查看: 1234|回复: 1
Akai software needed - CV338H-T42 / MSD6A338
发表于: 2020-5-1 08:25:39
ENGLISH:
Hi, i need the famous 4 software files for this type of board : CV338H-T42 with CPU MSD6A338 mounted on Akai AKTV3223.
them are named something like: mboot.bin, muninn_EISP_boot_0727.bin, muninn_EISP_user_0727.bin, rom_emmc_boot.bin
In other option i need to know what is the content of the "muninn" files, are them the spi flash content? Or  are only control files for
the program software?
I have cleared all the emmc flash for error using a command in U-Boot.. i have the original emmc single file dump but i don't know how to
load it into the board. If i can put it back i can after try another method to fix the original boot loop problem. THANKS!
Translated Chinese:
翻译中文:
嗨,我需要这种板子的著名的4个软件文件:CV338H-T42,Akai AKTV3223上装有CPU MSD6A338。
它们的名称类似于:mboot.bin,muninn_EISP_boot_0727.bin,muninn_EISP_user_0727.bin,rom_emmc_boot.bin
在另一个选择中,我需要知道“ muninn”文件的内容是什么,它们是spi flash内容吗? 还是仅用于
程序软件?
我已经使用U-Boot中的命令清除了所有emmc闪存的错误。.我具有原始的emmc单个文件转储,但我不知道如何
将其加载到板上。 如果我可以放回去,我可以在尝试另一种方法来解决原始的启动循环问题后再尝试。 谢谢!
发表于: 2020-5-3 20:13:24
Edited by krishankashyap at 2020-5-3 20:23
Hi, I need 4 famous software files of this board: CV338H-T42, CPU MSD6A338 is installed on Akai AKTV3223.
Their names are similar to: mboot.bin, muninn_EISP_boot_0727.bin, muninn_EISP_user_0727.bin, rom_emmc_boot.bin
In another option, I need to know what is the content of the "muninn" file, are they spi flash content? Or is it only for
program software?
I have used the commands in U-Boot to clear all emmc flash errors. . I have the original emmc single file dump, but I don't know how
to load it onto the board. If I can put it back, I can try another method to solve the original startup loop problem before trying again. please ...
GMT+8, 2024-12-22 19:12 , Processed in 0.048375 sec., 10 queries .
