查看: 1160|回复: 5
Spansion flash S29GL032N90FFIS3
发表于: 2020-10-4 15:35:06
Hello developers,
i need help for Spansion flash S29GL032N90FFIS3. Can you add to rt809h please! This flash has different pin outs. You can find datasheet here: http://www.ifix.net.cn/forum.php ... ;highlight=spansion
Thanks for sharing @gangster.
Registered first, later will buy chips to add, please wait patiently  发表于 2020-10-4 18:50
 楼主| 发表于: 2021-3-4 14:18:46
Any news here? Can you please add the S29GL-N (S Models) from Spansion to rt809h programmer? Thanks!
发表于: 2021-3-20 15:57:47
S29GL032N90FFIS3 = S29GL032N90TFI04@TSOP48  #read/write ok
 楼主| 发表于: 2021-3-20 22:29:41
Thanks. Did you modified pin layout for this or did you use the standard 64bga socket?
 楼主| 发表于: 2021-3-27 22:34:37
Didn't work
GMT+8, 2024-12-24 22:07 , Processed in 0.059254 sec., 11 queries .
