查看: 1262|回复: 5
RT8O9F
发表于: 2020-6-1 10:10:31
Edited by telli at 2020-6-3 14:18
HI dear
i tried to read  and write or even erase  the i.c 25Q40cl  WINBOND WITH RT809F . But it cant and i saw this massge:
046:  No chip on the adapter, or socket locking not properly!
047:  No chip on the adapter, or socket locking not properly!
048:  Chip pins is detected poor contact, operation has been terminated.
049:  Chip pin3,5Chip pins is detected poor contact.
050:  Chip pin1,3,5,6,7,8Chip pins is detected poor contact.
051:  Chip pin1,3,5,7Chip pins is detected poor contact.
052:  Chip ID verification OK.
053:  UniqueID:0x2A469243C2586757
054:  Start reading chip......
055:  Status register1 values: 0x0, Status register2 values: 0x0 .
056:  Read successful£¬Elapsed time£º0.807 seconds¡£
057:  Auto verifying...
058:  Chip verification error, start position: 0x5800.
059:  Verification failure£¬Elapsed time£º0.124 seconds¡£
060:  Read error, operation aborted.
i am using windows 10 pro 64 and the last software for rt908f ( 20200405)
How can i solve this problem?https://www.4shared.com/account/home.jsp
发表于: 2020-6-1 15:32:53
It is best to be able to screenshot up, you can first welding simple board test.
 楼主| 发表于: 2020-6-3 14:16:54
 楼主| 发表于: 2020-6-3 14:20:37
技术支持008 2020-6-1 15:32
 楼主| 发表于: 2020-6-3 14:25:02
Edited by telli at 2020-6-3 14:26
I tried welding but use lessI send the link to see the screenshot
发表于: 2020-6-14 13:35:28
Wonder if your chip is off the board, or onboard with a clip.
Use a cutter scrap the pins to make it a better contact in either case.
And if it is on board, try to de-solder the chip, flash it without the board.
GMT+8, 2024-12-19 17:21 , Processed in 0.054912 sec., 9 queries .
