完全开机后的打印信息:
COM4, BaudRate:115200 bps, RXD: VGA->11,TXD: VGA-> 4, Printed by RT809H:
UART_115200
[AT][MB][start sb][0]
AC_ON
AutoDQS0-[456789ABCDE][56789ABCDE][3456789ABCD][3456789ABC]-[0x7899]
AutoDQS1-[456789ABCDE][56789ABCDEF][3456789ABCDE][3456789ABCD]-[0x88A9]
BIST0-OK
BIST1-OK
_U[AT][MB][start ub][347]
U-Boot 2011.06-svn31 (Jun 18 2014 - 16:42:57)
CPU : Nike
Board: BD_MST049B_10AQV_NIKE
Hello U-Boot
DRAM: 256 MiB
SPI: Flash is detected (0x0B01, 0xC8, 0x40, 0x15)
spi_init: cfg_env_offset: 0x1e0000, at 560
uboot held at [2ecddf60~30000000]
Now running in RAM - U-Boot at: 2f100000
MMC: eMMC 3663MB [727FF8h]
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Get MAC from ethaddr env
MAC: 0x64: 0x88: 0xff: 0x59:0xb2: 0x42
@@@@@@ u32CpuSpeedMHz= 792 MHz
read_dbtable success...>>>
read table >>>
logo offset[0x00140038] size[0x00018744] end[0x0015877c]
music offset[0x0015877c] size[0x00005b07] end[0x0015e283]
panel offset[0x0015e283] size[0x0000005c] end[0x0015e2df]
ursa offset[0x0015e2eb] size[0x00000000] end[0x0015e2eb]
keypad offset[0x0015e2fb] size[0x00000000] end[0x0015e2fb]
It's the last cmd
msIR_Initialize
EEPROM @0xA2 read: addr 2ecf0860 off 0207 count 1 ... done
e2p 0x207 = 0xb9
EEPROM @0xA2 read: addr 2ecf0860 off 0306 count 12 ... done
==>In do_load_eeprom_data,no need to saveenv()
Wait for PM51 standby...........PM51 APP build code time Apr 25 2014 13:19:11
Lib51 build code time Aug 23 2013 17:14:16
Hello Main
_MDrv_PM_PowerDown2Standby
UART_115200
DC_ON
BIST0-OK
BIST1-OK
_U[AT][MB][start ub][352]
CPU : Nike
Hello U-Boot
DRAM: 256 MiB
In: serial
Out: serial
Err: serial
read table >>>
It's the last cmd
msIR_Initialize
e2p 0x207 = 0xb9
Wait for PM51 standby DRAM ...........PM51 run ok...........[LED_INV] src/CusPM.c pm_led_flash 360
Unknown command 'if_51OnRam_set' - try 'help'
Hit any key to stop autoboot: 0
[INFO] Load Ukulele 8x Mode DRAM Settings
Ukulele MIU BIST: OK
mmc change mount : uinside
Size of file "/MERGE_VB1.bin" from mmc device 0 partition uinside: 544396 bytes
Loading file "/MERGE_VB1.bin" at offset 0x0 from mmc device 0 partition uinside
544396 bytes read
MDrv_SS_MIU_Writes
MDrv_SS_MIU_Writes
db_table.panelpara_offset =:0x15e283...db_table.panelpara_size=:0x5c
Read_PanelParaFromflash success...>>>
## CRC check done, panel_crc
panel_data.m_wPanelVStart=: 0x18
panel_data.m_wPanelWidth=: 0x780
panel_data.m_wPanelHeight=: 0x438
db_table.boardpara_offset =:0x15e2df...db_table.boardpara_size=:0xc
Read_BoardParaFromflash success...>>>
## CRC check done, board_crc
db_table.ursa_offset =:0x15e2eb...db_table.ursa_size=:0x10
## CRC check done, ursa_crc
cmd_table.URSA_EXTERNAL is 0
cmd_table.URSA_MEMC_ENABLE is 0
cmd_table.URSA_LVDS_CHANNEL_SWAP_MODE is 0
cmd_table.URSA_LVDS_SWAP_POL is 1
cmd_table.URSA_IN_LVDS_TIMODE is 0
cmd_table.URSA_IN_LVDS_TI_BITNUM is 2
cmd_table.URSA_OUT_LVDS_TIMODE is 1
cmd_table.URSA_OUT_LVDS_TI_BITNUM is 2
cmd_table.URSA_SSC_SEL is 1
cmd_table.URSA_SSC_ENABLE is 0
cmd_table.URSA_SSC_FREQ is c8
cmd_table.URSA_SSC_PERCENT is 64
cmd_table.URSA_OSD_PROTECT_MODE is 1
>>CMD:62,2,0,0,e4,0,0
MDrv_Ursa_8_3D_Cmd write data success.....
sellect channel swap mode ok!!!
>>CMD:d2,1,0,0,0,2c,0
osd_protect_mode = 1
[URSA_8]Write cmd:a5,9,1,0,0,0,0
[Ursa_8]Send cmd:8, return:1
>>CMD:82,4,0,0,0,0,34
sellect output lvds swing ok!!!
>>CMD:53,9,10,0,c8,0,64
MDrv_PNL_Init u32PnlRiuBaseAddr = 1f200000
MDrv_PNL_Init u32PMRiuBaseAddr = 1f000000
LINK TYPE = EXT [_MDrv_PNL_Init_LPLL][300]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_LPLL][302]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][345]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_Output_Dclk][347]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[URSA_8]Write cmd:93,8,1,0,0,0,0
[Ursa_8]Send cmd:4, return:1
Init PWM1[ERROR] No Support PWM Clock Unit Divider in Nike Platform Changhong818_mboot_Version=v1.0026
Need to check USB
Check USB port[2]:
Host type:2
scanning bus for devices...
[USB] interface[0] conf:1 value 9:
Wait for hub reset....
checking hub ports...
[USB] interface[0] conf:1 value ff:
2 USB Device(s) found
scanning bus for storage devices... 0 Storage Device(s) found
FAIL : can not init usb!!
==>In do_check_changhong_upgrade,no need to saveenv()
db_table.logo_offset =:0x140038 ... db_table.logo_size=: 0x18744
Read_LogoToDisplayAddr success...>>>
## CRC check done, logo_crc
[AutoTest][MBoot][JPD Decode]
[GOP0, PID 0, TID 0x-1][Driver Version]: 0089, BuildNum: 0002, ChangeList: 00000340
[AutoTest][MBoot][Show Logo][7992]
Read_>>>
Read_MusicToPlayAddr success...>>>
Read_MusicToPlayAddr success...>>> 2
## CRC check done, music_crc
[[utopia]] DSPBinBaseAddress 0= 0x0
[[utopia]] DSPMadBaseBufferAdr 0= 0x19100000
[[utopia]] DSPBinBaseAddress 1= 0x0
[[utopia]] DSPMadBaseBufferAdr 1= 0x18fc8000
[[utopia]] DSPBinBaseAddress 2= 0x0
[[utopia]] DSPMadBaseBufferAdr 2= 0x18e88000
HAL_MAD_SetMemInfo : DDR_ADDR = 0x19100000, MIUBank = 0
******Amplifier_TI5711_SWMute(0)
[AutoTest][MBoot][Play Melody]
## Booting kernel from Legacy Image at 25000000 ...
Image Name: MStar-linux
Image Type: ARM Linux Multi-File Image (uncompressed)
Data Size: 3962061 Bytes = 3.8 MiB
Load Address: 20208000
Entry Point: 20208000
Contents:
Image 0: 3775124 Bytes = 3.6 MiB
Image 1: 186925 Bytes = 182.5 KiB
## Loading init Ramdisk from multi component Legacy Image at 25000000 ...
## Flattened Device Tree from multi component Image at 25000000
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
Loading Multi-File Image ... OK
[AT][MB][start kr][8766]
Starting kernel ...
KERN-3.1.10.00539225
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.1.10 (ChangHong@SuperServer) (gcc version 4.5.1 (Sourcery G++ Lite 2010.09-50) ) #14 SMP PREEMPT Mon Dec 30 20:17:17 HKT 2013
[ 0.000000] CPU: ARMv7 Processor [410fc073] revision 3 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: nike
[ 0.000000] KDebug = 1
[ 0.000000] SAR5=ON
[ 0.000000] LX_MEM = 0x20200000, 0x18800000
[ 0.000000] LX_MEM2 = 0xA0000000, 0x16B00000
[ 0.000000] LX_MEM3 = 0x0, 0x0
[ 0.000000] EMAC_LEN= 0x100000
[ 0.000000] DRAM_LEN= 0x20000000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c128d000 s10240 r8192 d14336 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 187859
[ 0.000000] Kernel command line: console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x0018800000 EMAC_MEM=0x100000 DRAM_LEN=0x20000000 LX_MEM2=0x0A0000000,0x0016B00000 CORE_DUMP_PATH=/data/core_dump.%%p.gz KDebug=1 SAR5=ON lpj=4000000 BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x1E0000 ENV_VAR_SIZE=0x10000 ENV=SERIAL SECURITY=OFF BOOTTIME_SBOOT=352 BOOTTIME_UBOOT=8766
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 392MB 363MB = 755MB total
[ 0.000000] Memory: 755336k/755336k available, 17784k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
[ 0.000000] vmalloc : 0xef800000 - 0xf8000000 ( 136 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xef300000 ( 755 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc071b000 (7244 kB)
[ 0.000000] .init : 0xc071b000 - 0xc0766800 ( 302 kB)
[ 0.000000] .data : 0xc0768000 - 0xc07a8d28 ( 260 kB)
[ 0.000000] .bss : 0xc07a8d4c - 0xc0981310 (1890 kB)
[ 0.000000] SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:256 nr_irqs:256 256
[ 0.000000] Global Timer Frequency = 444 MHz
[ 0.000000] CPU Clock Frequency = 1000 MHz
[ 0.000000] fre = 444000000, mult= -1876629855, shift= 30
[ 0.000000] sched_clock: 32 bits at 444MHz, resolution 2ns, wraps every 9673ms
[ 0.000000] [AT][Kernel][start_kernel][9285]
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [ttyS0] enabled
[ 0.233433] Calibrating delay loop (skipped) preset value.. 2000.00 BogoMIPS (lpj=4000000)
[ 0.240865] pid_max: default: 32768 minimum: 301
[ 0.245416] Mount-cache hash table entries: 512
[ 0.250357] Initializing cgroup subsys debug
[ 0.254220] Initializing cgroup subsys cpuacct
[ 0.258253] Initializing cgroup subsys freezer
[ 0.262295] CPU: Testing write buffer coherency: ok
[ 0.266761] ftrace: allocating 24995 entries in 74 pages
[ 0.300387] before forking init thread, kernel takes about 40 ms
[ 0.306003]
[ 0.306010] Kernel_Level test
[ 0.310193] smp_twd: clock not found: -2
[ 0.313704] Calibrating local timer... 4294.96MHz.
[ 0.340126] hw perfevents: enabled with ARMv7 Cortex-A7 PMU driver, 5 counters available
[ 0.395669] pen_release = 0x00000001, addr= 0xc07a76a4, pen_release ptr = 0x00000001
[ 0.395678] CPU1: Booted secondary processor
[ 0.406625] CPU1: Unknown IPI message 0x1
[ 0.430759] pen_release = 0x00000002, addr= 0xc07a76a4, pen_release ptr = 0x00000002
[ 0.430769] CPU2: Booted secondary processor
[ 0.441714] CPU2: Unknown IPI message 0x1
[ 0.465838] pen_release = 0x00000003, addr= 0xc07a76a4, pen_release ptr = 0x00000003
[ 0.465848] CPU3: Booted secondary processor
[ 0.476788] CPU3: Unknown IPI message 0x1
[ 0.484811] Brought up 4 CPUs
[ 0.487488] SMP: Total of 4 processors activated (8000.00 BogoMIPS).
[ 0.494084] devtmpfs: initialized
[ 0.509527] NET: Registered protocol family 16
[ 0.518137] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.524241] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
[ 0.530810] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.569881] bio: create slab <bio-0> at 0
[ 0.575277] SCSI subsystem initialized
[ 0.579296] usbcore: registered new interface driver usbfs
[ 0.584613] usbcore: registered new interface driver hub
[ 0.589632] usbcore: registered new device driver usb
[ 0.594591] =====flash_thread start====
[ 0.595590] eMMC: has SD, 2013/0617
[ 0.601901] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.608682] Bluetooth: Core ver 2.16
[ 0.612127] NET: Registered protocol family 31
[ 0.616160] Bluetooth: HCI device and connection manager initialized
[ 0.621873] Bluetooth: HCI socket layer initialized
[ 0.626258] Bluetooth: L2CAP socket layer initialized
[ 0.630838] Bluetooth: SCO socket layer initialized
[ 0.635296] Switching to clocksource timer1
[ 0.639070] stop_machine_cpu_stop smp=1
[ 0.639079] stop_machine_cpu_stop smp=2
[ 0.639088] stop_machine_cpu_stop smp=0
[ 0.639098] stop_machine_cpu_stop smp=3
[ 0.698569] NET: Registered protocol family 2
[ 0.702691] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.709545] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.718679] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
[ 0.725890] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.731821] TCP reno registered
[ 0.734655] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.739997] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.746052] NET: Registered protocol family 1
[ 0.750316] RPC: Registered named UNIX socket transport module.
[ 0.755634] RPC: Registered udp transport module.
[ 0.759894] RPC: Registered tcp transport module.
[ 0.764172] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.770228] Trying to unpack rootfs image as initramfs...
[ 0.789068] Freeing initrd memory: 184K
[ 0.792512] NetWinder Floating Point Emulator V0.97 (extended precision)
[ 0.798611] PMU: registered new PMU device of type 0
[ 0.897215] ashmem: initialized
[ 0.923911] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.931686] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 0.938901] NTFS driver 2.1.30 [Flags: R/O].
[ 0.943637] ROMFS MTD (C) 2007 Red Hat, Inc.
[ 0.948289] msgmni has been set to 1475
[ 0.953391] io scheduler noop registered
[ 0.956950] io scheduler deadline registered
[ 0.960886] io scheduler cfq registered (default)
[ 0.965654] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.971704] serial8250: ttyS0 at I/O 0xfd201300 (irq = 32) is a 16550
[ 0.977815] serial8250: ttyS1 at I/O 0xfd220c00 (irq = 71) is a 16550
[ 0.983888] serial8250: ttyS2 at I/O 0xfd220d00 (irq = 82) is a 16550
[ 1.003182] brd: module loaded
[ 1.012248] loop: module loaded
[ 1.015823] nbd: registered device at major 43
[ 1.028128] [mmc]:mmc_decode_cid:113 cid.prv 0x3a
[ 1.032479] PPP generic driver version 2.4.2
[ 1.032598] [mmc]:mmc_read_ext_csd:285 ext_csd.sectors 0x728000 prod_name MMC04G BOOT_MULTI 0x10
[ 1.032844] mmc0: new high speed MMC card at address 0001
[ 1.033220] [mmc]:mmc_rescan_try_freq:1900 mmc0: eMMC completed
[ 1.054877] PPP Deflate Compression module registered
[ 1.059442] PPP BSD Compression module registered
[ 1.064452] PPP MPPE Compression module registered
[ 1.068789] NET: Registered protocol family 24
[ 1.072854] tun: Universal TUN/TAP device driver, 1.6
[ 1.077431] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.083361] MStar xHCI init...
[ 1.086187] xHCI_740200
[ 1.088457] Mstar-xhci-1 H.W init
[ 1.091444] Mstar_xhc_init start
[ 1.109080] XHCI_enable_PPC: Turn on USB3.0 port power
[ 1.113771] Addr: 0x102b66 bit_num: 0
[ 1.117149] BC disable
[ 1.119346] Mstar-xhci-1 Mstar-xhci-1.0: Mstar xHCI Host Controller
[ 1.124989] Mstar-xhci-1 Mstar-xhci-1.0: new USB bus registered, assigned bus number 1
[ 1.132309] Mstar-xhci-1 Mstar-xhci-1.0: irq 60, io mem 0xfd320000
[ 1.137977] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.144070] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.150545] usb usb1: Product: Mstar xHCI Host Controller
[ 1.155390] usb usb1: Manufacturer: Linux 3.1.10 mstar_xhci_hcd
[ 1.160698] usb usb1: SerialNumber: mstar
[ 1.165298] hub 1-0:1.0: USB hub found
[ 1.168682] hub 1-0:1.0: 1 port detected
[ 1.172737] Mstar-xhci-1 Mstar-xhci-1.0: Mstar xHCI Host Controller
[ 1.178393] Mstar-xhci-1 Mstar-xhci-1.0: new USB bus registered, assigned bus number 2
[ 1.185631] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.191724] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.198201] usb usb2: Product: Mstar xHCI Host Controller
[ 1.203046] usb usb2: Manufacturer: Linux 3.1.10 mstar_xhci_hcd
[ 1.208354] usb usb2: SerialNumber: mstar
[ 1.212897] hub 2-0:1.0: USB hub found
[ 1.216276] hub 2-0:1.0: 1 port detected
[ 1.221210] mousedev: PS/2 mouse device common for all mice
[ 1.228127] lirc_dev: IR Remote Control driver registered, major 253
[ 1.233978] IR NEC protocol handler initialized
[ 1.238049] IR RC5(x) protocol handler initialized
[ 1.242447] IR RC6 protocol handler initialized
[ 1.246516] IR JVC protocol handler initialized
[ 1.250583] IR Sony protocol handler initialized
[ 1.254732] IR RC5 (streamzap) protocol handler initialized
[ 1.259730] IR MCE Keyboard/mouse protocol handler initialized
[ 1.264969] IR LIRC bridge handler initialized
[ 1.269036] Linux video capture interface: v2.00
[ 1.273386] gspca: v2.13.0 registered
[ 1.276937] usbcore: registered new interface driver uvcvideo
[ 1.282096] USB Video Class driver (1.1.1)
[ 1.287343] device-mapper: uevent: version 1.0.3
[ 1.292336] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: dm-devel@redhat.com
[ 1.299964] Bluetooth: HCI UART driver ver 2.2
[ 1.303962] Bluetooth: Generic Bluetooth USB driver ver 0.6
[ 1.309282] usbcore: registered new interface driver btusb
[ 1.314427] mmcblk0: mmc0:0001 MMC04G 3.57 GiB
[ 1.318733] mmcblk0boot0: mmc0:0001 MMC04G partition 1 2.00 MiB
[ 1.324223] mmcblk0boot1: mmc0:0001 MMC04G partition 2 2.00 MiB
[ 1.330208] emmc_partition()
[ 1.333838] [emmc]Start_block=14336, block_count=1024
[ 1.338505] Start_block=15360, block_count=16384
[ 1.342666] Start_block=31744, block_count=8192
[ 1.346739] Start_block=39936, block_count=921600
[ 1.350977] Start_block=961536, block_count=614400
[ 1.355282] Start_block=1575936, block_count=122880
[ 1.359663] Start_block=1698816, block_count=32768
[ 1.364525] Start_block=1731584, block_count=16384
[ 1.368834] Start_block=1747968, block_count=102400
[ 1.373215] Start_block=1850368, block_count=5517312
[ 1.377674] Start_block=7367680, block_count=32768
[ 1.381975]
[ 1.383314] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11emmc_partition()
[ 1.394727] [emmc]Start_block=14336, block_count=1024
[ 1.399375] Start_block=15360, block_count=16384
[ 1.403525] Start_block=31744, block_count=8192
[ 1.407748] Start_block=39936, block_count=921600
[ 1.411977] Start_block=961536, block_count=614400
[ 1.416284] Start_block=1575936, block_count=122880
[ 1.420665] Start_block=1698816, block_count=32768
[ 1.425533] Start_block=1731584, block_count=16384
[ 1.429841] Start_block=1747968, block_count=102400
[ 1.434229] Start_block=1850368, block_count=5517312
[ 1.438689] Start_block=7367680, block_count=32768
[ 1.443014]
[ 1.444353] mmcblk0boot1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 1.449389] mmcblk0boot1: p1 start 14336 is beyond EOD, truncated
[ 1.455042] mmcblk0boot1: p2 start 15360 is beyond EOD, truncated
[ 1.460524] mmcblk0boot1: p3 start 31744 is beyond EOD, truncated
[ 1.466009] mmcblk0boot1: p4 start 39936 is beyond EOD, truncated
[ 1.471490] mmcblk0boot1: p5 start 961536 is beyond EOD, truncated
[ 1.477062] mmcblk0boot1: p6 start 1575936 is beyond EOD, truncated
[ 1.482697] mmcblk0boot1: p7 start 1698816 is beyond EOD, truncated
[ 1.488332] mmcblk0boot1: p8 start 1731584 is beyond EOD, truncated
[ 1.493968] mmcblk0boot1: p9 start 1747968 is beyond EOD, truncated
[ 1.499603] mmcblk0boot1: p10 start 1850368 is beyond EOD, truncated
[ 1.505329] mmcblk0boot1: p11 start 7367680 is beyond EOD, truncated
[ 1.512118] emmc_partition()
[ 1.515319] [emmc]Start_block=14336, block_count=1024
[ 1.519961] Start_block=15360, block_count=16384
[ 1.524143] Start_block=31744, block_count=8192
[ 1.528216] Start_block=39936, block_count=921600
[ 1.532442] Start_block=961536, block_count=614400
[ 1.536745] Start_block=1575936, block_count=122880
[ 1.541130] Start_block=1698816, block_count=32768
[ 1.545995] Start_block=1731584, block_count=16384
[ 1.550305] Start_block=1747968, block_count=102400
[ 1.554687] Start_block=1850368, block_count=5517312
[ 1.559145] Start_block=7367680, block_count=32768
[ 1.563447]
[ 1.564785] mmcblk0boot0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 1.569817] mmcblk0boot0: p1 start 14336 is beyond EOD, truncated
[ 1.575468] mmcblk0boot0: p2 start 15360 is beyond EOD, truncated
[ 1.580963] mmcblk0boot0: p3 start 31744 is beyond EOD, truncated
[ 1.586448] mmcblk0boot0: p4 start 39936 is beyond EOD, truncated
[ 1.591929] mmcblk0boot0: p5 start 961536 is beyond EOD, truncated
[ 1.597501] mmcblk0boot0: p6 start 1575936 is beyond EOD, truncated
[ 1.603136] mmcblk0boot0: p7 start 1698816 is beyond EOD, truncated
[ 1.608771] mmcblk0boot0: p8 start 1731584 is beyond EOD, truncated
[ 1.614407] mmcblk0boot0: p9 start 1747968 is beyond EOD, truncated
[ 1.620042] mmcblk0boot0: p10 start 1850368 is beyond EOD, truncated
[ 1.625756] mmcblk0boot0: p11 start 7367680 is beyond EOD, truncated
[ 1.632355] [version_2013_7_30]
[ 1.635196] This is hidraw init for linux source with original trylock patch!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[ 1.648731] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.654122] usbcore: registered new interface driver usbhid
[ 1.659125] usbhid: USB HID core driver
[ 1.663458] logger: created 256K log 'log_main'
[ 1.667835] logger: created 256K log 'log_events'
[ 1.672404] logger: created 256K log 'log_radio'
[ 1.676868] logger: created 256K log 'log_system'
[ 1.682377] Mstar_emac: [ PHY Addr ] ==> :0
[ 1.686201] Mstar_emac: alloRAM_VA_BASE = 0xEFA00000 alloRAM_PA_BASE= 0x38A00000 alloRAM_SIZE= 0x100000
[ 1.695450] RBQP_BASE = 38a04000
[ 1.699579] >> [sdmmc] ms_sdmmc Driver Initializing...
[ 1.705097] >> [sdmmc_0] CDZ use Ext GPIO IRQ: 33
[ 1.705109] >> [sdmmc_0] Get CD => (0)
[ 1.712682] >> [sdmmc_0] Probe Devices...(Ret:0)
[ 1.720279] [0000000350][MAD_ALSA][001709] <6>Linux Kernel Version : 3.1.10
[ 1.726879] [0000000352][MAD_ALSA][001710] <6>ALSA Kernel Version : 1.0.24
[ 1.733482] [0000000354][MAD_ALSA][001711] <6>MStar ALSA Driver Version : 3.1.5
[ 1.740345] [0000000355][MAD_ALSA][001712] <6>Initiate MStar ALSA driver engine
[ 1.747210] [0000000357][MAD_ALSA][001581] <6>Go to register MStar ALSA driver
[ 1.756328] [0000000359][MAD_ALSA][001645] <6>MStar ALSA driver is registered to slot 0
[ 1.764109] [0000000361][MAD_ALSA][001429] <6>Initiate MStar ALSA core driver (customized)
[ 1.771902] [0000000363][MAD_ALSA][000279] <6>Hal Driver 'MAD NIKE' is hooked.
[ 1.778700] [0000000365][MAD_ALSA][000280] <6>MStar Core Version : 3.1.7
[ 1.785614] [mod_pwm_init][190] mod_pwm_init is invoked
[ 1.790317] blcr: vmadump: (from bproc-BPROC_VERSION) Erik Hendriks <erik@hendriks.cx>
[ 1.797415] blcr: vmadump: Modified for blcr 0.8.5 <http://ftg.lbl.gov/checkpoint>
[ 1.804197] blcr: Berkeley Lab Checkpoint/Restart (BLCR) module version 0.8.5.
[ 1.810696] blcr: Parameter cr_io_max = 0x4000000
[ 1.815074] blcr: Supports kernel interface version 0.10.3.
[ 1.820230] blcr: Supports context file format versions 8 though 9.
[ 1.826007] blcr: http://ftg.lbl.gov/checkpoint
[ 1.836797] usbcore: registered new interface driver snd-usb-audio
[ 1.842353] ALSA device list:
[ 1.845027] #0: MStar MPEG Audio Decoder No.00
[ 1.850324] oprofile: using timer interrupt.
[ 1.854301] Netfilter messages via NETLINK v0.30.
[ 1.858631] nf_conntrack version 0.5.0 (11805 buckets, 47220 max)
[ 1.864812] ctnetlink v0.93: registering with nfnetlink.
[ 1.869688] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 1.875931] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 1.881857] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.886821] TCP cubic registered
[ 1.891497] NET: Registered protocol family 10
[ 1.896603] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.901527] IPv6 over IPv4 tunneling driver
[ 1.907473] NET: Registered protocol family 17
[ 1.911573] NET: Registered protocol family 15
[ 1.915708] Bridge firewalling registered
[ 1.919532] Bluetooth: RFCOMM TTY layer initialized
[ 1.923942] Bluetooth: RFCOMM socket layer initialized
[ 1.928563] Bluetooth: RFCOMM ver 1.11
[ 1.931937] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.936709] Bluetooth: BNEP filters: protocol multicast
[ 1.941403] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.946995] 8021q: 802.1Q VLAN Support v1.8
[ 1.950804] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 3
[ 1.960173] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 1.966044] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) Setup!!!
[ 1.972317] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[ 1.977744] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[ 1.982669] [35mFunction = n_tty_open, Line = 1897, [KDEBUGD] enter : NA[m
[ 1.990860] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[ 2.001062] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[ 2.151082] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) Setup!!!
[ 2.157368] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[ 2.162684] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[ 2.167607] [35mFunction = n_tty_open, Line = 1897, [KDEBUGD] enter : NA[m
[ 2.174164] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[ 2.180778] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) Setup!!!
[ 2.187035] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[ 2.192349] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[ 2.197274] [35mFunction = n_tty_open, Line = 1897, [KDEBUGD] enter : NA[m
A N D R O I D
[ 2.212937] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[ 2.256980] fs_mgr: Warning: unknown flag block_validity
[ 2.261770] fs_mgr: Warning: unknown flag nodiscard
[ 2.266158] fs_mgr: Warning: unknown flag data=ordered
[ 2.270777] fs_mgr: Warning: unknown flag journal_checksum
[ 2.275723] fs_mgr: Warning: unknown flag block_validity
[ 2.280497] fs_mgr: Warning: unknown flag nodiscard
[ 2.284884] fs_mgr: Warning: unknown flag data=ordered
[ 2.289533] fs_mgr: Warning: unknown flag journal_checksum
[ 2.294517] fs_mgr: Warning: unknown flag block_validity
[ 2.299293] fs_mgr: Warning: unknown flag nodiscard
[ 2.303679] fs_mgr: Warning: unknown flag data=ordered
[ 2.308334] fs_mgr: Warning: unknown flag journal_checksum
[ 2.313280] fs_mgr: Warning: unknown flag block_validity
[ 2.318054] fs_mgr: Warning: unknown flag nodiscard
[ 2.322441] fs_mgr: Warning: unknown flag data=ordered
[ 2.327059] fs_mgr: Warning: unknown flag journal_checksum
[ 2.331999] fs_mgr: Warning: unknown flag block_validity
[ 2.336772] fs_mgr: Warning: unknown flag nodiscard
[ 2.341158] fs_mgr: Warning: unknown flag data=ordered
[ 2.345776] fs_mgr: Warning: unknown flag journal_checksum
[ 2.359993] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
[ 2.449485] EXT4-fs (mmcblk0p5): recovery complete
[ 2.454071] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.462765] EXT4-fs (mmcblk0p10): VFS: Can't find ext4 filesystem
[ 2.488878] fs_mgr: Cannot mount filesystem on /dev/block/platform/mstar_mci.0/by-name/userdata at /data
[ 2.497420] init: fs_mgr_mount_all returned an error
[ 2.532499] UMP: UMP device driver loaded
[ 2.610739] Mali: Mali device driver loaded
[ 2.630156] mdrv_gpio: exports duplicate symbol MDrv_GPIO_Get_LedRedInv (owned by kernel)
[ 2.663273] =====MDrv_IR_Input_Init====
[ 2.666760] Registered IR keymap rc-changhong-tv
[ 2.671673] input: ChangHong Smart TV IR Receiver as /devices/virtual/rc/rc0/input0
[ 2.679173] rc0: ChangHong Smart TV IR Receiver as /devices/virtual/rc/rc0
[ 2.686086] input: MCE IR Keyboard/Mouse (ir) as /devices/virtual/input/input1
[ 2.694082] rc rc0: lirc_dev: driver ir-lirc-codec (ir) registered at minor = 0
[ 2.700771] [KEY_INPUT]:key_dispatch thread start
[ 2.717845] mod_iic_init is invoked
[ 2.726861] init: Unable to open persistent property directory /data/property errno: 2
[ 2.738375] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) Setup!!!
[ 2.744704] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[ 2.750036] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[ 2.754975] [35mFunction = n_tty_open, Line = 1897, [KDEBUGD] enter : NA[m
shell@android:/ $ [ 2.842809] init: I read console
[ 2.842816] ===
[ 2.855175] init: =================app store running======================
[ 2.970127] init: not com.changhong.appstore.apk, or sdk appstore changed !
[ 2.976510] init: so copy /system/apk/com.changhong.appstore.apk to /data/app
[ 2.991614] init: I read console
[ 2.991621] ===
[ 3.003594] init: ===============check tent================
[ 3.010796] init: the nv is 0
[ 3.013528] init: the cv is 1
[ 3.023782] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[ 3.264869] ~!~current->flags = 400004 , pid = 1017 , tgid = 1017 , proc=virtualkeypad
[ 3.265733] input: Virtual Mouse as /devices/virtual/input/input2
[ 3.267826] input: Virtual Keyboard as /devices/virtual/input/input3
[ 3.269046] input: Virtual TouchScreen as /devices/virtual/input/input4
[ 3.270096] input: Virtual AccSensor as /devices/virtual/input/input5
[ 3.271231] input: Virtual MagneticField as /devices/virtual/input/input6
[ 3.272294] input: Virtual OriSensor as /devices/virtual/input/input7
[ 3.273368] input: Virtual Gyroscope as /devices/virtual/input/input8
[ 3.301864] btusb: module is already loaded
[ 4.293100] [0000000994][MAD_ALSA][000553] <6>Open 'subdevice #0'(0) of MStar ALSA playback device
[ 4.301678] [0000000996][MAD_ALSA][000402] <6>Open software timer.
[ 4.307690] [0000000997][MAD_ALSA][000708] <6>Configure PCM HW resource
[ 4.318454] ~!~current->flags = 400444 , pid = 1569 , tgid = 1009 , proc=SurfaceFlinger
[ 4.330434] init: untracked pid 1010 exited
[ 4.358802] [0000001010][MAD_ALSA][000553] <6>Open 'subdevice #0'(0) of MStar ALSA playback device
[ 4.369025] [0000001013][MAD_ALSA][000402] <6>Open software timer.
[ 4.375233] [0000001014][MAD_ALSA][000708] <6>Configure PCM HW resource
[ 4.651064] request_suspend_state: wakeup (3->0) at 4334238837 (1970-01-01 00:00:04.331558396 UTC)
[ 4.661566] init: untracked pid 1007 exited
[ 4.664606] [0000001086][MAD_ALSA][000719] <6>Free PCM HW resource
[ 4.664630] [0000001086][MAD_ALSA][000635] <6>Close 'subdevice #0'(0) of MStar ALSA playback device
[ 4.664703] [0000001086][MAD_ALSA][000424] <6>Close software timer.
[ 4.667082] [0000001086][MAD_ALSA][000398] <6>Exit MStar PCM Playback1 engine
[ 4.669502] [0000001086][MAD_ALSA][000719] <6>Free PCM HW resource
[ 4.669521] [0000001086][MAD_ALSA][000635] <6>Close 'subdevice #0'(0) of MStar ALSA playback device
[ 4.669579] [0000001086][MAD_ALSA][000424] <6>Close software timer.
[ 4.712856] init: untracked pid 1012 exited
[ 4.984375] [0000001166][MAD_ALSA][000553] <6>Open 'subdevice #0'(0) of MStar ALSA playback device
[ 4.992865] [0000001169][MAD_ALSA][000402] <6>Open software timer.
[ 4.998904] [0000001170][MAD_ALSA][000708] <6>Configure PCM HW resource
[ 5.021531] [0000001176][MAD_ALSA][000553] <6>Open 'subdevice #0'(0) of MStar ALSA playback device
[ 5.030019] [0000001178][MAD_ALSA][000402] <6>Open software timer.
[ 5.036022] [0000001179][MAD_ALSA][000708] <6>Configure PCM HW resource
[ 8.167039] ~!~current->flags = 400444 , pid = 2426 , tgid = 2422 , proc=SurfaceFlinger
[ 8.436684] request_suspend_state: wakeup (0->0) at 8119859862 (1970-01-01 00:00:08.117179878 UTC)
[ 8.449712] [0000002033][MAD_ALSA][000719] <6>Free PCM HW resource
[ 8.452381] init: untracked pid 1881 exited
[ 8.459407] [0000002035][MAD_ALSA][000635] <6>Close 'subdevice #0'(0) of MStar ALSA playback device
[ 8.467961] [0000002037][MAD_ALSA][000424] <6>Close software timer.
[ 8.476418] [0000002039][MAD_ALSA][000398] <6>Exit MStar PCM Playback1 engine
[ 8.485536] [0000002042][MAD_ALSA][000719] <6>Free PCM HW resource
[ 8.491443] [0000002043][MAD_ALSA][000635] <6>Close 'subdevice #0'(0) of MStar ALSA playback device
[ 8.499960] [0000002045][MAD_ALSA][000424] <6>Close software timer.
[ 8.506274] init: untracked pid 1880 exited
[ 8.775922] [0000002114][MAD_ALSA][000553] <6>Open 'subdevice #0'(0) of MStar ALSA playback device
[ 8.784386] [0000002116][MAD_ALSA][000402] <6>Open software timer.
[ 8.790429] [0000002118][MAD_ALSA][000708] <6>Configure PCM HW resource
[ 8.812899] [0000002124][MAD_ALSA][000553] <6>Open 'subdevice #0'(0) of MStar ALSA playback device
[ 8.821377] [0000002126][MAD_ALSA][000402] <6>Open software timer.
[ 8.827387] [0000002127][MAD_ALSA][000708] <6>Configure PCM HW resource
[ 9.260383] input: CyweeVirtualMouse as /devices/virtual/input/input9
[ 12.963153] ~!~current->flags = 400444 , pid = 2976 , tgid = 2971 , proc=SurfaceFlinger
[ 13.011789] init: untracked pid 2972 exited
