查看: 1603|回复: 3
这个打印信息是什么问题?
发表于: 2021-5-15 15:22:37
小米L32M5-AZ,开机定屏,换EMMC故障不变,数据没有问题
打印信息如下:
2021-5-15, 14:25:3
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
TXL:BL1:1ef924:56431c;FEAT:ADFC718COC:0;RCY:0;EMMC:0;READ:0;0.0;CHK:0;
TE: 52364
BL2 Built : 12:59:51, Jan  3 2018.
txl g3eab014 - xiaobo.gu@droid12
Board ID = 2
set vcck to 1100 mv
set vddee to 1000 mv
DRAM reset...
init panel power
board_id = 2
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR4 chl: Rank0+1 @ 792MHz - FAIL
DDR4 chl: Rank0 @ 792MHz - FAIL
DDR4 chl: Rank0 16bit @ 792MHz
bist_test rank: 0 21 00 42 34 15 54 21 00 43 39 1b 58 2f 2f 2f 2f 2f 2f 2f 2f 2f 2f 2f 2f 664   - PASS
Rank0: 1024MB(auto)-2T-18
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000
Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600
Load bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x0001b400
Load bl33 from eMMC, src: 0x0003c200, des: 0x01000000, size: 0x000e7c00
NOTICE:  BL3-1: v1.0(debug):e46962f
NOTICE:  BL3-1: Built : 17:20:18, Apr 20 2017
aml log : bl31 normal boot !
[Image: txl_v1.1.3166-87ff079 2018-01-02 17:24:45 jianxin.pan@droid06]
OPS=0x22
6a 6d 14 e7 5 35 8a 5c c9 4a 27 ce [0.601666 Inits done]
secure task start!
high task start!
low task start!
INFO:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-ge7f05cc (Jul 02 2018 - 12:35:38), Build: jenkins-Matrix_release-1266
DRAM:  1 GiB
Relocation Offset is: 36e8c000
register usb cfg[0][1] = 0000000037f635b8
gpio: pin GPIOH_3 (gpio 31) value is 1
gpio: pin GPIOH_2 (gpio 30) value is 1
gpio: pin GPIODV_5 (gpio 21) value is 1
gpio: pin GPIOZ_1 (gpio 39) value is 1
gpio: pin GPIOAO_2 (gpio 83) value is 1
gpio: pin GPIOAO_11 (gpio 92) value is 1
MMC:   aml_priv->desc_buf = 0x0000000033e8cd50
aml_priv->desc_buf = 0x0000000033e8eee0
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
[mmc_init] mmc init success
mmc read lba=0x14000, blocks=0x400
      Amlogic multi-dtb tool
      Multi dtb detected
txl_mt_950-1g
      Multi dtb tool version: v2 .
      Support 5 dtbs.
        aml_dt soc: txl platform: mt variant: 950-1g
        dtb 0 soc: txl   plat: mt   vari: 950-1g
        dtb 1 soc: txl   plat: mt   vari: cvte
        dtb 2 soc: txl   plat: mt   vari: magnolia
        dtb 3 soc: txl   plat: mt   vari: mi
        dtb 4 soc: txl   plat: mt-india   vari: hw-43
      Find match dtb: 0
start dts,buffer=0000000033e915f0,dt_addr=0000000033e91df0
parts: 13
00:      logo        0000000000400000 1
01:  recovery        0000000001000000 1
02:     param        0000000002000000 2
03:     crypt        0000000001000000 1
04:  cri_data        0000000000800000 2
05:    tvinfo        0000000000a00000 4
06:     panic        0000000000400000 4
07:   persist        0000000000800000 4
08:      misc        0000000001000000 1
09:      boot        0000000001400000 1
10:    system        0000000040000000 1
11:     cache        0000000010000000 2
12:      data        ffffffffffffffff 4
get_dtb_struct: Get emmc dtb OK!
overide_emmc_partition_table: overide cache
[mmc_get_partition_table] skip partition cache.
Partition table get from SPL is :
        name                        offset              size              flag
   0: bootloader                         0            400000                  0
   1: reserved                     2400000           4000000                  0
   2: cache                        6c00000          10000000                  2
   3: env                         17400000            800000                  0
   4: logo                        18400000            400000                  1
   5: recovery                    19000000           1000000                  1
   6: param                       1a800000           2000000                  2
   7: crypt                       1d000000           1000000                  1
   8: cri_data                    1e800000            800000                  2
   9: tvinfo                      1f800000            a00000                  4
  10: panic                       20a00000            400000                  4
  11: persist                     21600000            800000                  4
  12: misc                        22600000           1000000                  1
  13: boot                        23e00000           1400000                  1
  14: system                      25a00000          40000000                  1
  15: data                        66200000          85e00000                  4
mmc read lba=0x12000, blocks=0x2
mmc read lba=0x12002, blocks=0x2
mmc_read_partition_tbl: mmc read partition OK!
eMMC/TSD partition table have been checked OK!
mmc env offset: 0x17400000
In:    serial
Out:   serial
Err:   serial
reboot_mode=cold_boot
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
read emmc dtb
      Multi dtb detected
txl_mt_950-1g
      Support 5 dtbs.
      Find match dtb: 0
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[BL31]: tee size: 0
panel_detect: panel_id = 58, panel_type = lvds_6
Saving Environment to aml-storage...
Writing to MMC(1)... done
vpu: clk_level in dts: 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpp: vpp_init
lcd: no lcd_debug_print flag
lcd: no lcd_debug_test flag
lcd: detect mode: tv, key_valid: 0
lcd: load config from dts
lcd: use panel_type=lvds_6
lcd: set phy vswing=2, preemphasis=0
lcd: bl: name: backlight_1, method: 1
lcd: bl: aml_bl_power_ctrl: 0
lcd: vx1_filter_en: 0
lcd: vx1_filter_time: 20
lcd: vx1_filter_cnt: 6
lcd: vx1_filter_retry_cnt: 2
lcd: vx1_filter_retry_delay: 100
Net:   dwmac.c9410000
efuse_pw_en: 0x3
WARNING! efuse bits is disabled
Enable A53 JTAG to EE
ffu update start
[audio] use codec ad82584!
wipe_data=successful
wipe_cache=successful
upgrade_step=2
amlkey_init() 71: already init!
[BL31]: tee size: 0
[KM]Error:f[key_manage_query_size]L507:key[assm_sn] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[mac_bt] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[mac] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[cp_type] not programed yet
mwm 0xc8837004:[0x   aa203] with [0x   ea203] ok
mwm 0xc883740c:[0x 3e3b744] with [0x 3e3b764] ok
mwm 0xc8837010:[0x   c0101] with [0x   c8101] ok
mwm 0xc8837010:[0x   c8101] with [0x  128101] ok
IR init done!
InUsbBurn
noSof
disable bluetooth
[KM]Error:f[key_manage_query_size]L507:key[factory_power_mode] not programed yet
Hit Enter or space or Ctrl+C key to stop autoboot -- :  1  0
[OSD]load fb addr from dts
[OSD]failed to get fb addr for logo
[OSD]use default fb_addr parameters
[OSD]fb_addr for logo: 0x3d800000
[CANVAS]canvas init
[CANVAS]addr=0x3d800000 width=3840, height=1440
lcd: enable: 720p-hfreq, lvds, 1366x768@60.0Hz
lcd: tv driver init(ver: 20170810)
lcd: lcd_pll_wait_lock: pll_lock=1, wait_loop=1
lcd: set pll spread spectrum: 3, +/-0.9%
lcd: bl: set level: 100, last level: 0
lcd: bl: aml_bl_power_ctrl: 1
ee_gate_off ...
## Booting Android Image at 0x01080000 ...
reloc_addr =33f11810
copy done
      Single dtb detected
load dtb from 0x1000000 ......
   Uncompressing Kernel Image ... OK
   kernel loaded at 0x01080000, end = 0x02029610
   Loading Ramdisk to 33ceb000, end 33e7a346 ... OK
   Loading Device Tree to 000000001fff0000, end 000000001ffff032 ... OK
Starting kernel ...
uboot time: 3884956 us
[    0.000000@0] [TV][AMAUDIO] platform info:txl_matrix
domain-0 init dvfs: 4
[    0.218115@0] genirq: Setting trigger mode 8 for irq 249 failed (gic_set_type+0x0/0xbc)
[    0.744128@0] amlogic-new-usb3 d0078080.usb3phy: This phy has no usb port
[    0.755101@0] wakeup_reason: 0x2
[    0.756855@0] genirq: Setting trigger mode 8 for irq 249 failed (gic_set_type+0x0/0xbc)
[    0.799287@0] get_storage_dev return 1
[    0.888003@1] PPMGRDRV: err: ppmgr_driver_probe called
[    0.888704@1] emmc: retry, rx_phase 0 -> 1
[    1.103321@1] amlvideo2 probe called
INFO:    HDCP22 rx key read fail!
INFO:    pkf 0
INFO:    duk 0
INFO:    end set
[    1.128657@1] aud pll test OK
[    1.135726@1] DVB:async fifo 0 buf size 524288, flush size 262144
[    1.137018@1] cannot find tuner0 driver: si2151_tuner
[    1.156245@1] aml_snd_card_g9tv aml_g9tv_snd.50: parse aml aux device error -1
[    1.157806@1] aml_snd_card_g9tv aml_g9tv_snd.50: Can't probe snd_soc_card
[    1.881363@1] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[  [    2.291909@3] init: waitpid failed: No child processes
[    2.295936@3] init: /init.amlogic.rc: 433: invalid command 'e2fsck'
[    2.298351@3] init: could not import file 'init.amlogic.wifi.rc' from '/init.amlogic.rc'
[    2.305768@3] init: could not import file 'init.mtk.rc' from '/init.amlogic.rc'
[    2.313176@3] init: SELinux: Could not get canonical path /adb_keys restorecon: No such file or directory.
[    3.346973@2] WARNING: Running kernel does not match configured kernel headers the driver was built with!  The driver needs to be rebuilt with the correct kernel headers!
[    3.386197@2] WARNING: Running kernel does not match configured kernel headers the driver was built with!  The driver needs to be rebuilt with the correct kernel headers!
[    3.405525@2] init: property_set("ro.hwui.texture_cache_size", "64.0f" failed
[    3.408298@2] init: /recovery not specified in fstab
[    3.565933@2] dig: dig start!
[    3.577104@0] init: cannot find '/sbin/healthd', disabling 'healthd'
[    3.609052@1] SysRq : Changing Loglevel
[    3.609091@1] Loglevel set to 4
[    3.626038@1] init: cannot find '/system/bin/remotecfg', disabling 'remotecfg'
[    3.627752@1] init: cannot find '/system/bin/pppoe_wrapper', disabling 'pppoe_wrapper'
[    3.883685@1] zsmalloc no cma shrinker has been registered.
[    3.934726@1] init: cannot find '/system/xbin/perfprofd', disabling 'perfprofd'
[    3.936905@1] init: cannot find '/system/bin/logo_retriever.sh', disabling 'logo_retriever'
[    4.459064@3]  key_unify_init() already inited!
[    4.459201@3] amlkey_size() 244: ret 1
[    4.461686@3] read_show() 1029: key hdcp22_rx_fw may not burned yet!
[    5.417501@0] pgd = ffffffc02e704000
[    5.417524@0] [fffffffd] *pgd=000000002ff9a003, *pmd=000000002ac0f003, *pte=0000000000000000
[    8.990683@1] pgd = ffffffc028c40000
[    8.990704@1] [fffffffd] *pgd=0000000027cec003, *pmd=0000000028a44003, *pte=0000000000000000
[   13.637869@3] pgd = ffffffc0177a6000
[   13.637891@3] [fffffffd] *pgd=0000000017795003, *pmd=00000000177c4003, *pte=0000000000000000
[   18.659604@0] pgd = ffffffc016cbf000
[   18.659633@0] [fffffffd] *pgd=0000000016cc2003, *pmd=00000000177ad003, *pte=0000000000000000
[   24.225273@1] pgd = ffffffc0177a4000
[   24.225297@1] [fffffffd] *pgd=0000000017780003, *pmd=0000000017789003, *pte=0000000000000000
[   28.797415@1] pgd = ffffffc016ccd000
[   28.797440@1] [fffffffd] *pgd=00000000177a4003, *pmd=0000000017786003, *pte=0000000000000000
[   34.348397@0] pgd = ffffffc016ce1000
[   34.348418@0] [fffffffd] *pgd=0000000017781003, *pmd=0000000016cfb003, *pte=0000000000000000
[   38.895410@1] pgd = ffffffc016cf5000
[   38.895443@1] [fffffffd] *pgd=0000000016ce3003, *pmd=0000000017797003, *pte=0000000000000000
[   44.453427@0] pgd = ffffffc016cc5000
[   44.453448@0] [fffffffd] *pgd=0000000016ce5003, *pmd=0000000016cb8003, *pte=0000000000000000
[   49.001315@0] pgd = ffffffc016ce4000
[   49.001336@0] [fffffffd] *pgd=00000000177c0003, *pmd=0000000017724003, *pte=0000000000000000
[   54.548959@1] pgd = ffffffc016cdf000
[   54.548981@1] [fffffffd] *pgd=0000000017783003, *pmd=0000000017724003, *pte=0000000000000000
[   60.092888@1] pgd = ffffffc02ac7a000
[   60.092915@1] [fffffffd] *pgd=00000000177c0003, *pmd=0000000016ca1003, *pte=0000000000000000
[   64.636853@0] pgd = ffffffc016ca4000
[   64.636874@0] [fffffffd] *pgd=0000000016cf4003, *pmd=00000000177a4003, *pte=0000000000000000
小米的机器建议先三清再进行下一步操作。  发表于 2021-5-16 08:41
发表于: 2021-5-16 00:13:51
警告:正在运行的内核与生成驱动程序时使用的已配置内核头不匹配!驱动程序需要用正确的内核头来重建!
HDCP22 rx密钥读取失败
以上是网络翻译可能存在错误
GMT+8, 2024-12-24 08:47 , Processed in 0.057855 sec., 11 queries .
