查看: 1154|回复: 4
MS828机芯 红灯亮开机马上回到待机下面是打印信息
发表于: 2020-12-24 03:38:58
MS828机芯 红灯亮,开机马上回到待机下面是打印信息,请论坛朋友分析下是哪里的问题,看不懂打印信息
   EMMC拆下来测过没问题, TOSHIBA EMMC版本:V5.0.   0-10%的寿命已被使用
UART_115200
AC_ON
MIU0_DQS-OK
MIU1_DQS-OK
BIST0-OK
BIST1-OK
_U
Relocation Offset is: 01200000
[AT][MB][start ub][299]
U-Boot 2011.06-svn5821 (Apr 12 2016 - 21:48:06)  MBOT-2.12.$Change: 1142033 $
Function = UtopiaOpen, Line = 255, UtopiaOpen[MODULE_SYS] strange failed
having MODULE_XC
having MODULE_NJPEG_EX
having MODULE_MIU
having MODULE_GFX
having MODULE_GOP
having MODULE_PNL
having MODULE_CPU
having MODULE_BDMA
having MODULE_UTOPIA
Open SYS fail
[MIU INFO] miu opencreate instance at 345aa590 with private size 80 bytes at 345aa5d8
create instance at 345aa630 with private size 48 bytes at 345aa678
uboot held at [342ddf60~36200000],size=01f220a0
CPU  : Muji
Board: BD_MST072B_20AEV_MUJI
DRAM:  354 MiB
Now running in RAM - U-Boot at: 35300000
FCIE_MODE_GPIO_PAD_DEFO_SPEED
FCIE_MODE_8BITS_MACRO_HIGH_SPEED
FCIE_MODE_32BITS_MACRO_HS200
eMMC: HS200 200MHz
eMMC 7.28 GB [E8FFF8h]
In:    serial
Out:   serial
Err:   serial
Net:   No ethernet found.
MAC:  0x3c: 0x59: 0x1e: 0x2c:0x93: 0xa7
[CPU INFO] cpu opencreate instance at 345bab38 with private size 44 bytes at 345bab80
[UTOPIA INFO] close moduleNames[38]: MODULE_CPU
msIR_Initialize
[AT][MBoot][Driver Init][462]
[ERROR] MDrv_URSA_COM_Get_URSA_Type:482: [URSA_COMMON] ursa_type is an illeagal value !
MPOOL size : 0xa00000
Changelist:     24543697
run_ubootcmd_from_mtd0::368::cmd=mmc read.p 0x25000000 misc 1088
AC on
mmc change mount : tclconfig
Loading file "/mstar/tvconfig/config/PM.bin" at offset 0x0 from mmc device 0 partition tclconfig
24575 bytes read
Wait for PM51 stand波H?KVS&$琞Z恫 code time Mar 29 2016  15:16:46
Hi Main
CRC Check OPEN: 1
Power Down
standby by tcl system
发表于: 2020-12-30 08:05:52
你U盘升级试一下不就行了。
 楼主| 发表于: 2020-12-31 21:44:40
U盘升级能升,升级之后还是一样的的开机马上关机(用串口接U盘升的),这里有错看不懂啊[ERROR] MDrv_URSA_COM_Get_URSA_Type:482: [URSA_COMMON] ursa_type is an illeagal value !
GMT+8, 2024-12-21 15:49 , Processed in 0.048850 sec., 10 queries .
