查看: 765|回复: 0
海信LED55K20JD打印信息 《一》
发表于: 2020-11-5 16:18:26
2020-11-4, 15:59:43
COM4, BaudRate:115200 bps, RXD: VGA->15,TXD: VGA->12, Printed by RT809H:
Boot-
DRAM Channel A Calibration.
Byte 0 : Gating(2 ~ 67), Size=66, Mid=34, Set=34.
Byte 1 : Gating(2 ~ 52), Size=51, Mid=27, Set=27.
Byte 2 : Gating(2 ~ 72), Size=71, Mid=37, Set=37.
Byte 3 : Gating(2 ~ 67), Size=66, Mid=34, Set=34.
HW Byte 0 : DQS(10 ~ 44), Size 35, Set 27, HW_Set 29.
HW Byte 1 : DQS(10 ~ 42), Size 33, Set 26, HW_Set 28.
HW Byte 2 : DQS(12 ~ 44), Size 33, Set 28, HW_Set 30.
HW Byte 3 : DQS(9 ~ 44), Size 36, Set 26, HW_Set 29.
DRAM A Size = 768 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0x56fb80f9
:0x0401006c
:0x32473163
:0x90014a48
LZHS addr:0x00100040
LZHS size:0x000a73a0
LZHS checksum:0x000000b7
Boot
Start Lmain
MT5880 Boot Loader v0.9
Boot reason: A/C power on!!
use code based  EDID.................
Load HDMI internal EDID.................
CEC Physical offset 152
HDMI1 Physical adr 0x10
HDMI1 PA 0x10
HDMI1 checksum 0xdf
HDMI2 PA 0x10
HDMI2 checksum 0xdf
HDMI3 PA 0x20
HDMI3 checksum 0xcf
HDMI4 PA 0x30
HDMI4 checksum 0xbf
SIF_Master0: new design
IR DATA register : 0x       0
Load T8032 FW (addr: 0x  d81740, size: 24576)success!!
T8032 FW version: 73
LDR_FlashCopy 0xf010 0x59f80 0x80
1st MAC in EEP is valid (90:cf:7d:c4:ac:cc)
1st : (90:cf:7d:c4:ac:cc)
2nd : (ff:ff:ff:ff:ff:ff)
PDWNC_Init
Boot reason: A/C power on!!update check revovery,adc value:255
LDR_CheckRecovery,needn't enter recover
Do USB upgrade
USB: Vbus turn up time = 207 ms, Max =0 ms.
No USB device.
USB upgrade stop
Boot reason: A/C power on!!Boot reason: A/C power on!!Org:0x10 Flags:0x10
PDWNC_EnterPowerDown(100,0)
Disable VGA wakeup
LEE TEST: PDWNC_SetLED_Mode 1
Standby               ??enable wakeup Boot-Preloader T8032 ack !
Byte 0 : Gating(2 ~ 57), Size=56, Mid=29, Set=29.
Byte 1 : Gating(2 ~ 47), Size=46, Mid=24, Set=24.
HW Byte 1 : DQS(10 ~ 41), Size 32, Set 25, HW_Set 29.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0x56fb80f9
:0x0401006c
:0x32473163
:0x90014a48
Boot
Start Lmain
PDWNC_Init
Do USB upgrade
USB: Vbus turn up time = 163 ms, Max =0 ms.
No USB device.
USB upgrade stop
Org:0x10 Flags:0x10
Flash load lzhs header from 0x80000 to dram(0x1500020), size=2048
Decompression uboot to 0x00800000...
Flash load image from 0x80000 to dram(0x1500020), size=0x369ad
secure boot ok
LZHS start
LZHS done
Starting image...
U-Boot 2011.12.12 (Sep 23 2016 - 16:15:16)
DRAM:  624 MiB
WARNING: Caches not enabled
MMC:   HOST 1
Dev Num: 0, Timing Position: 0, Sample Edge: 0x00
90014A48:32473163:0401006C:56FB80F9
id1:4A483247 id2:31630401
eMMC Name: UNKNOWN
Dev Num: 0, Timing Position: 1, Sample Edge: 0x00
Dev Num: 0, Timing Position: 2, Sample Edge: 0x11
: 0
0.0.0.0
In:    serial
Out:   serial
Err:   serial
Net:   Net Initialization Skipped
No ethernet found.
PDWNC_REBOOT_CMD_OFFSET contains
## Booting kernel from Legacy Image at 00008000 ...
   XIP Kernel Image ... OK
OK
GMT+8, 2024-11-19 15:33 , Processed in 0.052301 sec., 9 queries .
