9E8
---MsDrv_PNL_BackLigth_On:1185 Set MsDrv_PNL_BackLigth_On DelayTask 117
[AT][MBoot][Boot Nuttx][1654]
## Booting kernel from Legacy Image at 25000000 ...
   Image Name:   MStar-linux
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    10596171 Bytes = 10.1 MiB
   Load Address: 20208000
   Entry Point:  20208000
   Contents:
      Image 0: 10249640 Bytes = 9.8 MiB
      Image 1: 346519 Bytes = 338.4 KiB
## Loading init Ramdisk from multi component Legacy Image at 25000000 ...
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
   Loading Multi-File Image ... OK
[AT][MB][start kr][1714]
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] cpu_logical_map(1) is 0x1
[    0.000000] cpu_logical_map(2) is 0x2
[    0.000000] cpu_logical_map(3) is 0x3
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.86 (luoyilong@ubuntu-234.bf.tv) (gcc version 4.7.2 (Sourcery CodeBench Lite 2012.09-64) ) #3 SMP PREEMPT Fri Nov 23 11:55:19 CST 2018
[    0.000000] CPU: ARMv7 Processor [410fd041] revision 1 (ARMv7), cr=10c0387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Ignoring memory below PHYS_OFFSET: 0x20000000-0x20200000
[    0.000000] SAR5=ON
[    0.000000] SAR5=ON
[    0.000000] LX_MEM  = 0x20200000, 0x1db00000
[    0.000000] LX_MEM2 = 0xa0400000, 0x1fc00000
[    0.000000] LX_MEM3 = 0x0, 0x0
[    0.000000] EMAC_LEN= 0x40000
[    0.000000] DRAM_LEN= 0x0
[    0.000000] Function = arm_memblock_init, Line = 405, find cma_default buffer at only LX0
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 16 MiB at 3cc00000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 40 MiB for mstar_driver(VDEC_XC_STR_MBOOT, pool_id is 20)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 40 MiB at 28400000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 32 MiB for mstar_driver(RETURN_ENUM0, pool_id is 26)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 32 MiB at 2ac00000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 32 MiB for mstar_driver(OTHERS, pool_id is 23)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 32 MiB at 2cc00000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 20 MiB for mstar_driver(RETURN_ENUM2, pool_id is 27)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 20 MiB at a0400000
[    0.000000] Function = dma_contiguous_reserve, Line = 620, cma: reserving 124 MiB for mstar_driver(VDEC1, pool_id is 19)
[    0.000000] Function = dma_contiguous_reserve_area, Line = 794, cma: CMA: reserved 124 MiB at a1800000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] PERCPU: Embedded 8 pages/cpu @c12a4000 s11904 r8192 d12672 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 250130
[    0.000000] Kernel command line: console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init CORE_DUMP_PATH=/data/core_dump.%%p.gz KDebug=1 androidboot.selinux=permissive swiotlb=512 LX_MEM=0x1DB00000 LX_MEM2=0xA0400000,0x1FC00000 EMAC_MEM=0x40000 PM51_ADDR=0x20010000 PM51_LEN=0x10000 tee_mode=nuttx SAR5=ON CMA0=VDEC_XC_STR_MBOOT,miu=0,hid=20,sz=0x2800000,st=0x8400000 CMA1=RETURN_ENUM0,miu=0,hid=26,sz=0x2000000,st=0xac00000 CMA2=OTHERS,miu=0,hid=23,sz=0x2000000,st=0xcc00000 CMA3=RETURN_ENUM2,miu=1,hid=27,sz=0x1400000,st=0x400000 CMA4=VDEC1,miu=1,hid=19,sz=0x7c00000,st=0x1800000 BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON BOOTTIME_SBOOT=447 BOOTTIME_UBOOT=1714
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 475MB 508MB = 983MB total
[    0.000000] Memory: 715060k/715060k available, 291532k reserved, 229376K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08e6fdc   (9084 kB)
[    0.000000]       .init : 0xc08e7000 - 0xc0943e80   ( 372 kB)
[    0.000000]       .data : 0xc0944000 - 0xc09ce5a8   ( 554 kB)
[    0.000000]        .bss : 0xc09ce5a8 - 0xc0a91dd4   ( 783 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:384
[    0.000000] Global Timer Frequency = 12 MHz
[    0.000000] CPU Clock Frequency = 1000 MHz
[    0.000000] fre = 12000000, mult= -1498764629, shift= 25
[    0.000000] sched_clock: 32 bits at 12MHz, resolution 83ns, wraps every 357913941932ns
[    0.000000] [AT][KR][reset timer][1922]
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [ttyS0] enabled
[    0.000000] Function = start_kernel, ready to count printk time
[    0.451530] Calibrating delay loop... 663.55 BogoMIPS (lpj=3317760)
[    0.517860] pid_max: default: 32768 minimum: 301
[    0.522544] thread_info_cache_init, alloc 512 thread_pool
[    0.528948] Security Framework initialized
[    0.533113] Mount-cache hash table entries: 512
[    0.538579] Initializing cgroup subsys debug
[    0.542860] Initializing cgroup subsys freezer
[    0.547334] CPU: Testing write buffer coherency: ok
[    0.552480] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.558387] Setting up static identity map for 0xc06b88d8 - 0xc06b8930
[    0.618453] pen_release = 0x00000001, addr = 0xc0963e74, pen_release ptr = 0x00000001
[    0.618605] [cpuid: 0x80000001] CPU1: Booted secondary processor
[    0.692338] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.712589] pen_release = 0x00000002, addr = 0xc0963e74, pen_release ptr = 0x00000002
[    0.712743] [cpuid: 0x80000002] CPU2: Booted secondary processor
[    0.792129] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.812403] pen_release = 0x00000003, addr = 0xc0963e74, pen_release ptr = 0x00000003
[    0.812552] [cpuid: 0x80000003] CPU3: Booted secondary processor
[    0.891942] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.892047] Brought up 4 CPUs
[    0.900686] SMP: Total of 4 processors activated (2662.80 BogoMIPS).
[    0.907067] CPU: All CPU(s) started in SVC mode.
[    0.912528] devtmpfs: initialized
[    0.922180] VFP support v0.3: implementor 41 architecture 3 part 40 variant 4 rev 1
[    0.938477] Cluster:0 CpuMask:f
[    0.942294] NET: Registered protocol family 16
[    0.949720] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.958269]  Function = chip_board_init Line = 541, [SAM-CC] alloRAM0_VA_BASE: 0xf0a06000, alloLXRAM0_PA_BASE: 0x20200000
[    0.970398]  Function = chip_board_init Line = 549, [SAM-CC] alloRAM1_VA_BASE: 0xf0a08000, alloLXRAM1_PA_BASE: 0xa9400000
[    0.982516]  Function = chip_board_init Line = 554, [SAM-CC] Cannot find miu2 address. alloLXRAM2_PA_BASE: 0x20200000
[    0.995982] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    1.003995] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    1.037932] bio: create slab <bio-0> at 0
[    1.044260] SCSI subsystem initialized
[    1.048596] usbcore: registered new interface driver usbfs
[    1.054245] usbcore: registered new interface driver hub
[    1.059713] usbcore: registered new device driver usb
[    1.065121] Linux video capture interface: v2.00
[    1.070380] Function = mstar_ion_init, Line = 655, default_heap: 1, mstar_driver heap: 5
[    1.079376] Function = mstar_ion_probe, Line = 517, doing mstar_ion_probe for ion-mstar, having 6 heaps
[    1.089811] Function = mstar_ion_probe, Line = 544, STR_MBOOT co-buffer heap is 20
[    1.098088] Function = ion_mstar_cma_heap_create, dev = VDEC_XC_STR_MBOOT, cma = c0a30068, cma from 0x28400 to 0x2AC00
[    1.109547] Function = mstar_ion_probe, Line = 593, cma_measurement_data name is VDEC_XC_STR_MBOOT, id is 20
[    1.120103] Function = ion_mstar_cma_heap_create, dev = RETURN_ENUM0, cma = c0a30090, cma from 0x2AC00 to 0x2CC00
[    1.131120] Function = mstar_ion_probe, Line = 593, cma_measurement_data name is RETURN_ENUM0, id is 26
[    1.141239] Function = ion_mstar_cma_heap_create, dev = OTHERS, cma = c0a300b8, cma from 0x2CC00 to 0x2EC00
[    1.151735] Function = mstar_ion_probe, Line = 593, cma_measurement_data name is OTHERS, id is 23
[    1.161313] Function = ion_mstar_cma_heap_create, dev = RETURN_ENUM2, cma = c0a300e0, cma from 0xA0400 to 0xA1800
[    1.172338] Function = mstar_ion_probe, Line = 593, cma_measurement_data name is RETURN_ENUM2, id is 27
[    1.182458] Function = ion_mstar_cma_heap_create, dev = VDEC1, cma = c0a30108, cma from 0xA1800 to 0xA9400
[    1.192864] Function = mstar_ion_probe, Line = 593, cma_measurement_data name is VDEC1, id is 19
[    1.202605] eMMC: no SD 1006
[    1.289048] Advanced Linux Sound Architecture Driver Initialized.
[    1.299763] Switching to clocksource timer1
[    1.329669] NET: Registered protocol family 2
[    1.334831] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    1.342023] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    1.348648] TCP: Hash tables configured (established 8192 bind 8192)
[    1.355126] TCP: reno registered
[    1.358400] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    1.364391] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    1.371199] NET: Registered protocol family 1
[    1.375623] mmc0: BKOPS_EN bit is not set
[    1.380768]
[    1.380768] eMMC: HS200 200MHz
[    1.385518] RPC: Registered named UNIX socket transport module.
[    1.391454] RPC: Registered udp transport module.
[    1.396221] mmc0: new HS200 MMC card at address 0001
[    1.401366] RPC: Registered tcp transport module.
[    1.406127] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.412754] Trying to unpack rootfs image as initramfs...
[    1.440220] Freeing initrd memory: 332K (c57c7000 - c581a000)
[    1.446785] CPU PMU: probing PMU on CPU 0
[    1.450814] CPU PMU: failed to probe PMU!
[    1.454677] CPU PMU: failed to register PMU devices![    1.460500] audit: initializing netlink socket (disabled)
[    1.465962] type=2000 audit(1.129:1): initialized
[    1.567226] bounce pool size: 64 pages
[    1.583517] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.590696] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.597799] NTFS driver 2.1.30 [Flags: R/O].
[    1.602565] ROMFS MTD (C) 2007 Red Hat, Inc.
[    1.607081] fuse init (API version 7.22)
[    1.611971] msgmni has been set to 1477
[    1.617258] io scheduler noop registered (default)
[    1.622423] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    1.628987] serial8250: ttyS0 at I/O 0xfd201300 (irq = 192) is a 16550
[    1.635816] serial8250: ttyS1 at I/O 0xfd220c00 (irq = 231) is a 16550
[    1.642625] serial8250: ttyS2 at I/O 0xfd220d00 (irq = 242) is a 16550
[    1.650787] [oases][oases_init:224] oases_init success
[    1.656099] [drm] Initialized drm 1.1.0 20060810
[    1.669762] brd: module loaded
[    1.677512] loop: module loaded
[    1.682984] nbd: registered device at major 43
[    1.695236] zram: Created 1 device(s) ...
[    1.700479] mtdoops: mtd device (mtddev=name/number) must be supplied
[    1.707098] tun: Universal TUN/TAP device driver, 1.6
[    1.712169] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    1.718570] PPP generic driver version 2.4.2
[    1.723143] PPP BSD Compression module registered
[    1.727871] PPP Deflate Compression module registered
[    1.732948] PPP MPPE Compression module registered
[    1.737761] NET: Registered protocol family 24
[    1.742233] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.748788] Mstar_ehc_init version:20170105_1
[    1.753182] Mstar-ehci-2 H.W init
[    1.756517] Titania3_series_start_ehc start
[    1.760715] [USB] config miu select [70] [f8] [ef] ][ef]
[    1.766050] [USB] enable miu lower bound address subtraction
[    1.771724] [USB] init squelch level 0x2
[    1.776675] [USB] no platform_data, device tree coming
[    1.781829] [USB][EHC] dma coherent_mask 0xffffffffffffffff mask 0xffffffffffffffff
[    1.789513] BC disable
[    1.791975] [USB] Mstar-ehci-2 irq --> 226
[    1.796097] Mstar-ehci-2 Mstar-ehci-2.1: EHCI Host Controller
[    1.801871] Mstar-ehci-2 Mstar-ehci-2.1: new USB bus registered, assigned bus number 1
[    1.810572] Mstar-ehci-2 Mstar-ehci-2.1: irq 226, io mem 0xfd201a00
[    1.834066] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    1.840875] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.848127] usb usb1: Product: EHCI Host Controller
[    1.853022] usb usb1: Manufacturer: Linux 3.10.86 ehci_hcd
[    1.858532] usb usb1: SerialNumber: mstar
[    1.863226] hub 1-0:1.0: USB hub found
[    1.867012] hub 1-0:1.0: 1 port detected
[    1.871227] Mstar-ehci-1 H.W init
[    1.874571] Titania3_series_start_ehc start
[    1.878761] [USB] config miu select [70] [f8] [ef] ][ef]
[    1.884091] [USB] enable miu lower bound address subtraction
[    1.889765] [USB] init squelch level 0x2
[    1.894712] [USB] no platform_data, device tree coming
[    1.899866] [USB][EHC] dma coherent_mask 0xffffffffffffffff mask 0xffffffffffffffff
[    1.907548] BC disable
[    1.910009] [USB] Mstar-ehci-1 irq --> 199
[    1.914134] Mstar-ehci-1 Mstar-ehci-1.0: EHCI Host Controller
[    1.919902] Mstar-ehci-1 Mstar-ehci-1.0: new USB bus registered, assigned bus number 2
[    1.928254] Mstar-ehci-1 Mstar-ehci-1.0: irq 199, io mem 0xfd204800
[    1.954047] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    1.960857] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.968135] usb usb2: Product: EHCI Host Controller
[    1.973031] usb usb2: Manufacturer: Linux 3.10.86 ehci_hcd
[    1.978540] usb usb2: SerialNumber: mstar
[    1.983137] hub 2-0:1.0: USB hub found
[    1.986921] hub 2-0:1.0: 1 port detected
[    1.991126] Mstar-ehci-3 H.W init
[    1.994472] Titania3_series_start_ehc start
[    1.998662] [USB] config miu select [70] [f8] [ef] ][ef]
[    2.003994] [USB] enable miu lower bound address subtraction
[    2.009667] [USB] init squelch level 0x2
[    2.014614] [USB] no platform_data, device tree coming
[    2.019768] [USB][EHC] dma coherent_mask 0xffffffffffffffff mask 0xffffffffffffffff
[    2.027447] BC disable
[    2.029908] [USB] Mstar-ehci-3 irq --> 229
[    2.034026] Mstar-ehci-3 Mstar-ehci-3.2: EHCI Host Controller
[    2.039794] Mstar-ehci-3 Mstar-ehci-3.2: new USB bus registered, assigned bus number 3
[    2.048116] Mstar-ehci-3 Mstar-ehci-3.2: irq 229, io mem 0xfd227200
[    2.074046] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    2.080855] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.088131] usb usb3: Product: EHCI Host Controller
[    2.093028] usb usb3: Manufacturer: Linux 3.10.86 ehci_hcd
[    2.098536] usb usb3: SerialNumber: mstar
[    2.103145] hub 3-0:1.0: USB hub found
[    2.106929] hub 3-0:1.0: 1 port detected
[    2.111306] usbcore: registered new interface driver usb-storage
[    2.117636] usbcore: registered new interface driver usbserial
[    2.123598] usbcore: registered new interface driver usbserial_generic
[    2.130279] usbserial: USB Serial support registered for generic
[    2.136433] usbcore: registered new interface driver ch341
[    2.142048] usbserial: USB Serial support registered for ch341-uart
[    2.148461] usbcore: registered new interface driver cp210x
[    2.154179] usbserial: USB Serial support registered for cp210x
[    2.160256] usbcore: registered new interface driver ftdi_sio
[    2.166147] usbserial: USB Serial support registered for FTDI USB Serial Device
[    2.173696] usbcore: registered new interface driver option
[    2.179424] usbserial: USB Serial support registered for GSM modem (1-port)
[    2.186459] ==20170105_1==> hub_port_init 1 #0
[    2.186694] usbcore: registered new interface driver pl2303
[    2.186808] usbserial: USB Serial support registered for pl2303
[    2.186943] usbcore: registered new interface driver ti_usb_3410_5052
[    2.187058] usbserial: USB Serial support registered for TI USB 3410 1 port adapter
[    2.187176] usbserial: USB Serial support registered for TI USB 5052 2 port adapter
[    2.187577] mousedev: PS/2 mouse device common for all mice
[    2.188148] rtc-mstar rtc-mstar.0: rtc core: registered rtc-mstar as rtc0
[    2.188407] IR NEC protocol handler initialized
[    2.188410] IR RC5(x) protocol handler initialized
[    2.188412] IR RC6 protocol handler initialized
[    2.188414] IR JVC protocol handler initialized
[    2.188416] IR Sony protocol handler initialized
[    2.188418] IR RC5 (streamzap) protocol handler initialized
[    2.188420] IR SANYO protocol handler initialized
[    2.188422] IR MCE Keyboard/mouse protocol handler initialized
[    2.188584] usbcore: registered new interface driver uvcvideo
[    2.188586] USB Video Class driver (1.1.1)
[    2.189089] device-mapper: uevent: version 1.0.3
[    2.189540] device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
[    2.189829] mmcblk0: mmc0:0001 8GND3R 7.28 GiB
[    2.190056] mmcblk0boot0: mmc0:0001 8GND3R partition 1 4.00 MiB
[    2.190271] mmcblk0boot1: mmc0:0001 8GND3R partition 2 4.00 MiB
[    2.190486] mmcblk0rpmb: mmc0:0001 8GND3R partition 3 512 KiB
[    2.190886] emmc_partition()
[    2.191263]  [emmc]Start_block=4096, block_count=6144
[    2.191270] Start_block=10240, block_count=4096
[    2.191275] Start_block=14336, block_count=1024
[    2.191279] Start_block=15360, block_count=1024
[    2.191283] Start_block=16384, block_count=30720
[    2.191288] Start_block=47104, block_count=22528
[    2.191292] Start_block=69632, block_count=12288
[    2.191500] Start_block=81920, block_count=512
[    2.191506] Start_block=82432, block_count=2097152
[    2.191511] Start_block=2179584, block_count=10354688
[    2.191516] Start_block=12534272, block_count=2097152
[    2.191521] Start_block=14631424, block_count=131072
[    2.191526] Start_block=14762496, block_count=327680
[    2.191530] Start_block=15090176, block_count=16384
[    2.191535] Start_block=15106560, block_count=32768
[    2.191730]
[    2.196003]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15emmc_partition()
[    2.196392] 0x0
[    2.196420]  mmcblk0boot1: unknown partition table
[    2.196970] emmc_partition()
[    2.197306] 0x5eaa
[    2.197331]  mmcblk0boot0: unknown partition table
[    2.197987] hidraw: raw HID events driver (C) Jiri Kosina
[    2.198289] usbcore: registered new interface driver usbhid
[    2.198291] usbhid: USB HID core driver
[    2.198744] ashmem: initialized
[    2.199655] Mstar_emac: [ PHY Addr ] ==> :0
[    2.199677] Mstar_emac: alloRAM_VA_BASE = 0xf0a80000 alloRAM_PA_BASE= 0x3dd00000  alloRAM_SIZE= 0x40000
[    2.199934] RBQP_BASE = 3dd04000
[    2.200767] Registered IR keymap rc-baofeng-tv
[    2.201366] input: Baofeng Smart TV IR Receiver as /devices/virtual/rc/rc0/input0
[    2.201568] rc0: Baofeng Smart TV IR Receiver as /devices/virtual/rc/rc0
[    2.201881] input: MCE IR Keyboard/Mouse (ir) as /devices/virtual/input/input1
[    2.202376] IR IRQ registartion OK
[    2.202656] mstar sdio host running...
[    2.202662] SDIO-CD(1) 0x000Fh[03h]#2
[    2.202667] SDIO-PC(0) 0x0000h[00h]#3697
[    2.202671] SDIO-WP(0) 0x0000h[00h]#3697
[    2.236929] [mod_pwm_init][198] mod_pwm_init is invoked
[    2.236935] Init PWM0
[    2.236942] [4294669196][MAD_ALSA][001978]     6Linux Kernel Version : 3.10.86
[    2.236946] [4294669196][MAD_ALSA][001980]     6ALSA Kernel Version : XX.XX.XX
[    2.236952] [4294669196][MAD_ALSA][001984]     6MStar ALSA Driver Version : 3.1.22
[    2.236955] [4294669196][MAD_ALSA][001985]     6Initiate MStar ALSA driver engine
[    2.236958] [4294669196][MAD_ALSA][001878]     6Go to register MStar ALSA driver
[    2.237120] [4294669196][MAD_ALSA][002168]     6Initiate MStar ALSA core driver
[    2.237127] [4294669196][MAD_ALSA][000306]     6MStar Core Version : 3.1.49
[    2.238418] [4294669196][MAD_ALSA][000357]     6MStar ALSA driver is registered to slot 0
[    2.239031] Function = CPU_calibrating_init, Line = 1904, [cpu 0] do CPU_calibrating_init
[    2.239067] Function = cpufreq_add_dev, Line = 923, adding CPU 0
[    2.239074] Function = cpufreq_add_dev, Line = 976, do cpufreq_driver->init
[    2.239086] Function = integrator_cpufreq_init, Line = 400, cluster = 0, policy->cpu = 0, cluster_m: 0, max_freq: 1600000, min_freq: 1300000
[    2.239091] Function = integrator_cpufreq_init, Line = 406, set cpu0 ac_str_cpufreq: 1000000 KHz
[    2.239146] Create T sensor on cpu:0, set str freq to 1000000khz
[    2.239778] Function = __cpufreq_set_policy, Line = 1836, re-assign governor
[    2.239783] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.239820] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.239827] Function = cpufreq_governor_dbs, Line = 358, [cpu 0] initialize cpu 0 timer
[    2.239831] Function = cpufreq_governor_dbs, Line = 384, [cpu 0] do first DVFS sampling
[    2.239839] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.239859] Function = cpufreq_add_dev, Line = 923, adding CPU 1
[    2.239864] Function = cpufreq_add_dev, Line = 976, do cpufreq_driver->init
[    2.686052] Function = integrator_cpufreq_init, Line = 400, cluster = 0, policy->cpu = 1, cluster_m: 0, max_freq: 1600000, min_freq: 1300000
[    2.699394] Plug in USB Port1
[    2.703490] Function = __cpufreq_set_policy, Line = 1836, re-assign governor
[    2.711308] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.719861] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.728410] Function = cpufreq_governor_dbs, Line = 358, [cpu 1] initialize cpu 1 timer
[    2.737133] Function = cpufreq_governor_dbs, Line = 384, [cpu 1] do first DVFS sampling
[    2.745866] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.754433] Function = cpufreq_add_dev, Line = 923, adding CPU 2
[    2.761145] Function = cpufreq_add_dev, Line = 976, do cpufreq_driver->init
[    2.768849] Function = integrator_cpufreq_init, Line = 400, cluster = 0, policy->cpu = 2, cluster_m: 0, max_freq: 1600000, min_freq: 1300000
[    2.783255] Function = __cpufreq_set_policy, Line = 1836, re-assign governor
[    2.791018] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.799563] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.808108] Function = cpufreq_governor_dbs, Line = 358, [cpu 2] initialize cpu 2 timer
[    2.816825] Function = cpufreq_governor_dbs, Line = 384, [cpu 2] do first DVFS sampling
[    2.825544] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.834091] Function = cpufreq_add_dev, Line = 923, adding CPU 3
[    2.840801] Function = cpufreq_add_dev, Line = 976, do cpufreq_driver->init
[    2.844007] usb 2-1: new high-speed USB device number 2 using Mstar-ehci-1
[    2.855379] Function = integrator_cpufreq_init, Line = 400, cluster = 0, policy->cpu = 3, cluster_m: 0, max_freq: 1600000, min_freq: 1300000
[    2.869802] Function = __cpufreq_set_policy, Line = 1836, re-assign governor
[    2.877564] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.886108] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.894652] Function = cpufreq_governor_dbs, Line = 358, [cpu 3] initialize cpu 3 timer
[    2.903359] Function = cpufreq_governor_dbs, Line = 384, [cpu 3] do first DVFS sampling
[    2.912078] Function = __cpufreq_governor, Line = 1653, do policy->governor: ondemand
[    2.921188] _gSlit0_FlagGroupBase = 0xf0a38000 mapping on 0x20000000
[    2.927563] _gSlit1_FlagGroupBase = 0xf0a3c000 mapping on 0xa0000000
[    2.933934] _gSlit0_FlagGroupBase = 0xf0a40000 mapping on 0x20000000
[    2.940307] _gSlit1_FlagGroupBase = 0xf0a44000 mapping on 0xa0000000
[    2.946684] Function = init_glob_miu_kranges, Line = 3752, Insert KProtect for LX @ MIU: 0
[    2.955665] Function = init_glob_miu_kranges, Line = 3761, [INIT] for LX0 kprotect: from 0x20200000 to 0x3DD00000, using block 0
[    2.967964] Function = init_glob_miu_kranges, Line = 3774, Insert KProtect for LX2 @ MIU: 1
[    2.977057] Function = init_glob_miu_kranges, Line = 3785, [INIT] for LX2 kprotect: from 0xA0400000 to 0xC0000000, using block 0
[    2.993213] logger: created 8192K log 'log_main'
[    2.998119] logger: created 256K log 'log_events'
[    3.003113] logger: created 256K log 'log_radio'
[    3.008002] logger: created 256K log 'log_system'
[    3.014610] usbcore: registered new interface driver snd-usb-audio
[    3.021074] oprofile: no performance counters
[    3.025694] oprofile: using timer interrupt.
[    3.030076] u32 classifier
[    3.032788]     Actions configured
[    3.036211] Netfilter messages via NETLINK v0.30.
[    3.040975] nf_conntrack version 0.5.0 (15402 buckets, 61608 max)
[    3.047871] ctnetlink v0.93: registering with nfnetlink.
[    3.053269] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    3.054518] usb 2-1: New USB device found, idVendor=1e3d, idProduct=2095
[    3.054525] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.054531] usb 2-1: Product: Flash Disk
[    3.054537] usb 2-1: Manufacturer: JT1199
[    3.054542] usb 2-1: SerialNumber: CCBB1512261826143104209200
[    3.055136] usb-storage 2-1:1.0: USB Mass Storage device detected
[    3.094613] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    3.100696] scsi0 : usb-storage 2-1:1.0
[    3.104792] xt_time: kernel timezone is -0000
[    3.109531] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.115136] arp_tables: (C) 2002 David S. Miller
[    3.119818] TCP: cubic registered
[    3.123139] Initializing XFRM netlink socket
[    3.128364] NET: Registered protocol family 10
[    3.133798] mip6: Mobile IPv6
[    3.136820] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.142490] sit: IPv6 over IPv4 tunneling driver
[    3.148636] NET: Registered protocol family 17
[    3.153109] NET: Registered protocol family 15
[    3.157666] Bridge firewalling registered
[    3.161687] 8021q: 802.1Q VLAN Support v1.8
[    3.166652] Registering SWP/SWPB emulation handler
[    3.173116] rtc-mstar rtc-mstar.0: setting system clock to 2007-01-01 12:00:00 UTC (1167652800)
[    3.181914] ALSA device list:
[    3.184907]   #0: MStar MPEG Audio Decoder No.00
[    3.190109] Freeing unused kernel memory: 368K (c08e7000 - c0943000)
[    3.196487] [AT][KR][start init][5119]
[    3.200241] [AutoTest][Kernel][start Initprocess][5119]
[    3.205485] Function = kernel_init, Line = 1087, ramdisk_execute_command is /init
[    3.216209] init: <Cvte-Init> ro.boot.AT_K=
[    3.220423] init: <Cvte-Init> Use init.rc
[    3.226598] init: /init.mainz.rc: 293: ignored duplicate definition of service 'dhcpcd_bnep0'
[    3.337209] init: /dev/hw_random not found
             A N D R O I D
[    3.369544] fs_mgr: Warning: unknown flag block_validity
[    3.374967] fs_mgr: Warning: unknown flag nodiscard
[    3.379860] fs_mgr: Warning: unknown flag data=ordered
[    3.385024] fs_mgr: Warning: unknown flag journal_checksum
[    3.390535] fs_mgr: Warning: unknown flag block_validity
[    3.395893] fs_mgr: Warning: unknown flag nodiscard
[    3.400784] fs_mgr: Warning: unknown flag data=ordered
[    3.405948] fs_mgr: Warning: unknown flag journal_checksum
[    3.411466] fs_mgr: Warning: unknown flag block_validity
[    3.416806] fs_mgr: Warning: unknown flag nodiscard
[    3.421696] fs_mgr: Warning: unknown flag data=ordered
[    3.426858] fs_mgr: Warning: unknown flag journal_checksum
[    3.432368] fs_mgr: Warning: unknown flag block_validity
[    3.437722] fs_mgr: Warning: unknown flag nodiscard
[    3.442612] fs_mgr: Warning: unknown flag data=ordered
[    3.447776] fs_mgr: Warning: unknown flag journal_checksum
[    3.453286] fs_mgr: Warning: unknown flag block_validity
[    3.458623] fs_mgr: Warning: unknown flag nodiscard
[    3.463513] fs_mgr: Warning: unknown flag data=ordered
[    3.468675] fs_mgr: Warning: unknown flag journal_checksum
[    3.477701] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
[    3.489310] EXT4-fs (mmcblk0p11): recovery complete
[    3.494246] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
[    3.505269] Unable to handle kernel paging request at virtual address 000a008c
[    3.512500] pgd = ee974000
[    3.515229] [000a008c] *pgd=b110f831, *pte=00000000, *ppte=00000000
[    3.521550] Internal error: Oops: 17 [#1] PREEMPT SMP ARM
[    3.526955] Modules linked in:
[    3.530031] CPU: 2 PID: 1106 Comm: init Not tainted 3.10.86 #3
[    3.535871] task: ef0a4440 ti: ef5aa000 task.ti: ef5aa000
[    3.541285] PC is at put_pwq_unlocked+0x14/0x30
[    3.545824] LR is at apply_workqueue_attrs+0x1a8/0x250
[    3.550972] pc : [<c0041314>]    lr : [<c0043334>]    psr: 200f0013
[    3.550972] sp : ef5abbd0  ip : ef5abbe8  fp : ef5abbe4
[    3.562460] r10: ee86eb80  r9 : 00ff00ff  r8 : ef168110
[    3.567692] r7 : ee86eb40  r6 : ef168200  r5 : ee86eb00  r4 : 000a008c
[    3.574231] r3 : 00000000  r2 : 00000001  r1 : 00000000  r0 : 000a008c
[    3.580767] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
[    3.587909] Control: 10c0383d  Table: b117406a  DAC: 00000015
[    3.593661]
[    3.593661] PC: 0xc0041294:
[    3.597937] 1294  e2433001 e5803010 e3530000 189da818 e5903004 e5933080 e3130002 0a000006
[    3.606247] 12b4  e30b3450 e34c3095 e2822070 e3a00004 e5931000 ebfffcfe e89da818 e30a421d
[    3.614564] 12d4  e34c409c e5d43019 e3530000 189da818 e30d0838 e3001431 e34c0081 ebff8f33
[    3.622876] 12f4  e3a03001 e5c43019 e89da818 e1a0c00d e92dd818 e24cb004 e2504000 089da818
[    3.631187] 1314  e5940000 eb19c509 e1a00004 ebffffd6 e5940000 eb19c445 e89da818 e1a0c00d
[    3.639500] 1334  e92dd830 e24cb004 e24dd008 e2804010 e1a05000 ebfffee5 e1a00004 eb19bc5c
[    3.647810] 1354  e5953000 e50b3018 e51b1018 e1550001 e2411060 0a00001e e3a03000 e0812003
[    3.656122] 1374  e2833004 e5922014 e3520000 1a000040 e353003c 1afffff8 e5953060 e1530001
[    3.664437]
[    3.664437] LR: 0xc00432b4:
[    3.668714] 32b4  e2833001 e5863010 e5856000 e2848010 e59f010c eb19b3e1 e1a00008 eb19b47c
[    3.677023] 32d4  e594305c e5972000 e5832000 e5972004 e5832004 e5d72008 e5c32008 e5959000
[    3.685335] 32f4  e1a00009 ebfffd21 e5943088 f57ff05a e5849088 e1a00006 e5853000 e3a03000
[    3.693646] 3314  e50b3030 ebfffd19 e5949060 e1a00008 e5846060 eb19b3c9 e5950000 ebfff7f2
[    3.701959] 3334  e1a00009 ebfff7f0 ebff96c3 e1a0000a ebfffe3e e1a00007 ebfffe3c e1a00005
[    3.710270] 3354  eb032ac8 e51b0030 e24bd028 e89daff0 e3e0300b e50b3030 eafffff3 e1a00004
[    3.718584] 3374  e1a0100a ebfffed9 e3500000 e5850000 1affffcd e1a00006 ebfffb94 e5950000
[    3.726897] 3394  e1500006 1a000005 e59f0034 e3e0300b e50b3030 eb19b3a9 ebff96a7 eaffffe2
[    3.735209]
[    3.735209] SP: 0xef5abb50:
[    3.739485] bb50  c00d10e0 ef42b880 ef168258 ef168100 ee86eb40 c0041314 200f0013 ffffffff
[    3.747799] bb70  ef5abbbc ef168110 ef5abbe4 ef5abb88 c06b2e18 c0008480 000a008c 00000000
[    3.756112] bb90  00000001 00000000 000a008c ee86eb00 ef168200 ee86eb40 ef168110 00ff00ff
[    3.764426] bbb0  ee86eb80 ef5abbe4 ef5abbe8 ef5abbd0 c0043334 c0041314 200f0013 ffffffff
[    3.772740] bbd0  00000000 ef168100 ef5abc1c ef5abbe8 c0043334 c004130c ef5abc1c 00000000
[    3.781059] bbf0  c003fb24 ef168100 ef168110 0000000a c0835478 c09f1870 ee8616b0 ee861400
[    3.789370] bc10  ef5abc74 ef5abc20 c0043504 c0043198 ef5abc44 ef5abc30 ef5abc44 ef5abc38
[    3.797683] bc30  c06b23d4 ef168168 ef5abc74 ef168108 ef5abc7c c06b23b4 00000000 ee861400
[    3.805995]
[    3.805995] IP: 0xef5abb68:
[    3.810270] bb68  200f0013 ffffffff ef5abbbc ef168110 ef5abbe4 ef5abb88 c06b2e18 c0008480
[    3.818584] bb88  000a008c 00000000 00000001 00000000 000a008c ee86eb00 ef168200 ee86eb40
[    3.826900] bba8  ef168110 00ff00ff ee86eb80 ef5abbe4 ef5abbe8 ef5abbd0 c0043334 c0041314
[    3.835212] bbc8  200f0013 ffffffff 00000000 ef168100 ef5abc1c ef5abbe8 c0043334 c004130c
[    3.843523] bbe8  ef5abc1c 00000000 c003fb24 ef168100 ef168110 0000000a c0835478 c09f1870
[    3.851835] bc08  ee8616b0 ee861400 ef5abc74 ef5abc20 c0043504 c0043198 ef5abc44 ef5abc30
[    3.860149] bc28  ef5abc44 ef5abc38 c06b23d4 ef168168 ef5abc74 ef168108 ef5abc7c c06b23b4
[    3.868463] bc48  00000000 ee861400 ee861400 ee861400 ee8ae400 ee861000 ee8616b0 ee861400
[    3.876777]
[    3.876777] FP: 0xef5abb64:
[    3.881053] bb64  c0041314 200f0013 ffffffff ef5abbbc ef168110 ef5abbe4 ef5abb88 c06b2e18
[    3.889363] bb84  c0008480 000a008c 00000000 00000001 00000000 000a008c ee86eb00 ef168200
[    3.897677] bba4  ee86eb40 ef168110 00ff00ff ee86eb80 ef5abbe4 ef5abbe8 ef5abbd0 c0043334
[    3.905989] bbc4  c0041314 200f0013 ffffffff 00000000 ef168100 ef5abc1c ef5abbe8 c0043334
[    3.914302] bbe4  c004130c ef5abc1c 00000000 c003fb24 ef168100 ef168110 0000000a c0835478
[    3.922619] bc04  c09f1870 ee8616b0 ee861400 ef5abc74 ef5abc20 c0043504 c0043198 ef5abc44
[    3.930935] bc24  ef5abc30 ef5abc44 ef5abc38 c06b23d4 ef168168 ef5abc74 ef168108 ef5abc7c
[    3.939248] bc44  c06b23b4 00000000 ee861400 ee861400 ee861400 ee8ae400 ee861000 ee8616b0
[    3.947563]
[    3.947563] R5: 0xee86ea80:
[    3.951838] ea80  00000001 00000001 00000001 00000000 00004003 00000000 00000000 00000000
[    3.960153] eaa0  00000020 00000000 00000000 00000000 ffffffe0 ee86eab4 ee86eab4 c0301ccc
[    3.968469] eac0  00000000 0000000f 00000000 00000000 00000000 00000000 00000000 00000000
[    3.976787] eae0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.985101] eb00  000a008c 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    3.993417] eb20  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.001732] eb40  00000000 0000000f 00000000 00000000 00000000 00000000 00000000 00000000
[    4.010043] eb60  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.018357]
[    4.018357] R6: 0xef168180:
[    4.022634] 8180  0000000a 00000002 ef168200 002a0040 00000000 00000000 00000000 00000000
[    4.030945] 81a0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.039259] 81c0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.047574] 81e0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.055888] 8200  ef403400 ef168100 00000000 ffffffff 00000002 00000000 00000000 00000000
[    4.064205] 8220  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.072520] 8240  00000000 00000000 00000000 00000000 00000000 00000001 ef168258 ef168258
[    4.080832] 8260  ef168100 ef168100 ef168268 ef168268 ffffffe0 ef168274 ef168274 c0042c90
[    4.089143]
[    4.089143] R7: 0xee86eac0:
[    4.093420] eac0  00000000 0000000f 00000000 00000000 00000000 00000000 00000000 00000000
[    4.101735] eae0  00000000 00000000[    4.104461] scsi 0:0:0:0: Direct-Access     JT1199   Flash Disk       5.00 PQ: 0 ANSI: 2
[    4.105601] sd 0:0:0:0: [sda] 8265728 512-byte logical blocks: (4.23 GB/3.94 GiB)
[    4.105799] sd 0:0:0:0: [sda] Write Protect is off
[    4.106014] sd 0:0:0:0: [sda] No Caching mode page found
[    4.106020] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    4.107248] sd 0:0:0:0: [sda] No Caching mode page found
[    4.107254] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    4.107318] emmc_partition()
[    4.107781] 0x0
[    4.107811]  sda: sda1
[    4.160241] eb00  000a008c 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.168553] eb20  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.176872] eb40  00000000 0000000f 00000000 00000000 00000000 00000000 00000000 00000000
[    4.185186] eb60  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.193500] eb80  00000000 0000000f 00000000 00000000 00000000 00000000 00000000 00000000
[    4.201815] eba0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.210131]
[    4.210131] R8: 0xef168090:
[    4.214407] 8090  000cf850 000dbba0 000e7ef0 000f4240 000f6180 00100590 0010c8e0 00118c30
[    4.222720] 80b0  00124f80 001312d0 0013d620 00149970 00155cc0 00162010 0016e360 0017a6b0
[    4.231031] 80d0  00186a00 00192d50 0019f0a0 001a8ce0 001ab3f0 001b7740 001c3a90 001cfde0
[    4.239345] 80f0  001dc130 001e8480 00000000 00000000 ef168260 ef168260 ef168108 ef168108
[    4.247662] 8110  00000001 00000000 ef168118 ef168118 00000000 00000000 00000000 00000000
[    4.255982] 8130  00000000 00000000 ef168138 ef168138 ef168140 ef168140 ef168148 ef168148
[    4.264293] 8150  00ff00ff 00ff00ff 00000001 ee86eac0 ef168200 00ff00ff 34747865 6f69642d
[    4.272607] 8170  776e752d 74746972 00006e65 00010088 0000000a 00000002 ef168200 002a0040
[    4.280925]
[    4.280925] R10: 0xee86eb00:
[    4.285289] eb00  000a008c 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.293602] eb20  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.301917] eb40  00000000 0000000f 00000000 00000000 00000000 00000000 00000000 00000000
[    4.310231] eb60  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.318544] eb80  00000000 0000000f 00000000 00000000 00000000 00000000 00000000 00000000
[    4.326857] eba0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.335169] ebc0  ee86ec00 ee86ebc0 ee86ebc8 ee86ebc8 eedb30dc 00000000 00000000 00000000
[    4.343483] ebe0  00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    4.351798] Process init (pid: 1106, stack limit = 0xef5aa238)
[    4.357638] Stack: (0xef5abbd0 to 0xef5ac000)
[    4.362005] bbc0:                                     00000000 ef168100 ef5abc1c ef5abbe8
[    4.370196] bbe0: c0043334 c004130c ef5abc1c 00000000 c003fb24 ef168100 ef168110 0000000a
[    4.378391] bc00: c0835478 c09f1870 ee8616b0 ee861400 ef5abc74 ef5abc20 c0043504 c0043198
[    4.386582] bc20: ef5abc44 ef5abc30 ef5abc44 ef5abc38 c06b23d4 ef168168 ef5abc74 ef168108
[    4.394774] bc40: ef5abc7c c06b23b4 00000000 ee861400 ee861400 ee861400 ee8ae400 ee861000
[    4.402965] bc60: ee8616b0 ee861400 ef5abe34 ef5abc78 c01c410c c00433e8 00000000 00000000
[    4.411156] bc80: ef5aa000 000000d0 ef401400 c12b97e8 ef5abd14 ef5abca0 c06aa068 c010c330
[    4.419347] bca0: ef400a40 c12b97e8 c014a534 000000d0 ef5abccc ef5abcc0 c00e6c20 c00e6bcc
[    4.427538] bcc0: ef5abce4 ef5abe54 ef5abd7c ef5abcd8 c031a988 c0318564 ef5abd34 ef5abce8
[    4.435728] bce0: 00000000 00000000 00000000 00000000 ffffffff 00000002 c095b408 0000000a
[    4.443920] bd00: 00000002 00000000 31303fbc c12c4160 ef0c6a00 c095b98c 600f0013 ef0c6a00
[    4.452111] bd20: c095b98c 00000004 ef5abdbc ef5abd38 c00e8520 c06b0260 ef5abd5c ef5abd48
[    4.460302] bd40: ef5abd5c ef5abe4c 00000000 00008000 ee861400 000001fe 00000000 00000000
[    4.468492] bd60: 00000002 ee8614b8 ee86165c 00000000 00000001 00000000 ee8614d8 00000000
[    4.476683] bd80: 00000000 00000000 ee8614f8 00000000 00000001 00000000 00000001 00000000
[    4.484874] bda0: ee861518 00000000 ee861400 00000000 c0a2750c ee8611f0 00000000 eee30100
[    4.493065] bdc0: 00000000 00000000 c0a208f4 ef5abdd8 ee8ae400 c095b408 ee861000 00000000
[    4.501256] bde0: 00004003 ef5abdf8 c0309950 c031ba4c c0855fbc ef32340c 0000000a ee8611f0
[    4.509447] be00: ef5abe4c 271ae74a ee861000 eee2e000 c095b408 ee861000 00000083 eee2e074
[    4.517638] be20: 00000000 00000000 ef5abe9c ef5abe38 c01185b0 c01c278c eee2e000 00000004
[    4.525829] be40: c06bc72c c01c2780 00000031 62636d6d 70306b6c ef003031 c011050c c06b4f54
[    4.534021] be60: c031090c c010e378 600f0013 271ae74a ee8a1af8 00000000 00000000 ee86e980
[    4.542212] be80: c0971100 c0971100 0000000b 00000000 ef5abeb4 ef5abea0 c01b6cd8 c0118420
[    4.550403] bea0: c01c2780 ef5abeb0 ef5abeec ef5abeb8 c0118f48 c01b6cc4 c01316b4 c00e8658
[    4.558594] bec0: 00000000 ee8a1a80 ee86e980 00000000 c0971100 00000000 0000000b ee86e940
[    4.566784] bee0: ef5abf14 ef5abef0 c0131b4c c0118f08 00000000 c0971100 00000000 00000000
[    4.574980] bf00: ee86e980 c096781c ef5abf6c ef5abf18 c0133db0 c0131b04 00000000 00000031
[    4.583171] bf20: 00001000 0117e660 ef4110d0 eed47770 c00e4318 c00e423c 0117e660 ef5abf80
[    4.591362] bf40: ee870000 00000000 ee870000 0117e660 00000406 c000e7c4 ef5aa000 00000000
[    4.599553] bf60: ef5abfa4 ef5abf70 c013457c c0133bc0 00000000 26be367f 4598f7c0 ee86e940
[    4.607745] bf80: ee86e980 00000000 00000000 ffffffff 0002cfee 00000015 00000000 ef5abfa8
[    4.615936] bfa0: c000e640 c01344fc 00000000 ffffffff 0117e660 0117e698 0117e6a8 00000406
[    4.624127] bfc0: 00000000 ffffffff 0002cfee 00000015 0117e660 00000406 0117e6a8 0002b449
[    4.632319] bfe0: be9f9cb8 be9f9ca8 0000eb19 00019e64 000f0010 0117e660 ffffffff ffffffff
[    4.640501] Backtrace:
[    4.642979] [<c0041300>] (put_pwq_unlocked+0x0/0x30) from [<c0043334>] (apply_workqueue_attrs+0x1a8/0x250)
[    4.652640]  r4:ef168100 r3:00000000
[    4.656256] [<c004318c>] (apply_workqueue_attrs+0x0/0x250) from [<c0043504>] (__alloc_workqueue_key+0x128/0x3c0)
[    4.666448] [<c00433dc>] (__alloc_workqueue_key+0x0/0x3c0) from [<c01c410c>] (ext4_fill_super+0x198c/0x2e34)
[    4.676292] [<c01c2780>] (ext4_fill_super+0x0/0x2e34) from [<c01185b0>] (mount_bdev+0x19c/0x1cc)
[    4.685092] [<c0118414>] (mount_bdev+0x0/0x1cc) from [<c01b6cd8>] (ext4_mount+0x20/0x28)
[    4.693197] [<c01b6cb8>] (ext4_mount+0x0/0x28) from [<c0118f48>] (mount_fs+0x4c/0x188)
[    4.701128] [<c0118efc>] (mount_fs+0x0/0x188) from [<c0131b4c>] (vfs_kern_mount+0x54/0xcc)
[    4.709406] [<c0131af8>] (vfs_kern_mount+0x0/0xcc) from [<c0133db0>] (do_mount+0x1fc/0x93c)
[    4.717764]  r8:c096781c r7:ee86e980 r6:00000000 r5:00000000 r4:c0971100
r3:00000000
[    4.725696] [<c0133bb4>] (do_mount+0x0/0x93c) from [<c013457c>] (SyS_mount+0x8c/0xc0)
[    4.733543] [<c01344f0>] (SyS_mount+0x0/0xc0) from [<c000e640>] (ret_fast_syscall+0x0/0x38)
[    4.741901]  r7:00000015 r6:0002cfee r5:ffffffff r4:00000000
[    4.747631] Code: e92dd818 e24cb004 e2504000 089da818 (e5940000)
[    4.753797] ---[ end trace 1eb9be4c6713f7d5 ]---
[    4.755319] sd 0:0:0:0: [sda] No Caching mode page found
[    4.755325] sd 0:0:0:0: [sda] Assuming drive cache: write through
[    4.755333] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    4.775360] Kernel panic - not syncing: Fatal exception
[    4.780594] CPU0: stopping
[    4.783314] CPU: 0 PID: 0 Comm: swapper/0 Tainted: G      D      3.10.86 #3
[    4.790280] Backtrace:
[    4.792758] [<c00126d0>] (dump_backtrace+0x0/0x110) from [<c00129f8>] (show_stack+0x18/0x1c)
[    4.801203]  r6:00000005 r5:c095bb28 r4:00000000 r3:271ae74a
[    4.806936] [<c00129e0>] (show_stack+0x0/0x1c) from [<c06ac4d8>] (dump_stack+0x24/0x28)
[    4.814952] [<c06ac4b4>] (dump_stack+0x0/0x28) from [<c0014d0c>] (handle_IPI+0x274/0x28c)
[    4.823143] [<c0014a98>] (handle_IPI+0x0/0x28c) from [<c0008620>] (gic_handle_irq+0x64/0x68)
[    4.831596] [<c00085bc>] (gic_handle_irq+0x0/0x68) from [<c06b2e80>] (__irq_svc+0x40/0x70)
[    4.839868] Exception stack(0xc0945f20 to 0xc0945f68)
[    4.844932] 5f20: 00000000 00000000 00001ae4 00000000 c0944000 c0944000 c095b4a8 c06bc728
[    4.853123] 5f40: c0944000 410fd041 c09cac44 c0945f74 c0945f78 c0945f68 c000f638 c000f63c
[    4.861308] 5f60: 600b0013 ffffffff
[    4.864800]  r7:c0945f54 r6:ffffffff r5:600b0013 r4:c000f63c
[    4.870534] [<c000f608>] (arch_cpu_idle+0x0/0x38) from [<c006dd30>] (cpu_startup_entry+0x70/0x228)
[    4.879510] [<c006dcc0>] (cpu_startup_entry+0x0/0x228) from [<c0690a28>] (rest_init+0x8c/0x90)
[    4.888129]  r7:c0963b74
[    4.890690] [<c069099c>] (rest_init+0x0/0x90) from [<c08e8690>] (start_kernel+0xe40/0xe4c)
[    4.898960]  r4:c095b7d8 r3:00000000
[    4.902575] [<c08e7850>] (start_kernel+0x0/0xe4c) from [<20208070>] (0x20208070)
[    4.909978] CPU3: stopping
[    4.912696] CPU: 3 PID: 0 Comm: swapper/3 Tainted: G      D      3.10.86 #3
[    4.919663] Backtrace:
[    4.922139] [<c00126d0>] (dump_backtrace+0x0/0x110) from [<c00129f8>] (show_stack+0x18/0x1c)
[    4.930584]  r6:00000005 r5:c095bb28 r4:00000003 r3:271ae74a
[    4.936315] [<c00129e0>] (show_stack+0x0/0x1c) from [<c06ac4d8>] (dump_stack+0x24/0x28)
[    4.944333] [<c06ac4b4>] (dump_stack+0x0/0x28) from [<c0014d0c>] (handle_IPI+0x274/0x28c)
[    4.952523] [<c0014a98>] (handle_IPI+0x0/0x28c) from [<c0008620>] (gic_handle_irq+0x64/0x68)
[    4.960975] [<c00085bc>] (gic_handle_irq+0x0/0x68) from [<c06b2e80>] (__irq_svc+0x40/0x70)
[    4.969246] Exception stack(0xef013f58 to 0xef013fa0)
[    4.974306] 3f40:                                                       00000003 00000000
[    4.982497] 3f60: 00000fc2 00000000 ef012000 ef012000 c095b4a8 c06bc728 ef012000 410fd041
[    4.990688] 3f80: c09cac44 ef013fac ef013fb0 ef013fa0 c000f638 c000f63c 600f0013 ffffffff
[    4.998871]  r7:ef013f8c r6:ffffffff r5:600f0013 r4:c000f63c
[    5.004605] [<c000f608>] (arch_cpu_idle+0x0/0x38) from [<c006dd30>] (cpu_startup_entry+0x70/0x228)
[    5.013581] [<c006dcc0>] (cpu_startup_entry+0x0/0x228) from [<c06a4134>] (secondary_start_kernel+0x494/0x49c)
[    5.023501]  r7:c09cea48
[    5.026059] [<c06a3ca0>] (secondary_start_kernel+0x0/0x49c) from [<202081b8>] (0x202081b8)
[    5.034330] CPU1: stopping
[    5.037047] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G      D      3.10.86 #3
[    5.044014] Backtrace:
[    5.046489] [<c00126d0>] (dump_backtrace+0x0/0x110) from [<c00129f8>] (show_stack+0x18/0x1c)
[    5.054933]  r6:00000005 r5:c095bb28 r4:00000001 r3:271ae74a
[    5.060665] [<c00129e0>] (show_stack+0x0/0x1c) from [<c06ac4d8>] (dump_stack+0x24/0x28)
[    5.068682] [<c06ac4b4>] (dump_stack+0x0/0x28) from [<c0014d0c>] (handle_IPI+0x274/0x28c)
[    5.076872] [<c0014a98>] (handle_IPI+0x0/0x28c) from [<c0008620>] (gic_handle_irq+0x64/0x68)
[    5.085324] [<c00085bc>] (gic_handle_irq+0x0/0x68) from [<c06b2e80>] (__irq_svc+0x40/0x70)
[    5.093595] Exception stack(0xef017f58 to 0xef017fa0)
[    5.098654] 7f40:                                                       00000001 00000000
[    5.106845] 7f60: 00000f90 00000000 ef016000 ef016000 c095b4a8 c06bc728 ef016000 410fd041
[    5.115036] 7f80: c09cac44 ef017fac ef017fb0 ef017fa0 c000f638 c000f63c 600f0113 ffffffff
[    5.123219]  r7:ef017f8c r6:ffffffff r5:600f0113 r4:c000f63c
[    5.128954] [<c000f608>] (arch_cpu_idle+0x0/0x38) from [<c006dd30>] (cpu_startup_entry+0x70/0x228)
[    5.137930] [<c006dcc0>] (cpu_startup_entry+0x0/0x228) from [<c06a4134>] (secondary_start_kernel+0x494/0x49c)
[    5.147851]  r7:c09cea48
[    5.150410] [<c06a3ca0>] (secondary_start_kernel+0x0/0x49c) from [<202081b8>] (0x202081b8)
举报
发表于: 2021-8-1 10:26:27
哈哈哈哈,这么长一串,应该基本的都过了,U盘升级试试吧。
举报
GMT+8, 2025-4-13 15:57 , Processed in 0.063002 sec., 9 queries .
