查看: 824|回复: 6
新手求助海信led49k300u开机无图像
发表于: 2021-3-4 15:39:49
有打印信息001: C:\Users\Administrator\Desktop\Print.log
002: COM3, BaudRate:115200 bps, RXD: VGA->12,TXD: VGA->15,
Bootrom start
Boot from eMMC
Starting fastboot ...
System startup
Fastboot 3.3.0 (gfkfcmo@ubuntu-CI-1) (Oct23 2015 - 14:12:14)
Fastboot:      Version 3.3.0
Build Date:    Oct 23 2015, 14:12:26
CPU:           Hi3751v600
Boot Media:    eMMC
MMC/SD controller initialization.
MMC/SD Card:
   MID:         0x15
   Read Block:  512 Bytes
   Write Block: 512 Bytes
   Chip Size:   3728M Bytes (HighCapacity)
   Chip Type:   MMC
   Version:     4.0
   Speed:       25000000Hz
   Bus Width:   8bit
   Boot Addr:   0 Bytes
The DDR memory layout:
     page table: 0x0c000000 - 0x0c400000 4 MiB
          stack: 0x0c400000 - 0x0c800000  4MiB
    global data: 0x0cbfffc4 - 0x0cc00000 60 Bytes
         malloc: 0x0cc00000 - 0x10c00000 64 MiB
          .text: 0x10c00000 - 0x10c7f908 510.3 KiB
           data: 0x10c7f908 - 0x10d98e44  1.1MiB
Boot Env on eMMC
   Env Offset:          0x00100000
   Env Size:            0x00010000
   Env Range:           0x00010000
BootMode = MEM:[1],DC
Read LEDMODE ret = 10 or u32CheckWord = 0
System suspend.
======== [MCU PARAM] ========
DBGMASK: 0x00000001
SUSPENDTYPE: 0x00000000
GPIO POWER KEY: 0x00000000
GPIO LEVEL: 0x00000000
0x0000FFFF:waittime
IRTYPE: 0x00000000
IR NUM: 0x00000002
IR KEY: 0x639CFF00
IR KEY: 0xF20DBF00
LSADC ZERO: 0x000000FC
LSADC channel A enable
LSADC channel B enable
LSADC GLITCHSAMPLE: 0x00000005
LSADC TIMESCAN: 0x00000258
DATA_LASDC_POWERKEY0: 0x00000020
LSADC POWERKEY0: 0x00000000, 0x000000C0
LSADC POWERKEY1: 0x00000000, 0x000000C0
LSADC POWERKEY2: 0x000000FF, 0x000000FF
LSADC POWERKEY3: 0x000000FF, 0x000000FF
CUSTOM: Others.
light init
light off
lsadc:6bit,data_delta=8,enabledeglitch,power down,continue scan
set gpio DIR for output
set gpio level
set gpio level
======== [MCU Init Ready] ========
Power down ARM ===>
Reset cpu ===>
Set MCU to 24MHz ===>
Config bus core idle state ===>
Test bus core state ===>
Power down DDR ===>
======== [ARM suspend Ready] ========
Wait for 2s ...
======== [Waiting for Powerkey] ==
 楼主| 发表于: 2021-3-4 17:56:38
没有开机画面,用U盘强刷也没反应。
发表于: 2021-3-4 18:05:56
屏幕坏了断开半边软排线试下
 楼主| 发表于: 2021-3-4 18:25:54
家电维修888 2021-3-4 18:05
屏幕坏了断开半边软排线试下
屏幕坏了我用tv160试机那。
发表于: 2021-3-5 02:26:30
屏坏了就只能换,或者刷数据。
 楼主| 发表于: 2021-3-5 10:34:36
我就想修上这块板,其实也不用,用U盘刷机之前好使了过2天又坏。现在刷不进去了。
GMT+8, 2024-11-19 13:23 , Processed in 0.057485 sec., 10 queries .
