查看: 2586|回复: 4
RT809H + GT34C04 Fail !
发表于: 2020-4-11 14:17:39
What is the problem with the RT809H removing write protection from a supported GT34C04 chip?
I took an oscilloscope and looked at the voltage on 1 pin while reading and writing.
Even when recording, there is a pulse of only 3.3V, nor any 7-10V. That is, the device CANNOT overwrite the GT34C04.
I applied external + 12V power to the RT809H. At the first contact 7-10V did not appear!
Overwrite data failed!
Developers, please solve the problem!
Best Regards.
 楼主| 发表于: 2020-4-13 12:56:02
How to make "clear write protection" command?
 楼主| 发表于: 2020-4-16 13:46:51
Are there any developers here? Thanks.
 楼主| 发表于: 2020-4-17 19:16:57
刪除GT34C04芯片上的寫保護的問題
我拿了示波器,在擦除過程中查看了1針的電壓。
只有3.3 V的脈衝。沒有7-10 V的脈衝。
RT809H無法覆蓋GT34C04 !!!
我為RT809H施加了+12 V外部電源。 在第一次接觸時,也沒有7-10伏電壓。
覆蓋數據失敗!
RT809H是否支持從支持的芯片列表中刪除GT34C04芯片的寫保護?
最好的祝福。
GMT+8, 2025-12-15 16:06 , Processed in 0.053965 sec., 10 queries .
