查看: 993|回复: 2
求助:小米打印信息
发表于: 2021-3-18 21:02:05
2021-3-18, 20:38:27
COM4, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15, Printed by RT809H:
TXL:BL1:1ef924:56431c;FEAT:ADFC718COC:0;RCY:0;EMMC:0;READ:0;0.0;CHK:0;
TE: 53235
BL2 Built : 12:59:51, Jan  3 2018.
txl g3eab014 - xiaobo.gu@droid12
Board ID = 3
set vcck to 1100 mv
set vddee to 1000 mv
DRAM reset...
init panel power
board_id = 3
CPU clk: 1200MHz
DQS-corr enabled
DDR scramble enabled
DDR4 chl: Rank0+1 @ 792MHz - FAIL
DDR4 chl: Rank0 @ 792MHz - FAIL
DDR4 chl: Rank0 16bit @ 792MHz
bist_test rank: 0 21 00 42 36 17 56 23 00 46 39 1b 58 30 30 30 30 30 30 30 30 30 30 30 30 657   - PASS
Rank0: 1024MB(auto)-2T-18
AddrBus test pass!
-s
Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x00004000
Load bl30 from eMMC, src: 0x00010200, des: 0x01100000, size: 0x0000d600
Load bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x0001b400
Load bl33 from eMMC, src: 0x0003c200, des: 0x01000000, size: 0x000e7c00
NOTICE:  BL3-1: v1.0(debug):e46962f
NOTICE:  BL3-1: Built : 17:20:18, Apr 20 2017
aml log : bl31 normal boot !
[Image: txl_v1.1.3166-87ff079 2018-01-02 17:24:45 jianxin.pan@droid06]
OPS=0x22
6a 6d 14 e7 5 35 8a 5c c9 4a 27 ce [0.601870 Inits done]
secure task start!
high task start!
low task start!
INFO:    BL3-1: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL3-1: Preparing for EL3 exit to normal world
INFO:    BL3-1: Next image address = 0x1000000
INFO:    BL3-1: Next image spsr = 0x3c9
U-Boot 2015.01-ge7f05cc (Jul 02 2018 - 12:35:38), Build: jenkins-Matrix_release-1266
DRAM:  1 GiB
Relocation Offset is: 36e8c000
register usb cfg[0][1] = 0000000037f635b8
gpio: pin GPIOH_3 (gpio 31) value is 1
gpio: pin GPIOH_2 (gpio 30) value is 1
gpio: pin GPIODV_5 (gpio 21) value is 1
gpio: pin GPIOZ_1 (gpio 39) value is 1
gpio: pin GPIOAO_2 (gpio 83) value is 1
gpio: pin GPIOAO_11 (gpio 92) value is 1
MMC:   aml_priv->desc_buf = 0x0000000033e8cd50
aml_priv->desc_buf = 0x0000000033e8eee0
SDIO Port B: 0, SDIO Port C: 1
emmc/sd response timeout, cmd8, status=0x1ff2800
emmc/sd response timeout, cmd55, status=0x1ff2800
[mmc_init] mmc init success
mmc read lba=0x14000, blocks=0x400
      Amlogic multi-dtb tool
      Multi dtb detected
txl_mt_950-1g
      Multi dtb tool version: v2 .
      Support 5 dtbs.
        aml_dt soc: txl platform: mt variant: 950-1g
        dtb 0 soc: txl   plat: mt   vari: 950-1g
        dtb 1 soc: txl   plat: mt   vari: cvte
        dtb 2 soc: txl   plat: mt   vari: magnolia
        dtb 3 soc: txl   plat: mt   vari: mi
        dtb 4 soc: txl   plat: mt-india   vari: hw-43
      Find match dtb: 0
start dts,buffer=0000000033e915f0,dt_addr=0000000033e91df0
parts: 13
00:      logo        0000000000400000 1
01:  recovery        0000000001000000 1
02:     param        0000000002000000 2
03:     crypt        0000000001000000 1
04:  cri_data        0000000000800000 2
05:    tvinfo        0000000000a00000 4
06:     panic        0000000000400000 4
07:   persist        0000000000800000 4
08:      misc        0000000001000000 1
09:      boot        0000000001400000 1
10:    system        0000000040000000 1
11:     cache        0000000010000000 2
12:      data        ffffffffffffffff 4
get_dtb_struct: Get emmc dtb OK!
overide_emmc_partition_table: overide cache
[mmc_get_partition_table] skip partition cache.
Partition table get from SPL is :
        name                        offset              size              flag
   0: bootloader                         0            400000                  0
   1: reserved                     2400000           4000000                  0
   2: cache                        6c00000          10000000                  2
   3: env                         17400000            800000                  0
   4: logo                        18400000            400000                  1
   5: recovery                    19000000           1000000                  1
   6: param                       1a800000           2000000                  2
   7: crypt                       1d000000           1000000                  1
   8: cri_data                    1e800000            800000                  2
   9: tvinfo                      1f800000            a00000                  4
  10: panic                       20a00000            400000                  4
  11: persist                     21600000            800000                  4
  12: misc                        22600000           1000000                  1
  13: boot                        23e00000           1400000                  1
  14: system                      25a00000          40000000                  1
  15: data                        66200000          85e00000                  4
mmc read lba=0x12000, blocks=0x2
mmc read lba=0x12002, blocks=0x2
mmc_read_partition_tbl: mmc read partition OK!
eMMC/TSD partition table have been checked OK!
mmc env offset: 0x17400000
In:    serial
Out:   serial
Err:   serial
reboot_mode=cold_boot
[store]To run cmd[emmc dtb_read 0x1000000 0x40000]
read emmc dtb
      Multi dtb detected
txl_mt_950-1g
      Support 5 dtbs.
      Find match dtb: 0
amlkey_init() enter!
[EFUSE_MSG]keynum is 4
[BL31]: tee size: 0
panel_detect: panel_id = 58, panel_type = lvds_6
Saving Environment to aml-storage...
Writing to MMC(1)... done
vpu: clk_level in dts: 7
vpu: set clk: 666667000Hz, readback: 666660000Hz(0x300)
vpp: vpp_init
lcd: no lcd_debug_print flag
lcd: no lcd_debug_test flag
lcd: detect mode: tv, key_valid: 0
lcd: load config from dts
lcd: use panel_type=lvds_6
lcd: set phy vswing=2, preemphasis=0
lcd: bl: name: backlight_1, method: 1
lcd: bl: aml_bl_power_ctrl: 0
lcd: vx1_filter_en: 0
lcd: vx1_filter_time: 20
lcd: vx1_filter_cnt: 6
lcd: vx1_filter_retry_cnt: 2
lcd: vx1_filter_retry_delay: 100
Net:   dwmac.c9410000
efuse_pw_en: 0x3
WARNING! efuse bits is disabled
Enable A53 JTAG to EE
ffu update start
[audio] use codec ad82584!
wipe_data=successful
wipe_cache=successful
upgrade_step=2
amlkey_init() 71: already init!
[BL31]: tee size: 0
[KM]Error:f[key_manage_query_size]L507:key[mac_bt] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[deviceid] not programed yet
[KM]Error:f[key_manage_query_size]L507:key[cp_type] not programed yet
mwm 0xc8837004:[0x   aa203] with [0x   ea203] ok
mwm 0xc883700c:[0x 3e3b744] with [0x 3e3b764] ok
mwm 0xc8837010:[0x   c0101] with [0x   c8101] ok
mwm 0xc8837010:[0x   c8101] with [0x  128101] ok
IR init done!
InUsbBurn
noSof
disable bluetooth
Factory power mode: secondary
INFO:    PSCI Affinity Map:
INFO:      AffInst: Level 0, MPID 0x0, State ON
INFO:      AffInst: Level 0, MPID 0x1, State OFF
INFO:      AffInst: Level 0, MPID 0x2, State OFF
INFO:      AffInst: Level 0, MPID 0x3, State OFF
bl31 reboot reason: 0x108
system cmd  0.
bl30 get wakeup sources!
process command 00000006
bl30 enter suspend!
cpu clk suspend rate 1200000000
suspend_counter: 1
Enter ddr suspend
first time suspend
ddr suspend time: 1913us
store restore gp0 pll
process command 00000001
CEC cfg:0x0000
08915c0000000000read stick mem bad value!
求助最后read stick mem bad value!反复出现,是什么问题?
发表于: 2021-3-19 13:50:34
可能EMMC不能用了
 楼主| 发表于: 2021-3-21 10:45:25
是的,EMMC问题,已修复
GMT+8, 2024-12-29 09:41 , Processed in 0.057374 sec., 9 queries .
