查看: 1827|回复: 2
怎么进入控制台?
发表于: 2020-4-14 16:12:11
Boot-
DRAM Channel A Calibration.
1T = (85 - 19) = 66 delay cells
Clock frequency = 798 MHz, Clock period = 1253 ps, 1 delay cell =18 ps
Byte 0 : Gating(-33 ~ 33), Size=67 .
Byte 1 : Gating(-33 ~ 33), Size=67 .
Byte 2 : Gating(-32 ~ 33), Size=66 .
Byte 3 : Gating(-32 ~ 33), Size=66 .
HW Byte 0 : DQS(-9 ~ 16), Size 26 , Set 4.
HW Byte 1 : DQS(-11 ~ 14), Size 26 , Set 2.
HW Byte 2 : DQS(-7 ~ 16), Size 24 , Set 5.
HW Byte 3 : DQS(-10 ~ 15), Size 26 , Set 3.
DATLAT calibration
first_step= 11 total pass= 5 best_step=12 .
TX HW Byte 0 : DQS(4 ~ 27), Size 24, Set 15.
TX HW Byte 1 : DQS(3 ~ 27), Size 25, Set 15.
TX HW Byte 2 : DQS(2 ~ 26), Size 25, Set 14.
TX HW Byte 3 : DQS(3 ~ 27), Size 25, Set 15.
DRAM A Size = 768 Mbytes.
Boot
Start Pmain
0x0000a000
EMMC boot
CID:0x14eeb2fb
:0x3002164c
:0x30344745
:0x11010030
LZHS addr:0x00100040
LZHS size:0x0015c650
LZHS checksum:0x000000d4
store RSA & AES keys in DMX SRAM
LZHS begin
Boot
Start Lmain
MT5882 Boot Loader v0.9
Boot reason: A/C power on!!read from eeprom ioff 0 phy_off 3ee0
SIF_Master0: V2 design
IR DATA register : 0x       0
Load T8032 FW (addr: 0x  e31850, size: 23142)success!!
T8032 FW version: 6
LDR_FlashCopy 0xf010 0x62b00 0x80
11010030:30344745:3002164c:11010030
id1:00303034 id2:47453002
eMMC Name: THGBMBG5D1KBAIL
Support network!1st MAC in EEP is valid (5c:36:b8:f7:b8:0b)
1st : (5c:36:b8:f7:b8:0b)
2nd : (ff:ff:ff:ff:ff:ff)
@@@@@@@@@epp_usbupgrade_flag[0x30]
Boot reason: A/C power on!!Boot reason: A/C power on!!
@@@@@@@@@rDtvCfg.u1Flags[48]@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@=
Org:0x30 Flags:0x30
         cccccccccccccccccc
---------test LYQ check eeprom boot-----------
---------boot reason is not watchdog-----------
PDWNC_EnterPowerDown(100,0)
Disable VGA wakeup
Standby
PDWNC_MTK_SetupPowerDown breath!!SWITCH_T8032
?vEnterPowerStandby: Cbus_Init
                               shop finished and standby
我按ESC上电,可是却不能进入控制台,应该怎么操作啊?请老师指导一下,谢谢!
发表于: 2020-4-17 16:08:55
人家都没说要给你控制台.
GMT+8, 2024-12-26 08:49 , Processed in 0.061521 sec., 11 queries .
