查看: 1333|回复: 8
求助乐视S50AIR卡开机画面
发表于: 2021-3-17 23:10:48
机器初期卡LOGO,写引导和备份,故障排除,看几天,又进不来系统,这次是出了广告始后终进不来系统,换EMMC,写量产,再写引导,又下载多个升级包都不行,帮忙看看打印,是什么问题。谢谢
 楼主| 发表于: 2021-3-17 23:12:33
UART_115200
AC_ON
BIST0-OK
BIST1-OK
_U
Relocation Offset is: 1bf00000
[AT][MB][start ub][920]
U-Boot 2011.06-00000-g4bc336e-dirty (Apr 23 2018 - 17:22:39)
[NOS] UtopiaInit
1st UTOPIARegisterToUtopia is done[MBoot] Driver Register to UtopiaAC on
uboot held at [3c0ddf60~3e000000]
CPU  : Napoli
Board: BD_MST051D_20ANV_NAPOLI
DRAM:  480 MiB
Now running in RAM - U-Boot at: 3d100000
eMMC: HS200 200MHz
eMMC 14.55 GB [1D1EFF8h]
In:    serial
Out:   serial
Err:   serial
original bootargs: console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x11900000 EMAC_MEM=0x100000 DRAM_LEN=0x40000000 LX_MEM2=0x3FF00000,0x00000000 LX_MEM3=0xB1400000,0xEA00000 CORE_DUMP_PATH=/data/Logs/Log.0/core_dump.%%p.gz KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON IsUseFactorCmdbBin=0
getenv pname error
set default pname S250F
getenv 3d error
set default 3D
getenv dtmb error
set default DTMB
getenv Channel error
no this env Channel
getenv system_update error
no this env system_update
new bootargs: console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x11900000 EMAC_MEM=0x100000 DRAM_LEN=0x40000000 LX_MEM2=0x3FF00000,0x00000000 LX_MEM3=0xB1400000,0xEA00000 CORE_DUMP_PATH=/data/Logs/Log.0/core_dump.%%p.gz KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON IsUseFactorCmdbBin=0
Net:   No ethernet found.
Set MAC default
MAC:  0x0: 0x30: 0x1b: 0xba:0x2: 0xdb
msIR_Initialize
mmc change mount : factory1
Failed to mount ext2 filesystem...
** Bad ext4 partition or disk - mmc 0:3 **
[ERROR] loadscript:744: No enough buffer or path fail(/device.ini) :
[src/MsUtility.c] [loadscript]
mmc change mount : factory2
** Bad ext4 partition or disk - mmc 0:4 **
OnOffValue[0]: 0
InOutValue[0]: 1
OnOffValue[1]: 0
InOutValue[1]: 1
OnOffValue[2]: 0
InOutValue[2]: 1
read GPIO FLASH_WP reTryCnt : 0, reReadCnt : 0
audio effect chip is not exist!
Changelist:        00112233
Unknown command 'if_51OnRam_set' - try 'help'
setCtvFacTestMode==bootargs =console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x11900000 EMAC_MEM=0x100000 DRAM_LEN=0x40000000 LX_MEM2=0x3FF00000,0x00000000 LX_MEM3=0xB1400000,0xEA00000 CORE_DUMP_PATH=/data/Logs/Log.0/core_dump.%%p.gz KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON IsUseFactorCmdbBin=0
AC on
Writing to MMC(0)... done
AC on
check_ir_cmd: TIMEOUT, at 534
MPOOL size : 0x200000
AC on
mmc change mount : tvconfig
Loading file "/config/PM.bin" at offset 0x0 from mmc device 0 partition tvconfig
24575 bytes read
Wait for PM51 standower Down
U
[AT][MB][start ub][907]
[NOS] UtopiaInit
1st UTOPIARegisterToUtopia is done[MBoot] Driver Register to UtopiaDC on
CPU  : Napoli
DRAM:  480 MiB
eMMC: HS200 200MHz
In:    serial
Out:   serial
Err:   serial
getenv pname error
getenv 3d error
set default 3D
getenv dtmb error
set default DTMB
no this env Channel
Set MAC default
msIR_Initialize
OnOffValue[0]: 0
InOutValue[0]: 1
OnOffValue[1]: 0
InOutValue[1]: 1
OnOffValue[2]: 0
InOutValue[2]: 1
DC on
DC on
DC on
Wait for PM51 standby DRAM ...........PM51 run ok...........create instance at 3c1d7af0 with private size 184 bytes at 3c1d7b38
[ERROR] get_project_id:499: [york]get_project_id=<NULL>  0x0
MDrv_PNL_Init u32PnlRiuBaseAddr = 1f200000
MDrv_PNL_Init u32PMRiuBaseAddr = 1f000000
[_MDrv_PNL_Init_LPLL][315]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_LPLL][317]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[_MDrv_PNL_Init_Output_Dclk][361]pstPanelInitData->u16Width=1920, pstPanelInitData->u16Height=1080
[_MDrv_PNL_Init_Output_Dclk][363]u16HTotal=2200,u16VTotal=1130,pstPanelInitData->u16HTotal=2200,pstPanelInitData->u16VTotal=1130, u16DefaultVFreq=600
[MApi_XC_MLG_GetStatus, 1555]No instance existed, please get an instance by calling MApi_XC_Init() first
Init PWM2[Utopia] T8 is not supportcreate instance at 3c1d7bf8 with private size 304 bytes at 3c1d7c40
[AutoTest][MBoot][JPD Decode]
[UTOPIA INFO] close moduleNames[35]: MODULE_NJPEG_EX
Size of file "/config/mmap.ini" from mmc device 0 partition tvconfig: 52947 bytes
Loading file "/config/mmap.ini" at offset 0x0 from mmc device 0 partition tvconfig
52947 bytes read
create instance at 3c1e4ad0 with private size 16 bytes at 3c1e4b18
[GOP INFO] gop opencreate instance at 3c1e4b30 with private size 108 bytes at 3c1e4b78
[IZZY] (_GOP_RegisterAllCBFunc)
[AutoTest][MBoot][Show Logo][2583]
Loading file "/config/tee.aes" at offset 0x0 from mmc device 0 partition tvconfig
128 bytes read
4886192 bytes read
## Booting kernel from Legacy Image at 25000000 ...
   Image Name:   MStar-linux
   Image Type:   ARM Linux Multi-File Image (uncompressed)
   Data Size:    4076215 Bytes = 3.9 MiB
   Load Address: 20208000
   Entry Point:  20208000
   Contents:
      Image 0: 3837680 Bytes = 3.7 MiB
      Image 1: 238523 Bytes = 232.9 KiB
## Loading init Ramdisk from multi component Legacy Image at 25000000 ...
-usb_stop(USB_PORT0)
-usb_stop(USB_PORT1)
-usb_stop(USB_PORT2)
-usb_stop(USB_PORT3)
   Loading Multi-File Image ... OK
[MBX Driver][000853]     [MDrv_MBX_RegisterMSG]MDrv_MSGQ_RegisterMSG Failed! Result=4
[ERROR] MsDrv_PNL_BackLigth_On:796: MBX register msg E_MBX_CLASS_PM_NOWAIT error
[ERROR] MsDrv_PNL_BackLigth_On:797: MBX maybe already openned!
DC on
wakeup_source=5,
[AT][MB][start kr][3655]
Starting kernel   ...
KERN-3.1.10.00734947
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Linux version 3.1.10 (letv@tv-k8s-52887af0a4b6d6) (gcc version 4.7.2 (Sourcery CodeBench Lite 2012.09-64) ) #1 SMP PREEMPT Mon Apr 23 17:34:04 CST 2018
[    0.000000] CPU: ARMv7 Processor [414fc091] revision 1 (ARMv7), cr=18c53c7d
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: napoli
[    0.000000] KDebug = 1
[    0.000000]
[    0.000000] LX_MEM  = 0x20200000, 0x11900000
[    0.000000] LX_MEM2 = 0x0, 0x0
[    0.000000] LX_MEM3 = 0xB1400000, 0xEA00000
[    0.000000] EMAC_LEN= 0x100000
[    0.000000] DRAM_LEN= 0x40000000
[    0.000000] sanity_check_meminfo bank (c0000000-294649856), e0000000, 0
[    0.000000] sanity_check_meminfo bank (d1900000-245366784), e0000000, 0
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] PERCPU: Embedded 8 pages/cpu @c12f0000 s10112 r8192 d14464 u32768
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 126089
[    0.000000] Kernel command line: console=ttyS0,115200 androidboot.console=ttyS0 root=/dev/ram rw rootwait init=/init LX_MEM=0x11900000 EMAC_MEM=0x100000 DRAM_LEN=0x40000000 LX_MEM2=0x3FF00000,0x00000000 LX_MEM3=0xB1400000,0xEA00000 CORE_DUMP_PATH=/data/Logs/Log.0/core_dump.%%p.gz KDebug=1 delaylogo=true BOOTLOGO_IN_MBOOT ENV_VAR_OFFSET=0x0 ENV_VAR_SIZE=0x10000 ENV=EMMC SECURITY=ON IsUseFactorCmdbBin=0 wakeup_source=5 BOOTTIME_SBOOT=907 BOOTTIME_UBOOT=3655
[    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 281MB 234MB = 515MB total
[    0.000000] Memory: 509204k/509204k available, 18156k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xffc00000 - 0xffe00000   (   2 MB)
[    0.000000]     vmalloc : 0xe0800000 - 0xf8000000   ( 376 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0300000   ( 515 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0712000   (7208 kB)
[    0.000000]       .init : 0xc0712000 - 0xc0758780   ( 282 kB)
[    0.000000]       .data : 0xc075a000 - 0xc07a3380   ( 293 kB)
[    0.000000]        .bss : 0xc07a33a4 - 0xc09dcb60   (2278 kB)
[    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:256 nr_irqs:256 256
[    0.000000] Global Timer Frequency = 550 MHz
[    0.000000] CPU Clock Frequency = 1100367936 Hz
[    0.000000] Global Timer Frequency = 800 MHz
[    0.000000] CPU Clock Frequency = 1100 MHz
[    0.000000] fre = 550183968, mult= -391757146, shift= 31
[    0.000000] sched_clock: 32 bits at 550MHz, resolution 1ns, wraps every 7806ms
[    0.000000] [AT][KR][reset timer][4069]
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [ttyS0] enabled
[    0.000000] register logcat console
[    0.294865] Calibrating delay loop...
[    0.298472] 2189.31 BogoMIPS (lpj=4378620)
[    0.302860] pid_max: default: 32768 minimum: 301
[    0.307783] Security Framework initialized
[    0.312306] Mount-cache hash table entries: 512
[    0.318107] Initializing cgroup subsys debug
[    0.322532] Initializing cgroup subsys cpuacct
[    0.327109] Initializing cgroup subsys freezer
[    0.331726] CPU: Testing write buffer coherency: ok
[    0.336821] ftrace: allocating 21097 entries in 63 pages
[    0.369367]
[    0.369374]  Kernel_Level test :kernel_init  946
[    0.375617] smp_twd: clock not found: -2
[    0.379625] Calibrating local timer... 550.19MHz.
[    0.404797] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[    0.461014] pen_release = 0x00000001, addr= 0xc07a1c7c, pen_release ptr = 0x00000001
[    0.461024]  CPU1: Booted secondary processor
[    0.473299] CPU1: Unknown IPI message 0x1
[    0.496936] pen_release = 0x00000002, addr= 0xc07a1c7c, pen_release ptr = 0x00000002
[    0.496945]  CPU2: Booted secondary processor
[    0.509173] CPU2: Unknown IPI message 0x1
[    0.532900] pen_release = 0x00000003, addr= 0xc07a1c7c, pen_release ptr = 0x00000003
[    0.532908]
[    1.540754] CPU3: failed to boot: -38
[    1.545157] Brought up 3 CPUs
[    1.548148] SMP: Total of 3 processors activated (6567.93 BogoMIPS).
[    1.555787] devtmpfs: initialized
[    1.574133] NET: Registered protocol family 16
[    1.588909] L310 cache controller enabled
[    1.592972] l2x0: 8 ways, CACHE_ID 0x410000c9, AUX_CTRL 0x32480000, Cache size: 1048576 B
[    1.601184] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    1.607996] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
[    1.615340] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    1.649568] bio: create slab <bio-0> at 0
[    1.654730] SCSI subsystem initialized
[    1.658945] usbcore: registered new interface driver usbfs
[    1.664752] usbcore: registered new interface driver hub
[    1.670275] usbcore: registered new device driver usb
[    1.676334] eMMC: has SD 0513
[    1.680093] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    1.687259] Switching to clocksource timer1
[    1.691492] stop_machine_cpu_stop smp=0
[    1.691499] stop_machine_cpu_stop smp=1
[    1.691507] stop_machine_cpu_stop smp=2
[    1.735536] NET: Registered protocol family 2
[    1.740074] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[    1.747358] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.754826] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[    1.761741] TCP: Hash tables configured (established 16384 bind 16384)
[    1.768316] TCP reno registered
[    1.771484] UDP hash table entries: 256 (order: 1, 8192 bytes)
[    1.777371] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[    1.783913] NET: Registered protocol family 1
[    1.788610] RPC: Registered named UNIX socket transport module.
[    1.794584] RPC: Registered udp transport module.
[    1.799336] RPC: Registered tcp transport module.
[    1.804062] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.810730] Trying to unpack rootfs image as initramfs...
[    1.818100]
[    1.818103] eMMC: HS200 200MHz
[    1.837313] [mmc]:mmc_decode_cid:113 cid.prv 0x1
[    1.845111] Freeing initrd memory: 236K
[    1.849075] NetWinder Floating Point Emulator V0.97 (extended precision)
[    1.855857] [mmc]:mmc_read_ext_csd:297 ext_csd.sectors 0x1d1f000 prod_name AGND3R BOOT_MULTI 0x20
[    1.864816] PMU: registered new PMU device of type 0
[    1.870063] mmc0: new high speed MMC card at address 0001
[    1.875833] [mmc]:mmc_rescan_try_freq:1970 mmc0: eMMC completed
[    1.881955] audit: initializing netlink socket (disabled)
[    1.887408] type=2000 audit(1.511:1): initialized
[    1.956954] ashmem: initialized
[    1.971948] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.979342] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    1.986873] ROMFS MTD (C) 2007 Red Hat, Inc.
[    1.991383] fuse init (API version 7.17)
[    1.996395] msgmni has been set to 995
[    2.001184] io scheduler noop registered
[    2.005135] io scheduler deadline registered
[    2.009495] io scheduler cfq registered (default)
[    2.014551] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.021142] serial8250: ttyS0 at I/O 0xfd201300 (irq = 192) is a 16550
[    2.027959] serial8250: ttyS1 at I/O 0xfd220c00 (irq = 231) is a 16550
[    2.034742] serial8250: ttyS2 at I/O 0xfd220d00 (irq = 242) is a 16550
[    2.050527] brd: module loaded
[    2.058356] loop: module loaded
[    2.062659] nbd: registered device at major 43
[    2.076125] PPP generic driver version 2.4.2
[    2.080813] PPP Deflate Compression module registered
[    2.085891] PPP BSD Compression module registered
[    2.091201] PPP MPPE Compression module registered
[    2.096018] NET: Registered protocol family 24
[    2.100540] tun: Universal TUN/TAP device driver, 1.6
[    2.105616] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    2.112272] Mstar-ehci-2 H.W init
[    2.115614] Titania3_series_start_ehc start: 20140515
[    2.121735] BC disable
[    2.124208] Mstar-ehci-2 Mstar-ehci-2.1: Mstar EHCI
[    2.129202] Mstar-ehci-2 Mstar-ehci-2.1: new USB bus registered, assigned bus number 1
[    2.137272] Mstar-ehci-2 Mstar-ehci-2.1: irq 226, io mem 0xfd201a00
[    2.155136] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.161952] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.169197] usb usb1: Product: Mstar EHCI
[    2.173225] usb usb1: Manufacturer: Linux 3.1.10 ehci_hcd
[    2.178644] usb usb1: SerialNumber: mstar
[    2.183316] hub 1-0:1.0: USB hub found
[    2.187103] hub 1-0:1.0: 1 port detected
[    2.191544] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.198129] Mstar-ehci-1 H.W init
[    2.201464] Titania3_series_start_ehc start: 20140515
[    2.207590] BC disable
[    2.210049] Mstar-ehci-1 Mstar-ehci-1.0: Mstar EHCI
[    2.214974] Mstar-ehci-1 Mstar-ehci-1.0: new USB bus registered, assigned bus number 2
[    2.223060] Mstar-ehci-1 Mstar-ehci-1.0: irq 199, io mem 0xfd204800
[    2.239115] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    2.245930] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.253175] usb usb2: Product: Mstar EHCI
[    2.257205] usb usb2: Manufacturer: Linux 3.1.10 ehci_hcd
[    2.262623] usb usb2: SerialNumber: mstar
[    2.267260] hub 2-0:1.0: USB hub found
[    2.271030] hub 2-0:1.0: 1 port detected
[    2.275527] Mstar-ehci-3 H.W init
[    2.278851] Titania3_series_start_ehc start: 20140515
[    2.284970] BC disable
[    2.287441] Mstar-ehci-3 Mstar-ehci-3.2: Mstar EHCI
[    2.292409] Mstar-ehci-3 Mstar-ehci-3.2: new USB bus registered, assigned bus number 3
[    2.300468] Mstar-ehci-3 Mstar-ehci-3.2: irq 229, io mem 0xfd227200
[    2.315119] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    2.321936] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.329182] usb usb3: Product: Mstar EHCI
[    2.333209] usb usb3: Manufacturer: Linux 3.1.10 ehci_hcd
[    2.338628] usb usb3: SerialNumber: mstar
[    2.343270] hub 3-0:1.0: USB hub found
[    2.347078] hub 3-0:1.0: 1 port detected
[    2.351555] Mstar-ehci-4 H.W init
[    2.354878] Titania3_series_start_ehc start: 20140515
[    2.360998] BC disable
[    2.363470] Mstar-ehci-4 Mstar-ehci-4.3: Mstar EHCI
[    2.368394] Mstar-ehci-4 Mstar-ehci-4.3: new USB bus registered, assigned bus number 4
[    2.376495] Mstar-ehci-4 Mstar-ehci-4.3: irq 217, io mem 0xfd244c00
[    2.391113] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    2.397928] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.405174] usb usb4: Product: Mstar EHCI
[    2.409201] usb usb4: Manufacturer: Linux 3.1.10 ehci_hcd
[    2.414620] usb usb4: SerialNumber: mstar
[    2.419258] hub 4-0:1.0: USB hub found
[    2.423028] hub 4-0:1.0: 1 port detected
[    2.427491] MStar xHCI init...
[    2.430599] xHCI_660201
[    2.433153] Mstar-xhci-1 H.W init
[    2.436487] Mstar_xhc_init version:20150611
[    2.442732]
[    2.442734]  [ XHC: get efuse value: 0x83dd ]
[    2.448746] XHCI_enable_PPC: Turn on USB3.0 port power
[    2.453995] Addr: 0x2e82 bit_num: 0 low_active:0
[    2.458636] BC disable
[    2.461107] Mstar-xhci-1 Mstar-xhci-1.0: Mstar xHCI Host Controller
[    2.467423] Mstar-xhci-1 Mstar-xhci-1.0: new USB bus registered, assigned bus number 5
[    2.475426] ==20140515==> hub_port_init 1
[    2.477803] Mstar-xhci-1 Mstar-xhci-1.0: irq 194, io mem 0xfd320000
[    2.477888] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002
[    2.477899] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.477909] usb usb5: Product: Mstar xHCI Host Controller
[    2.477917] usb usb5: Manufacturer: Linux 3.1.10 mstar_xhci_hcd
[    2.477924] usb usb5: SerialNumber: mstar
[    2.515230] Plug in USB Port1
[    2.518550] hub 5-0:1.0: USB hub found
[    2.522337] hub 5-0:1.0: 1 port detected
[    2.526708] Mstar-xhci-1 Mstar-xhci-1.0: Mstar xHCI Host Controller
[    2.533032] Mstar-xhci-1 Mstar-xhci-1.0: new USB bus registered, assigned bus number 6
[    2.541046] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003
[    2.547863] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.555111] usb usb6: Product: Mstar xHCI Host Controller
[    2.560532] usb usb6: Manufacturer: Linux 3.1.10 mstar_xhci_hcd
[    2.566472] usb usb6: SerialNumber: mstar
[    2.571143] hub 6-0:1.0: USB hub found
[    2.574914] hub 6-0:1.0: 1 port detected
[    2.579375] Initializing USB Mass Storage driver...
[    2.584529] usbcore: registered new interface driver usb-storage
[    2.590561] USB Mass Storage support registered.
[    2.595663] mousedev: PS/2 mouse device common for all mice
[    2.601620] usbcore: registered new interface driver xpad
[    2.607216] usbcore: registered new interface driver usb_nanosic_ts
[    2.614523] using rtc device, rtc-mstar, for alarms
[    2.619275] rtc-mstar rtc-mstar: rtc core: registered rtc-mstar as rtc0
[    2.626499] lirc_dev: IR Remote Control driver registered, major 253
[    2.632967] IR NEC protocol handler initialized
[    2.637517] IR RC5(x) protocol handler initialized
[    2.642327] IR RC6 protocol handler initialized
[    2.646877] IR JVC protocol handler initialized
[    2.651426] IR Sony protocol handler initialized
[    2.656062] IR RC5 (streamzap) protocol handler initialized
[    2.659063] usb 2-1: new high speed USB device number 2 using Mstar-ehci-1
[    2.668529] IR MCE Keyboard/mouse protocol handler initialized
[    2.674383] IR LIRC bridge handler initialized
[    2.678875] Linux video capture interface: v2.00
[    2.683639] gspca: v2.13.0 registered
[    2.687496] usbcore: registered new interface driver uvcvideo
[    2.693266] USB Video Class driver (1.1.1)
[    2.698222] device-mapper: uevent: version 1.0.3
[    2.703390] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: dm-devel@redhat.com
[    2.712163] mmcblk0: mmc0:0001 AGND3R 14.5 GiB
[    2.716871] mmcblk0boot0: mmc0:0001 AGND3R partition 1 4.00 MiB
[    2.722969] mmcblk0boot1: mmc0:0001 AGND3R partition 2 4.00 MiB
[    2.729392] emmc_partition()
[    2.736645]  [emmc]Start_block=4096, block_count=6144
[    2.741743] Start_block=10240, block_count=4096
[    2.746295] Start_block=14336, block_count=65536
[    2.750934] Start_block=79872, block_count=65536
[    2.755574] Start_block=145408, block_count=1024
[    2.760213] Start_block=146432, block_count=16384
[    2.764938] Start_block=162816, block_count=8192
[    2.769892] Start_block=171008, block_count=512
[    2.774449] Start_block=171520, block_count=1048576
[    2.779350] Start_block=1220096, block_count=1048576
[    2.784336] Start_block=2268672, block_count=1048576
[    2.789322] Start_block=3317248, block_count=122880
[    2.794221] Start_block=3440128, block_count=65536
[    2.799043] Start_block=3505664, block_count=16384
[    2.803854] Start_block=3522048, block_count=32768
[    2.808964] Start_block=3554816, block_count=26968064
[    2.814041]
[    2.815548]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16emmc_partition()
[    2.829171] 0x0
[    2.830976]  mmcblk0boot1: unknown partition table
[    2.836504] emmc_partition()
[    2.839759] 0x5eaa
[    2.841821]  mmcblk0boot0: unknown partition table
[    2.847195] This is hidraw init for linux source with original trylock  patch!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
[    2.863501] usbcore: registered new interface driver usbhid
[    2.869101] usbhid: USB HID core driver
[    2.873729] logger: created 256K log 'log_main'
[    2.878513] logger: created 256K log 'log_events'
[    2.883467] logger: created 256K log 'log_radio'
[    2.888328] logger: created 256K log 'log_system'
[    2.893267] logger: created 256K log 'log_kernel'
[    2.898854] Mstar_emac: [ PHY Addr ] ==> :0
[    2.903122] Mstar_emac: alloRAM_VA_BASE = 0xE0A00000 alloRAM_PA_BASE= 0x31B00000  alloRAM_SIZE= 0x100000
[    2.914308] RBQP_BASE = 31b04000
[    2.918362] >> [sdmmc] ms_sdmmc Driver Initializing...
[    2.923616] PM_GPIO_NUM:0
[    2.926722] >> [sdmmc_0] Get CD => (0)
[    2.926760] >> [sdmmc_0] CDZ use Ext GPIO IRQ: 193
[    2.926768] >> [sdmmc_0] Probe Devices...(Ret:0)
[    2.941778] [0000000641][MAD_ALSA][001752]     <6>Linux Kernel Version : 3.1.10
[    2.949120] [0000000643][MAD_ALSA][001756]     <6>ALSA Kernel Version : 1.0.24
[    2.956369] [0000000645][MAD_ALSA][001758]     <6>MStar ALSA Driver Version : 3.2.0
[    2.964049] [0000000647][MAD_ALSA][001760]     <6>Initiate MStar ALSA driver engine {matt patch}
[    2.972860] [0000000649][MAD_ALSA][001624]     <6>Go to register MStar ALSA driver
[    2.982139] [0000000651][MAD_ALSA][001688]     <6>MStar ALSA driver is registered to slot 0
[    2.990692] [0000000653][MAD_ALSA][001926]     <6>Initiate MStar ALSA core driver
[    2.998209] [0000000655][MAD_ALSA][000285]     <6>Hal Driver 'MAD NAPOLI' is hooked.
[    3.005978] [0000000657][MAD_ALSA][000286]     <6>MStar Core Version : 3.1.10
[    3.013518] Function = CPU_calibrating_init, Line = 755
[    3.019467] Function = init_procfs_msg, Line = 736, current_frequency = 1600000
[    3.027508] Function = integrator_cpufreq_init, Line = 210, integrator_get return 1100000
[    3.036610] Function = integrator_cpufreq_init, Line = 210, integrator_get return 1100000
[    3.045742] Function = integrator_cpufreq_init, Line = 210, integrator_get return 1100000
[    3.054915] blcr: vmadump: (from bproc-BPROC_VERSION) Erik Hendriks <erik@hendriks.cx>
[    3.062872] blcr: vmadump: Modified for blcr 0.8.5 <http://ftg.lbl.gov/checkpoint>
[    3.070474] blcr: Berkeley Lab Checkpoint/Restart (BLCR) module version 0.8.5.
[    3.077720] blcr:   Parameter cr_io_max = 0x4000000
[    3.082615] blcr:   Supports kernel interface version 0.10.3.
[    3.088383] blcr:   Supports context file format versions 8 though 9.
[    3.088644] usb 2-1: New USB device found, idVendor=05e3, idProduct=0610
[    3.088655] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    3.088665] usb 2-1: Product: USB2.0 Hub
[    3.089529] hub 2-1:1.0: USB hub found
[    3.089839] hub 2-1:1.0: 4 ports detected
[    3.120355] blcr: http://ftg.lbl.gov/checkpoint
[    3.129145] usbcore: registered new interface driver snd-usb-audio
[    3.135353] ALSA device list:
[    3.138328]   #0: MStar MPEG Audio Decoder No.00
[    3.143528] oprofile: using arm/armv7-ca9
[    3.147664] Netfilter messages via NETLINK v0.30.
[    3.152471] nf_conntrack version 0.5.0 (7960 buckets, 31840 max)
[    3.158970] ctnetlink v0.93: registering with nfnetlink.
[    3.164339] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    3.171333] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    3.177673] ip_tables: (C) 2000-2006 Netfilter Core Team
[    3.183212] TCP cubic registered
[    3.187616] NET: Registered protocol family 10
[    3.192957] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    3.198510] IPv6 over IPv4 tunneling driver
[    3.204369] NET: Registered protocol family 17
[    3.208873] NET: Registered protocol family 15
[    3.213446] Bridge firewalling registered
[    3.217539] 8021q: 802.1Q VLAN Support v1.8
[    3.221765] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    3.231470] rtc-mstar rtc-mstar: setting system clock to 2007-01-01 12:00:00 UTC (1167652800)
[    3.240272] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) Setup!!!
[    3.247313] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    3.253288] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    3.258802] Function = n_tty_open, Line = 1899, [KDEBUGD] enter : NA
[    3.266203] Freeing init memory: 280K
[    3.269887] [AT][KR][start init][7339]
[    3.273653] [AutoTest][Kernel][start Initprocess][7339]
[    3.280222] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[    3.288596] SELinux:  Could not mount selinuxfs:  No such device
[    3.296572] init: /init.napoli.rc: 113: invalid command 'if'
[    3.302303] init: /init.napoli.rc: 115: invalid command 'else'
[    3.308188] init: /init.napoli.rc: 117: invalid command 'if'
[    3.314009] init: /init.napoli.rc: 222: ignored duplicate definition of service 'dhcpcd_bnep0'
[    3.322665] init: /init.napoli.rc: 226: ignored duplicate definition of service 'dhcpcd_bnep1'
[    3.331321] init: /init.napoli.rc: 230: ignored duplicate definition of service 'dhcpcd_bnep2'
[    3.339975] init: /init.napoli.rc: 234: ignored duplicate definition of service 'dhcpcd_bnep3'
[    3.348627] init: /init.napoli.rc: 238: ignored duplicate definition of service 'dhcpcd_bnep4'
[    3.357278] init: /init.napoli.rc: 242: ignored duplicate definition of service 'dhcpcd_bt-pan'
[    3.366154] init: /init.napoli.rc: 247: ignored duplicate definition of service 'iprenew_bt-pan'
[    3.375145] init: /init.napoli.rc: 317: ignored duplicate definition of service 'dhcpcd_bnep0'
[    3.384464] init: wakeup_source is 5
[    3.388143] init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
[    3.518711] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) Setup!!!
[    3.525960] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    3.531918] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    3.537436] Function = n_tty_open, Line = 1899, [KDEBUGD] enter : NA
[    3.544680] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[    3.552015] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) Setup!!!
[    3.559023] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    3.565106] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    3.570613] Function = n_tty_open, Line = 1899, [KDEBUGD] enter : NA
             A N D R O I D
[    3.587122] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[    3.627551] EXT4-fs (mmcblk0p9): mounted filesystem with ordered data mode. Opts: (null)
[    3.642347] EXT4-fs (mmcblk0p11): recovery complete
[    3.647466] EXT4-fs (mmcblk0p11): mounted filesystem with ordered data mode. Opts: (null)
[    3.711762] EXT4-fs (mmcblk0p16): recovery complete
[    3.716868] EXT4-fs (mmcblk0p16): mounted filesystem with ordered data mode. Opts: (null)
[    3.728930] EXT4-fs (mmcblk0p12): mounted filesystem with ordered data mode. Opts: (null)
[    3.740724] EXT4-fs (mmcblk0p13): mounted filesystem with ordered data mode. Opts: (null)
[    3.769213] EXT4-fs (mmcblk0p14): recovery complete
[    3.774317] EXT4-fs (mmcblk0p14): mounted filesystem with ordered data mode. Opts: (null)
[    3.786278] EXT4-fs (mmcblk0p15): recovery complete
[    3.791207] EXT4-fs (mmcblk0p15): mounted filesystem with ordered data mode. Opts: (null)
[    3.806895] EXT4-fs (mmcblk0p10): recovery complete
[    3.812012] EXT4-fs (mmcblk0p10): mounted filesystem with ordered data mode. Opts: (null)
[    3.820607] EXT4-fs (mmcblk0p3): VFS: Can't find ext4 filesystem
[    3.851085] fs_mgr: Cannot mount filesystem on /dev/block/platform/mstar_mci.0/by-name/factory1 at /factory1
[    3.860960] init: fs_mgr_mount_all returned an error
[    3.886650] UMP: UMP device driver -CL867485 loaded
[    3.951648] Mali: Mali device driver loaded
[    3.966123] Registered IR keymap rc-letv
[    3.970855] input: LETV Smart IR Receiver as /devices/virtual/rc/rc0/input0
[    3.978279] rc0: LETV Smart IR Receiver as /devices/virtual/rc/rc0
[    3.984991] input: MCE IR Keyboard/Mouse (ir) as /devices/virtual/input/input1
[    3.993509] rc rc0: lirc_dev: driver ir-lirc-codec (ir) registered at minor = 0
[    4.001046] [KEY_INPUT]:key_dispatch thread start
[    4.014260] ufsd: module license 'Commercial product' taints kernel.
[    4.020685] Disabling lock debugging due to kernel taint
[    4.037536] ufsd:: trace mask set to 0000000f
[    4.041949] ufsd: driver (lke_8.9.0 lke_8.9.0_r229897_b2, LBD=ON, delalloc, acl, ioctl, bdi, sd(1), fua, tr) loaded at bf052000
[    4.041958] NTFS support included
[    4.041961] optimized: speed
[    4.041963] Build_for__LeTV_YueLi_a4.x_k3.1.10_2014-06-09_lke_8.9.0_r229897_b2
[    4.041969]
[    4.051041]
[    4.051044] Function = Mdrv_CPU_Freq_Check_callback, Line = 681, (freq = 1100000) != (current_frequency = 1600000)
[    4.051063]
[    4.051066] *** ori: timekeeper.cycle_interval = 2200736
[    4.051073]
[    4.051076] *** after: timekeeper.cycle_interval = 2200000
[    4.121273] exFAT: Version 1.2.6
[    4.126438] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) Setup!!!
[    4.133480] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    4.139428] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    4.144975] Function = n_tty_open, Line = 1899, [KDEBUGD] enter : NA
[    4.152248] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) is freed !!!
[    4.159686] ************* UART1 Request IRQ *************
[    4.178320] rtk_btusb: Unknown symbol release_firmware (err 0)
[    4.184327] rtk_btusb: Unknown symbol request_firmware (err 0)
[    4.266390] Bluetooth: Core ver 2.16
[    4.270242] NET: Registered protocol family 31
[    4.274734] Bluetooth: HCI device and connection manager initialized
[    4.281119] Bluetooth: HCI socket layer initialized
[    4.286023] Bluetooth: L2CAP socket layer initialized
[    4.291124] Bluetooth: SCO socket layer initialized
[    4.308031] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    4.333584] Bluetooth: RFCOMM TTY layer initialized
[    4.338535] Bluetooth: RFCOMM socket layer initialized
[    4.343705] Bluetooth: RFCOMM ver 1.11
[    4.361896] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.367274] Bluetooth: BNEP filters: protocol multicast
[    4.422036] [SERIAL INPUT MANAGE] Managed tty_struct(.name:ttyS0) Setup!!!
[    4.430822] [SERIAL INPUT MANAGE] disable_serial : ~~bye(len:5)
[    4.436900] [SERIAL INPUT MANAGE] enable_serial : (len: 0)
[    4.442442] Function = n_tty_open, Line = 1899, [KDEBUGD] enter : NA
root@mstarnapoli:/ # [    5.170116] --------->MBX DRIVER OPEN
[    5.175619] _MDrv_MBXIO_FASYNC is invoked
[    5.706663] [GFLIP] GFLIP DRIVER OPEN
[    5.710367] [GFLIP] New flip function enable
TVOS *checkPoint*
[    8.308625] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
[    8.416495] init: cannot find '/system/bin/nanosic_apps', disabling 'nanosic_apps'
[    8.439802] init: cannot find '/system/bin/livecap', disabling 'livecap'
[    8.459722] init: cannot find '/system/bin/virtualtouch', disabling 'virtualtouch'
[    8.500221] init: no such service 'renice-tvos-0'
[    8.533812] idong200 info:load idong200 driver
[    8.570224] usbcore: registered new interface driver idong200
[    8.733254] ADDRCONF(NETDEV_UP): eth0: link is not ready
[    8.886175] input: Letv Smart TV Keypad as /devices/virtual/input/input2
[    9.231958] [0000002214][MAD_ALSA][000558]     <6>Open 'subdevice #0'(0) of MStar ALSA playback device
[    9.241778] [0000002216][MAD_ALSA][000408]     <6>Open software timer.
[    9.248534] [0000002218][MAD_ALSA][000741]     <6>Configure PCM HW resource
[    9.269646] [0000002223][MAD_ALSA][000558]     <6>Open 'subdevice #0'(0) of MStar ALSA playback device
[    9.279853] [0000002226][MAD_ALSA][000408]     <6>Open software timer.
[    9.286819] [0000002228][MAD_ALSA][000741]     <6>Configure PCM HW resource
[    9.300698] [GFLIP] GFLIP DRIVER OPEN
[    9.312495] [GFLIP] New flip function enable
[   10.324951] [GFLIP] GFLIP DRIVER OPEN
[   10.332084] [GFLIP] New flip function enable
[   10.539490] Mali get page bus_address 0xBADF7000 in MIU_1
[   10.548185] Mali get page bus_address 0xBADF6000 in MIU_1
[   10.554686] Mali get page bus_address 0xBAE0A000 in MIU_1
[   10.561395] Mali get page bus_address 0xBADF5000 in MIU_1
[   10.570729] Mali get page bus_address 0xBAE09000 in MIU_1
[   10.577154] Mali get page bus_address 0xBADF4000 in MIU_1
[   10.582945] Mali get page bus_address 0xBADF3000 in MIU_1
[   10.588745] Mali get page bus_address 0xBADF2000 in MIU_1
[   10.594461] Mali get page bus_address 0xBADF1000 in MIU_1
[   10.600183] Mali get page bus_address 0xBADF0000 in MIU_1
[   10.607020] Mali get page bus_address 0xBAD57000 in MIU_1
[   10.612770] Mali get page bus_address 0xBB868000 in MIU_1
[   10.618715] Mali get page bus_address 0xBB86B000 in MIU_1
[   10.624517] Mali get page bus_address 0xBEFD0000 in MIU_1
[   10.630251] Mali get page bus_address 0xBEFD1000 in MIU_1
[   10.636182] Mali get page bus_address 0xBAD0E000 in MIU_1
[   10.641915] Mali get page bus_address 0xBB97E000 in MIU_1
[   10.647777] Mali get page bus_address 0xBADDF000 in MIU_1
[   10.658682] Mali get page bus_address 0xBADE6000 in MIU_1
[   10.667221] Mali get page bus_address 0xBADE7000 in MIU_1
[   10.673020] Mali get page bus_address 0xBADE8000 in MIU_1
[   10.678805] Mali get page bus_address 0xBADE9000 in MIU_1
[   10.684718] Mali get page bus_address 0xBADEA000 in MIU_1
[   10.690468] Mali get page bus_address 0xBB82B000 in MIU_1
[   10.696294] Mali get page bus_address 0xBADEF000 in MIU_1
[   10.702211] Mali get page bus_address 0xBB9A0000 in MIU_1
[   10.707921] Mali get page bus_address 0xBADE5000 in MIU_1
[   10.713652] Mali get page bus_address 0xBAD0A000 in MIU_1
[   10.719581] Mali get page bus_address 0xBBA1B000 in MIU_1
[   10.725408] Mali get page bus_address 0xBBA20000 in MIU_1
[   10.731254] Mali get page bus_address 0xBAD1D000 in MIU_1
[   10.736896] Mali get page bus_address 0xBB9F8000 in MIU_1
[   10.742901] Mali get page bus_address 0xBADED000 in MIU_1
[   10.748956] Mali get page bus_address 0xBEFC7000 in MIU_1
[   10.754764] Mali get page bus_address 0xBADEB000 in MIU_1
[   10.760469] Mali get page bus_address 0xBEFA8000 in MIU_1
[   10.765562] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   10.778207] Mali get page bus_address 0xBADBF000 in MIU_1
[   10.787235] Mali get page bus_address 0xBAE03000 in MIU_1
[   10.793055] Mali get page bus_address 0xBBA11000 in MIU_1
[   10.798867] Mali get page bus_address 0xBAD44000 in MIU_1
[   10.804539] Mali get page bus_address 0xBADE2000 in MIU_1
[   10.810238] Mali get page bus_address 0xBADE1000 in MIU_1
[   10.816233] Mali get page bus_address 0xBB97F000 in MIU_1
[   10.822012] Mali get page bus_address 0xBAD00000 in MIU_1
[   10.827891] Mali get page bus_address 0xBAE02000 in MIU_1
[   10.833920] Mali get page bus_address 0xBB98E000 in MIU_1
[   10.839633] Mali get page bus_address 0xBB98F000 in MIU_1
[   10.845691] Mali get page bus_address 0xBB940000 in MIU_1
[   10.851329] Mali get page bus_address 0xBB941000 in MIU_1
[   10.857030] Mali get page bus_address 0xBB942000 in MIU_1
[   10.862879] Mali get page bus_address 0xBB943000 in MIU_1
[   10.868691] Mali get page bus_address 0xBAE28000 in MIU_1
[   10.874403] Mali get page bus_address 0xBAE29000 in MIU_1
[   10.880619] Mali get page bus_address 0xBAE2A000 in MIU_1
[   10.886513] Mali get page bus_address 0xBAE2B000 in MIU_1
[   10.897988] Mali get page bus_address 0xBAE20000 in MIU_1
[   10.908001] Mali get page bus_address 0xBAE21000 in MIU_1
[   10.913739] Mali get page bus_address 0xBAE22000 in MIU_1
[   10.919485] Mali get page bus_address 0xBAE23000 in MIU_1
[   10.925357] Mali get page bus_address 0xBAE24000 in MIU_1
[   10.931263] Mali get page bus_address 0xBAE25000 in MIU_1
[   10.937255] Mali get page bus_address 0xBAE26000 in MIU_1
[   10.943170] Mali get page bus_address 0xBAE27000 in MIU_1
[   10.949324] Mali get page bus_address 0xBAE30000 in MIU_1
[   10.973158] Mali get page bus_address 0xBAE31000 in MIU_1
[   10.980230] Mali get page bus_address 0xBAD30000 in MIU_1
[   10.987230] Mali get page bus_address 0xBAE69000 in MIU_1
[   11.001912] Mali get page bus_address 0xBAE32000 in MIU_1
[   11.008658] Mali get page bus_address 0xBAE33000 in MIU_1
[   11.014399] Mali get page bus_address 0xBAE68000 in MIU_1
[   11.020017] Mali get page bus_address 0xBAE67000 in MIU_1
[   11.025516] Mali get page bus_address 0xBAE66000 in MIU_1
[   11.031075] Mali get page bus_address 0xBAE65000 in MIU_1
[   11.036627] Mali get page bus_address 0xBAE64000 in MIU_1
[   11.042098] Mali get page bus_address 0xBAE63000 in MIU_1
[   11.047586] Mali get page bus_address 0xBAE62000 in MIU_1
[   11.053117] Mali get page bus_address 0xBAE61000 in MIU_1
[   11.058610] Mali get page bus_address 0xBAE60000 in MIU_1
[   11.064228] Mali get page bus_address 0xBAE5F000 in MIU_1
[   11.069763] Mali get page bus_address 0xBAE5E000 in MIU_1
[   11.075252] Mali get page bus_address 0xBAE5D000 in MIU_1
[   11.080720] Mali get page bus_address 0xBAE5C000 in MIU_1
[   11.086250] Mali get page bus_address 0xBAE5B000 in MIU_1
[   11.091721] Mali get page bus_address 0xBAE5A000 in MIU_1
[   11.097192] Mali get page bus_address 0xBAE59000 in MIU_1
[   11.102738] Mali get page bus_address 0xBAE58000 in MIU_1
[   11.108267] Mali get page bus_address 0xBAE57000 in MIU_1
[   11.113784] Mali get page bus_address 0xBAE56000 in MIU_1
[   11.119384] Mali get page bus_address 0xBAE55000 in MIU_1
[   11.124902] Mali get page bus_address 0xBAE54000 in MIU_1
[   11.130919] Mali get page bus_address 0xBAE53000 in MIU_1
[   11.136509] Mali get page bus_address 0xBAE52000 in MIU_1
[   11.142607] Mali get page bus_address 0xBAE51000 in MIU_1
[   11.148129] Mali get page bus_address 0xBAE50000 in MIU_1
[   11.153709] Mali get page bus_address 0xBAE43000 in MIU_1
[   11.159227] Mali get page bus_address 0xBAE42000 in MIU_1
[   11.164881] Mali get page bus_address 0xBAE3D000 in MIU_1
[   11.170452] Mali get page bus_address 0xBAD8C000 in MIU_1
[   11.175969] Mali get page bus_address 0xBADDD000 in MIU_1
[   11.181478] Mali get page bus_address 0xBADDC000 in MIU_1
[   11.187044] Mali get page bus_address 0xBBA2B000 in MIU_1
[   11.192556] Mali get page bus_address 0xBAD2B000 in MIU_1
[   11.198071] Mali get page bus_address 0xBADF8000 in MIU_1
[   11.203642] Mali get page bus_address 0xBAD24000 in MIU_1
[   11.209153] Mali get page bus_address 0xBAD10000 in MIU_1
[   11.214672] Mali get page bus_address 0xBADBE000 in MIU_1
[   11.220749] Mali get page bus_address 0xBBA03000 in MIU_1
[   11.226878] Mali get page bus_address 0xBAD76000 in MIU_1
[   11.232993] Mali get page bus_address 0xBB9EE000 in MIU_1
[   11.239029] Mali get page bus_address 0xBBA2E000 in MIU_1
[   11.244998] Mali get page bus_address 0xBBA82000 in MIU_1
[   11.251001] Mali get page bus_address 0xBBA77000 in MIU_1
[   11.256885] Mali get page bus_address 0xBBA76000 in MIU_1
[   11.262966] Mali get page bus_address 0xBBA75000 in MIU_1
[   11.268511] Mali get page bus_address 0xBBA74000 in MIU_1
[   11.274444] Mali get page bus_address 0xBBAFC000 in MIU_1
[   11.280522] Mali get page bus_address 0xBBB09000 in MIU_1
[   11.286072] Mali get page bus_address 0xBB9ED000 in MIU_1
[   11.292102] Mali get page bus_address 0xBAE0F000 in MIU_1
[   11.298194] Mali get page bus_address 0xBBA72000 in MIU_1
[   11.303743] Mali get page bus_address 0xBBA71000 in MIU_1
[   11.309963] Mali get page bus_address 0xBBA70000 in MIU_1
[   11.315833] Mali get page bus_address 0xBBA6F000 in MIU_1
[   11.321495] Mali get page bus_address 0xBBA6E000 in MIU_1
[   11.327037] Mali get page bus_address 0xBBA6D000 in MIU_1
[   11.332607] Mali get page bus_address 0xBB8E8000 in MIU_1
[   11.338151] Mali get page bus_address 0xBBA0B000 in MIU_1
[   11.343667] Mali get page bus_address 0xBB971000 in MIU_1
[   11.349247] Mali get page bus_address 0xBAD7E000 in MIU_1
[   11.354770] Mali get page bus_address 0xBB97C000 in MIU_1
[   11.360265] Mali get page bus_address 0xBB97D000 in MIU_1
[   11.365971] Mali get page bus_address 0xBAE6C000 in MIU_1
[   11.371447] Mali get page bus_address 0xBAE6D000 in MIU_1
[   11.376982] Mali get page bus_address 0xBAE6E000 in MIU_1
[   11.382577] Mali get page bus_address 0xBAE6F000 in MIU_1
[   11.388086] Mali get page bus_address 0xBAE74000 in MIU_1
[   11.393557] Mali get page bus_address 0xBAE75000 in MIU_1
[   11.399092] Mali get page bus_address 0xBAE76000 in MIU_1
[   11.404589] Mali get page bus_address 0xBAE77000 in MIU_1
[   11.410091] Mali get page bus_address 0xBAE78000 in MIU_1
[   11.415564] Mali get page bus_address 0xBAE79000 in MIU_1
[   11.421120] Mali get page bus_address 0xBAE7A000 in MIU_1
[   11.426616] Mali get page bus_address 0xBAE7B000 in MIU_1
[   11.432089] Mali get page bus_address 0xBAE7C000 in MIU_1
[   11.437637] Mali get page bus_address 0xBAE7D000 in MIU_1
[   11.443110] Mali get page bus_address 0xBAE7E000 in MIU_1
[   11.448590] Mali get page bus_address 0xBAE7F000 in MIU_1
[   11.454252] Mali get page bus_address 0xBAE80000 in MIU_1
[   11.459734] Mali get page bus_address 0xBAE81000 in MIU_1
[   11.465390] Mali get page bus_address 0xBAE82000 in MIU_1
[   11.471141] Mali get page bus_address 0xBAE83000 in MIU_1
[   11.476622] Mali get page bus_address 0xBAE84000 in MIU_1
[   11.482094] Mali get page bus_address 0xBAE85000 in MIU_1
[   11.487789] Mali get page bus_address 0xBAE86000 in MIU_1
[   11.493275] Mali get page bus_address 0xBAE87000 in MIU_1
[   11.498749] Mali get page bus_address 0xBAE88000 in MIU_1
[   11.504450] Mali get page bus_address 0xBAE89000 in MIU_1
[   11.510138] Mali get page bus_address 0xBAE8A000 in MIU_1
[   11.515840] Mali get page bus_address 0xBAE8B000 in MIU_1
[   11.521379] Mali get page bus_address 0xBAE8C000 in MIU_1
[   11.526900] Mali get page bus_address 0xBAE8D000 in MIU_1
[   11.532615] Mali get page bus_address 0xBAE90000 in MIU_1
[   11.538105] Mali get page bus_address 0xBAE91000 in MIU_1
[   11.543573] Mali get page bus_address 0xBAE92000 in MIU_1
[   11.549308] Mali get page bus_address 0xBAE93000 in MIU_1
[   11.555002] Mali get page bus_address 0xBAE94000 in MIU_1
[   11.560667] Mali get page bus_address 0xBAE95000 in MIU_1
[   11.567174] Mali get page bus_address 0xBAE34000 in MIU_1
[   11.572790] Mali get page bus_address 0xBAE35000 in MIU_1
[   11.578309] Mali get page bus_address 0xBAE36000 in MIU_1
[   11.584334] Mali get page bus_address 0xBAE37000 in MIU_1
[   11.589910] Mali get page bus_address 0xBAE38000 in MIU_1
[   11.595502] Mali get page bus_address 0xBAD2E000 in MIU_1
[   11.601144] Mali get page bus_address 0xBBA1A000 in MIU_1
[   11.606652] Mali get page bus_address 0xBB9FC000 in MIU_1
[   11.612152] Mali get page bus_address 0xBADEE000 in MIU_1
[   11.617958] Mali get page bus_address 0xBEFD5000 in MIU_1
[   11.623713] Mali get page bus_address 0xBAE39000 in MIU_1
[   11.629238] Mali get page bus_address 0xBAE0D000 in MIU_1
[   11.635064] Mali get page bus_address 0xBB9FB000 in MIU_1
[   11.640932] Mali get page bus_address 0xBAEAE000 in MIU_1
[   11.646566] Mali get page bus_address 0xBAEAF000 in MIU_1
[   11.652359] Mali get page bus_address 0xBAEB0000 in MIU_1
[   11.657968] Mali get page bus_address 0xBAEB1000 in MIU_1
[   11.668720] Mali get page bus_address 0xBAEB2000 in MIU_1
[   11.677564] Mali get page bus_address 0xBAEB3000 in MIU_1
[   11.683215] Mali get page bus_address 0xBAEB4000 in MIU_1
[   11.689148] Mali get page bus_address 0xBAEB5000 in MIU_1
[   11.694842] Mali get page bus_address 0xBAEB6000 in MIU_1
[   11.700672] Mali get page bus_address 0xBAEB7000 in MIU_1
[   11.706409] Mali get page bus_address 0xBAEB8000 in MIU_1
[   11.712139] Mali get page bus_address 0xBAEB9000 in MIU_1
[   11.717925] Mali get page bus_address 0xBAEBA000 in MIU_1
[   11.723628] Mali get page bus_address 0xBAEBB000 in MIU_1
[   11.729376] Mali get page bus_address 0xBAEBC000 in MIU_1
[   11.735033] Mali get page bus_address 0xBAEBD000 in MIU_1
[   11.740703] Mali get page bus_address 0xBAEBE000 in MIU_1
[   11.746408] Mali get page bus_address 0xBAEBF000 in MIU_1
[   11.752110] Mali get page bus_address 0xBAEC0000 in MIU_1
[   11.757978] Mali get page bus_address 0xBAEC1000 in MIU_1
[   11.763617] Mali get page bus_address 0xBAEC2000 in MIU_1
[   11.769278] Mali get page bus_address 0xBAEC3000 in MIU_1
[   11.774919] Mali get page bus_address 0xBAEC4000 in MIU_1
[   11.781587] Mali get page bus_address 0xBAE96000 in MIU_1
[   11.787844] Mali get page bus_address 0xBAE97000 in MIU_1
[   11.793915] Mali get page bus_address 0xBAE98000 in MIU_1
[   11.800211] Mali get page bus_address 0xBAE99000 in MIU_1
[   11.805929] Mali get page bus_address 0xBAE9A000 in MIU_1
[   11.811700] Mali get page bus_address 0xBAE9B000 in MIU_1
[   11.817736] Mali get page bus_address 0xBAE9C000 in MIU_1
[   11.823462] Mali get page bus_address 0xBAE9D000 in MIU_1
[   11.829150] Mali get page bus_address 0xBAE9E000 in MIU_1
[   11.834918] Mali get page bus_address 0xBAE9F000 in MIU_1
[   11.841138] Mali get page bus_address 0xBAEA0000 in MIU_1
[   11.846725] Mali get page bus_address 0xBAEA1000 in MIU_1
[   11.852668] Mali get page bus_address 0xBAEA2000 in MIU_1
[   11.858226] Mali get page bus_address 0xBAEA3000 in MIU_1
[   11.864566] Mali get page bus_address 0xBAEA4000 in MIU_1
[   11.870379] Mali get page bus_address 0xBAEA5000 in MIU_1
[   11.875957] Mali get page bus_address 0xBAEA6000 in MIU_1
[   11.881461] Mali get page bus_address 0xBAEA7000 in MIU_1
[   11.887196] Mali get page bus_address 0xBAEA8000 in MIU_1
[   11.892680] Mali get page bus_address 0xBAEA9000 in MIU_1
[   11.898187] Mali get page bus_address 0xBAEAA000 in MIU_1
[   11.904380] Mali get page bus_address 0xBAEAB000 in MIU_1
[   11.909907] Mali get page bus_address 0xBAEAC000 in MIU_1
[   11.915509] Mali get page bus_address 0xBAEAD000 in MIU_1
[   11.921115] Mali get page bus_address 0xBAECD000 in MIU_1
[   11.926676] Mali get page bus_address 0xBAECE000 in MIU_1
[   11.932807] Mali get page bus_address 0xBAECF000 in MIU_1
[   11.938870] Mali get page bus_address 0xBAED0000 in MIU_1
[   11.944925] Mali get page bus_address 0xBAED1000 in MIU_1
[   11.951075] Mali get page bus_address 0xBAED2000 in MIU_1
[   11.957231] Mali get page bus_address 0xBAED3000 in MIU_1
[   11.963169] Mali get page bus_address 0xBAED4000 in MIU_1
[   11.968970] Mali get page bus_address 0xBAED5000 in MIU_1
[   11.975086] Mali get page bus_address 0xBAED6000 in MIU_1
[   11.980582] Mali get page bus_address 0xBAED7000 in MIU_1
[   11.986685] Mali get page bus_address 0xBAEC5000 in MIU_1
[   11.992279] Mali get page bus_address 0xBAEC6000 in MIU_1
[   11.998749] Mali get page bus_address 0xBAE1F000 in MIU_1
[   12.004995] Mali get page bus_address 0xBAE1E000 in MIU_1
[   12.011225] Mali get page bus_address 0xBAED8000 in MIU_1
[   12.017105] Mali get page bus_address 0xBAED9000 in MIU_1
[   12.023787] Mali get page bus_address 0xBAEDA000 in MIU_1
[   12.029865] Mali get page bus_address 0xBAEDB000 in MIU_1
[   12.035486] Mali get page bus_address 0xBAEDC000 in MIU_1
[   12.041009] Mali get page bus_address 0xBAEDD000 in MIU_1
[   12.046480] Mali get page bus_address 0xBAEDE000 in MIU_1
[   12.052244] Mali get page bus_address 0xBAEDF000 in MIU_1
[   12.057715] Mali get page bus_address 0xBAEE0000 in MIU_1
[   12.063323] Mali get page bus_address 0xBAEE1000 in MIU_1
[   12.068864] Mali get page bus_address 0xBAEE2000 in MIU_1
[   12.074336] Mali get page bus_address 0xBAEE3000 in MIU_1
[   12.079816] Mali get page bus_address 0xBAEE4000 in MIU_1
[   12.085942] Mali get page bus_address 0xBAEE5000 in MIU_1
[   12.091475] Mali get page bus_address 0xBAEE6000 in MIU_1
[   12.096993] Mali get page bus_address 0xBAEE7000 in MIU_1
[   12.103184] Mali get page bus_address 0xBAEE8000 in MIU_1
[   12.108669] Mali get page bus_address 0xBAEE9000 in MIU_1
[   12.114147] Mali get page bus_address 0xBAEEA000 in MIU_1
[   12.120354] Mali get page bus_address 0xBAEEB000 in MIU_1
[   12.125911] Mali get page bus_address 0xBAEEC000 in MIU_1
[   12.131425] Mali get page bus_address 0xBAEED000 in MIU_1
[   12.136998] Mali get page bus_address 0xBAEEE000 in MIU_1
[   12.142505] Mali get page bus_address 0xBAEEF000 in MIU_1
[   12.148704] Mali get page bus_address 0xBAEF0000 in MIU_1
[   12.154946] Mali get page bus_address 0xBAEF1000 in MIU_1
[   12.160564] Mali get page bus_address 0xBAEF2000 in MIU_1
[   12.166686] Mali get page bus_address 0xBAEC7000 in MIU_1
[   12.172495] Mali get page bus_address 0xBAEC8000 in MIU_1
[   12.178270] Mali get page bus_address 0xBAEC9000 in MIU_1
[   12.184044] Mali get page bus_address 0xBAECA000 in MIU_1
[   12.189812] Mali get page bus_address 0xBAECB000 in MIU_1
[   12.195568] Mali get page bus_address 0xBAF0B000 in MIU_1
[   12.201356] Mali get page bus_address 0xBAF0C000 in MIU_1
[   12.207270] Mali get page bus_address 0xBAF0D000 in MIU_1
[   12.213074] Mali get page bus_address 0xBAF0E000 in MIU_1
[   12.224742] Mali get page bus_address 0xBAF0F000 in MIU_1
[   12.234826] Mali get page bus_address 0xBAF10000 in MIU_1
[   12.240670] Mali get page bus_address 0xBAF11000 in MIU_1
[   12.246561] Mali get page bus_address 0xBAF12000 in MIU_1
[   12.252445] Mali get page bus_address 0xBAF13000 in MIU_1
[   12.258325] Mali get page bus_address 0xBAF14000 in MIU_1
[   12.264102] Mali get page bus_address 0xBAF15000 in MIU_1
[   12.269986] Mali get page bus_address 0xBAF16000 in MIU_1
[   12.275773] Mali get page bus_address 0xBAF17000 in MIU_1
[   12.281628] Mali get page bus_address 0xBAF18000 in MIU_1
[   12.287527] Mali get page bus_address 0xBAF19000 in MIU_1
[   12.293413] Mali get page bus_address 0xBAF1A000 in MIU_1
[   12.299260] Mali get page bus_address 0xBAF1B000 in MIU_1
[   12.305019] Mali get page bus_address 0xBAF1C000 in MIU_1
[   12.310729] Mali get page bus_address 0xBAF1D000 in MIU_1
[   12.316415] Mali get page bus_address 0xBAF1E000 in MIU_1
[   12.322223] Mali get page bus_address 0xBAF1F000 in MIU_1
[   12.327899] Mali get page bus_address 0xBAF20000 in MIU_1
[   12.333640] Mali get page bus_address 0xBAF21000 in MIU_1
[   12.344858] Mali get page bus_address 0xBAF22000 in MIU_1
[   12.353249] Mali get page bus_address 0xBAF23000 in MIU_1
[   12.359070] Mali get page bus_address 0xBAF24000 in MIU_1
[   12.364834] Mali get page bus_address 0xBAF25000 in MIU_1
[   12.370606] Mali get page bus_address 0xBAF26000 in MIU_1
[   12.376308] Mali get page bus_address 0xBAF27000 in MIU_1
[   12.381984] Mali get page bus_address 0xBAF28000 in MIU_1
[   12.387994] Mali get page bus_address 0xBAF29000 in MIU_1
[   12.393798] Mali get page bus_address 0xBAF2A000 in MIU_1
[   12.399690] Mali get page bus_address 0xBAF2B000 in MIU_1
[   12.405407] Mali get page bus_address 0xBAF2C000 in MIU_1
[   12.411103] Mali get page bus_address 0xBAF2D000 in MIU_1
[   12.416792] Mali get page bus_address 0xBAF2E000 in MIU_1
[   12.422463] Mali get page bus_address 0xBAF2F000 in MIU_1
[   12.428153] Mali get page bus_address 0xBAF30000 in MIU_1
[   12.433858] Mali get page bus_address 0xBAF31000 in MIU_1
[   12.439536] Mali get page bus_address 0xBAF32000 in MIU_1
[   12.445215] Mali get page bus_address 0xBAF33000 in MIU_1
[   12.450905] Mali get page bus_address 0xBAF34000 in MIU_1
[   12.462099] Mali get page bus_address 0xBAF35000 in MIU_1
[   12.470394] Mali get page bus_address 0xBAF36000 in MIU_1
[   12.476194] Mali get page bus_address 0xBAF37000 in MIU_1
[   12.482033] Mali get page bus_address 0xBAF38000 in MIU_1
[   12.487771] Mali get page bus_address 0xBAF39000 in MIU_1
[   12.493464] Mali get page bus_address 0xBAF3A000 in MIU_1
[   12.499150] Mali get page bus_address 0xBAF3B000 in MIU_1
[   12.504857] Mali get page bus_address 0xBAF3C000 in MIU_1
[   12.510552] Mali get page bus_address 0xBAF3D000 in MIU_1
[   12.516296] Mali get page bus_address 0xBAF3E000 in MIU_1
[   12.522008] Mali get page bus_address 0xBAF3F000 in MIU_1
[   12.527777] Mali get page bus_address 0xBAF40000 in MIU_1
[   12.533508] Mali get page bus_address 0xBAF41000 in MIU_1
[   12.539264] Mali get page bus_address 0xBAF42000 in MIU_1
[   12.544985] Mali get page bus_address 0xBAF43000 in MIU_1
[   12.550780] Mali get page bus_address 0xBAF44000 in MIU_1
[   12.556746] Mali get page bus_address 0xBAF45000 in MIU_1
[   12.562574] Mali get page bus_address 0xBAF46000 in MIU_1
[   12.568427] Mali get page bus_address 0xBAF47000 in MIU_1
[   12.580048] Mali get page bus_address 0xBAF48000 in MIU_1
[   12.586747] Mali get page bus_address 0xBAEF3000 in MIU_1
[   12.592422] Mali get page bus_address 0xBAEF4000 in MIU_1
[   12.597982] Mali get page bus_address 0xBAEF5000 in MIU_1
[   12.603639] Mali get page bus_address 0xBAEF6000 in MIU_1
[   12.609191] Mali get page bus_address 0xBAEF7000 in MIU_1
[   12.614676] Mali get page bus_address 0xBAEF8000 in MIU_1
[   12.620547] Mali get page bus_address 0xBAEF9000 in MIU_1
[   12.626277] Mali get page bus_address 0xBAEFA000 in MIU_1
[   12.631809] Mali get page bus_address 0xBAEFB000 in MIU_1
[   12.635821] warning: `zygote' uses 32-bit capabilities (legacy support in use)
[   12.644930] Mali get page bus_address 0xBAEFC000 in MIU_1
[   12.650922] Mali get page bus_address 0xBAEFD000 in MIU_1
[   12.656465] Mali get page bus_address 0xBAEFE000 in MIU_1
[   12.661982] Mali get page bus_address 0xBAEFF000 in MIU_1
[   12.667742] Mali get page bus_address 0xBAF00000 in MIU_1
[   12.673606] Mali get page bus_address 0xBAF01000 in MIU_1
[   12.679087] Mali get page bus_address 0xBAF02000 in MIU_1
[   12.684657] Mali get page bus_address 0xBAF03000 in MIU_1
[   12.690313] Mali get page bus_address 0xBAF04000 in MIU_1
[   12.696177] Mali get page bus_address 0xBAF05000 in MIU_1
[   12.701724] Mali get page bus_address 0xBAF06000 in MIU_1
[   12.707216] Mali get page bus_address 0xBAF07000 in MIU_1
[   12.712690] Mali get page bus_address 0xBAF08000 in MIU_1
[   12.718231] Mali get page bus_address 0xBAF09000 in MIU_1
[   12.723722] Mali get page bus_address 0xBAF8D000 in MIU_1
[   12.729238] Mali get page bus_address 0xBB9F4000 in MIU_1
[   12.734766] Mali get page bus_address 0xBB9F5000 in MIU_1
[   12.740239] Mali get page bus_address 0xBBAE4000 in MIU_1
[   12.745720] Mali get page bus_address 0xBBAE5000 in MIU_1
[   12.751267] Mali get page bus_address 0xBB8D6000 in MIU_1
[   12.756741] Mali get page bus_address 0xBB8D7000 in MIU_1
[   12.762223] Mali get page bus_address 0xBAFA6000 in MIU_1
[   12.767929] Mali get page bus_address 0xBAFA7000 in MIU_1
[   12.773436] Mali get page bus_address 0xBAFA8000 in MIU_1
[   12.778928] Mali get page bus_address 0xBAFA9000 in MIU_1
[   12.784497] Mali get page bus_address 0xBAFAA000 in MIU_1
[   12.790008] Mali get page bus_address 0xBAFAB000 in MIU_1
[   12.795479] Mali get page bus_address 0xBAFAC000 in MIU_1
[   12.801097] Mali get page bus_address 0xBAFAD000 in MIU_1
[   12.806618] Mali get page bus_address 0xBAFAE000 in MIU_1
[   12.812724] Mali get page bus_address 0xBAFAF000 in MIU_1
[   12.818616] Mali get page bus_address 0xBAFB0000 in MIU_1
[   12.824106] Mali get page bus_address 0xBAFB1000 in MIU_1
[   12.829575] Mali get page bus_address 0xBAFB2000 in MIU_1
[   12.835284] Mali get page bus_address 0xBAFB3000 in MIU_1
[   12.840755] Mali get page bus_address 0xBAFB4000 in MIU_1
[   12.846236] Mali get page bus_address 0xBAFB5000 in MIU_1
[   12.851801] Mali get page bus_address 0xBAFB6000 in MIU_1
[   12.857279] Mali get page bus_address 0xBAFB7000 in MIU_1
[   12.862765] Mali get page bus_address 0xBAFB8000 in MIU_1
[   12.868520] Mali get page bus_address 0xBAFB9000 in MIU_1
[   12.874003] Mali get page bus_address 0xBAFBA000 in MIU_1
[   12.879491] Mali get page bus_address 0xBAFBB000 in MIU_1
[   12.885083] Mali get page bus_address 0xBAFBC000 in MIU_1
[   12.890572] Mali get page bus_address 0xBAFBD000 in MIU_1
[   12.896053] Mali get page bus_address 0xBAFBE000 in MIU_1
[   12.901982] Mali get page bus_address 0xBAFBF000 in MIU_1
[   12.907561] Mali get page bus_address 0xBAFC0000 in MIU_1
[   12.913067] Mali get page bus_address 0xBAFC1000 in MIU_1
[   12.918974] Mali get page bus_address 0xBAFC2000 in MIU_1
[   12.924993] Mali get page bus_address 0xBAFC3000 in MIU_1
[   12.931056] Mali get page bus_address 0xBAFC4000 in MIU_1
[   12.936661] Mali get page bus_address 0xBAFC5000 in MIU_1
[   12.942179] Mali get page bus_address 0xBAFC6000 in MIU_1
[   12.947647] Mali get page bus_address 0xBAFC7000 in MIU_1
[   12.953542] Mali get page bus_address 0xBAFC8000 in MIU_1
[   12.959070] Mali get page bus_address 0xBAFC9000 in MIU_1
[   12.964541] Mali get page bus_address 0xBAFCA000 in MIU_1
[   12.970620] Mali get page bus_address 0xBAFCB000 in MIU_1
[   12.976105] Mali get page bus_address 0xBAFCC000 in MIU_1
[   12.981608] Mali get page bus_address 0xBAFCD000 in MIU_1
[   12.987261] Mali get page bus_address 0xBAFCE000 in MIU_1
[   12.992765] Mali get page bus_address 0xBAFCF000 in MIU_1
[   12.998233] Mali get page bus_address 0xBAFD0000 in MIU_1
[   13.003842] Mali get page bus_address 0xBAFD1000 in MIU_1
[   13.009311] Mali get page bus_address 0xBAFD2000 in MIU_1
[   13.014805] Mali get page bus_address 0xBAFD3000 in MIU_1
[   13.020693] Mali get page bus_address 0xBAFD4000 in MIU_1
[   13.026423] Mali get page bus_address 0xBAFD5000 in MIU_1
[   13.032219] Mali get page bus_address 0xBAFD6000 in MIU_1
[   13.037913] Mali get page bus_address 0xBAFD7000 in MIU_1
[   13.043711] Mali get page bus_address 0xBAFD8000 in MIU_1
[   13.049324] Mali get page bus_address 0xBAFD9000 in MIU_1
[   13.055151] Mali get page bus_address 0xBAFDA000 in MIU_1
[   13.061001] Mali get page bus_address 0xBAFDB000 in MIU_1
[   13.066970] Mali get page bus_address 0xBAFDC000 in MIU_1
[   13.072633] Mali get page bus_address 0xBAFDD000 in MIU_1
[   13.078122] Mali get page bus_address 0xBAFDE000 in MIU_1
[   13.083672] Mali get page bus_address 0xBAFDF000 in MIU_1
[   13.089142] Mali get page bus_address 0xBAFE4000 in MIU_1
[   13.094621] Mali get page bus_address 0xBAFE5000 in MIU_1
[   13.100156] Mali get page bus_address 0xBAFE6000 in MIU_1
[   13.105628] Mali get page bus_address 0xBAFE7000 in MIU_1
[   13.111141] Mali get page bus_address 0xBAFE8000 in MIU_1
[   13.117063] Mali get page bus_address 0xBAFE9000 in MIU_1
[   13.122545] Mali get page bus_address 0xBAFEA000 in MIU_1
[   13.128024] Mali get page bus_address 0xBAFEB000 in MIU_1
[   13.133805] Mali get page bus_address 0xBAFEC000 in MIU_1
[   13.139331] Mali get page bus_address 0xBAFED000 in MIU_1
[   13.144810] Mali get page bus_address 0xBAFEE000 in MIU_1
[   13.150526] Mali get page bus_address 0xBAFEF000 in MIU_1
[   13.155998] Mali get page bus_address 0xBAFF0000 in MIU_1
[   13.161475] Mali get page bus_address 0xBAFF1000 in MIU_1
[   13.167169] Mali get page bus_address 0xBAFF2000 in MIU_1
[   13.172652] Mali get page bus_address 0xBAFF3000 in MIU_1
[   13.178117] Mali get page bus_address 0xBAFF4000 in MIU_1
[   13.183847] Mali get page bus_address 0xBAFF5000 in MIU_1
[   13.189373] Mali get page bus_address 0xBAFF6000 in MIU_1
[   13.194852] Mali get page bus_address 0xBAFF7000 in MIU_1
[   13.200426] Mali get page bus_address 0xBAFF8000 in MIU_1
[   13.205900] Mali get page bus_address 0xBAFF9000 in MIU_1
[   13.211427] Mali get page bus_address 0xBAFFA000 in MIU_1
[   13.216988] Mali get page bus_address 0xBAFFB000 in MIU_1
[   13.222469] Mali get page bus_address 0xBAFFC000 in MIU_1
[   13.227947] Mali get page bus_address 0xBAFFD000 in MIU_1
[   13.233605] Mali get page bus_address 0xBAFFE000 in MIU_1
[   13.239180] Mali get page bus_address 0xBAFFF000 in MIU_1
[   13.244940] Mali get page bus_address 0xB5800000 in MIU_1
[   13.251047] Mali get page bus_address 0xB5801000 in MIU_1
[   13.257241] Mali get page bus_address 0xB5802000 in MIU_1
[   13.263070] Mali get page bus_address 0xB5803000 in MIU_1
[   13.269195] Mali get page bus_address 0xB5804000 in MIU_1
[   13.275324] Mali get page bus_address 0xB5805000 in MIU_1
[   13.281180] Mali get page bus_address 0xB5806000 in MIU_1
[   13.287190] Mali get page bus_address 0xB5807000 in MIU_1
[   13.292823] Mali get page bus_address 0xB5808000 in MIU_1
[   13.298616] Mali get page bus_address 0xB5809000 in MIU_1
[   13.304658] Mali get page bus_address 0xB580A000 in MIU_1
[   13.310363] Mali get page bus_address 0xB580B000 in MIU_1
[   13.316030] Mali get page bus_address 0xB580C000 in MIU_1
[   13.321990] Mali get page bus_address 0xB580D000 in MIU_1
[   13.327662] Mali get page bus_address 0xB580E000 in MIU_1
[   13.333581] Mali get page bus_address 0xB580F000 in MIU_1
[   13.339255] Mali get page bus_address 0xB5810000 in MIU_1
[   13.344910] Mali get page bus_address 0xB5811000 in MIU_1
[   13.350853] Mali get page bus_address 0xB5812000 in MIU_1
[   13.356505] Mali get page bus_address 0xB5813000 in MIU_1
[   13.362144] Mali get page bus_address 0xB5814000 in MIU_1
[   13.368166] Mali get page bus_address 0xB5815000 in MIU_1
[   13.373814] Mali get page bus_address 0xB5816000 in MIU_1
[   13.379472] Mali get page bus_address 0xB5817000 in MIU_1
[   13.385371] Mali get page bus_address 0xB5818000 in MIU_1
[   13.391020] Mali get page bus_address 0xB5819000 in MIU_1
[   13.396649] Mali get page bus_address 0xB581A000 in MIU_1
[   13.402493] Mali get page bus_address 0xB581B000 in MIU_1
[   13.408121] Mali get page bus_address 0xB581C000 in MIU_1
[   13.413736] Mali get page bus_address 0xB581D000 in MIU_1
[   13.419726] Mali get page bus_address 0xB581F000 in MIU_1
[   13.425384] Mali get page bus_address 0xBEF24000 in MIU_1
[   13.431057] Mali get page bus_address 0xBEF25000 in MIU_1
[   13.437347] Mali get page bus_address 0xB5820000 in MIU_1
[   13.443056] Mali get page bus_address 0xB5821000 in MIU_1
[   13.448773] Mali get page bus_address 0xB5822000 in MIU_1
[   13.454806] Mali get page bus_address 0xB5823000 in MIU_1
[   13.460633] Mali get page bus_address 0xB5824000 in MIU_1
[   13.466695] Mali get page bus_address 0xBAF67000 in MIU_1
[   13.472189] Mali get page bus_address 0xBAF66000 in MIU_1
[   13.477756] Mali get page bus_address 0xBAF65000 in MIU_1
[   13.483228] Mali get page bus_address 0xBAF64000 in MIU_1
[   13.488719] Mali get page bus_address 0xBAF63000 in MIU_1
[   13.494186] Mali get page bus_address 0xBAF62000 in MIU_1
[   13.499669] Mali get page bus_address 0xB5864000 in MIU_1
[   13.505127] Mali get page bus_address 0xB5865000 in MIU_1
[   13.510646] Mali get page bus_address 0xB5866000 in MIU_1
[   13.516109] Mali get page bus_address 0xB5867000 in MIU_1
[   13.521567] Mali get page bus_address 0xB5868000 in MIU_1
[   13.527023] Mali get page bus_address 0xB5869000 in MIU_1
[   13.532512] Mali get page bus_address 0xB586A000 in MIU_1
[   13.537969] Mali get page bus_address 0xB586B000 in MIU_1
[   13.543463] Mali get page bus_address 0xB586C000 in MIU_1
[   13.548923] Mali get page bus_address 0xB586D000 in MIU_1
[   13.554575] Mali get page bus_address 0xB586E000 in MIU_1
[   13.560073] Mali get page bus_address 0xB586F000 in MIU_1
[   13.565566] Mali get page bus_address 0xB5870000 in MIU_1
[   13.571024] Mali get page bus_address 0xB5871000 in MIU_1
[   13.576489] Mali get page bus_address 0xB5872000 in MIU_1
[   13.582054] Mali get page bus_address 0xB5873000 in MIU_1
[   13.587520] Mali get page bus_address 0xB5874000 in MIU_1
[   13.592978] Mali get page bus_address 0xB5875000 in MIU_1
[   13.598440] Mali get page bus_address 0xB5876000 in MIU_1
[   13.603896] Mali get page bus_address 0xB5877000 in MIU_1
[   13.609350] Mali get page bus_address 0xB5878000 in MIU_1
[   13.614840] Mali get page bus_address 0xB5879000 in MIU_1
[   13.620300] Mali get page bus_address 0xB587A000 in MIU_1
[   13.625909] Mali get page bus_address 0xB587B000 in MIU_1
[   13.631371] Mali get page bus_address 0xB587C000 in MIU_1
[   13.636827] Mali get page bus_address 0xB587D000 in MIU_1
[   13.642276] Mali get page bus_address 0xB587E000 in MIU_1
[   13.647766] Mali get page bus_address 0xB587F000 in MIU_1
[   13.653227] Mali get page bus_address 0xB5880000 in MIU_1
[   13.658690] Mali get page bus_address 0xB5881000 in MIU_1
[   13.664184] Mali get page bus_address 0xB5883000 in MIU_1
[   13.669672] Mali get page bus_address 0xB5862000 in MIU_1
[   13.675132] Mali get page bus_address 0xB5863000 in MIU_1
[   13.680589] Mali get page bus_address 0xB5884000 in MIU_1
[   13.686046] Mali get page bus_address 0xB5885000 in MIU_1
[   13.691503] Mali get page bus_address 0xB5886000 in MIU_1
[   13.696960] Mali get page bus_address 0xB5887000 in MIU_1
[   13.702418] Mali get page bus_address 0xB5888000 in MIU_1
[   13.707875] Mali get page bus_address 0xB5889000 in MIU_1
[   13.713329] Mali get page bus_address 0xB588A000 in MIU_1
[   13.718815] Mali get page bus_address 0xB588B000 in MIU_1
[   13.724286] Mali get page bus_address 0xB588C000 in MIU_1
[   13.729744] Mali get page bus_address 0xB588D000 in MIU_1
[   13.735200] Mali get page bus_address 0xB588E000 in MIU_1
[   13.740653] Mali get page bus_address 0xB588F000 in MIU_1
[   13.746107] Mali get page bus_address 0xB5890000 in MIU_1
[   13.751594] Mali get page bus_address 0xB5891000 in MIU_1
[   13.757053] Mali get page bus_address 0xB5892000 in MIU_1
[   13.762508] Mali get page bus_address 0xB5893000 in MIU_1
[   13.767996] Mali get page bus_address 0xB5894000 in MIU_1
[   13.773483] Mali get page bus_address 0xB5895000 in MIU_1
[   13.778941] Mali get page bus_address 0xB5896000 in MIU_1
[   13.784398] Mali get page bus_address 0xB5897000 in MIU_1
[   13.789857] Mali get page bus_address 0xB5898000 in MIU_1
[   13.795313] Mali get page bus_address 0xB5899000 in MIU_1
[   13.800770] Mali get page bus_address 0xB589A000 in MIU_1
[   13.806222] Mali get page bus_address 0xB589B000 in MIU_1
[   13.811678] Mali get page bus_address 0xB589C000 in MIU_1
[   13.817133] Mali get page bus_address 0xB589D000 in MIU_1
[   13.822634] Mali get page bus_address 0xB589E000 in MIU_1
[   13.828099] Mali get page bus_address 0xB58A0000 in MIU_1
[   13.833558] Mali get page bus_address 0xB58A1000 in MIU_1
[   13.839010] Mali get page bus_address 0xB58A2000 in MIU_1
[   13.844462] Mali get page bus_address 0xB58A3000 in MIU_1
[   13.849914] Mali get page bus_address 0xB58A4000 in MIU_1
[   13.855408] Mali get page bus_address 0xB58A5000 in MIU_1
[   13.860866] Mali get page bus_address 0xB58A6000 in MIU_1
[   13.866322] Mali get page bus_address 0xB58A7000 in MIU_1
[   13.871810] Mali get page bus_address 0xB58A8000 in MIU_1
[   13.877297] Mali get page bus_address 0xB58A9000 in MIU_1
[   13.882755] Mali get page bus_address 0xB58AA000 in MIU_1
[   13.888490] Mali get page bus_address 0xB58AB000 in MIU_1
[   13.894132] Mali get page bus_address 0xB58AC000 in MIU_1
[   13.899746] Mali get page bus_address 0xB58AD000 in MIU_1
[   13.905217] Mali get page bus_address 0xB58AE000 in MIU_1
[   13.910677] Mali get page bus_address 0xB58AF000 in MIU_1
[   13.916140] Mali get page bus_address 0xB58B0000 in MIU_1
[   13.921598] Mali get page bus_address 0xB58B1000 in MIU_1
[   13.927087] Mali get page bus_address 0xB58B2000 in MIU_1
[   13.932545] Mali get page bus_address 0xB58B3000 in MIU_1
[   13.938394] Mali get page bus_address 0xB58B4000 in MIU_1
[   13.943926] Mali get page bus_address 0xB58B5000 in MIU_1
[   13.949458] Mali get page bus_address 0xB58B6000 in MIU_1
[   13.954976] Mali get page bus_address 0xB58B7000 in MIU_1
[   13.960554] Mali get page bus_address 0xB58B8000 in MIU_1
[   13.966089] Mali get page bus_address 0xB58B9000 in MIU_1
[   13.971599] Mali get page bus_address 0xB58BA000 in MIU_1
[   13.977211] Mali get page bus_address 0xB58BB000 in MIU_1
[   13.982737] Mali get page bus_address 0xB58BC000 in MIU_1
[   13.988291] Mali get page bus_address 0xB58BD000 in MIU_1
[   13.993825] Mali get page bus_address 0xB58BE000 in MIU_1
[   13.999362] Mali get page bus_address 0xB58BF000 in MIU_1
[   14.004843] Mali get page bus_address 0xB58C6000 in MIU_1
[   14.010311] Mali get page bus_address 0xB58C7000 in MIU_1
[   14.015776] Mali get page bus_address 0xB58C8000 in MIU_1
[   14.021241] Mali get page bus_address 0xB58C9000 in MIU_1
[   14.026707] Mali get page bus_address 0xB58CA000 in MIU_1
[   14.032213] Mali get page bus_address 0xB58CB000 in MIU_1
[   14.037691] Mali get page bus_address 0xB58CC000 in MIU_1
[   14.043163] Mali get page bus_address 0xB58CD000 in MIU_1
[   14.048714] Mali get page bus_address 0xB58CE000 in MIU_1
[   14.054211] Mali get page bus_address 0xB58CF000 in MIU_1
[   14.059774] Mali get page bus_address 0xB58D0000 in MIU_1
[   14.065296] Mali get page bus_address 0xB58D1000 in MIU_1
[   14.070851] Mali get page bus_address 0xB58D2000 in MIU_1
[   14.076382] Mali get page bus_address 0xB58D3000 in MIU_1
[   14.082004] Mali get page bus_address 0xB58D4000 in MIU_1
[   14.087576] Mali get page bus_address 0xB58D5000 in MIU_1
[   14.093103] Mali get page bus_address 0xB58D6000 in MIU_1
[   14.098651] Mali get page bus_address 0xB58D7000 in MIU_1
[   14.104181] Mali get page bus_address 0xB58D8000 in MIU_1
[   14.109644] Mali get page bus_address 0xB58D9000 in MIU_1
[   14.115106] Mali get page bus_address 0xB58DA000 in MIU_1
[   14.120565] Mali get page bus_address 0xB58DB000 in MIU_1
[   14.126018] Mali get page bus_address 0xB58DC000 in MIU_1
[   14.131474] Mali get page bus_address 0xB58DD000 in MIU_1
[   14.136968] Mali get page bus_address 0xB58DE000 in MIU_1
[   14.142428] Mali get page bus_address 0xB58DF000 in MIU_1
[   14.147883] Mali get page bus_address 0xB58E0000 in MIU_1
[   14.153337] Mali get page bus_address 0xB58E1000 in MIU_1
[   14.158794] Mali get page bus_address 0xB58E2000 in MIU_1
[   14.164250] Mali get page bus_address 0xB58E3000 in MIU_1
[   14.169748] Mali get page bus_address 0xB58E6000 in MIU_1
[   14.175208] Mali get page bus_address 0xB58E7000 in MIU_1
[   14.180665] Mali get page bus_address 0xB58E8000 in MIU_1
[   14.186153] Mali get page bus_address 0xB58E9000 in MIU_1
[   14.191644] Mali get page bus_address 0xB58EA000 in MIU_1
[   14.197103] Mali get page bus_address 0xB58EB000 in MIU_1
[   14.202560] Mali get page bus_address 0xB58EC000 in MIU_1
[   14.208015] Mali get page bus_address 0xB58ED000 in MIU_1
[   14.213470] Mali get page bus_address 0xB58EE000 in MIU_1
[   14.218926] Mali get page bus_address 0xB58EF000 in MIU_1
[   14.224381] Mali get page bus_address 0xB58F0000 in MIU_1
[   14.229830] Mali get page bus_address 0xB58F1000 in MIU_1
[   14.235285] Mali get page bus_address 0xB58F2000 in MIU_1
[   14.240771] Mali get page bus_address 0xB58F3000 in MIU_1
[   14.246233] Mali get page bus_address 0xB58F4000 in MIU_1
[   14.251690] Mali get page bus_address 0xB58F5000 in MIU_1
[   14.257146] Mali get page bus_address 0xB58F6000 in MIU_1
[   14.262609] Mali get page bus_address 0xB58F7000 in MIU_1
[   14.268062] Mali get page bus_address 0xB58F8000 in MIU_1
[   14.273546] Mali get page bus_address 0xB58F9000 in MIU_1
[   14.279004] Mali get page bus_address 0xB58FA000 in MIU_1
[   14.284457] Mali get page bus_address 0xB58FB000 in MIU_1
[   14.327772] UMP get page bus_address 0xB5825000 in MIU_1
[   14.333457] UMP get page bus_address 0xB5826000 in MIU_1
[   14.339053] UMP get page bus_address 0xB5827000 in MIU_1
[   14.344604] UMP get page bus_address 0xB5828000 in MIU_1
[   14.350223] UMP get page bus_address 0xB5829000 in MIU_1
[   14.355771] UMP get page bus_address 0xB582A000 in MIU_1
[   14.361659] UMP get page bus_address 0xB58FC000 in MIU_1
[   14.367177] UMP get page bus_address 0xB58FD000 in MIU_1
[   14.372561] UMP get page bus_address 0xB58FE000 in MIU_1
[   14.377986] UMP get page bus_address 0xB58FF000 in MIU_1
[   14.383354] UMP get page bus_address 0xB5900000 in MIU_1
[   14.388730] UMP get page bus_address 0xB5901000 in MIU_1
[   14.391821] UMP get page bus_address 0xB5902000 in MIU_1
[   14.397212] UMP get page bus_address 0xB5903000 in MIU_1
[   14.402610] UMP get page bus_address 0xB5904000 in MIU_1
[   14.408800] UMP get page bus_address 0xB593F000 in MIU_1
[   14.415069] UMP get page bus_address 0xB593E000 in MIU_1
[   14.420464] UMP get page bus_address 0xB593D000 in MIU_1
[   14.425859] UMP get page bus_address 0xB593C000 in MIU_1
[   14.431232] UMP get page bus_address 0xB593B000 in MIU_1
[   14.436663] UMP get page bus_address 0xB593A000 in MIU_1
[   14.442080] UMP get page bus_address 0xB5939000 in MIU_1
[   14.447452] UMP get page bus_address 0xB5938000 in MIU_1
[   14.452826] UMP get page bus_address 0xB5937000 in MIU_1
[   14.458192] UMP get page bus_address 0xB5936000 in MIU_1
[   14.463591] UMP get page bus_address 0xB5935000 in MIU_1
[   14.468978] UMP get page bus_address 0xB5934000 in MIU_1
[   14.474353] UMP get page bus_address 0xB5933000 in MIU_1
[   14.479759] UMP get page bus_address 0xB5932000 in MIU_1
[   14.485136] UMP get page bus_address 0xB5931000 in MIU_1
[   14.490503] UMP get page bus_address 0xB5930000 in MIU_1
[   14.495932] UMP get page bus_address 0xB592F000 in MIU_1
[   14.501307] UMP get page bus_address 0xB592E000 in MIU_1
[   14.506670] UMP get page bus_address 0xB592D000 in MIU_1
[   14.512036] UMP get page bus_address 0xB592C000 in MIU_1
[   14.517405] UMP get page bus_address 0xB592B000 in MIU_1
[   14.522769] UMP get page bus_address 0xB592A000 in MIU_1
[   14.528134] UMP get page bus_address 0xB5929000 in MIU_1
[   14.533499] UMP get page bus_address 0xB5928000 in MIU_1
[   14.538866] UMP get page bus_address 0xB5927000 in MIU_1
[   14.544289] UMP get page bus_address 0xB5926000 in MIU_1
[   14.549666] UMP get page bus_address 0xB5925000 in MIU_1
[   14.555076] UMP get page bus_address 0xB5924000 in MIU_1
[   14.560442] UMP get page bus_address 0xB5923000 in MIU_1
[   14.565807] UMP get page bus_address 0xBB838000 in MIU_1
[   14.571171] UMP get page bus_address 0xBBA91000 in MIU_1
[   14.576531] UMP get page bus_address 0xB5905000 in MIU_1
[   14.582140] UMP get page bus_address 0xB5922000 in MIU_1
[   14.587514] UMP get page bus_address 0xBBA59000 in MIU_1
[   14.592896] UMP get page bus_address 0xBB8EC000 in MIU_1
[   14.598321] UMP get page bus_address 0xBB8ED000 in MIU_1
[   14.603688] UMP get page bus_address 0xBB914000 in MIU_1
[   14.609052] UMP get page bus_address 0xBB915000 in MIU_1
[   14.614426] UMP get page bus_address 0xBB916000 in MIU_1
[   14.619830] UMP get page bus_address 0xBB917000 in MIU_1
[   14.625396] UMP get page bus_address 0xB5940000 in MIU_1
[   14.630793] UMP get page bus_address 0xB5941000 in MIU_1
[   14.636178] UMP get page bus_address 0xB5942000 in MIU_1
[   14.641556] UMP get page bus_address 0xB5943000 in MIU_1
[   14.647032] UMP get page bus_address 0xB5944000 in MIU_1
[   14.652410] UMP get page bus_address 0xB5945000 in MIU_1
[   14.657796] UMP get page bus_address 0xB5946000 in MIU_1
[   14.663193] UMP get page bus_address 0xB5947000 in MIU_1
[   14.668594] UMP get page bus_address 0xB5948000 in MIU_1
[   14.673960] UMP get page bus_address 0xB5949000 in MIU_1
[   14.679368] UMP get page bus_address 0xB594A000 in MIU_1
[   14.684981] UMP get page bus_address 0xB594B000 in MIU_1
[   14.690611] UMP get page bus_address 0xB594C000 in MIU_1
[   14.696173] UMP get page bus_address 0xB594D000 in MIU_1
[   14.701762] UMP get page bus_address 0xB594E000 in MIU_1
[   14.707290] UMP get page bus_address 0xB594F000 in MIU_1
[   14.712812] UMP get page bus_address 0xB5950000 in MIU_1
[   14.718359] UMP get page bus_address 0xB5951000 in MIU_1
[   14.723992] UMP get page bus_address 0xB5952000 in MIU_1
[   14.729555] UMP get page bus_address 0xB5953000 in MIU_1
[   14.735168] UMP get page bus_address 0xB5954000 in MIU_1
[   14.740879] UMP get page bus_address 0xB5955000 in MIU_1
[   14.746502] UMP get page bus_address 0xB5956000 in MIU_1
[   14.752172] UMP get page bus_address 0xB5957000 in MIU_1
[   14.757711] UMP get page bus_address 0xB5958000 in MIU_1
[   14.763360] UMP get page bus_address 0xB5959000 in MIU_1
[   14.768960] UMP get page bus_address 0xB595A000 in MIU_1
[   14.774558] UMP get page bus_address 0xB595B000 in MIU_1
[   14.780157] UMP get page bus_address 0xB595C000 in MIU_1
[   14.785823] UMP get page bus_address 0xB595D000 in MIU_1
[   14.791390] UMP get page bus_address 0xB595E000 in MIU_1
[   14.797013] UMP get page bus_address 0xB595F000 in MIU_1
[   14.802614] UMP get page bus_address 0xB5960000 in MIU_1
[   14.808282] UMP get page bus_address 0xB5961000 in MIU_1
[   14.813818] UMP get page bus_address 0xB5962000 in MIU_1
[   14.819341] UMP get page bus_address 0xB5963000 in MIU_1
[   14.824908] UMP get page bus_address 0xB5964000 in MIU_1
[   14.830442] UMP get page bus_address 0xB5965000 in MIU_1
[   14.836100] UMP get page bus_address 0xB5966000 in MIU_1
[   14.841676] UMP get page bus_address 0xB5967000 in MIU_1
[   14.847213] UMP get page bus_address 0xB5968000 in MIU_1
[   14.852779] UMP get page bus_address 0xB5969000 in MIU_1
[   14.858401] UMP get page bus_address 0xB596A000 in MIU_1
[   14.864011] UMP get page bus_address 0xB596B000 in MIU_1
[   14.869603] UMP get page bus_address 0xB596C000 in MIU_1
[   14.875206] UMP get page bus_address 0xB596D000 in MIU_1
[   14.880792] UMP get page bus_address 0xB596E000 in MIU_1
[   14.886439] UMP get page bus_address 0xB596F000 in MIU_1
[   14.892014] UMP get page bus_address 0xB5970000 in MIU_1
[   14.897650] UMP get page bus_address 0xB5971000 in MIU_1
[   14.903277] UMP get page bus_address 0xB5972000 in MIU_1
[   14.908889] UMP get page bus_address 0xB5973000 in MIU_1
[   14.914411] UMP get page bus_address 0xB5974000 in MIU_1
[   14.919968] UMP get page bus_address 0xB5975000 in MIU_1
[   14.925511] UMP get page bus_address 0xB5976000 in MIU_1
[   14.931253] UMP get page bus_address 0xB5977000 in MIU_1
[   14.936805] UMP get page bus_address 0xB5978000 in MIU_1
[   14.942346] UMP get page bus_address 0xB5979000 in MIU_1
[   14.947902] UMP get page bus_address 0xB597A000 in MIU_1
[   14.953550] UMP get page bus_address 0xB597B000 in MIU_1
[   14.959352] UMP get page bus_address 0xB597C000 in MIU_1
[   14.964906] UMP get page bus_address 0xB597D000 in MIU_1
[   14.970444] UMP get page bus_address 0xB597E000 in MIU_1
[   14.976158] UMP get page bus_address 0xB597F000 in MIU_1
[   14.981730] UMP get page bus_address 0xB5980000 in MIU_1
[   14.987302] UMP get page bus_address 0xB5981000 in MIU_1
[   14.992902] UMP get page bus_address 0xB5982000 in MIU_1
[   14.998482] UMP get page bus_address 0xB5983000 in MIU_1
[   15.004236] UMP get page bus_address 0xB5984000 in MIU_1
[   15.009917] UMP get page bus_address 0xB5985000 in MIU_1
[   15.015541] UMP get page bus_address 0xB5986000 in MIU_1
[   15.021205] UMP get page bus_address 0xB5987000 in MIU_1
[   15.026778] UMP get page bus_address 0xB5988000 in MIU_1
[   15.032365] UMP get page bus_address 0xB5989000 in MIU_1
[   15.038037] UMP get page bus_address 0xB598A000 in MIU_1
[   15.043646] UMP get page bus_address 0xB598B000 in MIU_1
[   15.049222] UMP get page bus_address 0xB598C000 in MIU_1
[   15.054803] UMP get page bus_address 0xB598D000 in MIU_1
[   15.060390] UMP get page bus_address 0xB598E000 in MIU_1
[   15.065939] UMP get page bus_address 0xB598F000 in MIU_1
[   15.071799] UMP get page bus_address 0xB5990000 in MIU_1
[   15.077336] UMP get page bus_address 0xB5991000 in MIU_1
[   15.083059] UMP get page bus_address 0xB5992000 in MIU_1
[   15.088775] UMP get page bus_address 0xB5993000 in MIU_1
[   15.094316] UMP get page bus_address 0xB5994000 in MIU_1
[   15.099842] UMP get page bus_address 0xB5995000 in MIU_1
[   15.105433] UMP get page bus_address 0xB5996000 in MIU_1
[   15.111000] UMP get page bus_address 0xB5997000 in MIU_1
[   15.116537] UMP get page bus_address 0xB5998000 in MIU_1
[   15.122133] UMP get page bus_address 0xB5999000 in MIU_1
[   15.127734] UMP get page bus_address 0xB599A000 in MIU_1
[   15.133309] UMP get page bus_address 0xB599B000 in MIU_1
[   15.138957] UMP get page bus_address 0xB599C000 in MIU_1
[   15.144608] UMP get page bus_address 0xB599D000 in MIU_1
[   15.150233] UMP get page bus_address 0xB599E000 in MIU_1
[   15.155840] UMP get page bus_address 0xB599F000 in MIU_1
[   15.161452] UMP get page bus_address 0xB59A0000 in MIU_1
[   15.167072] UMP get page bus_address 0xB59A1000 in MIU_1
[   15.172689] UMP get page bus_address 0xB59A2000 in MIU_1
[   15.178279] UMP get page bus_address 0xB59A3000 in MIU_1
[   15.183882] UMP get page bus_address 0xB59A4000 in MIU_1
[   15.189411] UMP get page bus_address 0xB59A5000 in MIU_1
[   15.194955] UMP get page bus_address 0xB59A6000 in MIU_1
[   15.200514] UMP get page bus_address 0xB59A7000 in MIU_1
[   15.206225] UMP get page bus_address 0xB59A8000 in MIU_1
[   15.211855] UMP get page bus_address 0xB59A9000 in MIU_1
[   15.217483] UMP get page bus_address 0xB59AA000 in MIU_1
[   15.223042] UMP get page bus_address 0xB59AB000 in MIU_1
[   15.228642] UMP get page bus_address 0xB59AC000 in MIU_1
[   15.234261] UMP get page bus_address 0xB59AD000 in MIU_1
[   15.239813] UMP get page bus_address 0xB59AE000 in MIU_1
[   15.245333] UMP get page bus_address 0xB59AF000 in MIU_1
[   15.250863] UMP get page bus_address 0xB59B0000 in MIU_1
[   15.256424] UMP get page bus_address 0xB59B1000 in MIU_1
[   15.262032] UMP get page bus_address 0xB59B2000 in MIU_1
[   15.267630] UMP get page bus_address 0xB59B3000 in MIU_1
[   15.273221] UMP get page bus_address 0xB59B4000 in MIU_1
[   15.278799] UMP get page bus_address 0xB59B5000 in MIU_1
[   15.284547] UMP get page bus_address 0xB59B6000 in MIU_1
[   15.290137] UMP get page bus_address 0xB59B7000 in MIU_1
[   15.295704] UMP get page bus_address 0xB59B8000 in MIU_1
[   15.301260] UMP get page bus_address 0xB59B9000 in MIU_1
[   15.306883] UMP get page bus_address 0xB59BA000 in MIU_1
[   15.312465] UMP get page bus_address 0xB59BB000 in MIU_1
[   15.318059] UMP get page bus_address 0xB59BC000 in MIU_1
[   15.323778] UMP get page bus_address 0xB59BD000 in MIU_1
[   15.329356] UMP get page bus_address 0xB59BE000 in MIU_1
[   15.334954] UMP get page bus_address 0xB59BF000 in MIU_1
[   15.340512] UMP get page bus_address 0xB59C0000 in MIU_1
[   15.346075] UMP get page bus_address 0xB59C1000 in MIU_1
[   15.351638] UMP get page bus_address 0xB59C2000 in MIU_1
[   15.357185] UMP get page bus_address 0xB59C3000 in MIU_1
[   15.362767] UMP get page bus_address 0xB59C4000 in MIU_1
[   15.368375] UMP get page bus_address 0xB59C5000 in MIU_1
[   15.373935] UMP get page bus_address 0xB59C6000 in MIU_1
[   15.379518] UMP get page bus_address 0xB59C7000 in MIU_1
[   15.385115] UMP get page bus_address 0xB59C8000 in MIU_1
[   15.390852] UMP get page bus_address 0xB59C9000 in MIU_1
[   15.396431] UMP get page bus_address 0xB59CA000 in MIU_1
[   15.402036] UMP get page bus_address 0xB59CB000 in MIU_1
[   15.407693] UMP get page bus_address 0xB59CC000 in MIU_1
[   15.413291] UMP get page bus_address 0xB59CD000 in MIU_1
[   15.418937] UMP get page bus_address 0xB59CE000 in MIU_1
[   15.424602] UMP get page bus_address 0xB59CF000 in MIU_1
[   15.430180] UMP get page bus_address 0xB59D0000 in MIU_1
[   15.435741] UMP get page bus_address 0xB59D1000 in MIU_1
[   15.441285] UMP get page bus_address 0xB59D2000 in MIU_1
[   15.446873] UMP get page bus_address 0xB59D3000 in MIU_1
[   15.452466] UMP get page bus_address 0xB59D4000 in MIU_1
[   15.458028] UMP get page bus_address 0xB59D5000 in MIU_1
[   15.463633] UMP get page bus_address 0xB59D6000 in MIU_1
[   15.469193] UMP get page bus_address 0xB59D7000 in MIU_1
[   15.474750] UMP get page bus_address 0xB59D8000 in MIU_1
[   15.480330] UMP get page bus_address 0xB59D9000 in MIU_1
[   15.485924] UMP get page bus_address 0xB59DA000 in MIU_1
[   15.491559] UMP get page bus_address 0xB59DB000 in MIU_1
[   15.497104] UMP get page bus_address 0xB59DC000 in MIU_1
[   15.502659] UMP get page bus_address 0xB59DD000 in MIU_1
[   15.508352] UMP get page bus_address 0xB59DE000 in MIU_1
[   15.513900] UMP get page bus_address 0xB59DF000 in MIU_1
[   15.519465] UMP get page bus_address 0xB59E0000 in MIU_1
[   15.525032] UMP get page bus_address 0xB59E1000 in MIU_1
[   15.530716] UMP get page bus_address 0xB59E2000 in MIU_1
[   15.536270] UMP get page bus_address 0xB59E3000 in MIU_1
[   15.541835] UMP get page bus_address 0xB59E4000 in MIU_1
[   15.547460] UMP get page bus_address 0xB59E5000 in MIU_1
[   15.553011] UMP get page bus_address 0xB59E6000 in MIU_1
[   15.558592] UMP get page bus_address 0xB59E7000 in MIU_1
[   15.564183] UMP get page bus_address 0xB59E8000 in MIU_1
[   15.569786] UMP get page bus_address 0xB59E9000 in MIU_1
[   15.575385] UMP get page bus_address 0xB59EA000 in MIU_1
[   15.580972] UMP get page bus_address 0xB59EB000 in MIU_1
[   15.586616] UMP get page bus_address 0xB59EC000 in MIU_1
[   15.592235] UMP get page bus_address 0xB59ED000 in MIU_1
[   15.597772] UMP get page bus_address 0xB59EE000 in MIU_1
[   15.603313] UMP get page bus_address 0xB59EF000 in MIU_1
[   15.608894] UMP get page bus_address 0xB59F0000 in MIU_1
[   15.614477] UMP get page bus_address 0xB59F1000 in MIU_1
[   15.620056] UMP get page bus_address 0xB59F2000 in MIU_1
[   15.625646] UMP get page bus_address 0xB59F3000 in MIU_1
[   15.631257] UMP get page bus_address 0xB59F4000 in MIU_1
[   15.643777] UMP get page bus_address 0xB59F5000 in MIU_1
[   15.650885] UMP get page bus_address 0xB59F6000 in MIU_1
[   15.656629] UMP get page bus_address 0xB59F7000 in MIU_1
[   15.662282] UMP get page bus_address 0xB59F8000 in MIU_1
[   15.668758] UMP get page bus_address 0xB59F9000 in MIU_1
[   15.676641] UMP get page bus_address 0xB582C000 in MIU_1
[   15.682559] UMP get page bus_address 0xB5843000 in MIU_1
[   15.688085] UMP get page bus_address 0xB5A13000 in MIU_1
[   15.693525] UMP get page bus_address 0xB5A14000 in MIU_1
[   15.699831] UMP get page bus_address 0xB5A15000 in MIU_1
[   15.705367] UMP get page bus_address 0xB5A16000 in MIU_1
[   15.710897] UMP get page bus_address 0xB5A17000 in MIU_1
[   15.716660] UMP get page bus_address 0xB5A18000 in MIU_1
[   15.722050] UMP get page bus_address 0xB5A19000 in MIU_1
[   15.727428] UMP get page bus_address 0xB5A1A000 in MIU_1
[   15.733255] UMP get page bus_address 0xB5A1B000 in MIU_1
[   15.738662] UMP get page bus_address 0xB5A1C000 in MIU_1
[   15.744178] UMP get page bus_address 0xB5A1D000 in MIU_1
[   15.749916] UMP get page bus_address 0xB5A1E000 in MIU_1
[   15.755312] UMP get page bus_address 0xB5A1F000 in MIU_1
[   15.760735] UMP get page bus_address 0xB5A20000 in MIU_1
[   15.766631] UMP get page bus_address 0xB5A21000 in MIU_1
[   15.772030] UMP get page bus_address 0xB5A22000 in MIU_1
[   15.777411] UMP get page bus_address 0xB5A23000 in MIU_1
[   15.783063] UMP get page bus_address 0xB5A24000 in MIU_1
[   15.788496] UMP get page bus_address 0xB5A25000 in MIU_1
[   15.794518] UMP get page bus_address 0xB5A26000 in MIU_1
[   15.800125] UMP get page bus_address 0xB5A27000 in MIU_1
[   15.805865] UMP get page bus_address 0xB5A28000 in MIU_1
[   15.811443] UMP get page bus_address 0xB5A29000 in MIU_1
[   15.817255] UMP get page bus_address 0xB5A2A000 in MIU_1
[   15.823104] UMP get page bus_address 0xB5A2B000 in MIU_1
[   15.828538] UMP get page bus_address 0xB5A2C000 in MIU_1
[   15.834033] UMP get page bus_address 0xB5A2D000 in MIU_1
[   15.839579] UMP get page bus_address 0xB5A2E000 in MIU_1
[   15.845010] UMP get page bus_address 0xB5A2F000 in MIU_1
[   15.850492] UMP get page bus_address 0xB5A30000 in MIU_1
[   15.856021] UMP get page bus_address 0xB5A31000 in MIU_1
[   15.861993] UMP get page bus_address 0xB59FA000 in MIU_1
[   15.868015] UMP get page bus_address 0xB59FB000 in MIU_1
[   15.873817] UMP get page bus_address 0xB5A32000 in MIU_1
[   15.879253] UMP get page bus_address 0xB5A33000 in MIU_1
[   15.884740] UMP get page bus_address 0xB59FC000 in MIU_1
[   15.890198] UMP get page bus_address 0xB59FD000 in MIU_1
[   15.895626] UMP get page bus_address 0xB59FE000 in MIU_1
[   15.901199] UMP get page bus_address 0xB59FF000 in MIU_1
[   15.907119] UMP get page bus_address 0xB5A34000 in MIU_1
[   15.912756] UMP get page bus_address 0xB5A35000 in MIU_1
[   15.918543] UMP get page bus_address 0xB5A36000 in MIU_1
[   15.923977] UMP get page bus_address 0xB5A37000 in MIU_1
[   15.929407] UMP get page bus_address 0xB5A38000 in MIU_1
[   15.934888] UMP get page bus_address 0xB5A39000 in MIU_1
[   15.940333] UMP get page bus_address 0xB5A3A000 in MIU_1
[   15.945761] UMP get page bus_address 0xB5A3B000 in MIU_1
[   15.951301] UMP get page bus_address 0xB5A3C000 in MIU_1
[   15.956872] UMP get page bus_address 0xB5A3D000 in MIU_1
[   15.962277] UMP get page bus_address 0xB5A3E000 in MIU_1
[   15.967957] UMP get page bus_address 0xB5A3F000 in MIU_1
[   15.973354] UMP get page bus_address 0xB5A00000 in MIU_1
[   15.978762] UMP get page bus_address 0xB5A01000 in MIU_1
[   15.984420] UMP get page bus_address 0xB5A02000 in MIU_1
[   15.990077] UMP get page bus_address 0xB5A03000 in MIU_1
[   15.995644] UMP get page bus_address 0xB5A04000 in MIU_1
[   16.001364] UMP get page bus_address 0xB5A05000 in MIU_1
[   16.007077] UMP get page bus_address 0xB5A06000 in MIU_1
[   16.012518] UMP get page bus_address 0xB5A07000 in MIU_1
[   16.018380] UMP get page bus_address 0xB5A08000 in MIU_1
[   16.023955] UMP get page bus_address 0xB5A09000 in MIU_1
[   16.029557] UMP get page bus_address 0xB5A0A000 in MIU_1
[   16.035719] UMP get page bus_address 0xB5A0B000 in MIU_1
[   16.041276] UMP get page bus_address 0xB5A0C000 in MIU_1
[   16.046778] UMP get page bus_address 0xB5A0D000 in MIU_1
[   16.052412] UMP get page bus_address 0xB5A0E000 in MIU_1
[   16.057931] UMP get page bus_address 0xB5A0F000 in MIU_1
[   16.063428] UMP get page bus_address 0xB5A40000 in MIU_1
[   16.069085] UMP get page bus_address 0xB5A41000 in MIU_1
[   16.074479] UMP get page bus_address 0xB5A42000 in MIU_1
[   16.079855] UMP get page bus_address 0xB5A43000 in MIU_1
[   16.085340] UMP get page bus_address 0xB5A44000 in MIU_1
[   16.090767] UMP get page bus_address 0xB5A45000 in MIU_1
[   16.096164] UMP get page bus_address 0xB5A46000 in MIU_1
[   16.101970] UMP get page bus_address 0xB5A47000 in MIU_1
[   16.107365] UMP get page bus_address 0xB5A48000 in MIU_1
[   16.112745] UMP get page bus_address 0xB5A49000 in MIU_1
[   16.118204] UMP get page bus_address 0xB5A4A000 in MIU_1
[   16.123681] UMP get page bus_address 0xB5A4B000 in MIU_1
[   16.129063] UMP get page bus_address 0xB5A4C000 in MIU_1
[   16.134509] UMP get page bus_address 0xB5A4D000 in MIU_1
[   16.139935] UMP get page bus_address 0xB5A4E000 in MIU_1
[   16.145321] UMP get page bus_address 0xB5A4F000 in MIU_1
[   16.150993] UMP get page bus_address 0xB5A50000 in MIU_1
[   16.156394] UMP get page bus_address 0xB5A51000 in MIU_1
[   16.161797] UMP get page bus_address 0xB5A52000 in MIU_1
[   16.167425] UMP get page bus_address 0xB5A53000 in MIU_1
[   16.172979] UMP get page bus_address 0xB5A54000 in MIU_1
[   16.178408] UMP get page bus_address 0xB5A55000 in MIU_1
[   16.184008] UMP get page bus_address 0xB5A56000 in MIU_1
[   16.189554] UMP get page bus_address 0xB5A57000 in MIU_1
[   16.195112] UMP get page bus_address 0xB5A58000 in MIU_1
[   16.200728] UMP get page bus_address 0xB5A59000 in MIU_1
[   16.206315] UMP get page bus_address 0xB5A5C000 in MIU_1
[   16.211703] UMP get page bus_address 0xB5A5D000 in MIU_1
[   16.217152] UMP get page bus_address 0xB5A5E000 in MIU_1
[   16.222540] UMP get page bus_address 0xB5A5F000 in MIU_1
[   16.227926] UMP get page bus_address 0xB5A60000 in MIU_1
[   16.233402] UMP get page bus_address 0xB5A61000 in MIU_1
[   16.238783] UMP get page bus_address 0xB5A62000 in MIU_1
[   16.244200] UMP get page bus_address 0xB5A63000 in MIU_1
[   16.249678] UMP get page bus_address 0xB5A64000 in MIU_1
[   16.255092] UMP get page bus_address 0xB5A65000 in MIU_1
[   16.260470] UMP get page bus_address 0xB5A66000 in MIU_1
[   16.265929] UMP get page bus_address 0xB5A67000 in MIU_1
[   16.271305] UMP get page bus_address 0xB5A68000 in MIU_1
[   16.276840] UMP get page bus_address 0xB5A69000 in MIU_1
[   16.282301] UMP get page bus_address 0xB5A6A000 in MIU_1
[   16.287678] UMP get page bus_address 0xB5A6B000 in MIU_1
[   16.293055] UMP get page bus_address 0xB5A6C000 in MIU_1
[   16.298511] UMP get page bus_address 0xB5A6D000 in MIU_1
[   16.303888] UMP get page bus_address 0xB5A6E000 in MIU_1
[   16.309263] UMP get page bus_address 0xB5A6F000 in MIU_1
[   16.314658] UMP get page bus_address 0xB5A70000 in MIU_1
[   16.320099] UMP get page bus_address 0xB5A71000 in MIU_1
[   16.325510] UMP get page bus_address 0xB5A72000 in MIU_1
[   16.330887] UMP get page bus_address 0xB5A73000 in MIU_1
[   16.336368] UMP get page bus_address 0xB5A74000 in MIU_1
[   16.341748] UMP get page bus_address 0xB5A75000 in MIU_1
[   16.347162] UMP get page bus_address 0xB5A76000 in MIU_1
[   16.352632] UMP get page bus_address 0xB5A77000 in MIU_1
[   16.358044] UMP get page bus_address 0xB5A78000 in MIU_1
[   16.363421] UMP get page bus_address 0xB5A79000 in MIU_1
[   16.368881] UMP get page bus_address 0xB5A7A000 in MIU_1
[   16.374319] UMP get page bus_address 0xB5A7B000 in MIU_1
[   16.379887] UMP get page bus_address 0xB5A7C000 in MIU_1
[   16.385340] UMP get page bus_address 0xB5A7D000 in MIU_1
[   16.390729] UMP get page bus_address 0xB5A7E000 in MIU_1
[   16.396102] UMP get page bus_address 0xB5A7F000 in MIU_1
[   16.401549] UMP get page bus_address 0xB5A80000 in MIU_1
[   16.406926] UMP get page bus_address 0xB5A81000 in MIU_1
[   16.412302] UMP get page bus_address 0xB5A82000 in MIU_1
[   16.417767] UMP get page bus_address 0xB5A83000 in MIU_1
[   16.423221] UMP get page bus_address 0xB5A84000 in MIU_1
[   16.428624] UMP get page bus_address 0xB5A85000 in MIU_1
[   16.434071] UMP get page bus_address 0xB5A86000 in MIU_1
[   16.439480] UMP get page bus_address 0xB5A87000 in MIU_1
[   16.444854] UMP get page bus_address 0xB5A88000 in MIU_1
[   16.450355] UMP get page bus_address 0xB5A89000 in MIU_1
[   16.455735] UMP get page bus_address 0xB5A8A000 in MIU_1
[   16.461150] UMP get page bus_address 0xB5A8B000 in MIU_1
[   16.466748] UMP get page bus_address 0xB5A8C000 in MIU_1
[   16.472153] UMP get page bus_address 0xB5A8D000 in MIU_1
[   16.477671] UMP get page bus_address 0xB5A8E000 in MIU_1
[   16.483369] UMP get page bus_address 0xB5A8F000 in MIU_1
[   16.488776] UMP get page bus_address 0xB5A90000 in MIU_1
[   16.494201] UMP get page bus_address 0xB5A91000 in MIU_1
[   16.499832] UMP get page bus_address 0xB5A92000 in MIU_1
[   16.505225] UMP get page bus_address 0xB5A93000 in MIU_1
[   16.510604] UMP get page bus_address 0xB5A94000 in MIU_1
[   16.516043] UMP get page bus_address 0xB5A95000 in MIU_1
[   16.521439] UMP get page bus_address 0xB5A96000 in MIU_1
[   16.526831] UMP get page bus_address 0xB5A97000 in MIU_1
[   16.532374] UMP get page bus_address 0xB5A98000 in MIU_1
[   16.537790] UMP get page bus_address 0xB5A99000 in MIU_1
[   16.543179] UMP get page bus_address 0xB5A9A000 in MIU_1
[   16.548626] UMP get page bus_address 0xB5A9B000 in MIU_1
[   16.554014] UMP get page bus_address 0xB5A9C000 in MIU_1
[   16.559390] UMP get page bus_address 0xB5A9D000 in MIU_1
[   16.564787] UMP get page bus_address 0xB5A9E000 in MIU_1
[   16.570226] UMP get page bus_address 0xB5A9F000 in MIU_1
[   16.575636] UMP get page bus_address 0xB5AA0000 in MIU_1
[   16.581215] UMP get page bus_address 0xB5AA1000 in MIU_1
[   16.586661] UMP get page bus_address 0xB5AA2000 in MIU_1
[   16.592042] UMP get page bus_address 0xB5AA3000 in MIU_1
[   16.597416] UMP get page bus_address 0xB5AA4000 in MIU_1
[   16.602938] UMP get page bus_address 0xB5AA5000 in MIU_1
[   16.608422] UMP get page bus_address 0xB5AA6000 in MIU_1
[   16.613954] UMP get page bus_address 0xB5AA7000 in MIU_1
[   16.619505] UMP get page bus_address 0xB5AA8000 in MIU_1
[   16.625040] UMP get page bus_address 0xB5AA9000 in MIU_1
[   16.630750] UMP get page bus_address 0xB5AAA000 in MIU_1
[   16.636311] UMP get page bus_address 0xB5AAB000 in MIU_1
[   16.641724] UMP get page bus_address 0xB5AAC000 in MIU_1
[   16.646847] request_suspend_state: wakeup (3->0) at 16274597846 (1970-01-02 00:00:03.975129928 UTC)
[   16.656283] UMP get page bus_address 0xB5AAD000 in MIU_1
[   16.661671] UMP get page bus_address 0xB5AAE000 in MIU_1
[   16.667138] UMP get page bus_address 0xB5AAF000 in MIU_1
[   16.672517] UMP get page bus_address 0xB5AB0000 in MIU_1
[   16.677898] UMP get page bus_address 0xB5AB1000 in MIU_1
[   16.683553] UMP get page bus_address 0xB5AB2000 in MIU_1
[   16.689129] UMP get page bus_address 0xB5AB3000 in MIU_1
[   16.694676] UMP get page bus_address 0xB5AB4000 in MIU_1
[   16.700396] UMP get page bus_address 0xB5AB5000 in MIU_1
[   16.705976] UMP get page bus_address 0xB5AB6000 in MIU_1
[   16.711542] UMP get page bus_address 0xB5AB7000 in MIU_1
[   16.716990] UMP get page bus_address 0xB5AB8000 in MIU_1
[   16.722377] UMP get page bus_address 0xB5ABA000 in MIU_1
[   16.727753] UMP get page bus_address 0xB5ABB000 in MIU_1
[   16.733180] UMP get page bus_address 0xB5AEC000 in MIU_1
[   16.738556] UMP get page bus_address 0xB5AED000 in MIU_1
[   16.743932] UMP get page bus_address 0xB5AEE000 in MIU_1
[   16.749440] UMP get page bus_address 0xB5AEF000 in MIU_1
[   16.754842] UMP get page bus_address 0xB5AF0000 in MIU_1
[   16.760235] UMP get page bus_address 0xB5AF1000 in MIU_1
[   16.766250] UMP get page bus_address 0xB5AF2000 in MIU_1
[   16.772188] UMP get page bus_address 0xB5AF3000 in MIU_1
[   16.777588] UMP get page bus_address 0xB5AF4000 in MIU_1
[   16.783176] UMP get page bus_address 0xB5AF5000 in MIU_1
[   16.789107] UMP get page bus_address 0xB5AF6000 in MIU_1
[   16.794932] UMP get page bus_address 0xB5AF7000 in MIU_1
[   16.800386] UMP get page bus_address 0xB5AF8000 in MIU_1
[   16.806212] UMP get page bus_address 0xB5AF9000 in MIU_1
[   16.811728] UMP get page bus_address 0xB5AFA000 in MIU_1
[   16.817261] UMP get page bus_address 0xB5AFB000 in MIU_1
[   16.823232] UMP get page bus_address 0xB5AFC000 in MIU_1
[   16.828662] UMP get page bus_address 0xB5AFD000 in MIU_1
[   16.834142] UMP get page bus_address 0xB5AFE000 in MIU_1
[   16.839564] UMP get page bus_address 0xB5AFF000 in MIU_1
[   16.844990] UMP get page bus_address 0xB5B00000 in MIU_1
[   16.850466] UMP get page bus_address 0xB5B01000 in MIU_1
[   16.855888] UMP get page bus_address 0xB5B02000 in MIU_1
[   16.861316] UMP get page bus_address 0xB5B03000 in MIU_1
[   16.867175] UMP get page bus_address 0xB5B04000 in MIU_1
[   16.872672] UMP get page bus_address 0xB5B05000 in MIU_1
[   16.878115] UMP get page bus_address 0xB5B06000 in MIU_1
[   16.883773] UMP get page bus_address 0xB5B07000 in MIU_1
[   16.889201] UMP get page bus_address 0xB5B08000 in MIU_1
[   16.894658] UMP get page bus_address 0xB5B09000 in MIU_1
[   16.900528] UMP get page bus_address 0xB5B0E000 in MIU_1
[   16.906012] UMP get page bus_address 0xB5B0F000 in MIU_1
[   16.911493] UMP get page bus_address 0xB5B10000 in MIU_1
[   16.917006] UMP get page bus_address 0xB5B11000 in MIU_1
[   16.922485] UMP get page bus_address 0xB5B12000 in MIU_1
[   16.927970] UMP get page bus_address 0xB5B13000 in MIU_1
[   16.933594] UMP get page bus_address 0xB5B14000 in MIU_1
[   16.939191] UMP get page bus_address 0xB5B15000 in MIU_1
[   16.945474] UMP get page bus_address 0xB5B16000 in MIU_1
[   16.951023] UMP get page bus_address 0xB5B17000 in MIU_1
[   16.956513] UMP get page bus_address 0xB5B18000 in MIU_1
[   16.961975] UMP get page bus_address 0xB5B19000 in MIU_1
[   16.967485] UMP get page bus_address 0xB5B1A000 in MIU_1
[   16.972917] UMP get page bus_address 0xB5B1B000 in MIU_1
[   16.978339] UMP get page bus_address 0xB5B1C000 in MIU_1
[   16.983956] UMP get page bus_address 0xB5B1D000 in MIU_1
[   16.989380] UMP get page bus_address 0xB5B1E000 in MIU_1
[   16.994798] UMP get page bus_address 0xB5B1F000 in MIU_1
[   17.000286] UMP get page bus_address 0xB5B20000 in MIU_1
[   17.005707] UMP get page bus_address 0xB5B21000 in MIU_1
[   17.011677] UMP get page bus_address 0xB5B22000 in MIU_1
[   17.017277] UMP get page bus_address 0xB5B23000 in MIU_1
[   17.022961] UMP get page bus_address 0xB5B24000 in MIU_1
[   17.028388] UMP get page bus_address 0xB5B25000 in MIU_1
[   17.033958] UMP get page bus_address 0xB5B26000 in MIU_1
[   17.039385] UMP get page bus_address 0xB5B27000 in MIU_1
[   17.044807] UMP get page bus_address 0xB5B28000 in MIU_1
[   17.050281] UMP get page bus_address 0xB5B29000 in MIU_1
[   17.056308] UMP get page bus_address 0xB5B2A000 in MIU_1
[   17.061976] UMP get page bus_address 0xB5852000 in MIU_1
[   17.067670] UMP get page bus_address 0xB5851000 in MIU_1
[   17.073295] UMP get page bus_address 0xB5850000 in MIU_1
[   17.079020] UMP get page bus_address 0xB584F000 in MIU_1
[   17.084491] UMP get page bus_address 0xB584E000 in MIU_1
[   17.089932] UMP get page bus_address 0xB584D000 in MIU_1
[   17.095363] UMP get page bus_address 0xB584C000 in MIU_1
[   17.100831] UMP get page bus_address 0xB584B000 in MIU_1
[   17.106276] UMP get page bus_address 0xB584A000 in MIU_1
[   17.111787] UMP get page bus_address 0xB5B2C000 in MIU_1
[   17.117228] UMP get page bus_address 0xB5B2D000 in MIU_1
[   17.122658] UMP get page bus_address 0xB5B2E000 in MIU_1
[   17.128076] UMP get page bus_address 0xB5B2F000 in MIU_1
[   17.133525] UMP get page bus_address 0xB5B30000 in MIU_1
[   17.138947] UMP get page bus_address 0xB5B31000 in MIU_1
[   17.144436] UMP get page bus_address 0xB5B32000 in MIU_1
[   17.149922] UMP get page bus_address 0xB5B33000 in MIU_1
[   17.155368] UMP get page bus_address 0xB5B34000 in MIU_1
[   17.160860] UMP get page bus_address 0xB5B35000 in MIU_1
[   17.166312] UMP get page bus_address 0xB5B36000 in MIU_1
[   17.172980] UMP get page bus_address 0xB5B37000 in MIU_1
[   17.178446] UMP get page bus_address 0xB5B38000 in MIU_1
[   17.183940] UMP get page bus_address 0xB5B39000 in MIU_1
[   17.189399] UMP get page bus_address 0xB5B3A000 in MIU_1
[   17.194829] UMP get page bus_address 0xB5B3B000 in MIU_1
[   17.200274] UMP get page bus_address 0xB5B3C000 in MIU_1
[   17.205745] UMP get page bus_address 0xB5B3D000 in MIU_1
[   17.211216] UMP get page bus_address 0xB5B3E000 in MIU_1
[   17.216901] UMP get page bus_address 0xB5B3F000 in MIU_1
[   17.222378] UMP get page bus_address 0xB5B40000 in MIU_1
[   17.227847] UMP get page bus_address 0xB5B41000 in MIU_1
[   17.233349] UMP get page bus_address 0xB5B42000 in MIU_1
[   17.239022] UMP get page bus_address 0xB5B43000 in MIU_1
[   17.244646] UMP get page bus_address 0xB5B44000 in MIU_1
[   17.250250] UMP get page bus_address 0xB5B45000 in MIU_1
[   17.255868] UMP get page bus_address 0xB5B46000 in MIU_1
[   17.261486] UMP get page bus_address 0xB5B47000 in MIU_1
[   17.267130] UMP get page bus_address 0xB5B48000 in MIU_1
[   17.272738] UMP get page bus_address 0xB5B49000 in MIU_1
[   17.278450] UMP get page bus_address 0xB5B4A000 in MIU_1
[   17.284170] UMP get page bus_address 0xB5BFC000 in MIU_1
[   17.289887] UMP get page bus_address 0xB5BFD000 in MIU_1
[   17.295492] UMP get page bus_address 0xB5BFE000 in MIU_1
[   17.301123] UMP get page bus_address 0xB5BFF000 in MIU_1
[   17.306812] UMP get page bus_address 0xB3C00000 in MIU_1
[   17.312500] UMP get page bus_address 0xB3C01000 in MIU_1
[   17.318191] UMP get page bus_address 0xB3C02000 in MIU_1
[   17.323902] UMP get page bus_address 0xB3C03000 in MIU_1
[   17.332682] UMP get page bus_address 0xB5B69000 in MIU_1
[   17.338503] UMP get page bus_address 0xB5B68000 in MIU_1
[   17.344357] UMP get page bus_address 0xB5B67000 in MIU_1
[   17.350456] UMP get page bus_address 0xB5B66000 in MIU_1
[   17.356557] UMP get page bus_address 0xB5B65000 in MIU_1
[   17.362126] UMP get page bus_address 0xB5B64000 in MIU_1
[   17.367992] UMP get page bus_address 0xB5B63000 in MIU_1
[   17.373707] UMP get page bus_address 0xB5B62000 in MIU_1
[   17.379187] UMP get page bus_address 0xB5B61000 in MIU_1
[   17.385204] UMP get page bus_address 0xB5B60000 in MIU_1
[   17.390713] UMP get page bus_address 0xB5B5F000 in MIU_1
[   17.397312] UMP get page bus_address 0xB3C04000 in MIU_1
[   17.403050] UMP get page bus_address 0xB3C05000 in MIU_1
[   17.408543] UMP get page bus_address 0xB3C06000 in MIU_1
[   17.413987] UMP get page bus_address 0xB3C07000 in MIU_1
[   17.419529] UMP get page bus_address 0xB3C08000 in MIU_1
[   17.425030] UMP get page bus_address 0xB3C09000 in MIU_1
[   17.430550] UMP get page bus_address 0xB3C0A000 in MIU_1
[   17.436056] UMP get page bus_address 0xB3C0B000 in MIU_1
[   17.441572] UMP get page bus_address 0xB3C0C000 in MIU_1
[   17.447010] UMP get page bus_address 0xB3C0D000 in MIU_1
[   17.452502] UMP get page bus_address 0xB3C0E000 in MIU_1
[   17.457943] UMP get page bus_address 0xB3C0F000 in MIU_1
[   17.463408] UMP get page bus_address 0xB3C10000 in MIU_1
[   17.468856] UMP get page bus_address 0xB3C11000 in MIU_1
[   17.474320] UMP get page bus_address 0xB3C12000 in MIU_1
[   17.479807] UMP get page bus_address 0xB3C13000 in MIU_1
[   17.485288] UMP get page bus_address 0xB3C1B000 in MIU_1
[   17.490748] UMP get page bus_address 0xB3C2E000 in MIU_1
[   17.496222] UMP get page bus_address 0xB3C2F000 in MIU_1
[   17.501681] UMP get page bus_address 0xB5BF4000 in MIU_1
[   17.507116] UMP get page bus_address 0xB5BF5000 in MIU_1
[   17.512538] UMP get page bus_address 0xB5BF6000 in MIU_1
[   17.517966] UMP get page bus_address 0xB5BF7000 in MIU_1
[   17.523431] UMP get page bus_address 0xB3C30000 in MIU_1
[   17.528855] UMP get page bus_address 0xB3C31000 in MIU_1
[   17.534281] UMP get page bus_address 0xB3C32000 in MIU_1
[   17.539699] UMP get page bus_address 0xB3C33000 in MIU_1
[   17.545156] UMP get page bus_address 0xB3C34000 in MIU_1
[   17.550609] UMP get page bus_address 0xB3C35000 in MIU_1
[   17.556031] UMP get page bus_address 0xB3C36000 in MIU_1
[   17.561426] UMP get page bus_address 0xB3C37000 in MIU_1
[   17.566825] UMP get page bus_address 0xB3C38000 in MIU_1
[   17.572200] UMP get page bus_address 0xB3C39000 in MIU_1
[   17.577568] UMP get page bus_address 0xB3C3A000 in MIU_1
[   17.582946] UMP get page bus_address 0xB3C3B000 in MIU_1
[   17.588757] UMP get page bus_address 0xB3C3C000 in MIU_1
[   17.594189] UMP get page bus_address 0xB3C3D000 in MIU_1
[   17.599596] UMP get page bus_address 0xB3C3E000 in MIU_1
[   17.604992] UMP get page bus_address 0xB3C3F000 in MIU_1
[   17.610390] UMP get page bus_address 0xB3C40000 in MIU_1
[   17.615797] UMP get page bus_address 0xB3C41000 in MIU_1
[   17.621193] UMP get page bus_address 0xB3C42000 in MIU_1
[   17.626630] UMP get page bus_address 0xB3C43000 in MIU_1
[   17.632035] UMP get page bus_address 0xB3C44000 in MIU_1
[   17.637474] UMP get page bus_address 0xB3C45000 in MIU_1
[   17.642876] UMP get page bus_address 0xB3C46000 in MIU_1
[   17.648283] UMP get page bus_address 0xB3C47000 in MIU_1
[   17.653691] UMP get page bus_address 0xB3C48000 in MIU_1
[   17.659091] UMP get page bus_address 0xB3C49000 in MIU_1
[   17.664665] UMP get page bus_address 0xB3C4A000 in MIU_1
[   17.670049] UMP get page bus_address 0xB3C4B000 in MIU_1
[   17.675700] UMP get page bus_address 0xB3C4C000 in MIU_1
[   17.681080] UMP get page bus_address 0xB3C4D000 in MIU_1
[   17.686475] UMP get page bus_address 0xB3C4E000 in MIU_1
[   17.691864] UMP get page bus_address 0xB3C4F000 in MIU_1
[   17.697257] UMP get page bus_address 0xB3C50000 in MIU_1
[   17.702652] UMP get page bus_address 0xB3C51000 in MIU_1
[   17.708040] UMP get page bus_address 0xB3C52000 in MIU_1
[   17.713435] UMP get page bus_address 0xB3C53000 in MIU_1
[   17.718826] UMP get page bus_address 0xB3C54000 in MIU_1
[   17.724219] UMP get page bus_address 0xB3C55000 in MIU_1
[   17.729726] UMP get page bus_address 0xB3C56000 in MIU_1
[   17.735250] UMP get page bus_address 0xB3C57000 in MIU_1
[   17.740690] UMP get page bus_address 0xB3C58000 in MIU_1
[   17.746208] UMP get page bus_address 0xB3C59000 in MIU_1
[   17.751599] UMP get page bus_address 0xB3C5A000 in MIU_1
[   17.757093] UMP get page bus_address 0xB3C5B000 in MIU_1
[   17.762750] UMP get page bus_address 0xB3C5C000 in MIU_1
[   17.768136] UMP get page bus_address 0xB3C5D000 in MIU_1
[   17.773539] UMP get page bus_address 0xB3C5E000 in MIU_1
[   17.778937] UMP get page bus_address 0xB3C5F000 in MIU_1
[   17.784337] UMP get page bus_address 0xB3C60000 in MIU_1
[   17.789721] UMP get page bus_address 0xB3C61000 in MIU_1
[   17.795117] UMP get page bus_address 0xB3C62000 in MIU_1
[   17.800519] UMP get page bus_address 0xB3C63000 in MIU_1
[   17.805914] UMP get page bus_address 0xB3C64000 in MIU_1
[   17.811312] UMP get page bus_address 0xB3C65000 in MIU_1
[   17.816709] UMP get page bus_address 0xB3C66000 in MIU_1
[   17.822121] UMP get page bus_address 0xB3C67000 in MIU_1
[   17.827613] UMP get page bus_address 0xB3C68000 in MIU_1
[   17.833142] UMP get page bus_address 0xB3C69000 in MIU_1
[   17.838594] UMP get page bus_address 0xB3C6A000 in MIU_1
[   17.844125] UMP get page bus_address 0xB3C6B000 in MIU_1
[   17.849619] UMP get page bus_address 0xB3C6C000 in MIU_1
[   17.855330] UMP get page bus_address 0xB3C6D000 in MIU_1
[   17.860707] UMP get page bus_address 0xB3C6E000 in MIU_1
[   17.866114] UMP get page bus_address 0xB3C6F000 in MIU_1
[   17.871507] UMP get page bus_address 0xB3C70000 in MIU_1
[   17.876900] UMP get page bus_address 0xB3C71000 in MIU_1
[   17.882277] UMP get page bus_address 0xB3C72000 in MIU_1
[   17.887655] UMP get page bus_address 0xB3C73000 in MIU_1
[   17.893093] UMP get page bus_address 0xB3C74000 in MIU_1
[   17.898471] UMP get page bus_address 0xB3C75000 in MIU_1
[   17.903864] UMP get page bus_address 0xB3C76000 in MIU_1
[   17.909260] UMP get page bus_address 0xB3C77000 in MIU_1
[   17.914652] UMP get page bus_address 0xB3C78000 in MIU_1
[   17.920042] UMP get page bus_address 0xB3C79000 in MIU_1
[   17.925436] UMP get page bus_address 0xB3C7A000 in MIU_1
[   17.930833] UMP get page bus_address 0xB3C7B000 in MIU_1
[   17.936225] UMP get page bus_address 0xB3C7C000 in MIU_1
[   17.941714] UMP get page bus_address 0xB3C7D000 in MIU_1
[   17.947239] UMP get page bus_address 0xB3C7E000 in MIU_1
[   17.952646] UMP get page bus_address 0xB3C7F000 in MIU_1
[   17.958020] UMP get page bus_address 0xB3C80000 in MIU_1
[   17.963387] UMP get page bus_address 0xB3C81000 in MIU_1
[   17.968751] UMP get page bus_address 0xB3C82000 in MIU_1
[   17.974115] UMP get page bus_address 0xB3C83000 in MIU_1
[   17.979479] UMP get page bus_address 0xB3C84000 in MIU_1
[   17.984841] UMP get page bus_address 0xB3C85000 in MIU_1
[   17.990211] UMP get page bus_address 0xB3C2C000 in MIU_1
[   17.995573] UMP get page bus_address 0xB3C2D000 in MIU_1
[   18.000938] UMP get page bus_address 0xB3C86000 in MIU_1
[   18.006301] UMP get page bus_address 0xB3C87000 in MIU_1
[   18.011664] UMP get page bus_address 0xB3C88000 in MIU_1
[   18.017023] UMP get page bus_address 0xB3C89000 in MIU_1
[   18.022387] UMP get page bus_address 0xB3C8A000 in MIU_1
[   18.027748] UMP get page bus_address 0xB3C8B000 in MIU_1
[   18.033111] UMP get page bus_address 0xB3C8C000 in MIU_1
[   18.038474] UMP get page bus_address 0xB3C8D000 in MIU_1
[   18.043837] UMP get page bus_address 0xB3C8E000 in MIU_1
[   18.049201] UMP get page bus_address 0xB3C8F000 in MIU_1
[   18.054565] UMP get page bus_address 0xB3C90000 in MIU_1
[   18.059927] UMP get page bus_address 0xB3C91000 in MIU_1
[   18.065292] UMP get page bus_address 0xB3C92000 in MIU_1
[   18.070654] UMP get page bus_address 0xB3C93000 in MIU_1
[   18.076016] UMP get page bus_address 0xB3C94000 in MIU_1
[   18.081379] UMP get page bus_address 0xB3C95000 in MIU_1
[   18.086743] UMP get page bus_address 0xB3C96000 in MIU_1
[   18.092106] UMP get page bus_address 0xB3C97000 in MIU_1
[   18.097477] UMP get page bus_address 0xB3C98000 in MIU_1
[   18.102844] UMP get page bus_address 0xB3C99000 in MIU_1
[   18.108209] UMP get page bus_address 0xB3C9A000 in MIU_1
[   18.113573] UMP get page bus_address 0xB3C9B000 in MIU_1
[   18.118935] UMP get page bus_address 0xB3C9C000 in MIU_1
[   18.124297] UMP get page bus_address 0xB3C9D000 in MIU_1
[   18.129659] UMP get page bus_address 0xB3C9E000 in MIU_1
[   18.135020] UMP get page bus_address 0xB3C9F000 in MIU_1
[   18.140383] UMP get page bus_address 0xB3CA0000 in MIU_1
[   18.145748] UMP get page bus_address 0xB3CA1000 in MIU_1
[   18.151112] UMP get page bus_address 0xB3CA2000 in MIU_1
[   18.156482] UMP get page bus_address 0xB3CA3000 in MIU_1
[   18.161848] UMP get page bus_address 0xB3CA4000 in MIU_1
[   18.167209] UMP get page bus_address 0xB3CA5000 in MIU_1
[   18.172573] UMP get page bus_address 0xB3CA6000 in MIU_1
[   18.177935] UMP get page bus_address 0xB3CA7000 in MIU_1
[   18.183295] UMP get page bus_address 0xB3CA8000 in MIU_1
[   18.188655] UMP get page bus_address 0xB3CA9000 in MIU_1
[   18.194016] UMP get page bus_address 0xB3CAA000 in MIU_1
[   18.199377] UMP get page bus_address 0xB3CAB000 in MIU_1
[   18.204740] UMP get page bus_address 0xB3CAC000 in MIU_1
[   18.210104] UMP get page bus_address 0xB3CAD000 in MIU_1
[   18.215466] UMP get page bus_address 0xB3CAE000 in MIU_1
[   18.220829] UMP get page bus_address 0xB3CAF000 in MIU_1
[   18.226192] UMP get page bus_address 0xB3CB0000 in MIU_1
[   18.231553] UMP get page bus_address 0xB3CB1000 in MIU_1
[   18.236915] UMP get page bus_address 0xB3CB2000 in MIU_1
[   18.242279] UMP get page bus_address 0xB3CB3000 in MIU_1
[   18.247641] UMP get page bus_address 0xB3CB4000 in MIU_1
[   18.253002] UMP get page bus_address 0xB3CB5000 in MIU_1
[   18.258366] UMP get page bus_address 0xB3CB6000 in MIU_1
[   18.263729] UMP get page bus_address 0xB3CB7000 in MIU_1
[   18.269093] UMP get page bus_address 0xB3CB8000 in MIU_1
[   18.274456] UMP get page bus_address 0xB3CB9000 in MIU_1
[   18.279819] UMP get page bus_address 0xB3CBA000 in MIU_1
[   18.285179] UMP get page bus_address 0xB3CBB000 in MIU_1
[   18.290541] UMP get page bus_address 0xB3CBC000 in MIU_1
[   18.295901] UMP get page bus_address 0xB3CBD000 in MIU_1
[   18.301266] UMP get page bus_address 0xB3CBE000 in MIU_1
[   18.306630] UMP get page bus_address 0xB3CBF000 in MIU_1
[   18.311993] UMP get page bus_address 0xB3CC0000 in MIU_1
[   18.317358] UMP get page bus_address 0xB3CC1000 in MIU_1
[   18.322727] UMP get page bus_address 0xB3CC2000 in MIU_1
[   18.328093] UMP get page bus_address 0xB3CC3000 in MIU_1
[   18.333458] UMP get page bus_address 0xB3CC4000 in MIU_1
[   18.338821] UMP get page bus_address 0xB3CC5000 in MIU_1
[   18.344184] UMP get page bus_address 0xB3CC6000 in MIU_1
[   18.349584] UMP get page bus_address 0xB3CC7000 in MIU_1
[   18.354959] UMP get page bus_address 0xB3CC8000 in MIU_1
[   18.360323] UMP get page bus_address 0xB3CC9000 in MIU_1
[   18.365687] UMP get page bus_address 0xB3CCA000 in MIU_1
[   18.371048] UMP get page bus_address 0xB3CCB000 in MIU_1
[   18.376430] UMP get page bus_address 0xB3CCC000 in MIU_1
[   18.381929] UMP get page bus_address 0xB3CCD000 in MIU_1
[   18.387427] UMP get page bus_address 0xB3CCE000 in MIU_1
[   18.392919] UMP get page bus_address 0xB3CCF000 in MIU_1
[   18.398440] UMP get page bus_address 0xB3CD0000 in MIU_1
[   18.403935] UMP get page bus_address 0xB3CD1000 in MIU_1
[   18.409428] UMP get page bus_address 0xB3CD2000 in MIU_1
[   18.414920] UMP get page bus_address 0xB3CD3000 in MIU_1
[   18.420409] UMP get page bus_address 0xB3CD4000 in MIU_1
[   18.425930] UMP get page bus_address 0xB3CD5000 in MIU_1
[   18.431675] UMP get page bus_address 0xB3CD6000 in MIU_1
[   18.437299] UMP get page bus_address 0xB3CD7000 in MIU_1
[   18.442882] UMP get page bus_address 0xB3CD8000 in MIU_1
[   18.448516] UMP get page bus_address 0xB3CD9000 in MIU_1
[   18.454297] UMP get page bus_address 0xB3CDA000 in MIU_1
[   18.460229] UMP get page bus_address 0xB3CDB000 in MIU_1
[   18.466060] UMP get page bus_address 0xB3CDC000 in MIU_1
[   18.471635] UMP get page bus_address 0xB3CDD000 in MIU_1
[   18.477515] UMP get page bus_address 0xB3CDE000 in MIU_1
[   18.477526] init: no such service 'nameserver'
[   18.478431] init: no such service 'wifirc:start'
[   18.492575] UMP get page bus_address 0xB3CDF000 in MIU_1
[   18.498184] UMP get page bus_address 0xB3CE0000 in MIU_1
[   18.503791] UMP get page bus_address 0xB3D1C000 in MIU_1
[   18.509378] UMP get page bus_address 0xB3D1D000 in MIU_1
[   18.515137] UMP get page bus_address 0xB3D1E000 in MIU_1
[   18.520650] UMP get page bus_address 0xB3D1F000 in MIU_1
[   18.526244] UMP get page bus_address 0xB3D20000 in MIU_1
[   18.531780] UMP get page bus_address 0xB3D21000 in MIU_1
[   18.537363] UMP get page bus_address 0xB3D22000 in MIU_1
[   18.543005] UMP get page bus_address 0xB3D23000 in MIU_1
[   18.548614] UMP get page bus_address 0xB3D24000 in MIU_1
[   18.554251] UMP get page bus_address 0xB3D25000 in MIU_1
[   18.559824] UMP get page bus_address 0xB3D26000 in MIU_1
[   18.565884] UMP get page bus_address 0xB3D27000 in MIU_1
[   18.571513] UMP get page bus_address 0xB3D28000 in MIU_1
[   18.577051] UMP get page bus_address 0xB3D29000 in MIU_1
[   18.582682] UMP get page bus_address 0xB3D2A000 in MIU_1
[   18.593193] UMP get page bus_address 0xB3D11000 in MIU_1
[   18.598719] UMP get page bus_address 0xB3D10000 in MIU_1
[   18.604365] UMP get page bus_address 0xB3D0F000 in MIU_1
[   18.609900] UMP get page bus_address 0xB3D0E000 in MIU_1
[   18.615382] UMP get page bus_address 0xB3D0D000 in MIU_1
[   18.620924] UMP get page bus_address 0xB3D0C000 in MIU_1
[   18.626347] UMP get page bus_address 0xB3D0B000 in MIU_1
[   18.631957] UMP get page bus_address 0xB3D0A000 in MIU_1
[   18.637471] UMP get page bus_address 0xB3D09000 in MIU_1
[   18.642902] UMP get page bus_address 0xB3D08000 in MIU_1
[   18.648433] UMP get page bus_address 0xB3D07000 in MIU_1
[   18.654230] UMP get page bus_address 0xB3D06000 in MIU_1
[   18.660021] UMP get page bus_address 0xB3D05000 in MIU_1
[   18.665426] UMP get page bus_address 0xB3D04000 in MIU_1
[   18.671055] UMP get page bus_address 0xB3D03000 in MIU_1
[   18.676591] UMP get page bus_address 0xB3D02000 in MIU_1
[   18.681968] UMP get page bus_address 0xB3D01000 in MIU_1
[   18.687705] UMP get page bus_address 0xB3D00000 in MIU_1
[   18.693291] UMP get page bus_address 0xB3CFF000 in MIU_1
[   18.698836] UMP get page bus_address 0xB3CFE000 in MIU_1
[   18.704440] UMP get page bus_address 0xB3D3B000 in MIU_1
[   18.710375] UMP get page bus_address 0xB3D4E000 in MIU_1
[   18.715878] UMP get page bus_address 0xB3D4F000 in MIU_1
[   18.721317] UMP get page bus_address 0xB3D50000 in MIU_1
[   18.726796] UMP get page bus_address 0xB3D51000 in MIU_1
[   18.732222] UMP get page bus_address 0xB3D52000 in MIU_1
[   18.737714] UMP get page bus_address 0xB3D53000 in MIU_1
[   18.743161] UMP get page bus_address 0xB3D54000 in MIU_1
[   18.748586] UMP get page bus_address 0xB3D55000 in MIU_1
[   18.754062] UMP get page bus_address 0xB3D56000 in MIU_1
[   18.759507] UMP get page bus_address 0xB3D57000 in MIU_1
[   18.765552] UMP get page bus_address 0xB3D58000 in MIU_1
[   18.771070] UMP get page bus_address 0xB5B51000 in MIU_1
[   18.776808] UMP get page bus_address 0xB5BD5000 in MIU_1
[   18.782723] UMP get page bus_address 0xB3D4A000 in MIU_1
[   18.788508] UMP get page bus_address 0xB3D4B000 in MIU_1
[   18.794494] UMP get page bus_address 0xB3D6C000 in MIU_1
[   18.800353] UMP get page bus_address 0xB3D6D000 in MIU_1
[   18.806190] UMP get page bus_address 0xB3D6E000 in MIU_1
[   18.812231] UMP get page bus_address 0xB3D6F000 in MIU_1
[   18.818022] UMP get page bus_address 0xB3D78000 in MIU_1
[   18.827613] UMP get page bus_address 0xB3D79000 in MIU_1
[   18.833702] UMP get page bus_address 0xB3D7A000 in MIU_1
[   18.839412] UMP get page bus_address 0xB3D7B000 in MIU_1
[   18.846988] UMP get page bus_address 0xB3D7C000 in MIU_1
[   18.853463] UMP get page bus_address 0xB3D7D000 in MIU_1
[   18.860406] UMP get page bus_address 0xB3D7E000 in MIU_1
[   18.866061] UMP get page bus_address 0xB3D7F000 in MIU_1
[   18.871660] UMP get page bus_address 0xB3D80000 in MIU_1
[   18.877667] UMP get page bus_address 0xB3D59000 in MIU_1
[   18.884107] UMP get page bus_address 0xB3DE1000 in MIU_1
[   18.890977] UMP get page bus_address 0xB3D81000 in MIU_1
[   18.897168] UMP get page bus_address 0xB3D48000 in MIU_1
[   18.902779] UMP get page bus_address 0xB3D49000 in MIU_1
[   18.908403] UMP get page bus_address 0xB3D92000 in MIU_1
[   18.913872] UMP get page bus_address 0xB3D93000 in MIU_1
[   18.919407] UMP get page bus_address 0xBAF90000 in MIU_1
[   18.924965] UMP get page bus_address 0xBAF91000 in MIU_1
[   18.930394] UMP get page bus_address 0xBAF8E000 in MIU_1
[   18.935901] UMP get page bus_address 0xBAF8F000 in MIU_1
[   18.941393] UMP get page bus_address 0xB3D98000 in MIU_1
[   18.946817] UMP get page bus_address 0xB3D99000 in MIU_1
[   18.952461] UMP get page bus_address 0xB3D94000 in MIU_1
[   18.957905] UMP get page bus_address 0xB3D95000 in MIU_1
[   18.963314] UMP get page bus_address 0xB3D96000 in MIU_1
[   18.968809] UMP get page bus_address 0xB3D97000 in MIU_1
[   18.974223] UMP get page bus_address 0xB3DF8000 in MIU_1
[   18.979625] UMP get page bus_address 0xB3DF9000 in MIU_1
[   18.985065] UMP get page bus_address 0xB3DFA000 in MIU_1
[   18.990592] UMP get page bus_address 0xB3DFB000 in MIU_1
[   18.995961] UMP get page bus_address 0xB3DFC000 in MIU_1
[   19.001515] UMP get page bus_address 0xB3DFD000 in MIU_1
[   19.006933] UMP get page bus_address 0xB3DFE000 in MIU_1
[   19.012312] UMP get page bus_address 0xB3DFF000 in MIU_1
[   19.017821] UMP get page bus_address 0xB3E00000 in MIU_1
[   19.023195] UMP get page bus_address 0xB3E01000 in MIU_1
[   19.028599] UMP get page bus_address 0xB3E02000 in MIU_1
[   19.034042] UMP get page bus_address 0xB3E03000 in MIU_1
[   19.039589] UMP get page bus_address 0xB3E04000 in MIU_1
[   19.045010] UMP get page bus_address 0xB3E05000 in MIU_1
[   19.050694] UMP get page bus_address 0xB3E06000 in MIU_1
[   19.056140] UMP get page bus_address 0xB3E0C000 in MIU_1
[   19.061578] UMP get page bus_address 0xB3E0D000 in MIU_1
[   19.067428] UMP get page bus_address 0xB3E0E000 in MIU_1
[   19.072841] UMP get page bus_address 0xB3E0F000 in MIU_1
[   19.078259] UMP get page bus_address 0xB3E10000 in MIU_1
[   19.083771] UMP get page bus_address 0xB3E11000 in MIU_1
[   19.089545] UMP get page bus_address 0xB3E12000 in MIU_1
[   19.094950] UMP get page bus_address 0xB3E13000 in MIU_1
[   19.100635] UMP get page bus_address 0xB3E14000 in MIU_1
[   19.106063] UMP get page bus_address 0xB3E15000 in MIU_1
[   19.111471] UMP get page bus_address 0xB3E16000 in MIU_1
[   19.117149] UMP get page bus_address 0xB3E17000 in MIU_1
[   19.122547] UMP get page bus_address 0xB3E18000 in MIU_1
[   19.127927] UMP get page bus_address 0xB3E19000 in MIU_1
[   19.133465] UMP get page bus_address 0xB3E1A000 in MIU_1
[   19.138868] UMP get page bus_address 0xB3E1B000 in MIU_1
[   19.144260] UMP get page bus_address 0xB3E1C000 in MIU_1
[   19.149858] UMP get page bus_address 0xB3E1D000 in MIU_1
[   19.155243] UMP get page bus_address 0xB3E1E000 in MIU_1
[   19.160621] UMP get page bus_address 0xB3E1F000 in MIU_1
[   19.166213] UMP get page bus_address 0xB3E20000 in MIU_1
[   19.171595] UMP get page bus_address 0xB3E21000 in MIU_1
[   19.176971] UMP get page bus_address 0xB3E22000 in MIU_1
[   19.182352] UMP get page bus_address 0xB3E23000 in MIU_1
[   19.187815] UMP get page bus_address 0xB3E24000 in MIU_1
[   19.193397] UMP get page bus_address 0xB3E25000 in MIU_1
[   19.198818] UMP get page bus_address 0xB3E26000 in MIU_1
[   19.204368] UMP get page bus_address 0xB3E27000 in MIU_1
[   19.209795] UMP get page bus_address 0xB3E28000 in MIU_1
[   19.215175] UMP get page bus_address 0xB3E29000 in MIU_1
[   19.220659] UMP get page bus_address 0xB3E2A000 in MIU_1
[   19.226057] UMP get page bus_address 0xB3E2B000 in MIU_1
[   19.231484] UMP get page bus_address 0xB3E30000 in MIU_1
[   19.236929] UMP get page bus_address 0xB3E31000 in MIU_1
[   19.242311] UMP get page bus_address 0xB3E32000 in MIU_1
[   19.247789] UMP get page bus_address 0xB3E33000 in MIU_1
[   19.253263] UMP get page bus_address 0xB3E34000 in MIU_1
[   19.258642] UMP get page bus_address 0xB3E35000 in MIU_1
[   19.264020] UMP get page bus_address 0xB3E36000 in MIU_1
[   19.269498] UMP get page bus_address 0xB3E37000 in MIU_1
[   19.274880] UMP get page bus_address 0xB3E38000 in MIU_1
[   19.280271] UMP get page bus_address 0xB3E39000 in MIU_1
[   19.285710] UMP get page bus_address 0xB3E3A000 in MIU_1
[   19.291090] UMP get page bus_address 0xB3E3B000 in MIU_1
[   19.296610] UMP get page bus_address 0xB3E3C000 in MIU_1
[   19.302079] UMP get page bus_address 0xB3E3D000 in MIU_1
[   19.307460] UMP get page bus_address 0xB3E3E000 in MIU_1
[   19.312882] UMP get page bus_address 0xB3E3F000 in MIU_1
[   19.318325] UMP get page bus_address 0xB3E40000 in MIU_1
[   19.323701] UMP get page bus_address 0xB3E41000 in MIU_1
[   19.329075] UMP get page bus_address 0xB3E42000 in MIU_1
[   19.334512] UMP get page bus_address 0xB3E43000 in MIU_1
[   19.339888] UMP get page bus_address 0xB3E44000 in MIU_1
[   19.345262] UMP get page bus_address 0xB3E45000 in MIU_1
[   19.350706] UMP get page bus_address 0xB3E46000 in MIU_1
[   19.356083] UMP get page bus_address 0xB3E47000 in MIU_1
[   19.361547] UMP get page bus_address 0xB3E48000 in MIU_1
[   19.366997] UMP get page bus_address 0xB3E49000 in MIU_1
[   19.372460] UMP get page bus_address 0xB3E4A000 in MIU_1
[   19.377844] UMP get page bus_address 0xB3E4B000 in MIU_1
[   19.383351] UMP get page bus_address 0xB3E4C000 in MIU_1
[   19.388741] UMP get page bus_address 0xB3E4D000 in MIU_1
[   19.394138] UMP get page bus_address 0xB3E50000 in MIU_1
[   19.399784] UMP get page bus_address 0xB3E51000 in MIU_1
[   19.405195] UMP get page bus_address 0xB3E52000 in MIU_1
[   19.410569] UMP get page bus_address 0xB3E53000 in MIU_1
[   19.416009] UMP get page bus_address 0xB3E54000 in MIU_1
[   19.421392] UMP get page bus_address 0xB3E55000 in MIU_1
[   19.426786] UMP get page bus_address 0xB3E56000 in MIU_1
[   19.432163] UMP get page bus_address 0xB3E57000 in MIU_1
[   19.437725] UMP get page bus_address 0xB3E58000 in MIU_1
[   19.443133] UMP get page bus_address 0xB3E59000 in MIU_1
[   19.448536] UMP get page bus_address 0xB3E5A000 in MIU_1
[   19.454009] UMP get page bus_address 0xB3E5B000 in MIU_1
[   19.459392] UMP get page bus_address 0xB3E5C000 in MIU_1
[   19.464778] UMP get page bus_address 0xB3E5D000 in MIU_1
[   19.470236] UMP get page bus_address 0xB3E5E000 in MIU_1
[   19.475616] UMP get page bus_address 0xB3E5F000 in MIU_1
[   19.480992] UMP get page bus_address 0xB3E60000 in MIU_1
[   19.486432] UMP get page bus_address 0xB3E61000 in MIU_1
[   19.491876] UMP get page bus_address 0xB3E62000 in MIU_1
[   19.497538] UMP get page bus_address 0xB3E63000 in MIU_1
[   19.503631] UMP get page bus_address 0xB3E64000 in MIU_1
[   19.509366] UMP get page bus_address 0xB3E65000 in MIU_1
[   19.514887] UMP get page bus_address 0xB3E66000 in MIU_1
[   19.520738] UMP get page bus_address 0xB3E67000 in MIU_1
[   19.526363] UMP get page bus_address 0xB3E68000 in MIU_1
[   19.531810] UMP get page bus_address 0xB3E69000 in MIU_1
[   19.537272] UMP get page bus_address 0xB3E6A000 in MIU_1
[   19.542677] UMP get page bus_address 0xB3E6B000 in MIU_1
[   19.548056] UMP get page bus_address 0xB3E6C000 in MIU_1
[   19.553624] UMP get page bus_address 0xB3E6D000 in MIU_1
[   19.559013] UMP get page bus_address 0xB3E6E000 in MIU_1
[   19.564425] UMP get page bus_address 0xB3E6F000 in MIU_1
[   19.569988] UMP get page bus_address 0xB3E70000 in MIU_1
[   19.575368] UMP get page bus_address 0xB3E71000 in MIU_1
[   19.580744] UMP get page bus_address 0xB3E72000 in MIU_1
[   19.586191] UMP get page bus_address 0xB3E73000 in MIU_1
[   19.591629] UMP get page bus_address 0xB3E74000 in MIU_1
[   19.597156] UMP get page bus_address 0xB3E75000 in MIU_1
[   19.602876] UMP get page bus_address 0xB3E76000 in MIU_1
[   19.608290] UMP get page bus_address 0xB3E77000 in MIU_1
[   19.613686] UMP get page bus_address 0xB3E78000 in MIU_1
[   19.619139] UMP get page bus_address 0xB3E79000 in MIU_1
[   19.624735] UMP get page bus_address 0xB3E7A000 in MIU_1
[   19.630122] UMP get page bus_address 0xB3E7B000 in MIU_1
[   19.635772] UMP get page bus_address 0xB3E7C000 in MIU_1
[   19.641319] UMP get page bus_address 0xB3E7D000 in MIU_1
[   19.646703] UMP get page bus_address 0xB3E7E000 in MIU_1
[   19.652189] UMP get page bus_address 0xB3E7F000 in MIU_1
[   19.657729] UMP get page bus_address 0xB3E80000 in MIU_1
[   19.663130] UMP get page bus_address 0xB3E81000 in MIU_1
[   19.668925] UMP get page bus_address 0xB3E82000 in MIU_1
[   19.674330] UMP get page bus_address 0xB3E83000 in MIU_1
[   19.679712] UMP get page bus_address 0xB3E84000 in MIU_1
[   19.685340] UMP get page bus_address 0xB3E85000 in MIU_1
[   19.690782] UMP get page bus_address 0xB3E86000 in MIU_1
[   19.696205] UMP get page bus_address 0xB3E87000 in MIU_1
[   19.702124] UMP get page bus_address 0xB3E88000 in MIU_1
[   19.707579] UMP get page bus_address 0xB3E89000 in MIU_1
[   19.712965] UMP get page bus_address 0xB3E8A000 in MIU_1
[   19.718637] UMP get page bus_address 0xB3E8B000 in MIU_1
[   19.724046] UMP get page bus_address 0xB3E8C000 in MIU_1
[   19.729457] UMP get page bus_address 0xB3E8D000 in MIU_1
[   19.735045] UMP get page bus_address 0xB3E8E000 in MIU_1
[   19.740431] UMP get page bus_address 0xB3E8F000 in MIU_1
[   19.745806] UMP get page bus_address 0xB3E90000 in MIU_1
[   19.751349] UMP get page bus_address 0xB3E91000 in MIU_1
[   19.756730] UMP get page bus_address 0xB3E92000 in MIU_1
[   19.762128] UMP get page bus_address 0xB3E93000 in MIU_1
[   19.767812] UMP get page bus_address 0xB3E94000 in MIU_1
[   19.773195] UMP get page bus_address 0xB3E95000 in MIU_1
[   19.778571] UMP get page bus_address 0xB3E96000 in MIU_1
[   19.784047] UMP get page bus_address 0xB3E97000 in MIU_1
[   19.789626] UMP get page bus_address 0xB3E98000 in MIU_1
[   19.795072] UMP get page bus_address 0xB3E99000 in MIU_1
[   19.800725] UMP get page bus_address 0xB3E9A000 in MIU_1
[   19.806242] UMP get page bus_address 0xB3E9B000 in MIU_1
[   19.811662] UMP get page bus_address 0xB3E9C000 in MIU_1
[   19.817124] UMP get page bus_address 0xB3E9D000 in MIU_1
[   19.822641] UMP get page bus_address 0xB3E9E000 in MIU_1
[   19.828078] UMP get page bus_address 0xB3E9F000 in MIU_1
[   19.833547] UMP get page bus_address 0xB3EA0000 in MIU_1
[   19.838942] UMP get page bus_address 0xB3EA1000 in MIU_1
[   19.844616] UMP get page bus_address 0xB3EA2000 in MIU_1
[   19.850558] UMP get page bus_address 0xB3EA3000 in MIU_1
[   19.855990] UMP get page bus_address 0xB3EA4000 in MIU_1
[   19.861912] UMP get page bus_address 0xB3EA5000 in MIU_1
[   19.867589] UMP get page bus_address 0xB3EA6000 in MIU_1
[   19.873046] UMP get page bus_address 0xB3EA7000 in MIU_1
[   19.878652] UMP get page bus_address 0xB3EA8000 in MIU_1
[   19.884297] UMP get page bus_address 0xB3EA9000 in MIU_1
[   19.889822] UMP get page bus_address 0xB3EAA000 in MIU_1
[   19.895401] UMP get page bus_address 0xB3EAB000 in MIU_1
[   19.901071] UMP get page bus_address 0xB3EAC000 in MIU_1
[   19.906697] UMP get page bus_address 0xB3EAD000 in MIU_1
[   19.912560] UMP get page bus_address 0xB3EB0000 in MIU_1
[   19.918348] UMP get page bus_address 0xB3EB1000 in MIU_1
[   19.923854] UMP get page bus_address 0xB3EB2000 in MIU_1
[   19.929321] UMP get page bus_address 0xB3EB3000 in MIU_1
[   19.935240] UMP get page bus_address 0xB3EB4000 in MIU_1
[   19.940699] UMP get page bus_address 0xB3EB5000 in MIU_1
[   19.946415] UMP get page bus_address 0xB3EB6000 in MIU_1
[   19.952482] UMP get page bus_address 0xB3EB7000 in MIU_1
[   19.957917] UMP get page bus_address 0xB3EB8000 in MIU_1
[   19.963337] UMP get page bus_address 0xB3EB9000 in MIU_1
[   19.968821] UMP get page bus_address 0xB3EBA000 in MIU_1
[   19.974242] UMP get page bus_address 0xB3EBB000 in MIU_1
[   19.979665] UMP get page bus_address 0xB3EBC000 in MIU_1
[   19.986190] UMP get page bus_address 0xB3EBD000 in MIU_1
[   19.991654] UMP get page bus_address 0xB3EBE000 in MIU_1
[   19.997095] UMP get page bus_address 0xB3EBF000 in MIU_1
[   20.002740] UMP get page bus_address 0xB3EC0000 in MIU_1
[   20.008168] UMP get page bus_address 0xB3EC1000 in MIU_1
[   20.013589] UMP get page bus_address 0xB3EC2000 in MIU_1
[   20.019067] UMP get page bus_address 0xB3EC3000 in MIU_1
[   20.024488] UMP get page bus_address 0xB3EC4000 in MIU_1
[   20.029909] UMP get page bus_address 0xB3EC5000 in MIU_1
[   20.035381] UMP get page bus_address 0xB3EC6000 in MIU_1
[   20.040780] UMP get page bus_address 0xB3EC7000 in MIU_1
[   20.046911] UMP get page bus_address 0xB3EC8000 in MIU_1
[   20.052547] UMP get page bus_address 0xB3EC9000 in MIU_1
[   20.058148] UMP get page bus_address 0xB3ECA000 in MIU_1
[   20.063550] UMP get page bus_address 0xB3ECB000 in MIU_1
[   20.069193] UMP get page bus_address 0xB3ECC000 in MIU_1
[   20.074739] UMP get page bus_address 0xB3ECD000 in MIU_1
[   20.080360] UMP get page bus_address 0xB3ED0000 in MIU_1
[   20.085879] UMP get page bus_address 0xB3ED1000 in MIU_1
[   20.091308] UMP get page bus_address 0xB3ED2000 in MIU_1
[   20.096688] UMP get page bus_address 0xB3ED3000 in MIU_1
[   20.102400] UMP get page bus_address 0xB3ED4000 in MIU_1
[   20.107846] UMP get page bus_address 0xB3ED5000 in MIU_1
[   20.113249] UMP get page bus_address 0xB3ED6000 in MIU_1
[   20.118710] UMP get page bus_address 0xB3ED7000 in MIU_1
[   20.124095] UMP get page bus_address 0xB3ED8000 in MIU_1
[   20.129494] UMP get page bus_address 0xB3ED9000 in MIU_1
[   20.135009] UMP get page bus_address 0xB3EDA000 in MIU_1
[   20.140425] UMP get page bus_address 0xB3EDB000 in MIU_1
[   20.145843] UMP get page bus_address 0xB3EDC000 in MIU_1
[   20.151696] UMP get page bus_address 0xB3EDD000 in MIU_1
[   20.157161] UMP get page bus_address 0xB3EDE000 in MIU_1
[   20.162582] UMP get page bus_address 0xB3EDF000 in MIU_1
[   20.168447] UMP get page bus_address 0xB3EE0000 in MIU_1
[   20.173866] UMP get page bus_address 0xB3EE1000 in MIU_1
[   20.179279] UMP get page bus_address 0xB3EE2000 in MIU_1
[   20.185081] UMP get page bus_address 0xB3EE3000 in MIU_1
[   20.190480] UMP get page bus_address 0xB3EE4000 in MIU_1
[   20.195855] UMP get page bus_address 0xB3EE5000 in MIU_1
[   20.201754] UMP get page bus_address 0xB3EE6000 in MIU_1
[   20.207171] UMP get page bus_address 0xB3EE7000 in MIU_1
[   20.212565] UMP get page bus_address 0xB3EE8000 in MIU_1
[   20.218047] UMP get page bus_address 0xB3EE9000 in MIU_1
[   20.223642] UMP get page bus_address 0xB3EEA000 in MIU_1
[   20.229046] UMP get page bus_address 0xB3EEB000 in MIU_1
[   20.234721] UMP get page bus_address 0xB3EEC000 in MIU_1
[   20.240108] UMP get page bus_address 0xB3EED000 in MIU_1
[   20.245543] UMP get page bus_address 0xB3EEE000 in MIU_1
[   20.251630] UMP get page bus_address 0xB3F10000 in MIU_1
[   20.257708] UMP get page bus_address 0xB3F11000 in MIU_1
[   20.263489] UMP get page bus_address 0xB3F12000 in MIU_1
[   20.269403] UMP get page bus_address 0xB3F13000 in MIU_1
[   20.274935] UMP get page bus_address 0xB3F14000 in MIU_1
[   20.280759] UMP get page bus_address 0xB3F15000 in MIU_1
[   20.286839] UMP get page bus_address 0xB3F16000 in MIU_1
[   20.292282] UMP get page bus_address 0xB3F17000 in MIU_1
[   20.297703] UMP get page bus_address 0xB3F18000 in MIU_1
[   20.303621] UMP get page bus_address 0xB3F19000 in MIU_1
[   20.309301] UMP get page bus_address 0xB3F1A000 in MIU_1
[   20.315186] UMP get page bus_address 0xB3F1B000 in MIU_1
[   20.321262] UMP get page bus_address 0xB3F1C000 in MIU_1
[   20.327205] UMP get page bus_address 0xB3F1D000 in MIU_1
[   20.332845] UMP get page bus_address 0xB3F1E000 in MIU_1
[   20.339229] UMP get page bus_address 0xB3F1F000 in MIU_1
[   20.344990] UMP get page bus_address 0xB3F20000 in MIU_1
[   20.350848] UMP get page bus_address 0xB3F21000 in MIU_1
[   20.356569] UMP get page bus_address 0xB3F22000 in MIU_1
[   20.362214] UMP get page bus_address 0xB3F23000 in MIU_1
[   20.368024] UMP get page bus_address 0xB3F24000 in MIU_1
[   20.373736] UMP get page bus_address 0xB3F25000 in MIU_1
[   20.379215] UMP get page bus_address 0xB3F26000 in MIU_1
[   20.385097] UMP get page bus_address 0xB3F27000 in MIU_1
[   20.390533] UMP get page bus_address 0xB3F28000 in MIU_1
[   20.395941] UMP get page bus_address 0xB3F29000 in MIU_1
[   20.401864] UMP get page bus_address 0xB3F2A000 in MIU_1
[   20.407451] UMP get page bus_address 0xB3F2B000 in MIU_1
[   20.413342] UMP get page bus_address 0xB3F2C000 in MIU_1
[   20.419263] UMP get page bus_address 0xB3F2D000 in MIU_1
[   20.424836] UMP get page bus_address 0xB3F2E000 in MIU_1
[   20.430439] UMP get page bus_address 0xB2C83000 in MIU_1
[   20.436418] UMP get page bus_address 0xB2C8C000 in MIU_1
[   20.441856] UMP get page bus_address 0xB2C8D000 in MIU_1
[   20.447289] UMP get page bus_address 0xB2C8E000 in MIU_1
[   20.453081] UMP get page bus_address 0xB2C8F000 in MIU_1
[   20.458537] UMP get page bus_address 0xB2C90000 in MIU_1
[   20.463963] UMP get page bus_address 0xB2C91000 in MIU_1
[   20.469879] UMP get page bus_address 0xB2C92000 in MIU_1
[   20.475320] UMP get page bus_address 0xB2C93000 in MIU_1
[   20.480781] UMP get page bus_address 0xB2C94000 in MIU_1
[   20.487177] UMP get page bus_address 0xB2C95000 in MIU_1
[   20.495651] UMP get page bus_address 0xB2C96000 in MIU_1
[   20.503220] UMP get page bus_address 0xB2C97000 in MIU_1
[   20.509640] UMP get page bus_address 0xB2C98000 in MIU_1
[   20.515716] UMP get page bus_address 0xB2C99000 in MIU_1
[   20.521960] UMP get page bus_address 0xB2C9A000 in MIU_1
[   20.527801] UMP get page bus_address 0xB2C9B000 in MIU_1
[   20.533982] UMP get page bus_address 0xB2C9C000 in MIU_1
[   20.540156] UMP get page bus_address 0xB2C9D000 in MIU_1
[   20.545725] UMP get page bus_address 0xB2C9E000 in MIU_1
[   20.551565] UMP get page bus_address 0xB2C9F000 in MIU_1
[   20.557188] UMP get page bus_address 0xB2CA0000 in MIU_1
[   20.562704] UMP get page bus_address 0xB2CA1000 in MIU_1
[   20.569224] UMP get page bus_address 0xB2CA2000 in MIU_1
[   20.574898] UMP get page bus_address 0xB2CA3000 in MIU_1
[   20.585072] UMP get page bus_address 0xB2E6C000 in MIU_1
[   20.590854] UMP get page bus_address 0xB2E6B000 in MIU_1
[   20.598244] UMP get page bus_address 0xB2E6A000 in MIU_1
[   20.613047] UMP get page bus_address 0xB2E69000 in MIU_1
[   20.621056] UMP get page bus_address 0xB2E68000 in MIU_1
[   20.632227] UMP get page bus_address 0xB2E67000 in MIU_1
[   20.642234] UMP get page bus_address 0xB2E66000 in MIU_1
[   20.650649] UMP get page bus_address 0xB2E97000 in MIU_1
[   20.660866] UMP get page bus_address 0xB2E96000 in MIU_1
[   20.666754] UMP get page bus_address 0xB2E95000 in MIU_1
[   20.672514] UMP get page bus_address 0xB2E94000 in MIU_1
[   20.678208] UMP get page bus_address 0xB2E93000 in MIU_1
[   20.693854] UMP get page bus_address 0xB2EE3000 in MIU_1
[   20.699879] UMP get page bus_address 0xB2EE2000 in MIU_1
[   20.706077] UMP get page bus_address 0xB2EE1000 in MIU_1
[   20.717659] UMP get page bus_address 0xB2EE0000 in MIU_1
[   20.737379] UMP get page bus_address 0xB2EDF000 in MIU_1
[   20.743727] UMP get page bus_address 0xB2EDE000 in MIU_1
[   20.757589] UMP get page bus_address 0xB2EDD000 in MIU_1
[   20.774237] UMP get page bus_address 0xB2EDC000 in MIU_1
[   20.779819] UMP get page bus_address 0xB2EDB000 in MIU_1
[   20.791369] UMP get page bus_address 0xB2EDA000 in MIU_1
[   20.808367] UMP get page bus_address 0xB2E65000 in MIU_1
[   20.815145] UMP get page bus_address 0xB2EFC000 in MIU_1
[   20.821475] UMP get page bus_address 0xB2EFD000 in MIU_1
[   20.830418] UMP get page bus_address 0xB2EFE000 in MIU_1
[   20.839705] UMP get page bus_address 0xB2EFF000 in MIU_1
[   20.846132] UMP get page bus_address 0xB2F00000 in MIU_1
[   20.852400] UMP get page bus_address 0xB2E01000 in MIU_1
[   20.863455] UMP get page bus_address 0xB2E00000 in MIU_1
[   20.874908] UMP get page bus_address 0xB2ED9000 in MIU_1
[   20.880520] UMP get page bus_address 0xB2ED8000 in MIU_1
[   20.886749] UMP get page bus_address 0xB2ED7000 in MIU_1
[   20.892271] UMP get page bus_address 0xB2ED6000 in MIU_1
[   20.897781] UMP get page bus_address 0xB2F1B000 in MIU_1
[   20.903294] UMP get page bus_address 0xB2F1C000 in MIU_1
[   20.908807] UMP get page bus_address 0xB2F1D000 in MIU_1
[   20.918946] UMP get page bus_address 0xB2F1E000 in MIU_1
[   20.924564] UMP get page bus_address 0xB2F1F000 in MIU_1
[   20.930391] UMP get page bus_address 0xB2F28000 in MIU_1
[   20.935871] UMP get page bus_address 0xB2F29000 in MIU_1
[   20.941448] UMP get page bus_address 0xB2F2A000 in MIU_1
[   20.947082] UMP get page bus_address 0xB2F2B000 in MIU_1
[   20.952624] UMP get page bus_address 0xB2F2C000 in MIU_1
[   20.958833] UMP get page bus_address 0xB2F2D000 in MIU_1
[   20.964325] UMP get page bus_address 0xB2F2E000 in MIU_1
[   20.970164] UMP get page bus_address 0xB2F2F000 in MIU_1
[   20.982131] UMP get page bus_address 0xB2F30000 in MIU_1
[   20.989445] UMP get page bus_address 0xB2F31000 in MIU_1
[   21.000047] UMP get page bus_address 0xB2F32000 in MIU_1
[   21.007015] UMP get page bus_address 0xB2F33000 in MIU_1
[   21.014374] UMP get page bus_address 0xB2F34000 in MIU_1
[   21.020101] UMP get page bus_address 0xB2F35000 in MIU_1
[   21.026517] UMP get page bus_address 0xB2F36000 in MIU_1
[   21.032142] UMP get page bus_address 0xB2F37000 in MIU_1
[   21.037703] UMP get page bus_address 0xB2F38000 in MIU_1
[   21.043308] UMP get page bus_address 0xB2F39000 in MIU_1
[   21.048971] UMP get page bus_address 0xB2F3A000 in MIU_1
[   21.055211] UMP get page bus_address 0xB2F3B000 in MIU_1
[   21.062506] UMP get page bus_address 0xB2F3C000 in MIU_1
[   21.068510] UMP get page bus_address 0xB2F3D000 in MIU_1
[   21.074267] UMP get page bus_address 0xB2F3E000 in MIU_1
[   21.079944] UMP get page bus_address 0xB2F3F000 in MIU_1
[   21.089920] UMP get page bus_address 0xB2FBB000 in MIU_1
[   21.096769] UMP get page bus_address 0xB2EEA000 in MIU_1
[   21.102542] UMP get page bus_address 0xB2EEB000 in MIU_1
[   21.108207] UMP get page bus_address 0xB2FBC000 in MIU_1
[   21.128751] UMP get page bus_address 0xB2FBD000 in MIU_1
[   21.135655] UMP get page bus_address 0xB2FBE000 in MIU_1
[   21.141996] UMP get page bus_address 0xB2FBF000 in MIU_1
[   21.148009] UMP get page bus_address 0xB2FC0000 in MIU_1
[   21.165332] UMP get page bus_address 0xB2FC1000 in MIU_1
[   21.172288] UMP get page bus_address 0xB2FC2000 in MIU_1
[   21.181457] UMP get page bus_address 0xB2FC3000 in MIU_1
[   21.187379] UMP get page bus_address 0xB2FC4000 in MIU_1
[   21.193633] UMP get page bus_address 0xB2FC5000 in MIU_1
[   21.199045] UMP get page bus_address 0xB2FC6000 in MIU_1
[   21.204653] UMP get page bus_address 0xB2FC7000 in MIU_1
[   21.210060] UMP get page bus_address 0xB2FC8000 in MIU_1
[   21.215616] UMP get page bus_address 0xB2FC9000 in MIU_1
[   21.221370] UMP get page bus_address 0xB2FCA000 in MIU_1
[   21.226845] UMP get page bus_address 0xB2FCB000 in MIU_1
[   21.232375] UMP get page bus_address 0xB2FCC000 in MIU_1
[   21.237993] UMP get page bus_address 0xB2FCD000 in MIU_1
[   21.243439] UMP get page bus_address 0xB2FCE000 in MIU_1
[   21.250258] UMP get page bus_address 0xB2FCF000 in MIU_1
[   21.264095] UMP get page bus_address 0xB2FD0000 in MIU_1
[   21.272011] UMP get page bus_address 0xB2FD1000 in MIU_1
[   21.277774] UMP get page bus_address 0xB2FD2000 in MIU_1
[   21.283367] UMP get page bus_address 0xB2FD3000 in MIU_1
[   21.289847] UMP get page bus_address 0xB2FD4000 in MIU_1
[   21.295780] UMP get page bus_address 0xB2FD5000 in MIU_1
[   21.301453] UMP get page bus_address 0xB2FD6000 in MIU_1
[   21.307586] UMP get page bus_address 0xB2FD7000 in MIU_1
[   21.313336] UMP get page bus_address 0xB2F53000 in MIU_1
[   21.428418] UMP get page bus_address 0xB2F53000 in MIU_1
[   21.433856] UMP get page bus_address 0xB2FBB000 in MIU_1
[   21.439479] UMP get page bus_address 0xB2F1B000 in MIU_1
[   21.445437] UMP get page bus_address 0xB2F00000 in MIU_1
[   21.451196] UMP get page bus_address 0xB2E65000 in MIU_1
[   21.456929] UMP get page bus_address 0xB2E93000 in MIU_1
[   21.462679] UMP get page bus_address 0xB2E6C000 in MIU_1
[   21.468221] UMP get page bus_address 0xB2C83000 in MIU_1
[   21.473686] UMP get page bus_address 0xB3DE1000 in MIU_1
[   21.479173] UMP get page bus_address 0xB5BD5000 in MIU_1
[   21.484969] UMP get page bus_address 0xB5B51000 in MIU_1
[   21.492489] UMP get page bus_address 0xB3D3B000 in MIU_1
[   21.498199] UMP get page bus_address 0xB3CE0000 in MIU_1
[   21.504300] UMP get page bus_address 0xB3C7D000 in MIU_1
[   21.509955] UMP get page bus_address 0xB3C1B000 in MIU_1
[   21.515723] UMP get page bus_address 0xB5B5F000 in MIU_1
[   21.521479] UMP get page bus_address 0xB584E000 in MIU_1
[   21.527178] UMP get page bus_address 0xB5852000 in MIU_1
[   21.533321] UMP get page bus_address 0xB5AB8000 in MIU_1
[   21.539019] UMP get page bus_address 0xB5A13000 in MIU_1
[   21.545406] UMP get page bus_address 0xB5843000 in MIU_1
[   21.551392] UMP get page bus_address 0xB582C000 in MIU_1
[   21.557104] UMP get page bus_address 0xB596C000 in MIU_1
[   21.562855] UMP get page bus_address 0xBBA59000 in MIU_1
[   21.568674] UMP get page bus_address 0xBBA91000 in MIU_1
[   21.574421] UMP get page bus_address 0xBB838000 in MIU_1
[   21.580099] UMP get page bus_address 0xB5825000 in MIU_1
[   21.586082] UMP get page bus_address 0xB582A000 in MIU_1
[   21.591989] UMP get page bus_address 0xB5B2A000 in MIU_1
[   21.597825] UMP get page bus_address 0xB2FF0000 in MIU_1
[   21.604110] UMP get page bus_address 0xB2FF1000 in MIU_1
[   21.609898] UMP get page bus_address 0xB2F6C000 in MIU_1
[   21.615789] UMP get page bus_address 0xB2F6D000 in MIU_1
[   21.621438] UMP get page bus_address 0xB584A000 in MIU_1
[   21.627133] UMP get page bus_address 0xB584B000 in MIU_1
[   21.633196] UMP get page bus_address 0xB584C000 in MIU_1
[   21.645235] UMP get page bus_address 0xB2E14000 in MIU_1
[   21.654940] UMP get page bus_address 0xB2E29000 in MIU_1
[   21.660934] UMP get page bus_address 0xB2ED3000 in MIU_1
[   21.667057] UMP get page bus_address 0xB2ED2000 in MIU_1
[   21.672732] UMP get page bus_address 0xB2E53000 in MIU_1
[   21.678985] UMP get page bus_address 0xB2E7E000 in MIU_1
[   21.684834] UMP get page bus_address 0xB2E7B000 in MIU_1
[   21.690500] UMP get page bus_address 0xB2E7F000 in MIU_1
[   21.696341] UMP get page bus_address 0xB2E7C000 in MIU_1
[   21.702386] UMP get page bus_address 0xB2E7D000 in MIU_1
[   21.708261] UMP get page bus_address 0xB2CA4000 in MIU_1
[   21.714052] UMP get page bus_address 0xB2E3F000 in MIU_1
[   21.720576] UMP get page bus_address 0xB2E3E000 in MIU_1
[   21.726842] UMP get page bus_address 0xB2E3D000 in MIU_1
[   21.735283] UMP get page bus_address 0xB2E3C000 in MIU_1
[   21.740891] UMP get page bus_address 0xB2E3A000 in MIU_1
[   21.754543] UMP get page bus_address 0xB5B69000 in MIU_1
[   21.760893] UMP get page bus_address 0xB2E39000 in MIU_1
[   21.767670] UMP get page bus_address 0xB2E38000 in MIU_1
[   21.781945] UMP get page bus_address 0xB2E37000 in MIU_1
[   21.792162] UMP get page bus_address 0xB2E36000 in MIU_1
[   21.797989] UMP get page bus_address 0xB2E34000 in MIU_1
[   21.803832] UMP get page bus_address 0xB2E33000 in MIU_1
[   21.810192] UMP get page bus_address 0xB2E32000 in MIU_1
[   21.816037] UMP get page bus_address 0xB2E30000 in MIU_1
[   21.821766] UMP get page bus_address 0xB2E2F000 in MIU_1
[   21.828138] UMP get page bus_address 0xB2F0F000 in MIU_1
[   21.835114] UMP get page bus_address 0xB2F08000 in MIU_1
[   21.841195] UMP get page bus_address 0xB2F09000 in MIU_1
[   21.847245] UMP get page bus_address 0xB2F0C000 in MIU_1
[   21.852811] UMP get page bus_address 0xB2F0D000 in MIU_1
[   21.858309] UMP get page bus_address 0xB2DFB000 in MIU_1
[   21.864267] UMP get page bus_address 0xB2FFB000 in MIU_1
[   21.869822] UMP get page bus_address 0xB2FFA000 in MIU_1
[   21.875259] UMP get page bus_address 0xB2E43000 in MIU_1
[   21.881041] UMP get page bus_address 0xB2ED4000 in MIU_1
[   21.893797] UMP get page bus_address 0xB2F03000 in MIU_1
[   21.900179] UMP get page bus_address 0xB2F05000 in MIU_1
[   21.906144] UMP get page bus_address 0xB2F07000 in MIU_1
[   21.912765] UMP get page bus_address 0xB2DFD000 in MIU_1
[   21.918367] UMP get page bus_address 0xB2E4E000 in MIU_1
[   21.923896] UMP get page bus_address 0xB2E19000 in MIU_1
[   21.929882] UMP get page bus_address 0xB2E1B000 in MIU_1
[   21.935502] UMP get page bus_address 0xB2E21000 in MIU_1
[   21.941696] UMP get page bus_address 0xB2E28000 in MIU_1
[   21.947676] UMP get page bus_address 0xB2DE8000 in MIU_1
[   21.953253] UMP get page bus_address 0xB2C7D000 in MIU_1
[   21.959405] UMP get page bus_address 0xB2E0A000 in MIU_1
[   21.965474] UMP get page bus_address 0xB2E13000 in MIU_1
[   21.970911] UMP get page bus_address 0xB2E15000 in MIU_1
[   21.976985] UMP get page bus_address 0xB2E17000 in MIU_1
[   21.982804] UMP get page bus_address 0xB584D000 in MIU_1
[   21.988979] UMP get page bus_address 0xB2E0C000 in MIU_1
[   21.994483] UMP get page bus_address 0xB2FF4000 in MIU_1
[   22.000104] UMP get page bus_address 0xB2FF5000 in MIU_1
[   22.005512] UMP get page bus_address 0xB2E72000 in MIU_1
[   22.010897] UMP get page bus_address 0xB2E73000 in MIU_1
[   22.016692] UMP get page bus_address 0xB2E02000 in MIU_1
[   22.022133] UMP get page bus_address 0xB2E03000 in MIU_1
[   22.027540] UMP get page bus_address 0xB2F6A000 in MIU_1
[   22.033702] UMP get page bus_address 0xB2F6B000 in MIU_1
[   22.039367] UMP get page bus_address 0xB2E76000 in MIU_1
[   22.044786] UMP get page bus_address 0xB2E77000 in MIU_1
[   22.051212] UMP get page bus_address 0xB2E78000 in MIU_1
[   22.057038] UMP get page bus_address 0xB2E79000 in MIU_1
[   22.062478] UMP get page bus_address 0xB2E6E000 in MIU_1
[   22.068224] UMP get page bus_address 0xB2E6F000 in MIU_1
[   22.073779] UMP get page bus_address 0xB2DDA000 in MIU_1
[   22.080044] UMP get page bus_address 0xB2DDB000 in MIU_1
[   22.085597] UMP get page bus_address 0xB2FE6000 in MIU_1
[   22.091184] UMP get page bus_address 0xB2FE7000 in MIU_1
[   22.096614] UMP get page bus_address 0xB2DD0000 in MIU_1
[   22.102266] UMP get page bus_address 0xB2DD1000 in MIU_1
[   22.107679] UMP get page bus_address 0xB596E000 in MIU_1
[   22.113095] UMP get page bus_address 0xB596F000 in MIU_1
[   22.118891] UMP get page bus_address 0xB5ABA000 in MIU_1
[   22.124320] UMP get page bus_address 0xB5ABB000 in MIU_1
[   22.129747] UMP get page bus_address 0xB5B08000 in MIU_1
[   22.135736] UMP get page bus_address 0xB5B09000 in MIU_1
[   22.141475] UMP get page bus_address 0xB5B0E000 in MIU_1
[   22.147180] UMP get page bus_address 0xB5B0F000 in MIU_1
[   22.153250] UMP get page bus_address 0xB5850000 in MIU_1
[   22.158842] UMP get page bus_address 0xB5851000 in MIU_1
[   22.164296] UMP get page bus_address 0xB5B48000 in MIU_1
[   22.169761] UMP get page bus_address 0xB5B49000 in MIU_1
[   22.175412] UMP get page bus_address 0xB5904000 in MIU_1
[   22.181538] UMP get page bus_address 0xB5905000 in MIU_1
[   22.186982] UMP get page bus_address 0xB3E04000 in MIU_1
[   22.192378] UMP get page bus_address 0xB3E05000 in MIU_1
[   22.197757] UMP get page bus_address 0xB3E4C000 in MIU_1
[   22.203395] UMP get page bus_address 0xB3E4D000 in MIU_1
[   22.208795] UMP get page bus_address 0xB3EAC000 in MIU_1
[   22.214181] UMP get page bus_address 0xB3EAD000 in MIU_1
[   22.219909] UMP get page bus_address 0xB3ECC000 in MIU_1
[   22.225304] UMP get page bus_address 0xB3ECD000 in MIU_1
[   22.230718] UMP get page bus_address 0xB3EEC000 in MIU_1
[   22.236313] UMP get page bus_address 0xB3EED000 in MIU_1
[   22.241740] UMP get page bus_address 0xB3F2C000 in MIU_1
[   22.247119] UMP get page bus_address 0xB3F2D000 in MIU_1
[   22.252643] UMP get page bus_address 0xB5922000 in MIU_1
[   22.258157] UMP get page bus_address 0xB5923000 in MIU_1
[   22.263546] UMP get page bus_address 0xB5828000 in MIU_1
[   22.268989] UMP get page bus_address 0xB5829000 in MIU_1
[   22.274375] UMP get page bus_address 0xB5826000 in MIU_1
[   22.279756] UMP get page bus_address 0xB5827000 in MIU_1
[   22.285251] UMP get page bus_address 0xB2E10000 in MIU_1
[   22.290633] UMP get page bus_address 0xB2E11000 in MIU_1
[   22.296016] UMP get page bus_address 0xB2E0E000 in MIU_1
[   22.301666] UMP get page bus_address 0xB2E0F000 in MIU_1
[   22.307199] UMP get page bus_address 0xB2E22000 in MIU_1
[   22.312569] UMP get page bus_address 0xB2E23000 in MIU_1
[   22.318174] UMP get page bus_address 0xB2E2A000 in MIU_1
[   22.323547] UMP get page bus_address 0xB2E2B000 in MIU_1
[   22.328917] UMP get page bus_address 0xB5B28000 in MIU_1
[   22.334353] UMP get page bus_address 0xB5B29000 in MIU_1
[   22.339726] UMP get page bus_address 0xB5A58000 in MIU_1
[   22.345130] UMP get page bus_address 0xB5A59000 in MIU_1
[   22.350815] UMP get page bus_address 0xB2E98000 in MIU_1
[   22.356209] UMP get page bus_address 0xB2E99000 in MIU_1
[   22.361601] UMP get page bus_address 0xB2E9C000 in MIU_1
[   22.367474] UMP get page bus_address 0xB2E9D000 in MIU_1
[   22.372957] UMP get page bus_address 0xB2E9E000 in MIU_1
[   22.378346] UMP get page bus_address 0xB2E9F000 in MIU_1
[   22.384074] UMP get page bus_address 0xB2E04000 in MIU_1
[   22.389505] UMP get page bus_address 0xB2E05000 in MIU_1
[   22.394915] UMP get page bus_address 0xB2E06000 in MIU_1
[   22.400678] UMP get page bus_address 0xB2E07000 in MIU_1
[   22.406239] UMP get page bus_address 0xB2E1C000 in MIU_1
[   22.411638] UMP get page bus_address 0xB2E1D000 in MIU_1
[   22.417110] UMP get page bus_address 0xB2E1E000 in MIU_1
[   22.422631] UMP get page bus_address 0xB2E1F000 in MIU_1
[   22.428018] UMP get page bus_address 0xB2E24000 in MIU_1
[   22.433505] UMP get page bus_address 0xB2E25000 in MIU_1
[   22.439119] UMP get page bus_address 0xB2E26000 in MIU_1
[   22.444586] UMP get page bus_address 0xB2E27000 in MIU_1
[   22.450569] UMP get page bus_address 0xB2FBC000 in MIU_1
[   22.455971] UMP get page bus_address 0xB2FBD000 in MIU_1
[   22.461360] UMP get page bus_address 0xB2FBE000 in MIU_1
[   22.467047] UMP get page bus_address 0xB2FBF000 in MIU_1
[   22.472434] UMP get page bus_address 0xB2F1C000 in MIU_1
[   22.477815] UMP get page bus_address 0xB2F1D000 in MIU_1
[   22.483434] UMP get page bus_address 0xB2F1E000 in MIU_1
[   22.488825] UMP get page bus_address 0xB2F1F000 in MIU_1
[   22.494245] UMP get page bus_address 0xB2EFC000 in MIU_1
[   22.500080] UMP get page bus_address 0xB2EFD000 in MIU_1
[   22.505537] UMP get page bus_address 0xB2EFE000 in MIU_1
[   22.511123] UMP get page bus_address 0xB2EFF000 in MIU_1
[   22.516634] UMP get page bus_address 0xB2EE0000 in MIU_1
[   22.522190] UMP get page bus_address 0xB2EE1000 in MIU_1
[   22.527579] UMP get page bus_address 0xB2EE2000 in MIU_1
[   22.533327] UMP get page bus_address 0xB2EE3000 in MIU_1
[   22.538735] UMP get page bus_address 0xB2E94000 in MIU_1
[   22.544117] UMP get page bus_address 0xB2E95000 in MIU_1
[   22.549607] UMP get page bus_address 0xB2E96000 in MIU_1
[   22.555019] UMP get page bus_address 0xB2E97000 in MIU_1
[   22.560398] UMP get page bus_address 0xB2E68000 in MIU_1
[   22.565835] UMP get page bus_address 0xB2E69000 in MIU_1
[   22.571215] UMP get page bus_address 0xB2E6A000 in MIU_1
[   22.576592] UMP get page bus_address 0xB2E6B000 in MIU_1
[   22.582131] UMP get page bus_address 0xB2CA0000 in MIU_1
[   22.587511] UMP get page bus_address 0xB2CA1000 in MIU_1
[   22.592885] UMP get page bus_address 0xB2CA2000 in MIU_1
[   22.598352] UMP get page bus_address 0xB2CA3000 in MIU_1
[   22.603818] UMP get page bus_address 0xB2C8C000 in MIU_1
[   22.609234] UMP get page bus_address 0xB2C8D000 in MIU_1
[   22.614827] UMP get page bus_address 0xB2C8E000 in MIU_1
[   22.620204] UMP get page bus_address 0xB2C8F000 in MIU_1
[   22.625578] UMP get page bus_address 0xB3E0C000 in MIU_1
[   22.630967] UMP get page bus_address 0xB3E0D000 in MIU_1
[   22.636482] UMP get page bus_address 0xB3E0E000 in MIU_1
[   22.641927] UMP get page bus_address 0xB3E0F000 in MIU_1
[   22.647344] UMP get page bus_address 0xB3E00000 in MIU_1
[   22.652834] UMP get page bus_address 0xB3E01000 in MIU_1
[   22.658252] UMP get page bus_address 0xB3E02000 in MIU_1
[   22.664937] UMP get page bus_address 0xB3E03000 in MIU_1
[   22.670436] UMP get page bus_address 0xB3D94000 in MIU_1
[   22.676182] UMP get page bus_address 0xB3D95000 in MIU_1
[   22.681738] UMP get page bus_address 0xB3D96000 in MIU_1
[   22.687173] UMP get page bus_address 0xB3D97000 in MIU_1
[   22.692596] UMP get page bus_address 0xB3D48000 in MIU_1
[   22.698078] UMP get page bus_address 0xB3D49000 in MIU_1
[   22.703502] UMP get page bus_address 0xB3D4A000 in MIU_1
[   22.708944] UMP get page bus_address 0xB3D4B000 in MIU_1
[   22.714502] UMP get page bus_address 0xB3D6C000 in MIU_1
[   22.719977] UMP get page bus_address 0xB3D6D000 in MIU_1
[   22.725987] UMP get page bus_address 0xB5B68000 in MIU_1
[   22.731758] UMP get page bus_address 0xB3C7F000 in MIU_1
[   22.737560] UMP get page bus_address 0xB3C7E000 in MIU_1
[   22.743377] UMP get page bus_address 0xB3D29000 in MIU_1
[   22.749263] UMP get page bus_address 0xB3D28000 in MIU_1
[   22.755181] UMP get page bus_address 0xB3D11000 in MIU_1
[   22.760944] UMP get page bus_address 0xB3D10000 in MIU_1
[   22.766682] UMP get page bus_address 0xB3CFF000 in MIU_1
[   22.772550] UMP get page bus_address 0xB3CFE000 in MIU_1
[   22.778356] UMP get page bus_address 0xB3D4F000 in MIU_1
[   22.784064] UMP get page bus_address 0xB3D4E000 in MIU_1
[   22.789861] UMP get page bus_address 0xB3D59000 in MIU_1
[   22.795638] UMP get page bus_address 0xB2F06000 in MIU_1
[   22.801361] UMP get page bus_address 0xB2FF8000 in MIU_1
[   22.807371] UMP get page bus_address 0xB2FDF000 in MIU_1
[   22.813807] UMP get page bus_address 0xB2FFF000 in MIU_1
[   22.819638] UMP get page bus_address 0xB2FFE000 in MIU_1
[   22.825431] UMP get page bus_address 0xB3F2E000 in MIU_1
[   22.837635] UMP get page bus_address 0xB3EEE000 in MIU_1
[   22.845885] UMP get page bus_address 0xB3E06000 in MIU_1
[   22.854789] UMP get page bus_address 0xB3D2A000 in MIU_1
[   22.860620] UMP get page bus_address 0xB5B4A000 in MIU_1
[   22.866550] UMP get page bus_address 0xB2E00000 in MIU_1
[   22.872352] UMP get page bus_address 0xB2ED7000 in MIU_1
[   22.878474] UMP get page bus_address 0xB2EEB000 in MIU_1
[   22.884184] UMP get page bus_address 0xB2EEA000 in MIU_1
[   22.890246] UMP get page bus_address 0xB2FDE000 in MIU_1
[   22.896013] UMP get page bus_address 0xB3F0E000 in MIU_1
[   22.902237] UMP get page bus_address 0xB3D80000 in MIU_1
[   22.908252] UMP get page bus_address 0xB3D92000 in MIU_1
[   22.914701] UMP get page bus_address 0xBAF91000 in MIU_1
[   22.920443] UMP get page bus_address 0xBAF90000 in MIU_1
[   22.927066] UMP get page bus_address 0xBAF8F000 in MIU_1
[   22.933086] UMP get page bus_address 0xBAF8E000 in MIU_1
[   22.939065] UMP get page bus_address 0xB3D99000 in MIU_1
[   22.944803] UMP get page bus_address 0xB2E67000 in MIU_1
[   22.950948] UMP get page bus_address 0xB2E66000 in MIU_1
[   22.956681] UMP get page bus_address 0xB5A14000 in MIU_1
[   22.962411] UMP get page bus_address 0xB5A16000 in MIU_1
[   22.968369] UMP get page bus_address 0xB3EEA000 in MIU_1
[   22.974176] UMP get page bus_address 0xB2F28000 in MIU_1
[   22.980000] UMP get page bus_address 0xB3EC1000 in MIU_1
[   22.985742] UMP get page bus_address 0xB2FDA000 in MIU_1
[   22.991684] UMP get page bus_address 0xB2FDB000 in MIU_1
[   22.997565] UMP get page bus_address 0xB3E40000 in MIU_1
[   23.003498] UMP get page bus_address 0xB3E41000 in MIU_1
[   23.009353] UMP get page bus_address 0xB3E42000 in MIU_1
[   23.010453] Mali get page bus_address 0xB3D6E000 in MIU_1
[   23.010495] Mali get page bus_address 0xB3D6F000 in MIU_1
[   23.010534] Mali get page bus_address 0xB3D1C000 in MIU_1
[   23.010578] Mali get page bus_address 0xB3D1D000 in MIU_1
[   23.010619] Mali get page bus_address 0xB3D1E000 in MIU_1
[   23.010660] Mali get page bus_address 0xB3D1F000 in MIU_1
[   23.010694] Mali get page bus_address 0xB3C2C000 in MIU_1
[   23.010728] Mali get page bus_address 0xB3C2D000 in MIU_1
[   23.010763] Mali get page bus_address 0xB3C2E000 in MIU_1
[   23.010799] Mali get page bus_address 0xB3C2F000 in MIU_1
[   23.010832] Mali get page bus_address 0xB5BF4000 in MIU_1
[   23.010869] Mali get page bus_address 0xB5BF5000 in MIU_1
[   23.010906] Mali get page bus_address 0xB5BF6000 in MIU_1
[   23.010942] Mali get page bus_address 0xB5BF7000 in MIU_1
[   23.010977] Mali get page bus_address 0xB3C10000 in MIU_1
[   23.011007] Mali get page bus_address 0xB3C11000 in MIU_1
[   23.011042] Mali get page bus_address 0xB3C12000 in MIU_1
[   23.011081] Mali get page bus_address 0xB3C13000 in MIU_1
[   23.011122] Mali get page bus_address 0xB5BFC000 in MIU_1
[   23.011159] Mali get page bus_address 0xB5BFD000 in MIU_1
[   23.011203] Mali get page bus_address 0xB5BFE000 in MIU_1
[   23.011242] Mali get page bus_address 0xB5903000 in MIU_1
[   23.011299] Mali get page bus_address 0xB5A5F000 in MIU_1
[   23.011334] Mali get page bus_address 0xB5A5E000 in MIU_1
[   23.011366] Mali get page bus_address 0xB5B2D000 in MIU_1
[   23.011396] Mali get page bus_address 0xB2E52000 in MIU_1
[   23.011427] Mali get page bus_address 0xB2E7A000 in MIU_1
[   23.011461] Mali get page bus_address 0xB2E4F000 in MIU_1
[   23.011492] Mali get page bus_address 0xB2E42000 in MIU_1
[   23.011522] Mali get page bus_address 0xB2E41000 in MIU_1
[   23.011589] Mali get page bus_address 0xB2E09000 in MIU_1
[   23.011632] Mali get page bus_address 0xB2E0D000 in MIU_1
[   23.011671] Mali get page bus_address 0xB2E12000 in MIU_1
[   23.011714] Mali get page bus_address 0xB2E16000 in MIU_1
[   23.011786] Mali get page bus_address 0xB58FF000 in MIU_1
[   23.011824] Mali get page bus_address 0xB58FE000 in MIU_1
[   23.011865] Mali get page bus_address 0xB58FD000 in MIU_1
[   23.011898] Mali get page bus_address 0xB58FC000 in MIU_1
[   23.011929] Mali get page bus_address 0xB5901000 in MIU_1
[   23.011968] Mali get page bus_address 0xB5900000 in MIU_1
[   23.012003] Mali get page bus_address 0xB5927000 in MIU_1
[   23.012044] Mali get page bus_address 0xB5926000 in MIU_1
[   23.012079] Mali get page bus_address 0xB5925000 in MIU_1
[   23.012116] Mali get page bus_address 0xB5924000 in MIU_1
[   23.012153] Mali get page bus_address 0xBB917000 in MIU_1
[   23.012196] Mali get page bus_address 0xBB916000 in MIU_1
[   23.012239] Mali get page bus_address 0xBB915000 in MIU_1
[   23.012281] Mali get page bus_address 0xB3E48000 in MIU_1
[   23.012321] Mali get page bus_address 0xB3E2B000 in MIU_1
[   23.012367] Mali get page bus_address 0xB3E2A000 in MIU_1
[   23.012400] Mali get page bus_address 0xB3E29000 in MIU_1
[   23.012441] Mali get page bus_address 0xB3C7B000 in MIU_1
[   23.012483] Mali get page bus_address 0xB3C79000 in MIU_1
[   23.012518] Mali get page bus_address 0xB3C78000 in MIU_1
[   23.012559] Mali get page bus_address 0xB596B000 in MIU_1
[   23.012592] Mali get page bus_address 0xB596A000 in MIU_1
[   23.012632] Mali get page bus_address 0xB5969000 in MIU_1
[   23.012665] Mali get page bus_address 0xB5968000 in MIU_1
[   23.332555] UMP get page bus_address 0xB2C90000 in MIU_1
[   23.338435] UMP get page bus_address 0xB2F3F000 in MIU_1
[   23.344223] UMP get page bus_address 0xB2F3C000 in MIU_1
[   23.350364] UMP get page bus_address 0xB2F3B000 in MIU_1
[   23.356556] UMP get page bus_address 0xB2F3A000 in MIU_1
[   23.362377] UMP get page bus_address 0xB2F39000 in MIU_1
[   23.368096] UMP get page bus_address 0xB3F1D000 in MIU_1
[   23.373676] UMP get page bus_address 0xB3F1C000 in MIU_1
[   23.379191] UMP get page bus_address 0xB3F1A000 in MIU_1
[   23.384638] UMP get page bus_address 0xB3F19000 in MIU_1
[   23.390139] UMP get page bus_address 0xB3F18000 in MIU_1
[   23.398981] UMP get page bus_address 0xB3F17000 in MIU_1
[   23.405323] UMP get page bus_address 0xB3F16000 in MIU_1
[   23.411376] UMP get page bus_address 0xB3F14000 in MIU_1
[   23.423796] UMP get page bus_address 0xB3F12000 in MIU_1
[   23.431978] UMP get page bus_address 0xB3F11000 in MIU_1
[   23.437467] UMP get page bus_address 0xB2C9D000 in MIU_1
[   23.442975] UMP get page bus_address 0xB2C9C000 in MIU_1
[   23.448730] UMP get page bus_address 0xB2C9B000 in MIU_1
[   23.454390] UMP get page bus_address 0xB2C9A000 in MIU_1
[   23.460026] UMP get page bus_address 0xB3EDD000 in MIU_1
[   23.467265] UMP get page bus_address 0xB3EDC000 in MIU_1
[   23.472729] UMP get page bus_address 0xB3EDB000 in MIU_1
[   23.478138] UMP get page bus_address 0xB3ED9000 in MIU_1
[   23.483577] UMP get page bus_address 0xB3ED8000 in MIU_1
[   23.489024] UMP get page bus_address 0xB3ED7000 in MIU_1
[   23.501105] UMP get page bus_address 0xB3EB9000 in MIU_1
[   23.512685] UMP get page bus_address 0xB3EB8000 in MIU_1
[   23.519384] UMP get page bus_address 0xB3ED5000 in MIU_1
[   23.526490] UMP get page bus_address 0xB3E43000 in MIU_1
[   23.532275] UMP get page bus_address 0xB3E44000 in MIU_1
[   23.537856] UMP get page bus_address 0xB3E45000 in MIU_1
[   23.543592] UMP get page bus_address 0xB3E46000 in MIU_1
[   23.549730] UMP get page bus_address 0xB3E47000 in MIU_1
[   23.555695] UMP get page bus_address 0xB3E20000 in MIU_1
[   23.561597] UMP get page bus_address 0xB3E21000 in MIU_1
[   23.567729] UMP get page bus_address 0xB3E22000 in MIU_1
[   23.573843] UMP get page bus_address 0xB3E23000 in MIU_1
[   23.580000] UMP get page bus_address 0xB3E24000 in MIU_1
[   23.586943] UMP get page bus_address 0xB3E25000 in MIU_1
[   23.592898] UMP get page bus_address 0xB3E26000 in MIU_1
[   23.598790] UMP get page bus_address 0xB3E27000 in MIU_1
[   23.604697] UMP get page bus_address 0xB3DF8000 in MIU_1
[   23.610465] UMP get page bus_address 0xB3DF9000 in MIU_1
[   23.616294] UMP get page bus_address 0xB3DFA000 in MIU_1
[   23.622009] UMP get page bus_address 0xB3DFB000 in MIU_1
[   23.627874] UMP get page bus_address 0xB5B40000 in MIU_1
[   23.633676] UMP get page bus_address 0xB5B41000 in MIU_1
[   23.639410] UMP get page bus_address 0xB5A1C000 in MIU_1
[   23.645089] UMP get page bus_address 0xB5A1D000 in MIU_1
[   23.650826] UMP get page bus_address 0xB3D22000 in MIU_1
[   23.656452] UMP get page bus_address 0xB3D23000 in MIU_1
[   23.662137] UMP get page bus_address 0xB3D24000 in MIU_1
[   23.667721] UMP get page bus_address 0xB3D25000 in MIU_1
[   23.673335] UMP get page bus_address 0xB5B60000 in MIU_1
[   23.678883] UMP get page bus_address 0xB5B61000 in MIU_1
[   23.684520] UMP get page bus_address 0xB5B64000 in MIU_1
[   23.690143] UMP get page bus_address 0xB5B65000 in MIU_1
[   23.695758] UMP get page bus_address 0xB5AB2000 in MIU_1
[   23.701364] UMP get page bus_address 0xB5AB3000 in MIU_1
[   23.707002] UMP get page bus_address 0xB3EA4000 in MIU_1
[   23.712662] UMP get page bus_address 0xB3EA5000 in MIU_1
[   23.718328] UMP get page bus_address 0xB3EA0000 in MIU_1
[   23.723917] UMP get page bus_address 0xB3EA1000 in MIU_1
[   23.729545] UMP get page bus_address 0xB3EA2000 in MIU_1
[   23.735256] UMP get page bus_address 0xB3EA3000 in MIU_1
[   23.740944] UMP get page bus_address 0xB2F30000 in MIU_1
[   23.746542] UMP get page bus_address 0xB2F31000 in MIU_1
[   23.752155] UMP get page bus_address 0xB2F32000 in MIU_1
[   23.757726] UMP get page bus_address 0xB2F33000 in MIU_1
[   23.763357] UMP get page bus_address 0xB3EC8000 in MIU_1
[   23.769062] UMP get page bus_address 0xB3EC9000 in MIU_1
[   23.774810] UMP get page bus_address 0xB3ECA000 in MIU_1
[   23.780485] UMP get page bus_address 0xB3ECB000 in MIU_1
[   23.786259] UMP get page bus_address 0xB5B37000 in MIU_1
[   23.791935] UMP get page bus_address 0xB5B12000 in MIU_1
[   23.797673] UMP get page bus_address 0xB5B13000 in MIU_1
[   23.803309] UMP get page bus_address 0xB5B14000 in MIU_1
[   23.809013] UMP get page bus_address 0xB5B15000 in MIU_1
[   23.814608] UMP get page bus_address 0xB5B16000 in MIU_1
[   23.820248] UMP get page bus_address 0xB5B17000 in MIU_1
[   23.825892] UMP get page bus_address 0xB5B18000 in MIU_1
[   23.831547] UMP get page bus_address 0xB5B19000 in MIU_1
[   23.837297] UMP get page bus_address 0xB5B1A000 in MIU_1
[   23.843381] UMP get page bus_address 0xB5B1B000 in MIU_1
[   23.849023] UMP get page bus_address 0xB5B1C000 in MIU_1
[   23.855085] UMP get page bus_address 0xB5B1D000 in MIU_1
[   23.860822] UMP get page bus_address 0xB5B1E000 in MIU_1
[   23.866573] UMP get page bus_address 0xB5B1F000 in MIU_1
[   23.872135] UMP get page bus_address 0xB5AF0000 in MIU_1
[   23.877709] UMP get page bus_address 0xB5AF1000 in MIU_1
[   23.883258] UMP get page bus_address 0xB5AF2000 in MIU_1
[   23.888855] UMP get page bus_address 0xB5AF3000 in MIU_1
[   23.895160] UMP get page bus_address 0xB5AF4000 in MIU_1
[   23.900706] UMP get page bus_address 0xB5AF5000 in MIU_1
[   23.906119] UMP get page bus_address 0xB5AF6000 in MIU_1
[   23.911483] UMP get page bus_address 0xB5AF7000 in MIU_1
[   23.917137] UMP get page bus_address 0xB5AF8000 in MIU_1
[   23.922653] UMP get page bus_address 0xB5AF9000 in MIU_1
[   23.928154] UMP get page bus_address 0xB5AFA000 in MIU_1
[   23.933705] UMP get page bus_address 0xB5AFB000 in MIU_1
[   23.939336] UMP get page bus_address 0xB5AFC000 in MIU_1
[   23.944926] UMP get page bus_address 0xB5AFD000 in MIU_1
[   23.950461] UMP get page bus_address 0xB5AFE000 in MIU_1
[   23.956054] UMP get page bus_address 0xB5AFF000 in MIU_1
[   23.961645] UMP get page bus_address 0xB3C09000 in MIU_1
[   23.967207] UMP get page bus_address 0xB3C0B000 in MIU_1
[   23.972768] UMP get page bus_address 0xB5B36000 in MIU_1
[   23.978306] UMP get page bus_address 0xB3D0E000 in MIU_1
[   23.983904] UMP get page bus_address 0xB3ED0000 in MIU_1
[   23.989621] UMP get page bus_address 0xB3C01000 in MIU_1
[   23.995244] UMP get page bus_address 0xB3C3D000 in MIU_1
[   24.000917] UMP get page bus_address 0xB3C3F000 in MIU_1
[   24.006518] UMP get page bus_address 0xB3C05000 in MIU_1
[   24.012133] UMP get page bus_address 0xB3D53000 in MIU_1
[   24.017734] UMP get page bus_address 0xB5963000 in MIU_1
[   24.023365] UMP get page bus_address 0xB5A4F000 in MIU_1
[   24.028971] UMP get page bus_address 0xB5B30000 in MIU_1
[   24.034582] UMP get page bus_address 0xB5B32000 in MIU_1
[   24.040228] UMP get page bus_address 0xB5B33000 in MIU_1
[   24.045875] UMP get page bus_address 0xB5960000 in MIU_1
[   24.051496] UMP get page bus_address 0xB5961000 in MIU_1
[   24.057052] UMP get page bus_address 0xB5B34000 in MIU_1
[   24.062622] UMP get page bus_address 0xB5B35000 in MIU_1
[   24.068166] UMP get page bus_address 0xB3C02000 in MIU_1
[   24.073720] UMP get page bus_address 0xB3C03000 in MIU_1
[   24.079272] UMP get page bus_address 0xB5B3C000 in MIU_1
[   24.084843] UMP get page bus_address 0xB5B3D000 in MIU_1
[   24.090412] UMP get page bus_address 0xB5B3E000 in MIU_1
[   24.096053] UMP get page bus_address 0xB5B3F000 in MIU_1
[   24.101608] UMP get page bus_address 0xB3C0C000 in MIU_1
[   24.107166] UMP get page bus_address 0xB3C0D000 in MIU_1
[   24.112747] UMP get page bus_address 0xB3C0E000 in MIU_1
[   24.118317] UMP get page bus_address 0xB3C0F000 in MIU_1
[   24.123895] UMP get page bus_address 0xB5970000 in MIU_1
[   24.129506] UMP get page bus_address 0xB5971000 in MIU_1
[   24.135122] UMP get page bus_address 0xB5972000 in MIU_1
[   24.140775] UMP get page bus_address 0xB5973000 in MIU_1
[   24.146439] UMP get page bus_address 0xB5974000 in MIU_1
[   24.152074] UMP get page bus_address 0xB5975000 in MIU_1
[   24.157705] UMP get page bus_address 0xB5976000 in MIU_1
[   24.163273] UMP get page bus_address 0xB5977000 in MIU_1
[   24.168837] UMP get page bus_address 0xB5978000 in MIU_1
[   24.174400] UMP get page bus_address 0xB5979000 in MIU_1
[   24.179943] UMP get page bus_address 0xB597A000 in MIU_1
[   24.185637] UMP get page bus_address 0xB597B000 in MIU_1
[   24.191181] UMP get page bus_address 0xB597C000 in MIU_1
[   24.196733] UMP get page bus_address 0xB597D000 in MIU_1
[   24.202267] UMP get page bus_address 0xB597E000 in MIU_1
[   24.207798] UMP get page bus_address 0xB597F000 in MIU_1
[   24.213354] UMP get page bus_address 0xB5930000 in MIU_1
[   24.218767] UMP get page bus_address 0xB5931000 in MIU_1
[   24.224147] UMP get page bus_address 0xB5932000 in MIU_1
[   24.229537] UMP get page bus_address 0xB5933000 in MIU_1
[   24.234920] UMP get page bus_address 0xB5934000 in MIU_1
[   24.240299] UMP get page bus_address 0xB5935000 in MIU_1
[   24.245717] UMP get page bus_address 0xB5936000 in MIU_1
[   24.251135] UMP get page bus_address 0xB5937000 in MIU_1
[   24.256514] UMP get page bus_address 0xB5938000 in MIU_1
[   24.261917] UMP get page bus_address 0xB5939000 in MIU_1
[   24.267306] UMP get page bus_address 0xB593A000 in MIU_1
[   24.272707] UMP get page bus_address 0xB593B000 in MIU_1
[   24.278100] UMP get page bus_address 0xB593C000 in MIU_1
[   24.283486] UMP get page bus_address 0xB593D000 in MIU_1
[   24.288872] UMP get page bus_address 0xB593E000 in MIU_1
[   24.294243] UMP get page bus_address 0xB593F000 in MIU_1
[   24.299994] UMP get page bus_address 0xB5A00000 in MIU_1
[   24.305460] UMP get page bus_address 0xB5A01000 in MIU_1
[   24.310839] UMP get page bus_address 0xB5A02000 in MIU_1
[   24.316266] UMP get page bus_address 0xB5A03000 in MIU_1
[   24.321672] UMP get page bus_address 0xB5A04000 in MIU_1
[   24.327054] UMP get page bus_address 0xB5A05000 in MIU_1
[   24.332529] UMP get page bus_address 0xB5A06000 in MIU_1
[   24.337924] UMP get page bus_address 0xB5A07000 in MIU_1
[   24.343294] UMP get page bus_address 0xB5A08000 in MIU_1
[   24.348750] UMP get page bus_address 0xB5A09000 in MIU_1
[   24.354199] UMP get page bus_address 0xB5A0A000 in MIU_1
[   24.359575] UMP get page bus_address 0xB5A0B000 in MIU_1
[   24.364949] UMP get page bus_address 0xB5A0C000 in MIU_1
[   24.370316] UMP get page bus_address 0xB5A0D000 in MIU_1
[   24.375684] UMP get page bus_address 0xB5A0E000 in MIU_1
[   24.381130] UMP get page bus_address 0xB5A0F000 in MIU_1
[   24.386521] UMP get page bus_address 0xB5AA0000 in MIU_1
[   24.391898] UMP get page bus_address 0xB5AA1000 in MIU_1
[   24.397275] UMP get page bus_address 0xB5AA2000 in MIU_1
[   24.402651] UMP get page bus_address 0xB5AA3000 in MIU_1
[   24.408191] UMP get page bus_address 0xB5AA4000 in MIU_1
[   24.413606] UMP get page bus_address 0xB5AA5000 in MIU_1
[   24.419081] UMP get page bus_address 0xB5AA6000 in MIU_1
[   24.424467] UMP get page bus_address 0xB5AA7000 in MIU_1
[   24.429955] UMP get page bus_address 0xB5AA8000 in MIU_1
[   24.435377] UMP get page bus_address 0xB5AA9000 in MIU_1
[   24.440772] UMP get page bus_address 0xB5AAA000 in MIU_1
[   24.446214] UMP get page bus_address 0xB5AAB000 in MIU_1
[   24.451643] UMP get page bus_address 0xB5AAC000 in MIU_1
[   24.457030] UMP get page bus_address 0xB5AAD000 in MIU_1
[   24.462425] UMP get page bus_address 0xB5AAE000 in MIU_1
[   24.467862] UMP get page bus_address 0xB5AAF000 in MIU_1
[   24.473252] UMP get page bus_address 0xB3C60000 in MIU_1
[   24.478619] UMP get page bus_address 0xB3C61000 in MIU_1
[   24.483998] UMP get page bus_address 0xB3C62000 in MIU_1
[   24.489377] UMP get page bus_address 0xB3C63000 in MIU_1
[   24.494745] UMP get page bus_address 0xB3C64000 in MIU_1
[   24.500133] UMP get page bus_address 0xB3C65000 in MIU_1
[   24.505517] UMP get page bus_address 0xB3C66000 in MIU_1
[   24.510894] UMP get page bus_address 0xB3C67000 in MIU_1
[   24.516323] UMP get page bus_address 0xB3C68000 in MIU_1
[   24.522460] UMP get page bus_address 0xB3C69000 in MIU_1
[   24.527900] UMP get page bus_address 0xB3C6A000 in MIU_1
[   24.533384] UMP get page bus_address 0xB3C6B000 in MIU_1
[   24.538777] UMP get page bus_address 0xB3C6C000 in MIU_1
[   24.544216] UMP get page bus_address 0xB3C6D000 in MIU_1
[   24.549671] UMP get page bus_address 0xB3C6F000 in MIU_1
[   24.556185] UMP get page bus_address 0xB3E80000 in MIU_1
[   24.561623] UMP get page bus_address 0xB3E81000 in MIU_1
[   24.567003] UMP get page bus_address 0xB3E82000 in MIU_1
[   24.572380] UMP get page bus_address 0xB3E83000 in MIU_1
[   24.577831] UMP get page bus_address 0xB3E84000 in MIU_1
[   24.583295] UMP get page bus_address 0xB3E85000 in MIU_1
[   24.588672] UMP get page bus_address 0xB3E86000 in MIU_1
[   24.594125] UMP get page bus_address 0xB3E87000 in MIU_1
[   24.599511] UMP get page bus_address 0xB3E88000 in MIU_1
[   24.604967] UMP get page bus_address 0xB3E89000 in MIU_1
[   24.610347] UMP get page bus_address 0xB3E8A000 in MIU_1
[   24.615725] UMP get page bus_address 0xB3E8B000 in MIU_1
[   24.621187] UMP get page bus_address 0xB3E8C000 in MIU_1
[   24.626573] UMP get page bus_address 0xB3E8D000 in MIU_1
[   24.631976] UMP get page bus_address 0xB3E8E000 in MIU_1
[   24.637475] UMP get page bus_address 0xB3E8F000 in MIU_1
[   24.642894] UMP get page bus_address 0xB3E90000 in MIU_1
[   24.648380] UMP get page bus_address 0xB3E91000 in MIU_1
[   24.653776] UMP get page bus_address 0xB3E92000 in MIU_1
[   24.659269] UMP get page bus_address 0xB3E93000 in MIU_1
[   24.664700] UMP get page bus_address 0xB3E94000 in MIU_1
[   24.670106] UMP get page bus_address 0xB3E95000 in MIU_1
[   24.675557] UMP get page bus_address 0xB3E96000 in MIU_1
[   24.680953] UMP get page bus_address 0xB3E97000 in MIU_1
[   24.686347] UMP get page bus_address 0xB3E98000 in MIU_1
[   24.691736] UMP get page bus_address 0xB3E99000 in MIU_1
[   24.697186] UMP get page bus_address 0xB3E9A000 in MIU_1
[   24.702570] UMP get page bus_address 0xB3E9B000 in MIU_1
[   24.707944] UMP get page bus_address 0xB3E9C000 in MIU_1
[   24.713318] UMP get page bus_address 0xB3E9D000 in MIU_1
[   24.718701] UMP get page bus_address 0xB3E9E000 in MIU_1
[   24.724087] UMP get page bus_address 0xB3E9F000 in MIU_1
[   24.729459] UMP get page bus_address 0xB3E60000 in MIU_1
[   24.734839] UMP get page bus_address 0xB3E61000 in MIU_1
[   24.740226] UMP get page bus_address 0xB3E62000 in MIU_1
[   24.745600] UMP get page bus_address 0xB3E63000 in MIU_1
[   24.751059] UMP get page bus_address 0xB3E64000 in MIU_1
[   24.756472] UMP get page bus_address 0xB3E65000 in MIU_1
[   24.762000] UMP get page bus_address 0xB3E66000 in MIU_1
[   24.767380] UMP get page bus_address 0xB3E67000 in MIU_1
[   24.772816] UMP get page bus_address 0xB3E68000 in MIU_1
[   24.778238] UMP get page bus_address 0xB3E69000 in MIU_1
[   24.783633] UMP get page bus_address 0xB3E6A000 in MIU_1
[   24.789060] UMP get page bus_address 0xB3E6B000 in MIU_1
[   24.794451] UMP get page bus_address 0xB3E6C000 in MIU_1
[   24.799840] UMP get page bus_address 0xB3E6D000 in MIU_1
[   24.805239] UMP get page bus_address 0xB3E7A000 in MIU_1
[   24.810680] UMP get page bus_address 0xB3E7B000 in MIU_1
[   24.816072] UMP get page bus_address 0xB3E7C000 in MIU_1
[   24.821460] UMP get page bus_address 0xB3E7D000 in MIU_1
[   24.826859] UMP get page bus_address 0xB3E7E000 in MIU_1
[   24.832259] UMP get page bus_address 0xB3E7F000 in MIU_1
[   24.837643] UMP get page bus_address 0xB3C40000 in MIU_1
[   24.843034] UMP get page bus_address 0xB3C41000 in MIU_1
[   24.848425] UMP get page bus_address 0xB3C42000 in MIU_1
[   24.853834] UMP get page bus_address 0xB3C43000 in MIU_1
[   24.859231] UMP get page bus_address 0xB3C44000 in MIU_1
[   24.864721] UMP get page bus_address 0xB3C45000 in MIU_1
[   24.870148] UMP get page bus_address 0xB3C46000 in MIU_1
[   24.875658] UMP get page bus_address 0xB3C47000 in MIU_1
[   24.881058] UMP get page bus_address 0xB3C48000 in MIU_1
[   24.886515] UMP get page bus_address 0xB3C49000 in MIU_1
[   24.891943] UMP get page bus_address 0xB3C4A000 in MIU_1
[   24.897345] UMP get page bus_address 0xB3C4B000 in MIU_1
[   24.902794] UMP get page bus_address 0xB3C4C000 in MIU_1
[   24.908248] UMP get page bus_address 0xB3C4D000 in MIU_1
[   24.913839] UMP get page bus_address 0xB3C4E000 in MIU_1
[   24.919454] UMP get page bus_address 0xB3C4F000 in MIU_1
[   24.925137] UMP get page bus_address 0xB3C50000 in MIU_1
[   24.930762] UMP get page bus_address 0xB3C51000 in MIU_1
[   24.936343] UMP get page bus_address 0xB3C52000 in MIU_1
[   24.941976] UMP get page bus_address 0xB3C53000 in MIU_1
[   24.947561] UMP get page bus_address 0xB3C54000 in MIU_1
[   24.953142] UMP get page bus_address 0xB3C55000 in MIU_1
[   24.958691] UMP get page bus_address 0xB3C56000 in MIU_1
[   24.964345] UMP get page bus_address 0xB3C57000 in MIU_1
[   24.970014] UMP get page bus_address 0xB3C58000 in MIU_1
[   24.975754] UMP get page bus_address 0xB3C59000 in MIU_1
[   24.981375] UMP get page bus_address 0xB5A80000 in MIU_1
[   24.986977] UMP get page bus_address 0xB5A81000 in MIU_1
[   24.992682] UMP get page bus_address 0xB5A82000 in MIU_1
[   24.998245] UMP get page bus_address 0xB5A83000 in MIU_1
[   25.003859] UMP get page bus_address 0xB5A84000 in MIU_1
[   25.009963] UMP get page bus_address 0xB5A85000 in MIU_1
[   25.015622] UMP get page bus_address 0xB5A86000 in MIU_1
[   25.021246] UMP get page bus_address 0xB5A87000 in MIU_1
[   25.026872] UMP get page bus_address 0xB5A88000 in MIU_1
[   25.032473] UMP get page bus_address 0xB5A89000 in MIU_1
[   25.038081] UMP get page bus_address 0xB5A8A000 in MIU_1
[   25.043684] UMP get page bus_address 0xB5A8B000 in MIU_1
[   25.049271] UMP get page bus_address 0xB5A8C000 in MIU_1
[   25.054878] UMP get page bus_address 0xB5A8D000 in MIU_1
[   25.060492] UMP get page bus_address 0xB5A8E000 in MIU_1
[   25.066128] UMP get page bus_address 0xB5A8F000 in MIU_1
[   25.071811] UMP get page bus_address 0xB5A90000 in MIU_1
[   25.077468] UMP get page bus_address 0xB5A91000 in MIU_1
[   25.083105] UMP get page bus_address 0xB5A92000 in MIU_1
[   25.088716] UMP get page bus_address 0xB5A93000 in MIU_1
[   25.094299] UMP get page bus_address 0xB5A94000 in MIU_1
[   25.099904] UMP get page bus_address 0xB5A95000 in MIU_1
[   25.105501] UMP get page bus_address 0xB5A96000 in MIU_1
[   25.111108] UMP get page bus_address 0xB5A97000 in MIU_1
[   25.116736] UMP get page bus_address 0xB5A98000 in MIU_1
[   25.122341] UMP get page bus_address 0xB5A99000 in MIU_1
[   25.127957] UMP get page bus_address 0xB5A9A000 in MIU_1
[   25.133599] UMP get page bus_address 0xB5A9B000 in MIU_1
[   25.139414] UMP get page bus_address 0xB5A9C000 in MIU_1
[   25.145134] UMP get page bus_address 0xB5A9D000 in MIU_1
[   25.152603] UMP get page bus_address 0xB5A1B000 in MIU_1
[   25.158178] UMP get page bus_address 0xB3E3A000 in MIU_1
[   25.163789] UMP get page bus_address 0xB3E3D000 in MIU_1
[   25.169418] UMP get page bus_address 0xB3E1B000 in MIU_1
[   25.175078] UMP get page bus_address 0xB3EA8000 in MIU_1
[   25.180718] UMP get page bus_address 0xB3F15000 in MIU_1
[   25.186293] UMP get page bus_address 0xB3EB4000 in MIU_1
[   25.191901] UMP get page bus_address 0xB3ED1000 in MIU_1
[   25.197525] UMP get page bus_address 0xB3ED4000 in MIU_1
[   25.203204] UMP get page bus_address 0xB3EDE000 in MIU_1
[   25.208807] UMP get page bus_address 0xB3EB0000 in MIU_1
[   25.214419] UMP get page bus_address 0xB5A28000 in MIU_1
[   25.220005] UMP get page bus_address 0xB5A20000 in MIU_1
[   25.225677] UMP get page bus_address 0xB5967000 in MIU_1
[   25.231962] UMP get page bus_address 0xB5A4D000 in MIU_1
[   25.237618] UMP get page bus_address 0xB3E10000 in MIU_1
[   25.243204] UMP get page bus_address 0xB5B31000 in MIU_1
[   25.248905] UMP get page bus_address 0xB3C0A000 in MIU_1
[   25.254508] UMP get page bus_address 0xB3C04000 in MIU_1
[   25.260086] UMP get page bus_address 0xB3EB6000 in MIU_1
[   25.265702] UMP get page bus_address 0xB5A4E000 in MIU_1
[   25.271613] UMP get page bus_address 0xB3D0B000 in MIU_1
[   25.277245] UMP get page bus_address 0xB2F35000 in MIU_1
[   25.282858] UMP get page bus_address 0xB2FCF000 in MIU_1
[   25.288514] UMP get page bus_address 0xB5A1E000 in MIU_1
[   25.294129] UMP get page bus_address 0xB3D57000 in MIU_1
[   25.299720] UMP get page bus_address 0xB3D21000 in MIU_1
[   25.305243] UMP get page bus_address 0xB5B63000 in MIU_1
[   25.310642] UMP get page bus_address 0xB5B67000 in MIU_1
[   25.316361] UMP get page bus_address 0xB5B06000 in MIU_1
[   25.321989] UMP get page bus_address 0xB3F1F000 in MIU_1
[   25.327614] UMP get page bus_address 0xB3EAB000 in MIU_1
[   25.333280] UMP get page bus_address 0xB2C95000 in MIU_1
[   25.338866] UMP get page bus_address 0xB3C3A000 in MIU_1
[   25.344508] UMP get page bus_address 0xB3D0F000 in MIU_1
[   25.350189] UMP get page bus_address 0xB3E1F000 in MIU_1
[   25.355770] UMP get page bus_address 0xB5A52000 in MIU_1
[   25.361365] UMP get page bus_address 0xB5965000 in MIU_1
[   25.366974] UMP get page bus_address 0xB5929000 in MIU_1
[   25.372584] UMP get page bus_address 0xB592A000 in MIU_1
[   25.378220] UMP get page bus_address 0xB3C08000 in MIU_1
[   25.383817] UMP get page bus_address 0xB5AB4000 in MIU_1
[   25.389400] UMP get page bus_address 0xB3E16000 in MIU_1
[   25.395001] UMP get page bus_address 0xB3E17000 in MIU_1
[   25.400610] UMP get page bus_address 0xB3D0C000 in MIU_1
[   25.406215] UMP get page bus_address 0xB3D0D000 in MIU_1
[   25.411861] UMP get page bus_address 0xB5AB6000 in MIU_1
[   25.417455] UMP get page bus_address 0xB5AB7000 in MIU_1
[   25.423062] UMP get page bus_address 0xB3E38000 in MIU_1
[   25.430283] UMP get page bus_address 0xB3E39000 in MIU_1
[   25.435885] UMP get page bus_address 0xB3E3E000 in MIU_1
[   25.441488] UMP get page bus_address 0xB3E3F000 in MIU_1
[   25.447092] UMP get page bus_address 0xB3E12000 in MIU_1
[   25.452637] UMP get page bus_address 0xB3E13000 in MIU_1
[   25.458218] UMP get page bus_address 0xB3EE8000 in MIU_1
[   25.463789] UMP get page bus_address 0xB3EE9000 in MIU_1
[   25.469411] UMP get page bus_address 0xB3D06000 in MIU_1
[   25.475051] UMP get page bus_address 0xB3D07000 in MIU_1
[   25.480658] UMP get page bus_address 0xB2C92000 in MIU_1
[   25.486307] UMP get page bus_address 0xB2C93000 in MIU_1
[   25.491922] UMP get page bus_address 0xB5A72000 in MIU_1
[   25.497532] UMP get page bus_address 0xB5A73000 in MIU_1
[   25.503119] UMP get page bus_address 0xB5952000 in MIU_1
[   25.508745] UMP get page bus_address 0xB5953000 in MIU_1
[   25.514343] UMP get page bus_address 0xB5A48000 in MIU_1
[   25.519951] UMP get page bus_address 0xB5A49000 in MIU_1
[   25.525649] UMP get page bus_address 0xB5A4A000 in MIU_1
[   25.531247] UMP get page bus_address 0xB5A4B000 in MIU_1
[   25.536851] UMP get page bus_address 0xB592C000 in MIU_1
[   25.542485] UMP get page bus_address 0xB592D000 in MIU_1
[   25.548104] UMP get page bus_address 0xB592E000 in MIU_1
[   25.553788] UMP get page bus_address 0xB592F000 in MIU_1
[   25.559416] UMP get page bus_address 0xB3CC0000 in MIU_1
[   25.565033] UMP get page bus_address 0xB3CC1000 in MIU_1
[   25.570641] UMP get page bus_address 0xB3CC2000 in MIU_1
[   25.576226] UMP get page bus_address 0xB3CC3000 in MIU_1
[   25.581771] UMP get page bus_address 0xB3CC4000 in MIU_1
[   25.587401] UMP get page bus_address 0xB3CC5000 in MIU_1
[   25.592978] UMP get page bus_address 0xB3CC6000 in MIU_1
[   25.598585] UMP get page bus_address 0xB3CC7000 in MIU_1
[   25.604174] UMP get page bus_address 0xB3CC8000 in MIU_1
[   25.609778] UMP get page bus_address 0xB3CC9000 in MIU_1
[   25.615363] UMP get page bus_address 0xB3CCA000 in MIU_1
[   25.620945] UMP get page bus_address 0xB3CCB000 in MIU_1
[   25.626539] UMP get page bus_address 0xB3CCC000 in MIU_1
[   25.632161] UMP get page bus_address 0xB3CCD000 in MIU_1
[   25.637754] UMP get page bus_address 0xB3CCE000 in MIU_1
[   25.643379] UMP get page bus_address 0xB3CCF000 in MIU_1
[   25.649134] UMP get page bus_address 0xB3CD4000 in MIU_1
[   25.654758] UMP get page bus_address 0xB3CD5000 in MIU_1
[   25.660366] UMP get page bus_address 0xB3CD6000 in MIU_1
[   25.665981] UMP get page bus_address 0xB3CD7000 in MIU_1
[   25.672233] UMP get page bus_address 0xB3CD2000 in MIU_1
[   25.677838] UMP get page bus_address 0xB3CD3000 in MIU_1
[   25.683465] UMP get page bus_address 0xB2C98000 in MIU_1
[   25.689298] UMP get page bus_address 0xB2C99000 in MIU_1
[   25.699371] UMP get page bus_address 0xB3C80000 in MIU_1
[   25.704941] UMP get page bus_address 0xB3C81000 in MIU_1
[   25.710368] UMP get page bus_address 0xB3C82000 in MIU_1
[   25.716078] UMP get page bus_address 0xB3C83000 in MIU_1
[   25.721704] UMP get page bus_address 0xB3C84000 in MIU_1
[   25.727321] UMP get page bus_address 0xB3C85000 in MIU_1
[   25.732927] UMP get page bus_address 0xB3C86000 in MIU_1
[   25.738515] UMP get page bus_address 0xB3C87000 in MIU_1
[   25.744115] UMP get page bus_address 0xB3C88000 in MIU_1
[   25.749700] UMP get page bus_address 0xB3C89000 in MIU_1
[   25.755307] UMP get page bus_address 0xB3C8A000 in MIU_1
[   25.760905] UMP get page bus_address 0xB3C8B000 in MIU_1
[   25.766334] UMP get page bus_address 0xB3C8C000 in MIU_1
[   25.771728] UMP get page bus_address 0xB3C8D000 in MIU_1
[   25.777137] UMP get page bus_address 0xB3C8E000 in MIU_1
[   25.782542] UMP get page bus_address 0xB3C8F000 in MIU_1
[   25.787952] UMP get page bus_address 0xB3C90000 in MIU_1
[   25.793351] UMP get page bus_address 0xB3C91000 in MIU_1
[   25.795540] Mali get page bus_address 0xB2F3E000 in MIU_1
[   25.795578] Mali get page bus_address 0xB3F1E000 in MIU_1
[   25.795612] Mali get page bus_address 0xB3ED6000 in MIU_1
[   25.795646] Mali get page bus_address 0xB5A18000 in MIU_1
[   25.795682] Mali get page bus_address 0xB3EB2000 in MIU_1
[   25.795725] Mali get page bus_address 0xB3E18000 in MIU_1
[   25.795760] Mali get page bus_address 0xB3CD1000 in MIU_1
[   25.795794] Mali get page bus_address 0xB5951000 in MIU_1
[   25.795827] Mali get page bus_address 0xB5950000 in MIU_1
[   25.795860] Mali get page bus_address 0xB594F000 in MIU_1
[   25.795894] Mali get page bus_address 0xB594E000 in MIU_1
[   25.795924] Mali get page bus_address 0xB594D000 in MIU_1
[   25.795958] Mali get page bus_address 0xB594C000 in MIU_1
[   25.795989] Mali get page bus_address 0xB594A000 in MIU_1
[   25.796064] Mali get page bus_address 0xB5949000 in MIU_1
[   25.796102] Mali get page bus_address 0xB5948000 in MIU_1
[   25.796135] Mali get page bus_address 0xB5946000 in MIU_1
[   25.796166] Mali get page bus_address 0xB5945000 in MIU_1
[   25.796200] Mali get page bus_address 0xB3D01000 in MIU_1
[   25.796234] Mali get page bus_address 0xB3EB3000 in MIU_1
[   25.796490] Mali get page bus_address 0xB3CDE000 in MIU_1
[   25.796528] Mali get page bus_address 0xB3CDD000 in MIU_1
[   25.796562] Mali get page bus_address 0xB3CDC000 in MIU_1
[   25.796596] Mali get page bus_address 0xB3CDB000 in MIU_1
[   25.796627] Mali get page bus_address 0xB3CDA000 in MIU_1
[   25.796661] Mali get page bus_address 0xB3CD9000 in MIU_1
[   25.796692] Mali get page bus_address 0xB3CD8000 in MIU_1
[   25.944676] UMP get page bus_address 0xB3C92000 in MIU_1
[   25.950064] UMP get page bus_address 0xB3C93000 in MIU_1
[   25.955450] UMP get page bus_address 0xB3C94000 in MIU_1
[   25.960833] UMP get page bus_address 0xB3C95000 in MIU_1
[   25.966213] UMP get page bus_address 0xB3C96000 in MIU_1
[   25.971610] UMP get page bus_address 0xB3C97000 in MIU_1
[   25.976988] UMP get page bus_address 0xB3C98000 in MIU_1
[   25.982366] UMP get page bus_address 0xB3C99000 in MIU_1
[   25.987754] UMP get page bus_address 0xB3C9A000 in MIU_1
[   25.993138] UMP get page bus_address 0xB3C9B000 in MIU_1
[   25.998524] UMP get page bus_address 0xB2EFA000 in MIU_1
[   26.003912] UMP get page bus_address 0xB2EFB000 in MIU_1
[   26.009280] UMP get page bus_address 0xB3CA8000 in MIU_1
[   26.014646] UMP get page bus_address 0xB3CA9000 in MIU_1
[   26.020013] UMP get page bus_address 0xB3CAA000 in MIU_1
[   26.025375] UMP get page bus_address 0xB3CAB000 in MIU_1
[   26.030740] UMP get page bus_address 0xB3CAC000 in MIU_1
[   26.036105] UMP get page bus_address 0xB3CAD000 in MIU_1
[   26.041465] UMP get page bus_address 0xB3CAE000 in MIU_1
[   26.046830] UMP get page bus_address 0xB3CAF000 in MIU_1
[   26.052191] UMP get page bus_address 0xB3CB0000 in MIU_1
[   26.057555] UMP get page bus_address 0xB3CB1000 in MIU_1
[   26.062920] UMP get page bus_address 0xB3CB2000 in MIU_1
[   26.068283] UMP get page bus_address 0xB3CB3000 in MIU_1
[   26.073647] UMP get page bus_address 0xB3CB4000 in MIU_1
[   26.079010] UMP get page bus_address 0xB3CB5000 in MIU_1
[   26.084371] UMP get page bus_address 0xB3CB6000 in MIU_1
[   26.089732] UMP get page bus_address 0xB3CB7000 in MIU_1
[   26.095096] UMP get page bus_address 0xB3CB8000 in MIU_1
[   26.100459] UMP get page bus_address 0xB3CB9000 in MIU_1
[   26.105821] UMP get page bus_address 0xB3CBA000 in MIU_1
[   26.111184] UMP get page bus_address 0xB3CBB000 in MIU_1
[   26.116546] UMP get page bus_address 0xB3CBC000 in MIU_1
[   26.121917] UMP get page bus_address 0xB3CBD000 in MIU_1
[   26.127277] UMP get page bus_address 0xB3CBE000 in MIU_1
[   26.132640] UMP get page bus_address 0xB3CBF000 in MIU_1
[   26.138003] UMP get page bus_address 0xB5980000 in MIU_1
[   26.143367] UMP get page bus_address 0xB5981000 in MIU_1
[   26.148728] UMP get page bus_address 0xB5982000 in MIU_1
[   26.154093] UMP get page bus_address 0xB5983000 in MIU_1
[   26.159457] UMP get page bus_address 0xB5984000 in MIU_1
[   26.164829] UMP get page bus_address 0xB5985000 in MIU_1
[   26.170189] UMP get page bus_address 0xB5986000 in MIU_1
[   26.175552] UMP get page bus_address 0xB5987000 in MIU_1
[   26.180915] UMP get page bus_address 0xB5988000 in MIU_1
[   26.186306] UMP get page bus_address 0xB5989000 in MIU_1
[   26.191688] UMP get page bus_address 0xB598A000 in MIU_1
[   26.197055] UMP get page bus_address 0xB598B000 in MIU_1
[   26.202423] UMP get page bus_address 0xB598C000 in MIU_1
[   26.207788] UMP get page bus_address 0xB598D000 in MIU_1
[   26.213150] UMP get page bus_address 0xB598E000 in MIU_1
[   26.218513] UMP get page bus_address 0xB598F000 in MIU_1
[   26.223874] UMP get page bus_address 0xB5990000 in MIU_1
[   26.229243] UMP get page bus_address 0xB5991000 in MIU_1
[   26.234605] UMP get page bus_address 0xB5992000 in MIU_1
[   26.239969] UMP get page bus_address 0xB5993000 in MIU_1
[   26.245333] UMP get page bus_address 0xB5994000 in MIU_1
[   26.250698] UMP get page bus_address 0xB5995000 in MIU_1
[   26.256062] UMP get page bus_address 0xB5996000 in MIU_1
[   26.261425] UMP get page bus_address 0xB5997000 in MIU_1
[   26.266789] UMP get page bus_address 0xB5998000 in MIU_1
[   26.272161] UMP get page bus_address 0xB5999000 in MIU_1
[   26.277526] UMP get page bus_address 0xB599A000 in MIU_1
[   26.282892] UMP get page bus_address 0xB599B000 in MIU_1
[   26.288257] UMP get page bus_address 0xB599C000 in MIU_1
[   26.293621] UMP get page bus_address 0xB599D000 in MIU_1
[   26.298984] UMP get page bus_address 0xB599E000 in MIU_1
[   26.304346] UMP get page bus_address 0xB599F000 in MIU_1
[   26.309710] UMP get page bus_address 0xB59A0000 in MIU_1
[   26.315073] UMP get page bus_address 0xB59A1000 in MIU_1
[   26.320435] UMP get page bus_address 0xB59A2000 in MIU_1
[   26.325797] UMP get page bus_address 0xB59A3000 in MIU_1
[   26.331171] UMP get page bus_address 0xB59A4000 in MIU_1
[   26.336549] UMP get page bus_address 0xB59A5000 in MIU_1
[   26.341922] UMP get page bus_address 0xB59A6000 in MIU_1
[   26.347324] UMP get page bus_address 0xB59A7000 in MIU_1
[   26.352692] UMP get page bus_address 0xB59A8000 in MIU_1
[   26.358057] UMP get page bus_address 0xB59A9000 in MIU_1
[   26.363421] UMP get page bus_address 0xB59AA000 in MIU_1
[   26.368786] UMP get page bus_address 0xB59AB000 in MIU_1
[   26.374147] UMP get page bus_address 0xB59AC000 in MIU_1
[   26.379510] UMP get page bus_address 0xB59AD000 in MIU_1
[   26.384932] UMP get page bus_address 0xB59AE000 in MIU_1
[   26.390299] UMP get page bus_address 0xB59AF000 in MIU_1
[   26.395666] UMP get page bus_address 0xB59B0000 in MIU_1
[   26.401028] UMP get page bus_address 0xB59B1000 in MIU_1
[   26.406392] UMP get page bus_address 0xB59B2000 in MIU_1
[   26.411754] UMP get page bus_address 0xB59B3000 in MIU_1
[   26.417119] UMP get page bus_address 0xB59B4000 in MIU_1
[   26.422483] UMP get page bus_address 0xB59B5000 in MIU_1
[   26.427843] UMP get page bus_address 0xB59B6000 in MIU_1
[   26.433205] UMP get page bus_address 0xB59B7000 in MIU_1
[   26.438568] UMP get page bus_address 0xB59B8000 in MIU_1
[   26.443930] UMP get page bus_address 0xB59B9000 in MIU_1
[   26.449330] UMP get page bus_address 0xB59BA000 in MIU_1
[   26.454695] UMP get page bus_address 0xB59BB000 in MIU_1
[   26.460062] UMP get page bus_address 0xB59BC000 in MIU_1
[   26.465425] UMP get page bus_address 0xB59BD000 in MIU_1
[   26.470789] UMP get page bus_address 0xB59BE000 in MIU_1
[   26.476151] UMP get page bus_address 0xB59BF000 in MIU_1
[   26.481515] UMP get page bus_address 0xB59C0000 in MIU_1
[   26.486884] UMP get page bus_address 0xB59C1000 in MIU_1
[   26.492247] UMP get page bus_address 0xB59C2000 in MIU_1
[   26.497618] UMP get page bus_address 0xB59C3000 in MIU_1
[   26.502982] UMP get page bus_address 0xB59C4000 in MIU_1
[   26.508346] UMP get page bus_address 0xB59C5000 in MIU_1
[   26.513707] UMP get page bus_address 0xB59C6000 in MIU_1
[   26.519067] UMP get page bus_address 0xB59C7000 in MIU_1
[   26.524430] UMP get page bus_address 0xB59C8000 in MIU_1
[   26.529792] UMP get page bus_address 0xB59C9000 in MIU_1
[   26.535153] UMP get page bus_address 0xB59CA000 in MIU_1
[   26.540516] UMP get page bus_address 0xB59CB000 in MIU_1
[   26.545881] UMP get page bus_address 0xB59CC000 in MIU_1
[   26.551260] UMP get page bus_address 0xB59CD000 in MIU_1
[   26.556634] UMP get page bus_address 0xB59CE000 in MIU_1
[   26.562001] UMP get page bus_address 0xB59CF000 in MIU_1
[   26.567380] UMP get page bus_address 0xB59D0000 in MIU_1
[   26.572759] UMP get page bus_address 0xB59D1000 in MIU_1
[   26.578234] UMP get page bus_address 0xB59D2000 in MIU_1
[   26.583626] UMP get page bus_address 0xB59D3000 in MIU_1
[   26.588993] UMP get page bus_address 0xB59D4000 in MIU_1
[   26.594428] UMP get page bus_address 0xB59D5000 in MIU_1
[   26.599799] UMP get page bus_address 0xB59D6000 in MIU_1
[   26.605224] UMP get page bus_address 0xB59D7000 in MIU_1
[   26.610595] UMP get page bus_address 0xB59D8000 in MIU_1
[   26.615958] UMP get page bus_address 0xB59D9000 in MIU_1
[   26.621320] UMP get page bus_address 0xB59DA000 in MIU_1
[   26.626682] UMP get page bus_address 0xB59DB000 in MIU_1
[   26.632042] UMP get page bus_address 0xB59DC000 in MIU_1
[   26.637406] UMP get page bus_address 0xB59DD000 in MIU_1
[   26.642771] UMP get page bus_address 0xB59DE000 in MIU_1
[   26.648132] UMP get page bus_address 0xB59DF000 in MIU_1
[   26.653518] UMP get page bus_address 0xB59E0000 in MIU_1
[   26.658925] UMP get page bus_address 0xB59E1000 in MIU_1
[   26.675137] UMP get page bus_address 0xB3EC2000 in MIU_1
[   26.680540] UMP get page bus_address 0xB3EC3000 in MIU_1
[   26.690951] UMP get page bus_address 0xB59FF000 in MIU_1
[   26.696574] UMP get page bus_address 0xB59FE000 in MIU_1
[   26.702063] UMP get page bus_address 0xB59FD000 in MIU_1
[   26.707493] UMP get page bus_address 0xB59FC000 in MIU_1
[   26.712899] UMP get page bus_address 0xB59FB000 in MIU_1
[   26.718315] UMP get page bus_address 0xB59FA000 in MIU_1
[   26.723729] UMP get page bus_address 0xB59F9000 in MIU_1
[   26.729122] UMP get page bus_address 0xB59F8000 in MIU_1
[   26.734517] UMP get page bus_address 0xB59F7000 in MIU_1
[   26.739885] UMP get page bus_address 0xB59F6000 in MIU_1
[   26.745248] UMP get page bus_address 0xB59F5000 in MIU_1
[   26.750794] UMP get page bus_address 0xB59F4000 in MIU_1
[   26.756184] UMP get page bus_address 0xB59F3000 in MIU_1
[   26.761611] UMP get page bus_address 0xB59F2000 in MIU_1
[   26.851415] UMP get page bus_address 0xB3C33000 in MIU_1
[   26.857100] UMP get page bus_address 0xB3C31000 in MIU_1
[   26.862897] UMP get page bus_address 0xB5A19000 in MIU_1
[   27.003730] UMP get page bus_address 0xB3ED2000 in MIU_1
[   27.011268] UMP get page bus_address 0xB5944000 in MIU_1
[   27.053075] UMP get page bus_address 0xB59F4000 in MIU_1
[   27.059070] UMP get page bus_address 0xB59F5000 in MIU_1
[   27.071541] UMP get page bus_address 0xB59EA000 in MIU_1
[   27.077488] UMP get page bus_address 0xB59EB000 in MIU_1
[   27.083625] UMP get page bus_address 0xB59EC000 in MIU_1
[   27.089358] UMP get page bus_address 0xB59ED000 in MIU_1
[   27.096060] UMP get page bus_address 0xB59EE000 in MIU_1
[   27.101568] UMP get page bus_address 0xB59EF000 in MIU_1
[   27.107082] UMP get page bus_address 0xB59F0000 in MIU_1
[   27.107870] Mali get page bus_address 0xB59F6000 in MIU_1
[   27.107924] Mali get page bus_address 0xB59F7000 in MIU_1
[   27.110454] Mali get page bus_address 0xB59F8000 in MIU_1
[   27.110490] Mali get page bus_address 0xB59F9000 in MIU_1
[   27.110531] Mali get page bus_address 0xB59FA000 in MIU_1
[   27.110568] Mali get page bus_address 0xB59FB000 in MIU_1
[   27.110610] Mali get page bus_address 0xB59FC000 in MIU_1
[   27.110648] Mali get page bus_address 0xB59FD000 in MIU_1
[   27.110684] Mali get page bus_address 0xB59FE000 in MIU_1
[   27.110719] Mali get page bus_address 0xB59FF000 in MIU_1
[   27.303603] UMP get page bus_address 0xB5A7B000 in MIU_1
[   27.309183] UMP get page bus_address 0xB5A21000 in MIU_1
[   27.314677] UMP get page bus_address 0xB5A25000 in MIU_1
[   27.320198] UMP get page bus_address 0xB2C9F000 in MIU_1
[   27.325613] UMP get page bus_address 0xB5A3E000 in MIU_1
[   27.331161] UMP get page bus_address 0xB5940000 in MIU_1
[   27.336565] UMP get page bus_address 0xB5943000 in MIU_1
[   27.341996] UMP get page bus_address 0xB5A2F000 in MIU_1
[   27.347391] UMP get page bus_address 0xB5A33000 in MIU_1
[   27.352858] UMP get page bus_address 0xB5A36000 in MIU_1
[   27.358403] UMP get page bus_address 0xB5A38000 in MIU_1
[   27.363907] UMP get page bus_address 0xB5A3A000 in MIU_1
[   27.369361] UMP get page bus_address 0xB5A30000 in MIU_1
[   27.374819] UMP get page bus_address 0xB5A31000 in MIU_1
[   27.380294] UMP get page bus_address 0xB5A7C000 in MIU_1
[   27.385805] UMP get page bus_address 0xB5A7D000 in MIU_1
[   27.391249] UMP get page bus_address 0xB5A7E000 in MIU_1
[   27.396676] UMP get page bus_address 0xB5A7F000 in MIU_1
[   27.402351] UMP get page bus_address 0xB59E2000 in MIU_1
[   27.407758] UMP get page bus_address 0xB59E3000 in MIU_1
[   27.413198] UMP get page bus_address 0xB5A5C000 in MIU_1
[   27.418597] UMP get page bus_address 0xB5A5D000 in MIU_1
[   27.424370] UMP get page bus_address 0xB59E4000 in MIU_1
[   27.429761] UMP get page bus_address 0xB59E5000 in MIU_1
[   27.435277] UMP get page bus_address 0xB59E6000 in MIU_1
[   27.440790] UMP get page bus_address 0xB59E7000 in MIU_1
[   27.448488] UMP get page bus_address 0xB5A7A000 in MIU_1
[   27.453984] UMP get page bus_address 0xB5A79000 in MIU_1
[   27.459386] UMP get page bus_address 0xB5A3D000 in MIU_1
[   27.464847] UMP get page bus_address 0xB5A3C000 in MIU_1
[   27.470260] UMP get page bus_address 0xB5A3B000 in MIU_1
[   27.475675] UMP get page bus_address 0xB3EB1000 in MIU_1
[   27.481042] UMP get page bus_address 0xB5A2D000 in MIU_1
[   27.486445] UMP get page bus_address 0xB5A29000 in MIU_1
[   27.491887] UMP get page bus_address 0xB5A27000 in MIU_1
[   27.497250] UMP get page bus_address 0xB59F3000 in MIU_1
[   27.502797] UMP get page bus_address 0xB3ED3000 in MIU_1
[   27.508194] UMP get page bus_address 0xB3E3C000 in MIU_1
[   27.513598] UMP get page bus_address 0xB3E11000 in MIU_1
[   27.519006] UMP get page bus_address 0xB3E1D000 in MIU_1
[   27.524382] UMP get page bus_address 0xB5A66000 in MIU_1
[   27.529754] UMP get page bus_address 0xB5A65000 in MIU_1
[   27.535120] UMP get page bus_address 0xB3D04000 in MIU_1
[   27.540488] UMP get page bus_address 0xB3D03000 in MIU_1
[   27.545851] UMP get page bus_address 0xB3D02000 in MIU_1
[   27.551216] UMP get page bus_address 0xB3D00000 in MIU_1
[   27.556756] UMP get page bus_address 0xB3E1E000 in MIU_1
[   27.562261] UMP get page bus_address 0xB3E19000 in MIU_1
[   27.567644] UMP get page bus_address 0xB3E15000 in MIU_1
[   27.573015] UMP get page bus_address 0xB3C35000 in MIU_1
[   27.578381] UMP get page bus_address 0xB59E8000 in MIU_1
[   27.583745] UMP get page bus_address 0xB59F2000 in MIU_1
[   27.589195] UMP get page bus_address 0xB5A1A000 in MIU_1
[   27.594601] UMP get page bus_address 0xB5942000 in MIU_1
[   27.599963] UMP get page bus_address 0xB5A32000 in MIU_1
[   27.605364] UMP get page bus_address 0xB5A35000 in MIU_1
[   27.610765] UMP get page bus_address 0xB5A39000 in MIU_1
[   27.616174] UMP get page bus_address 0xB5A67000 in MIU_1
[   27.621544] UMP get page bus_address 0xB5A2E000 in MIU_1
[   27.626910] UMP get page bus_address 0xB3E14000 in MIU_1
[   27.632272] UMP get page bus_address 0xB3C32000 in MIU_1
[   27.694744] Mali get page bus_address 0xB5947000 in MIU_1
[   27.700608] Mali get page bus_address 0xB594B000 in MIU_1
[   27.706525] Mali get page bus_address 0xB3C31000 in MIU_1
[   27.712336] Mali get page bus_address 0xB5A19000 in MIU_1
[   30.751596] fence timeout on [d60ff780] after 3000ms
[   31.743643] fence error -62 on [d60ff780]
发表于: 2021-3-18 09:52:53
这个是什么方案,估计要换cpu
发表于: 2021-3-19 16:37:08
加密了,换的是不是同型号的EMMC,写原机量产软件,不行换CPU
 楼主| 发表于: 2021-3-20 15:02:38
renxiaoyao 2021-3-18 09:52
这个是什么方案,估计要换cpu
是918方案
 楼主| 发表于: 2021-3-20 15:04:18
刘顿 2021-3-19 16:37
换的是同型号EMMC,升蓬买新的
发表于: 2021-3-20 16:52:45
918方案一般不加密。建议更换主控cpu。
 楼主| 发表于: 2021-3-20 21:23:34
renxiaoyao 2021-3-20 16:52
群里问过罗老师,都是说918问题,已经订件,但是爱修课程里有一课就是这个板的,老师说是加密的,只是不关闭串口写引导。量产也有这个的量产备份
发表于: 2021-3-24 10:48:44
好,期待你修好后,告知一下维修过程。互相学习
GMT+8, 2024-11-17 19:44 , Processed in 0.077861 sec., 9 queries .
