查看: 767|回复: 0
F1C100S启动成功的打印信息和失败信息
发表于: 2020-12-4 18:25:01
成功的
BOOT0 is starting
DBG: init jtag OK
init dram , base        is 0x80000000
init dram , clk         is 120
init dram , access_mode is 1
init dram , cs_num      is 1
init dram , ddr8_remap  is 0
init dram , sdr_ddr     is 1
init dram , bwidth      is 16
init dram , col_width   is 10
init dram , row_width   is 13
init dram , bank_size   is 4
init dram , cas         is 3
init dram , size        is 0
dram init successed,size is 32
DBG: init heap OK, base address is 0x80000000, size is 0x00100000
DBG: load boot1 from spinor
DBG: init spinor OK
DBG: the size of BOOT1 is 71168
DBG: src_sum = 0x0xc0b0d58f
DBG: sum = 0x0xc0b0d58f
succeed in loading BOOT1
jump to BOOT1
DBG: boot1 starting!
DBG: init heap OK, base address is 0x80800000, size is 0x00100000
begin to init file system
DBG: init block device OK
DBG: init mini file system OK
DBG: mount c partition OK
0
jump to kernal
port=4,port_num=1,mul_sel=6 eint_num=1 trigger=2
Mount Parts Thread running.....
partition [D] plug in..
Mount Parts Thread work now.....
.Start Shell from partion 'c'..................................................................................
Mount Parts Thread work end....
pend event sem overtime!
*divider=9
b_interlace=0
lcd_power_used=1 ret=0
partition [E] plug in..
.Please press enter key(keypad or irkey) to continue!
Execute startup script begin..............
Esh Error: OpenConfigFile y:\config\config.bin failed.
1
2
3
.orange Installed and Openned!........................................................................................
4
失败的
BOOT0 is starting
DBG: init jtag OK
DBG: init spinor OK
DBG: src_sum = 0x0x9fd3eed5
DBG: sum = 0x0x9fd3eed5
jump to BOOT1
0
jump to kernal
*divider=9
b_interlace=0
1
2
3
=        Prefetch Abort(instruction fetch memory abort)        =
Address of aborted instruction:e02d37e4
r[1] = 0xe18016c8
r[2] = 0xe18016c4
r[3] = 0x00000001
r[4] = 0xc2093774
r[5] = 0x00000078
r[6] = 0x00000000
r[7] = 0xffff0ef0
r[8] = 0xc201088c
r[9] = 0xc6100438
r[10] = 0x00000001
r[11] = 0x0000e03c
r[12] = 0x11111111
r[13] = 0xc2093774
r[14] = 0xc22eff04
pid = 1, (module:c:\shell.zgj)
before enter IFA mode , the lr addr = 0xe1801494
processor mode =FIQ , the lr_addr = 0xbc8079f4
processor mode =IRQ , the lr_addr = 0xc2012048
processor mode =SVC , the lr_addr = 0x00001b2c
processor mode =SYSTEM , the lr_addr = 0xe1801494
BOOT0 is starting 重启中
GMT+8, 2024-12-25 11:15 , Processed in 0.053400 sec., 9 queries .
