查看: 953|回复: 8
海信LED40K16P 打印文件帮忙看一下什么故障!!!
发表于: 2020-12-27 22:00:26
大家帮忙看一下 海信LED40K16P 液晶电视打印文件,电视看到LOGO后黑屏。分析一下主板故障部位!!!
OK
[12345678][012345678]-44
_nPD
U-Boot 1.1.6 (Aug 27 2010 - 18:22:39)
Board: MSTAR TITANIA (CPU Speed 504 MHz)
DRAM:  134217728
Skipping flash_init
Flash:  0 kB
NAND:  nand_bbt: searching bbt....Bad block table found at page 65472, version 0x01
nand_bbt: searching bbt.....Bad block table found at page 65408, version 0x01
128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MSVC00B000100100208811DA0000000T
Set MIU0 group priority:c9.....
Set MIU1 group priority:c9.....
Change MIU0 select.....
Group0:d80   Group1:88    Group2:200   Group3:f1
Change MIU1 select.....
Group0:4200  Group1:e00   Group2:30    Group3:4000
EEPROM @0x0 read: addr 80200000  off 1ffa  count 1 ... cmd: md.b 0x80200000 0x1
80200000: ff    .
done
80200000: 5a5aa5ff    ..ZZ
data_1[1ffa]--->:ff
check_keypad is[0]--keypad_pressed is [0] ---check_version is[0]
0x00220000-0x07220000 : "mtd=3"
Volume KL found at volume id 0
read 4194304 bytes from volume 0 to 81000000(buf address)
## Booting image at 81000000 ...
   Image Name:   Linux-2.6.28.10-mstar
   Created:      2010-06-02   4:22:41 UTC
   Image Type:   MIPS Linux Kernel Image (lzo compressed)
   Data Size:    3408227 Bytes =  3.3 MB
   Load Address: 80400000
   Entry Point:  80404150
   Uncompressing Kernel Image ... OK
Starting kernel ...
Linux version 2.6.28.10 (root@localhost.localdomain) (gcc version 4.3.2 (Sourcery G++ Lite 4.3-51) ) #15 PREEMPT Wed Jun 2 12:22:23 CST 2010
LINUX started...
boot_command_line: console=ttyS0,115200 ubi.mtd=3,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x2800000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x46104000,0x1E00000 MS_GOP0_MIU=0 mtdparts=edb64M-nand:128k(NPT),1m(BL0),1m(BL1),112m(UBI),-(NA)
LX_MEM  = 0x400000, 0x2800000
LX_MEM2 = 0x46104000, 0x1E00000
CPHYSADDR(PFN_ALIGN(&_end))= 0x9AB000
EMAC_LEN= 0x100000
DRAM_LEN= 0x10000000
console [early0] enabled
CPU revision is: 00019554 (MIPS 34Kc)
Begin Titania3_setup
Determined physical RAM map:
memory: 02800000 @ 00400000 (usable)
memory: 01e00000 @ 46104000 (usable)
Wasting 32768 bytes for tracking 1024 unused pages
Initrd not found or empty - disabling initrd
Zone PFN ranges:
  DMA      0x00000400 -> 0x00008000
  Normal   0x00008000 -> 0x00020000
  HighMem  0x00020000 -> 0x00047f04
Movable zone start PFN for each node
early_node_map[2] active PFN ranges
    0: 0x00000400 -> 0x00002c00
    0: 0x00046104 -> 0x00047f04
  Normal zone: 768 pages exceeds realsize 0
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16393
Kernel command line: console=ttyS0,115200 ubi.mtd=3,2048 root=ubi:RFS rootfstype=ubifs rw LX_MEM=0x2800000 EMAC_MEM=0x100000 DRAM_LEN=0x10000000 LX_MEM2=0x46104000,0x1E00000 MS_GOP0_MIU=0 mtdparts=edb64M-nand:128k(NPT),1m(BL0),1m(BL1),112m(UBI),-(NA)
alloc ebase: 81207000
Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Writing ErrCtl register=00065fa4
Readback ErrCtl register=00065fa4
PID hash table entries: 256 (order: 8, 1024 bytes)
CPU freq count = 252000000
CPU frequency 504.00 MHz
console handover: boot [early0] -> real [ttyS0]
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 63708k/40960k available (3902k kernel code, 7952k reserved, 1329k data, 168k init, 30720k highmem)
SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 334.84 BogoMIPS (lpj=167424)
Mount-cache hash table entries: 512
net_namespace: 288 bytes
NET: Registered protocol family 16
SCSI subsystem initialized
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: US
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
(5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
 楼主| 发表于: 2020-12-27 22:03:23
cfg80211: Calling CRDA for country: US
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
highmem bounce pool size: 64 pages
JFFS2 version 2.2. (NAND)2001-2006 Red Hat, Inc.
fuse init (API version 7.10)
msgmni has been set to 64
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver4 ports, IRQ sharing disabled
serial8250: ttyS0 at I/O 0xbf201300 (irq = 8) is a 16550
brd: module loaded
loop: module loaded
PPP generic driver version 2.4.2
PPP Deflate Compression module registered
PPP BSD Compression module registered
PPP MPPE Compression module registered
NET: Registered protocol family 24
PPPoL2TP kernel driver, V1.0
pegasus: v0.6.14 (2006/09/27), Pegasus/Pegasus II USB Ethernet driver
usbcore: registered new interface driver pegasus
rtl8150: v0.6.2 (2004/08/27):rtl8150 based usb-ethernet driver
usbcore: registered new interface driver rtl8150
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver net1080
usbcore: registered new interface driver rndis_host
usbcore: registered new interface driver cdc_subset
usbcore: registered new interface driver zaurus
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
Driver 'sd' needs updating - please use bus_type methods
Driver 'sr' needs updating - please use bus_type methods
usbmon: debugfs is not available
Mstar-ehci-2 H.W init
Titania3_later_start_ehc2 start
Mstar-ehci-2 Mstar-ehci-2.1: Mstar EHCI
Mstar-ehci-2 Mstar-ehci-2.1: new USB bus registered, assigned bus number 1
Mstar-ehci-2 Mstar-ehci-2.1: irq 74, io mem 0xbf201a00
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Mstar EHCI
usb usb1: Manufacturer: Linux 2.6.28.10 ehci_hcd
usb usb1: SerialNumber: mstar
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Mstar-ehci-1 H.W init
Titania3_later_start_ehc1 start
Mstar-ehci-1 Mstar-ehci-1.0: Mstar EHCI
Mstar-ehci-1 Mstar-ehci-1.0: new USB bus registered, assigned bus number 2
Mstar-ehci-1 Mstar-ehci-1.0: irq 15, io mem 0xbf204800
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Mstar EHCI
usb usb2: Manufacturer: Linux 2.6.28.10 ehci_hcd
usb usb2: SerialNumber: mstar
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
[ PHY Addr ] ==> :1
alloRAM_ADDR_BASE= 0x2C00000  alloRAM_SIZE= 0x100000
NAND device: Manufacturer ID: 0xad, Chip ID: 0xf1 (Hynix NAND 128MiB 3,3V 8-bit)
Creating 5 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x00000000-0x00020000 : "NPT"
mtd: Giving out device 0 to NPT
0x00020000-0x00120000 : "BL0"
mtd: Giving out device 1 to BL0
0x00120000-0x00220000 : "BL1"
mtd: Giving out device 2 to BL1
0x00220000-0x07220000 : "UBI"
mtd: Giving out device 3 to UBI
0x07220000-0x08000000 : "NA"
mtd: Giving out device 4 to NA
parse_cmdline_partitions: add_mtd_partitions
TCP cubic registered
NET: Registered protocol family 17
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
ieee80211: 802.11 data/management/control stack, git-1.1.13
ieee80211: Copyright (C) 2004-2005 Intel Corporation <jketreno@linux.intel.com>
VFS: Mounted root (ubifs filesystem).
Freeing unused kernel memory: 168k freed
init started: BusyBox v1.14.2 (2009-10-09 15:10:22 CST)
starting pid 355, tty '': '/etc/init.d/rcS'
Mounting vendor
Mounting conf
Mounting chakra
Open dbus!!
Open Chakra!!
====> Time: 15:32:35
[UTOPIA]Initializing HW...MsOS_MPool_Init
MPOOL MAP INFORMATION:
    MIU0 Length=0x08000000
Mounting opt
    MIU0 MAP:0x02D00000,0x05300000
    MIU1 MAP:0x40000000,0x08000000
MDrv_MIOMap_Init
PM Bank mapping success. Base=[38604000], Size=[225600]
NonPM Bank mapping success. Base=[3882a000], Size=[25600]
Flash Bank0 mapping success. Base=[38850000], Size=[4000000]
MsOS_Init
Mounting application
pthread_mutex_init
CHIP_InitISR
Mounting font
 楼主| 发表于: 2020-12-27 22:08:32
Mounting PTS
Parse IR file /conf/IR_HISENSE_USER.conf
Parse IR file /conf/IR_HISENSE_FACTORY.conf
Parse IR file /conf/IR_HISENSE_COMPUTER.conf
Success!!
--------->MBX DRIVER OPEN
_MDrv_MBXIO_FASYNC is invoked
!!NYI[porting/OBA2/p_drvpower.c]MDrv_Power_SetMode
!!NYI[porting/OBA2/p_drvpower.c]MDrv_Set_Power_Flag
Flash is detected (0x0502, 0xC2, 0x20, 0x16)
[irq_proc_open][277] -16
Device or resource busy
Cannot open interrupt descriptor for irq=8
sar input test...
Dclk = 3531de
XC RIU base=3882a000
IRQThread_18
PQ INPUTTYPE NUM MISMATCH: MAIN != EX [MWE] H-SPLIT-RIGHT/H-SCAN Function
[MWE] Hstart  4a0  Hend  7ef  Vstart    0 Vend  437
usbcore: registered new interface driver r871x_usb_drv
usbcore: registered new interface driver rndis_wlan
Broadcom 43xx driver loaded [ Features: , Firmware-ID: FW13 ]
MDrv_PWM_Init has MMIO base 0x3882A000
MDrv_PWM_SetDbgLevel(3)
MDrv_PWM_UnitDiv(0x0000)
MDrv_PWM_Oen(2, 0)
MDrv_PWM_Period(2, 0x00013880)
MDrv_PWM_Div(2, 0x0000)
MDrv_PWM_Polarity(2, 1)
MDrv_PWM_Vdben(2, 0)
MDrv_PWM_Dben(2, 1)
[GFLIP] GFLIP DRIVER OPEN
[SYS][000166]     MDrv_SYS_SetPanelInfo
apiGOP.c 6794
apiGOP.c 6796
drvGOP.c 3119
drvGOP.c 3121
drvGOP.c 3123
drvGOP.c 3125
drvGOP.c 3127
drvGOP.c 3129
apiGOP.c 6798IRQThread_24
[HAL_DSCMB_SetBank][82] Set bank 0x3882a000
IRQThread_34
MAc Data in file:00-1A-95-11-1A-14
s8SN0(10) s8SN1(f)
usbcore: registered new interface driver snd-usb-audio
usbcore: registered new interface driver snd-usb-caiaq
argv[1]: "response_timeout=30"reponse_timeout: 30
starting pid 456, tty '': '/bin/echo /bin/Xjys > /proc/sys/kernel/hotplug'
Please press Enter to activate this console. Disable all multicast mode
PM Bank mapping success. Base=[2ae32000], Size=[225600]Change to specific multicasts
NonPM Bank mapping success. Base=[2b058000], Size=[25600]
Flash Bank0 mapping success. Base=[2b07e000], Size=[4000000]
[upgrade_daemon.c] main Line:1615 start sleeping!
DSPBinBaseAddress = 0x0
DSPMadBaseBufferAdr = 0x3500000
DSPMadBaseBufferAdr = 0x3400000
[HAL_AUDIO_AllocateVars][371] This is first initial 0x3c856870
init Shared
IRQThread_69
IRQThread_54
HAL_AUDIO_SetPowerOn(1)
audio DSP_SE LoadCode success..
audio DSP_DEC LoadCode success..
mirror function test~~mirror----on~~~~~~/nMApi_XC_SetWindow: H can't do pre scaling up
DI mode =3, bitPerPixel=24
1.SC Crop width=0xa, LBOffset=0x0
2.OPM Crop Offset=0x0, LBOffset=0x0
_COPRO_Init: u32RiuBaseAdd = 3882a000
[PHOTO] Decode Memory
[PHOTO] statue, 0 --> 1
[PHOTO] JPEG, Baseline, (1920x1080, 1920(1920)x1080), size: 4147200, thumbnail: 0
[PHOTO] Orient: 1, Date Time: NO
[PHOTO] statue, 1 --> 2
[PHOTO] statue, 2 --> 3
[PHOTO] total time: 129, progress: 1000
[PHOTO] statue, 3 --> 0
###EDDIE: stDstWin.width=0x1920  stDstWin.height=0x1080
[HS_PM_GetProServiceUniqueID] Please initialize prgm before use this function!
[HS_PM_GetProInfoByUniqueID] Please initialize prgm before use this function!
[HS_PM_GetCurProgType] Please initialize prgm before use this function!
[HS_PM_GetCurProgNo] Please initialize prgm before use this function!
KKK: (Temp)EXT_RF_AGC_On...for ATV
INTERN_DVBC_Power_On_Initialization call stop vdmcu
>> u8BinType = 0
DVB-C Load DSP Code OK
fix vtt feature is not enabled
The pstCropWin->y :1
MApp_LoadOverScanData>>>[can't get video mode.]:
DI mode =1, bitPerPixel=24
1.SC Crop width=0x4f8, LBOffset=0x4
2.OPM Crop Offset=0x5a0, LBOffset=0x4
1.LOGO Show --------------------------
drvTAS5707_Shutdown-> Fail!
Write 5707A Fail!
<<Switch to Main_Speaker>>
2.Play POWERON_MUSIC-------------------------------
read_app_info
msAPI_NPlayer_IPCInit(3.2.2.3)
Date[Sep 25 2010/11:08:31]
HIPC:[ffffffff][ffffffff][ffffffff][ffff]
shmid[32769]
shm[3f88a000]
semid[0]
_MAPP_EPGDB_Setup: [Current EPG DB occupy size: 0x552d18];  [Max EPG DB config. size: 0x840000]
set env language---------2--
[upgrade_daemon.c] main Line:1619 sleep over!
>> u8BinType = 4
PCMCIA open /dev/system success >> SYS_fd= 23
IRQThread_29
msAPI_Tuner_Serial_Control.........0
_______________________Serials [1]____________________
_GOP_GWIN_AlignChecker, This FB format needs to 8-pixels alignment !!!
3.Close POWERON_MUSIC-----------------
1.SC Crop width=0x500, LBOffset=0x0
>> u8BinType = 4
SIF dsp code is same(b3)
 楼主| 发表于: 2020-12-27 22:14:54
4.Close LOGO------------------------
--------------------->the str is 1
The machine type is LED40K16P
The machine type child is is 0000
The sw_version is V01.16
The board type is B
MApp_PostInit(void)
DVB-T Hisense Software Version: 0.00,CK_CL[190003],OB_CL[184955],ZD_CL[178859]
N51FS_Wrapper_MultiTask Start...
@@@@@@@@@@@@@@@@@@@start  init allproglist@@@@@@@@@@@@@@@@
creat clusterlist file failed  file=NULL
<core/hs/middleware/prgm/hs_prgm_db.c><9707>creat proglist file failed
[core/hs/middleware/prgm/hs_prgm_init.c] 184 HS_InitAllProgList: [ERROR] program number =0 or Failed to initialise prgmanager!
*******Use Ext Mem 16384000 **** TextChar:1048576, NowNext:501600, EPG:32256000 *********
get last channel type  :1
[core/hs/app/init/hs_init.c]204 --------atv now!
IRQ 24 polling thread destroyed
IRQ 24 polling fd closed!!
[core/hs/middleware/bookmg/hs_book.c]2796 book working init ,cur priority:255, Working.endtime  0-0-0  0:0
HS_BOOK_Initialize:creat timer task.
[tv-ap/dvb/ui2_obama/MApp_ZUI_ConfigNetwork.c] 879 MApp_NetTaskInit: Now star net monitor task!
[tv-ap/dvb/ui2_obama/MApp_ZUI_ConfigNetwork.c] 863 MApp_ConfigSystemMAC: the mac is 00:1A:95:11:1A:14
MApp_MSTV_Debug_Init
read register 0x0,data 0x0
[tv-ap/dvb/ui2_obama/MApp_ZUI_ConfigNetwork.c] 915 MApp_ConfigMACAddr: mac_addr addr is 00:1A:95:11:1A:14
STATE_CHANNELCHANGE_INIT-----------1--------------
STATE_CHANNELCHANGE_INIT------------3-------------
[tv-ap/dvb/ui2_obama/MApp_ZUI_ACTglobal.c][532]startup:3 [now=0,1]
EffEnd
pid 454
========================>The is auto check value :1
g_u16upgrade_pid: 454
[tv-ap/dvb/ui2_obama/MApp_ZUI_ConfigNetwork.c] 402 MApp_CableMonitor: start cable dhcp for obtain the ip addr
[tv-ap/dvb/ui2_obama/MApp_ZUI_ConfigNetwork.c] 244 MApp_AutoConfigNetwork: Now auto config the network!!
sh: cannot kill pid 586: No such process
read_all_timer_data  start
[core/hs/middleware/bookmg/hs_book.c] 218 read_all_timer_data: creat timerlist file successful timer total =0
[core/hs/middleware/bookmg/hs_book.c] 230 read_all_timer_data: creat clusterlist file failed  file=NULL
[core/hs/middleware/bookmg/hs_book.c] 318 read_all_timer_data: end   read_all_timerlist_data. err:0
### adapter index 2
### adapter hardware address 00:1a:95:11:1a:14
udhcpc (v1.14.2) started
### vfork'ing and exec'ing /usr/share/udhcpc/default.script
### entering raw listen mode
### opening raw socket on ifindex 2
### got raw socket fd 22
### attached filter to raw socket fd 22
### bound to raw socket fd 22
### adding option 0x35
### adding option 0x3d
### adding option 0x3c
### adding option 0x39
Sending discover...
### Waiting on select...
[core/hs/middleware/bookmg/hs_book.c] 408 Book_SortList: sort begin  timernum =60
[core/hs/middleware/bookmg/hs_book.c] 434 Book_SortList: get count = -----0------
[core/hs/middleware/bookmg/hs_book.c] 476 Book_SortList: sort end
****----QUICK_DB_ERASE_DONE=17
[upgrade_daemon.c] get_sys_mac Line:1181 the mac is 001a95111a14
[upgrade_daemon.c] get_sys_info Line:1125 Now get the system info
[upgrade_daemon.c] get_sys_info Line:1142 machine type ED40K16P-B0000 ,  version :V01.16
[upgrade_daemon.c] Update_DBUS_receive Line:201 The data receive is 198
[upgrade_daemon.c] Update_DBUS_receive Line:201 The data receive is 10
[upgrade_daemon.c] Update_DBUS_receive Line:277 UPGRADE_CMD_AUTO_CHECK_ON
Sending discover...
EffEnd
[tv-ap/dvb/ui2_obama/MApp_ZUI_ACTglobal.c][983]shutdown [now=3,5]
[tv-ap/dvb/ui2_obama/MApp_ZUI_ACTglobal.c][775]terminate
[tv-ap/dvb/ui2_obama/MApp_ZUI_ACTchannelinfo.c][436]term:chinfo
_GOPFBAddCheck, Wrong MIU setting! Your FB address is across MIU0, but GOP1 MIU setting is still MIU0
Sending discover...
No lease, forking to background
[tv-ap/dvb/ui2_obama/MApp_ZUI_ACTglobal.c][532]startup:2 [now=0,1]
[upgrade_daemon.c] auto_net_detect_task Line:1469 Now start auto checking...
ping: bad address 'tvwg.dnethome.net'
[upgrade_daemon.c] net_isvalid Line:1311 check network state error!
 楼主| 发表于: 2020-12-27 22:17:35
参考有海信特有的开机声,、
Write 5707A Fail!
这些是不是提示故障部位呢?
发表于: 2020-12-28 09:10:57
换空片EMMC 。写引导。升级
发表于: 2020-12-29 12:46:54
   看到LOGO后黑屏  ?  背光不亮?  遥控开关机是否有效?
   信息显示主程序已运行完毕,如果遥控开关机正常,建议检测一下背光及相关器件。
GMT+8, 2024-11-19 14:43 , Processed in 0.057296 sec., 9 queries .
