用户名  找回密码
查看: 1477|回复: 2
PLEASE ADD THIS NAND FLASH
发表于: 2021-5-3 14:00:36
PLEASE ADMINISTRATORS AND MANUFACTURERS OF RT809H, ADD THIS NAND FLASH
I HAVE RECEIVED THIS MESSAGE AND IT TELLS ME TO POST IT ON THE FORUM ..
006:  Chip pins contact is detected OK.
007:  TotalPageNum: 0x100,PageNumInBlock: 64,PageSize: 0
008:  Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box.
009:  The currently selected:NAND_AUTO
010:  You have selected the GENEREAL MODE, it will ignore the ID verification and using compatible with most manufacturer's General algorithm.
011:  Download device programming algorithm......
012:  Algo update OK
013:  >------------------------------------OK---------------------------------------<
014:  Point "read" will pop up "save" dialog box, "write" will pop up the "open" dialog box.
015:  The currently selected:NAND_AUTO
016:  You have selected the GENEREAL MODE, it will ignore the ID verification and using compatible with most manufacturer's General algorithm.
017:  Download device programming algorithm......
018:  Algo update OK
019:  >------------------------------------OK---------------------------------------<
020:  VCC: 1.8V
021:  TotalPageNum: 0x100,PageNumInBlock: 64,PageSize: 2112
022:  NewMFR: 0x7F , ID: 0x7F7F7F7F7F7F7F7F, 3.3V, CE:1, 16bit, Col: 2, Row: 2, TLC.
023:  PageSize:8192B, OobSize:256B, BlockSize:512KB, ChipSize:0MB.
024:  Recognition of the NAND parameters is special£¬Please submit to WWW.IFIX.NET.CN to add this model.
举报
发表于: 2021-6-11 09:23:04
看来英语小白是无法搞维修了
举报
GMT+8, 2025-4-13 20:13 , Processed in 0.057911 sec., 11 queries .
