查看: 817|回复: 1
I cannor erase full GL064N90FFA04
发表于: 2020-11-13 19:59:40
Hi my friends, i have a problem to can program BGA memory GL064N90FFA04, with socket RT-BGA64-01 V1.0, my problem is i cannot erase full the ic, at the address: "Chip is not blank, start position: 0x800008."
I checked in 2 ic´s more, and continuous with the same problem, then, i cannot clone exactly the original memory data.
I have the last version RT809H (20201106)
Someone idea?
Help me please.
Thank you for all.
Rgds
Jorge García
发表于: 2020-11-13 21:54:15
OTP (One Time Programable) is a kind of memory type . It can not be changed and cleaned again after the program is burned into IC.
  • This chip prompts 0x800000 to be the starting address of the OTP
GMT+8, 2024-12-19 18:15 , Processed in 0.050785 sec., 11 queries .
