Starting kernel ...
Initializing cgroup subsys cpuset
Linux version 3.0.13 (gfkfcmo@ubuntu-num3) (gcc version 4.5.1 (GCC) ) #1 SMP PREEMPT Fri Sep 23 16:15:01 CST 2016
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=10c53c7d
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: MT5880
Memory policy: ECC disabled, Data cache writealloc
====> PMEM BOOTMEM ALLOC <=====
allocating 49283072 bytes at (null) (40000000 physical) for pmem arena
PERCPU: Embedded 7 pages/cpu @c0af5000 s4960 r8192 d15520 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 191264
Kernel command line: lpj=4571136 console=ttyMT0,115200n1 root=/dev/mmcblk0p5 vmalloc=512M no_console_suspend androidboot.carrier=wifi-only mtdparts=mt53xx-emmc:2M(uboot),2M(uboot_env),1M(misc),16M(recovery),16M(boot),500M(system),500M(userdata),500M(cache),1M(reserved),1M(channelA),1M(channelB),1M(pq),1M(aq),4M(logo),4M(bootlogo) mali_core_num=2 usbportusing=1,1,1,0 usbpwrgpio=-1,-1,-1,-1 usbpwrpolarity=-1,-1,-1,-1 usbocgpio=-1,-1,-1,-1 usbocgpiopolarity=-1,-1,-1,-1
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
allocated 2555904 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 624MB = 624MB total
Memory: 617156k/617156k available, 21820k reserved, 131072K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xdf800000 - 0xff000000 ( 504 MB)
lowmem : 0xc0000000 - 0xdf000000 ( 496 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0029000 ( 132 kB)
.text : 0xc0029000 - 0xc049ff44 (4572 kB)
.data : 0xc04a0000 - 0xc04d71e0 ( 221 kB)
.bss : 0xc04d7204 - 0xc060f398 (1249 kB)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
Preemptible hierarchical RCU implementation.
NR_IRQS:256
timekeeping_init done
ckgen Xtal:27000000 Hz
Console: colour dummy device 80x30
console [ttyMT0] enabled
Calibrating delay loop (skipped) preset value.. 1828.45 BogoMIPS (lpj=4571136)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Initializing cgroup subsys cpuacct
Initializing cgroup subsys memory
CPU: Testing write buffer coherency: ok
Calibrating local timer... 445.31MHz.
L310 cache controller enabled
l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x73440001, Cache size: 262144 B
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated (3656.90 BogoMIPS).
NET: Registered protocol family 16
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Advanced Linux Sound Architecture Driver Version 1.0.24.
Bluetooth: Core ver 2.16
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
Switching to clocksource timer2
NET: Registered protocol family 2
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Trying to unpack rootfs image as initramfs...
rootfs image is not initramfs (junk in compressed archive); looks like an initrd
Freeing initrd memory: 7244K
PMU: registered new PMU device of type 0
Power Management for MTK DTV.
highmem bounce pool size: 64 pages
ashmem: initialized
squashfs: version 4.0 (2009/01/31) Phillip Lougher
msgmni has been set to 963
io scheduler noop registered
io scheduler deadline registered
io scheduleSerial: MT53xxttyMT0 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
ttyMT1 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
ttyMT2 at MMIO 0xf0028800 (irq = 32) is a MT53xx Serial
ttyMT3 at MMIO 0xf000c000 (irq = 49) is a MT53xx Serial
brd: module loaded
loop: module loaded
pmem: 1 init
android_pmem: probe of android_pmem.0 failed with error -1
