海信55E3A.量产软件。写入自动绑定。直接开机。
第一次开机一定不要接入网络。不然后悔 。
第二次开机按电视机开机键插上电源。等到开机画面出厂出现初始化、电视正常后回复出厂设置。完全正常才可以联网。切记
我把闪存换成了16G的测试。打印信息显示16G.可惜是系统不认。系统显示8G
COM6, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
m
armfwNOTICE: BL3-1: v1.1(debug):e9dbd72
NOTICE: BL3-1: Built : 14:07:05, Mar 18 2017
INFO: BL3-1: Initializing runtime services
INFO: BL3-1: Initializing BL3-2
NOTICE: [Ian] opteed_synchronous_sp_entry 103 20103750
INNFO PP1 PPeeaaiin oor LL3eeii to eeuueewwordd
IINF:: CCUU Nxxt iaageaaddrsss = 0x3df00164
INFO: PUU Nxx mmgge spsr = xxdd3
INFO: BL3-1: Preparing for EL3 exit to normal world
INFO: BL3-1: Next image address = 0x201009bc
INFO: BL3-1: Next image spsr = 0x1d3
INFO: BIN1_32bit mode
INFO: R1 491bc02d16f80f18
INFO: R2 cf402d15692c315b
INFO: R3 a3ca10bf656e1acf
U
Relocation Offset is: 01700000
hs>>power-on
[AT][MB][start ub][780]
U-Boot 2011.06-00555-gb8175ae-dirty (May 26 2019 - 03:51:22)
msIR_Initialize
[35mFunction = SYSOpen, Line = 1071, current resource pri_shm content is: 0[m
[35mFunction = SYSOpen, Line = 1090, [SYS INFO] OPEN INSTANCE...[m
create instance at 2B4F3C50 with private size 128 bytes at 2B4F3C98
[MIU INFO] miu opencreate instance at 2B4F3D20 with private size 80 bytes at 2B4F3D68
create instance at 2B4F3DC0 with private size 52 bytes at 2B4F3E08
create instance at 2B4F3E40 with private size 52 bytes at 2B4F3E88
uboot held at [2B2DDF60~2C500000],size=012220A0
CPU : << MStar >>#
Board: BD_MST123B_10A_MOONEY
DRAM: 197 MiB
Now running in RAM - U-Boot at: 2BB00000
eMMC: HS400 200MHz
eMMC 14.67 GB [1D59FF8h]
eMMC SLC mmc type 0%-10% device life time used
eMMC MLC mmc type undifined
eMMC pre_eol_info normal
UART BUS OFF!!
